    4. bri, is not modifiable ?
    UNSOLVED bri, is not modifiable ?
      Michaelnorge last edited by
      Mein Log ist voll mit solchen Einträgen:
      deconz.0	2020-10-14 17:01:17.896	warn	(1622) {"address":"/lights/41/state","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
      deconz.0	2020-10-14 17:01:17.891	warn	(1622) {"address":"/lights/24/state","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
      deconz.0	2020-10-14 16:47:14.208	warn	(1622) {"address":"/lights/41/state","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
      deconz.0	2020-10-14 16:47:14.200	warn	(1622) {"address":"/lights/24/state","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
      deconz.0	2020-10-14 16:37:31.339	warn	(1622) {"address":"/lights/41/state","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
      deconz.0	2020-10-14 16:37:31.337	warn	(1622) {"address":"/lights/24/state","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
      deconz.0	2020-10-14 16:36:07.789	warn	(1622) {"address":"/lights/32/state","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
      deconz.0	2020-10-14 16:36:07.788	warn	(1622) {"address":"/lights/35/state","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
      deconz.0	2020-10-14 16:36:07.751	warn	(1622) {"address":"/lights/34/state","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
      deconz.0	2020-10-14 16:36:07.749	warn	(1622) {"address":"/lights/33/state","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
      deconz.0	2020-10-14 16:36:07.746	warn	(1622) {"address":"/lights/31/state","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
      deconz.0	2020-10-14 16:18:30.821	warn	(1622) {"address":"/lights/41/state","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
      deconz.0	2020-10-14 16:18:30.817	warn	(1622) {"address":"/lights/24/state","description":"parameter, bri, is not modifiable. Device is set to off.","type":201}
      Ich hatte dazu auch schon mal was im Forum gefunden (wo genau weiss ich nicht mehr) aber kann es nicht mehr wieder finden.
      Es handelt sich um Trådfri-Lampen von IKEA.
      Allerdings ändere ich den Wert "bri" überhaupt nicht, sondern nur "level" und (falls verfügbar) den "ct"-Wert.
      Kann man diese Warnings irgendwie abstellen?
      Michael
      • Jey Cee
        Jey Cee Developer @Michaelnorge last edited by
        @Michaelnorge setzt bri (level ist das gleiche nur in %) bevor du deine Lampe eingeschalten hast.
          Michaelnorge @Jey Cee last edited by
          @Jey-Cee Okay, aber abschaltbar ist das zur Zeit nicht, oder?
          • Jey Cee
            @Michaelnorge nein warum auch, das ist eine Fehlermeldung von deConz. Bri setzen bevor Lampe an ist hat keinen Wert weil es nicht übernommen wird.
            M AlCalzone 2 Replies Last reply Reply Quote 0
              @Jey-Cee Ok, danke Dir!
              • AlCalzone
                AlCalzone Developer @Jey Cee last edited by
                @Jey-Cee Interessanterweise sorgt eine Änderung der Helligkeit bei Nutzung des Gateways (also per tradfri-Adapter) dafür, dass die Lampe an (>0) bzw. aus (=0) geschaltet wird. Macht IMO auch Sinn.
                • Jey Cee
                  Jey Cee Developer @AlCalzone last edited by
                  @AlCalzone jetzt wo du es sagst, das sollte beim deConz Adapter auch so sein. Hatte ich extra eingebaut weil deConz das nicht macht. Da muss ich mal danach schauen.
                  bri ikea trådfri
