    4. Probleme mit Conbee II auf Debian GNU
      marios774 last edited by
      ich habe folgendes Problem bei der Installation des ConBee Sticks
      parallels@iobroker:~$ sudo gpasswd -a $USER dialout
      Adding user parallels to group dialout
      parallels@iobroker:~$ wget -O - http://phoscon.de/apt/deconz.pub.key | \
      >            sudo apt-key add -
      --2020-09-23 21:17:44--  http://phoscon.de/apt/deconz.pub.key
      Resolving phoscon.de (phoscon.de)... 144.76.96.194
      Connecting to phoscon.de (phoscon.de)|144.76.96.194|:80... connected.
      HTTP request sent, awaiting response... 200 OK
      Length: 1692 (1.7K) [application/octet-stream]
      Saving to: ‘STDOUT’
      -                   100%[===================>]   1.65K  --.-KB/s    in 0s
      2020-09-23 21:17:44 (163 MB/s) - written to stdout [1692/1692]
      OK
      parallels@iobroker:~$ sudo sh -c "echo 'deb [arch=amd64] http://phoscon.de/apt/deconz \
      >             $(lsb_release -cs) main' > \
      >             /etc/apt/sources.list.d/deconz.list"
      parallels@iobroker:~$ sudo apt update
      Get:1 http://phoscon.de/apt/deconz stretch InRelease [2,859 B]
      Hit:2 http://security.debian.org/debian-security stretch/updates InRelease
      Ign:3 http://ftp.us.debian.org/debian stretch InRelease
      Hit:4 https://deb.nodesource.com/node_12.x stretch InRelease
      Hit:5 http://ftp.us.debian.org/debian stretch-updates InRelease
      Hit:6 http://ftp.us.debian.org/debian stretch Release
      Fetched 2,859 B in 0s (4,279 B/s)
      Reading package lists... Done
      Building dependency tree
      3 packages can be upgraded. Run 'apt list --upgradable' to see them.
      parallels@iobroker:~$ sudo apt install deconz
      E: Unable to locate package deconz
      mit LSUSB wird mir der Stick angezeigt.
      parallels@iobroker:~$ lsusb
      Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
      Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
      Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
      Bus 001 Device 002: ID 1cf1:0030 Dresden Elektronik
      Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
      Wer kann mir hier helfen?
      LG Mario
        Thomas Braun Most Active @marios774 last edited by Thomas Braun
        @marios774
        Die Anleitung ist etwas 'unglücklich'. Die \ bedeuten lediglich, das hier ein Zeilenumbruch ist und der Befehl eigentlich nahtlos weiter geht. Es muss also so lauten:
        wget -O - http://phoscon.de/apt/deconz.pub.key | sudo apt-key add -
        sudo sh -c "echo 'deb http://phoscon.de/apt/deconz $(lsb_release -cs) main' > /etc/apt/sources.list.d/deconz.list"
        sudo apt update
        Durch die komische Schreibweise in deren Anleitung landet der key in ‘STDOUT’ und wird nicht nacht apt-key gepiped, vermute ich.
          marios774 @Thomas Braun last edited by
          @Thomas-Braun
          Danke schon mal für den Tipp mit dem Slash.
          Es kommt trotzdem noch der Fehler mit der E: Unable to locate package deconz.
            @marios774
            sudo apt update
            sudo apt upgrade
            Hier funktioniert es:
            pi@raspberrypi:~ $ wget -O - http://phoscon.de/apt/deconz.pub.key | sudo apt-key add -
            do sh -c "echo 'deb http://phoscon.d--2020-09-23 22:24:14--  http://phoscon.de/apt/deconz.pub.key
            Auflösen des Hostnamens phoscon.de (phoscon.de)… e/apt/deconz $(lsb_release -cs)144.76.96.194
            Verbindungsaufbau zu phoscon.de (phoscon.de)|144.76.96.194|:80 …  main' > /etc/apt/sourceverbunden.
            HTTP-Anforderung gesendet, auf Antwort wird gewartet … s.list.d/deconz.list"
            sudo 200 OK
            Länge: 1692 (1,7K) [application/octet-stream]
            Wird in »STDOUT« gespeichert.
            -                             100%[=================================================>]   1,65K  --.-KB/s    in 0s
            2020-09-23 22:24:14 (38,7 MB/s) - auf die Standardausgabe geschrieben [1692/1692]
            apt update
            sudo apt install deconzOK
            pi@raspberrypi:~ $ sudo sh -c "echo 'deb http://phoscon.de/apt/deconz $(lsb_release -cs) main' > /etc/apt/sources.list.d/deconz.list"
            pi@raspberrypi:~ $ sudo apt update
            OK:1 http://archive.raspberrypi.org/debian buster InRelease
            OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
            Holen:3 http://phoscon.de/apt/deconz buster InRelease [2.857 B]
            OK:4 https://deb.nodesource.com/node_14.x buster InRelease
            Holen:5 http://phoscon.de/apt/deconz buster/main armhf Packages [717 B]
            Es wurden 3.574 B in 1 s geholt (2.675 B/s).
            Abhängigkeitsbaum wird aufgebaut.
            Statusinformationen werden eingelesen.... Fertig
            Alle Pakete sind aktuell.
            pi@raspberrypi:~ $ apt policy deconz
            deconz:
              Installiert:           (keine)
              Installationskandidat: 2.05.81-raspbian-buster-stable
              Versionstabelle:
                 2.05.81-raspbian-buster-stable 500
                    500 http://phoscon.de/apt/deconz buster/main armhf Packages
            Was liefert
            apt policy deconz
            S M 2 Replies Last reply Reply Quote 0
              succo_J @Thomas Braun last edited by
              Was ist das Resultat von
              apt-cache search deconz
              Vielleicht gibt es nichts auf dem Server (zB. es wurde irrtümlich gelöscht oder es gibt nix für Stretch).
                @Thomas-Braun
                Leider klappt es immer noch nicht..
                parallels@iobroker:~$ apt policy deconz
                N: Unable to locate package deconz
                parallels@iobroker:~$ apt-cache search deconz
                  @marios774
                  Was steht denn in der deconz.list nun drin?
                  cat /etc/apt/sources.list.d/deconz.list
                  Und schau dir mal den Kernel an.
                  uname -a
                    @Thomas-Braun sagte in Probleme mit Conbee II auf Debian GNU:
                    parallels@iobroker:~$ cat /etc/apt/sources.list.d/deconz.list
                    deb http://phoscon.de/apt/deconz stretch main
                    parallels@iobroker:~$ uname -a
                    Linux iobroker 4.9.0-13-amd64 #1 SMP Debian 4.9.228-1 (2020-07-05) x86_64 GNU/Linux
                      @marios774
                      Zeig Mal die komplette Ausgabe von
                      sudo apt update
                        [sudo] password for parallels:
                        Get:1 http://security.debian.org/debian-security stretch/updates InRelease [53.0 kB]
                        Hit:2 http://phoscon.de/apt/deconz stretch InRelease
                        Get:5 http://ftp.us.debian.org/debian stretch-updates InRelease [93.6 kB]
                        Get:6 http://security.debian.org/debian-security stretch/updates/main Sources [255 kB]
                        Get:7 http://security.debian.org/debian-security stretch/updates/main amd64 Packages [580 kB]
                        Get:8 http://security.debian.org/debian-security stretch/updates/main Translation-en [259 kB]
                        Hit:9 http://ftp.us.debian.org/debian stretch Release
                        Fetched 1,241 kB in 1s (976 kB/s)
                        4 packages can be upgraded. Run 'apt list --upgradable' to see them.
                        parallels@iobroker:~$ apt list --upgradable
                        Listing... Done
                        default-jre/oldstable 2:1.8-58+deb9u1 amd64 [upgradable from: 2:1.8-58]
                        default-jre-headless/oldstable 2:1.8-58+deb9u1 amd64 [upgradable from: 2:1.8-58]
                        icedtea-netx/oldstable 1.6.2-3.1+deb9u1 amd64 [upgradable from: 1.6.2-3.1]
                        liblua5.3-0/oldstable 5.3.3-1+deb9u1 amd64 [upgradable from: 5.3.3-1]
                          @Thomas-Braun
                          Kann man daraus den Grund für den Fehler finden?
                            @marios774 Nö.
                            Gib mal die Ausgabe von
                            apt-cache policy
                            M Thomas Braun 2 Replies Last reply Reply Quote 0
                              @Thomas-Braun
                              Hast du oder jemand anderes ggf. noch eine Idee?
                              Das System ist ein Parallels-Image mit Debian Stretch auf eine MacMini (Intel i5) macOS 14.6.
                                Thomas Braun Most Active @Thomas Braun last edited by
                                @marios774 Nö.
                                apt-cache policy
                                  @Thomas-Braun
                                  parallels@iobroker:~$ apt-cache policy
                                  Package files:
                                   100 /var/lib/dpkg/status
                                       release a=now
                                   500 https://deb.nodesource.com/node_12.x stretch/main amd64 Packages
                                       release o=Node Source,n=stretch,l=Node Source,c=main,b=amd64
                                       origin deb.nodesource.com
                                   500 http://ftp.us.debian.org/debian stretch-updates/main amd64 Packages
                                       release o=Debian,a=oldstable-updates,n=stretch-updates,l=Debian,c=main,b=amd64
                                       origin ftp.us.debian.org
                                   500 http://security.debian.org/debian-security stretch/updates/contrib amd64 Packages
                                       release v=9,o=Debian,a=oldstable,n=stretch,l=Debian-Security,c=contrib,b=amd64
                                       origin security.debian.org
                                   500 http://security.debian.org/debian-security stretch/updates/main amd64 Packages
                                       release v=9,o=Debian,a=oldstable,n=stretch,l=Debian-Security,c=main,b=amd64
                                   500 http://ftp.us.debian.org/debian stretch/main amd64 Packages
                                       release v=9.13,o=Debian,a=oldstable,n=stretch,l=Debian,c=main,b=amd64
                                  Pinned packages:
                                    @marios774
                                    Das phoscon-Repo wird nicht herangezogen. Weiß der Geier warum nicht.
                                      marios774 @Thomas Braun last edited by marios774
                                      @Thomas-Braun
                                      Ich weiß nicht so genau wie oder warum.. ich habe den folgend thread gefunden:
                                      https://forum.iobroker.net/topic/24331/bekomme-deconz-nicht-installiert
                                      wget https://www.dresden-elektronik.de/deconz/raspbian/alpha/deconz_2.05.67-debian-stretch-beta_arm64.deb
                                      sudo dpkg -i deconz_2.05.67-debian-stretch-beta_arm64.deb
                                      sudo apt --fix-broken install
                                      sudo systemctl enable deconz
                                      sudo service deconz
                                      Durch anpassen der der wget Zeile und der dpkg-i Befehle auf:
                                      wget http://deconz.dresden-elektronik.de/ubuntu/stable/deconz-2.05.81-qt5.deb
                                      sudo dpkg -i deconz-2.05.81-qt5.deb
                                      sudo service deconz
                                      ... klappt es irgendwie?!?
                                      Hier der aktuelle Link http://deconz.dresden-elektronik.de
                                      conbee 2 debian deconz parallels
                                      1719
