    4. Gelöst: TypeError: schedule is not a function
    UNSOLVED Gelöst: TypeError: schedule is not a function
    • wendy2702
      mir ist gerade aufgefallen das ich von meiner Wärmepumpe keine Daten mehr bekomme.
      Ein einfaches Blockly dazu bringt mir seit dem letzten Javascript Adapter update diesen Fehler:
      12:19:36.651	error	javascript.2 (14727) script.js.Waterkotte.Restart_Abfrage_Waterkotte_Test: TypeError: schedule is not a function
      12:19:36.652	error	javascript.2 (14727) at script.js.Waterkotte.Restart_Abfrage_Waterkotte_Test:4:12
      12:19:36.652	error	javascript.2 (14727) at script.js.Waterkotte.Restart_Abfrage_Waterkotte_Test:14:3
      Hier das Blockly:
       <variables>
         <variable type="cron" id="schedule1">schedule1</variable>
       </variables>
       <block type="schedule_create" id="U^a/a|R.Ag0SUHC5`R_X" x="-512" y="-63">
         <field name="NAME">schedule1</field>
         <value name="SCHEDULE">
           <shadow type="field_cron" id="RoVW,)EZwML}A7XD8Xc/">
             <field name="CRON">12 */3 * * * *</field>
           <block type="debug" id=";E~}`cmu%ZUC50DV#p?Y">
             <value name="TEXT">
               <shadow type="text" id="0w!y-Pmlm,f`O0?~@jC@">
                 <field name="TEXT">Abfrage_Waterkotte</field>
               <block type="controls_if" id="WEoLFzJ0#-xub!Bwhv~H">
                   <block type="logic_operation" id="%[579SWxQ72Thpq|e}II" inline="false">
                     <field name="OP">AND</field>
                       <block type="logic_compare" id=";I2G)sOC7K3E#aG*1^{n">
                         <field name="OP">EQ</field>
                           <block type="get_value" id="2wot(2t*g8UEm.+2pLu@">
                             <field name="OID">javascript.2.scriptEnabled.Waterkotte.Abfrage_Waterkotte_Test</field>
                           <block type="logic_boolean" id="/w]{^LZ9,e*gI5Na*=AX">
                       <block type="logic_operation" id="DFqv1XTuf5Jcd6~d4Pl9">
                           <block type="logic_compare" id="Q%hn`r~GuwSiW|`lwXy4">
                               <block type="get_value" id="=gAZ0qIl%Q2=a)w=}wsm">
                                 <field name="OID">javascript.2.scriptEnabled.Waterkotte.WW_Temp_45</field>
                               <block type="logic_boolean" id="z(f3588pY)X5T1JY`L}o">
                           <block type="logic_compare" id="QF-a*[%R+[u!Z(LIu]Nj">
                               <block type="get_value" id="`P_T2QF-wSoJ!ZJN0:^y">
                                 <field name="OID">javascript.2.scriptEnabled.Waterkotte.WW_Temp_60</field>
                               <block type="logic_boolean" id="nI4s86@mVMZfHAb+k9u+">
                   <block type="debug" id="-twd|JK7:Q5Q6+M2lTmO">
                     <value name="TEXT">
                       <shadow type="text" id="e+uKa0:h7S7tL{x@5ZIM">
                         <field name="TEXT">Aktiviere Abfrage Waterkotte</field>
                       <block type="control" id="Hh@%xY%GsRI1g208b7ce">
                           <block type="logic_boolean" id="dJ]azVd7r~N1IN8Wdlr-">
                           <block type="control" id="S[V15.2;~h|N4vnsb3J0">
                             <field name="DELAY_MS">3</field>
                               <block type="logic_boolean" id="c`7aVan7RyUsJ=0=)={!">
      So sieht es als Javascript aus:
      var schedule;
      schedule = schedule('12 */3 * * * *', function () {
        console.log('Abfrage_Waterkotte');
        if (getState("javascript.2.scriptEnabled.Waterkotte.Abfrage_Waterkotte_Test").val == false && getState("javascript.2.scriptEnabled.Waterkotte.WW_Temp_45").val == false && getState("javascript.2.scriptEnabled.Waterkotte.WW_Temp_60").val == false) {
        console.log('Aktiviere Abfrage Waterkotte');
        setState("javascript.2.scriptEnabled.Waterkotte.Abfrage_Waterkotte_Test"/*scriptEnabled.Waterkotte.Abfrage_Waterkotte_Test*/, true);
        setStateDelayed("javascript.2.scriptEnabled.Waterkotte.Abfrage_Waterkotte_Test"/*scriptEnabled.Waterkotte.Abfrage_Waterkotte_Test*/, false, 3000, false);
      Ist das schon bekannt?
      Wie kann ich das lösen?
      Soll ich ein Issue auf Github erstellen oder liegt der Fehler im Blockly welches allerdings bis zum Upgrade ohne Probleme lief.
      Thomas Braun AlCalzone 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @wendy2702 last edited by
        @wendy2702 sagte in TypeError: schedule is not a function:
        Welches Upgrade?
        • wendy2702
          wendy2702 @Thomas Braun last edited by
          @Thomas-Braun Javascript Adapter auf 4.9.3
          • AlCalzone
            AlCalzone Developer @wendy2702 last edited by AlCalzone
            Zeile 1:
            var schedule;
            schedule ist demnach keine Funktion, sondern eine Variable, die du selbst definierst. Nenn die um und die Funktion gibts wieder 😉
            Edit: gerade gesehen, dass das Blockly ist. Bei mir kommt folgender Code raus, wenn ich deine Blöcke importiere:
            var schedule1;
            schedule1 = schedule('12 */3 * * * *', async function () {
            Kann es sein, dass du das Blockly mal neu speichern must oder so?
            • wendy2702
              wendy2702 @AlCalzone last edited by
              @AlCalzone Neu Speichern war die Lösung.
              Aber ist das jetzt ein Feature oder ein Bug ?
              • AlCalzone
                @wendy2702 Schätze das war mal ein Bug. Das Skript hätte so aber eigentlich nie funktionieren dürfen.
                  paul53 @AlCalzone last edited by
                  @AlCalzone sagte:
                  Ja, war es mal.
                  blockly javascript schedule typeerror
