    4. cannot stop iobroker - some processes are still running
    UNSOLVED cannot stop iobroker - some processes are still running
    • U
      User2313145 last edited by
      Systemdata
      Hardwaresystem: PI4
      Arbeitsspeicher: 4GB
      Festplattenart: SD-Karte
      Betriebssystem: Raspberrypi OS Buster
      Node-Version: 10.x.x
      Nodejs-Version: 12.18.4
      NPM-Version: 6.14.6
      Image genutzt: Ja/Nein
      Ort/Name der Imagedatei: buanet:iobroker
      Hello, I am trying to stop iobroker without success to make a restore but it wont work.
      using iobroker stop it says it stops but when trying restore it tells me iobroker is running.
      Apparently fix.sh tells me io.admin.0 io.discovery.0 etc are running and need to be stopped first.
      But how?
      I tried every command I could find (pkill, pkill-9 etc.)
      When I start iobroker it tells me it is running and says the PID.
      I can kill the process (I assume its killed because next time I start the PID is different) but still iobroker tells me its running.
      see also
      https://forum.iobroker.net/topic/27271/howto-iobroker-restore-unter-linux-durchführen/168
      maloross Homoran Z 3 Replies Last reply Reply Quote 0
      • maloross
        maloross @User2313145 last edited by
        @User2313145
        you could try
        systemctl stop iobroker
          Homoran Global Moderator Administrators @User2313145 last edited by
          @User2313145 sagte in cannot stop iobroker - some processes are still running:
          Node-Version:
          10.x.x
          Nodejs-Version:
          12.18.4
          you have a Version mismatch. This points to a double (and wrong) install of nodejs and should be fixed immediately
          • Z
            zahnheinrich @User2313145 last edited by
            @User2313145
            And first you have to change to the correct directory by "cd /opt/iobroker".
            Mind the gap after "cd"
            stop iobroker
