    2. English
    3. ioBroker general
    4. Zigbee adapter problem
      ap2017 last edited by ap2017
      Recently Zigbee adapter became unstable. Sometimes it works (green light, all devices are alive), sometimes it has green light but not able to access devices, sometimes it has red light, see log below. Restarting controller did not help. Re-flashing cc2531 dongle did not help. All ioBroker components and Linux are freshly updated.
      Zigbee errors start with the following
      zigbee.0	2020-10-21 11:38:36.533	error	(32262) TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:214:55) at Func
      zigbee.0	2020-10-21 11:38:36.533	error	(32262) unhandled promise rejection: Cannot read property 'getEntries' of null
      zigbee.0	2020-10-21 11:38:36.533	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      Here is more detailed log
      2020-10-19 14:11:37.270 - info: host.AP-Tiny instance system.adapter.zigbee.0 started with pid 4081
      2020-10-19 14:11:37.747 - debug: zigbee.0 (4081) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2020-10-19 14:11:37.766 - debug: zigbee.0 (4081) Objects client ready ... initialize now
      2020-10-19 14:11:37.768 - debug: zigbee.0 (4081) Objects create System PubSub Client
      2020-10-19 14:11:37.768 - debug: zigbee.0 (4081) Objects create User PubSub Client
      2020-10-19 14:11:37.769 - debug: zigbee.0 (4081) Objects client initialize lua scripts
      2020-10-19 14:11:37.774 - debug: zigbee.0 (4081) Objects connected to redis: 127.0.0.1:9001
      2020-10-19 14:11:37.777 - debug: zigbee.0 (4081) objectDB connected
      2020-10-19 14:11:37.778 - debug: zigbee.0 (4081) Redis States: Use Redis connection: 127.0.0.1:9000
      2020-10-19 14:11:37.781 - debug: zigbee.0 (4081) States create User PubSub Client
      2020-10-19 14:11:37.782 - debug: zigbee.0 (4081) States create System PubSub Client
      2020-10-19 14:11:37.786 - debug: zigbee.0 (4081) States connected to redis: 127.0.0.1:9000
      2020-10-19 14:11:37.786 - debug: zigbee.0 (4081) statesDB connected
      2020-10-19 14:11:38.359 - info: zigbee.0 (4081) starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.19.0, js-controller: 3.1.6
      2020-10-19 14:11:38.377 - debug: zigbee.0 (4081) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"zstack"}}
      2020-10-19 14:11:38.399 - info: zigbee.0 (4081) Starting Zigbee...
      2020-10-19 14:11:38.400 - debug: zigbee.0 (4081) Starting zigbee-herdsman...
      2020-10-19 14:11:38.457 - debug: zigbee.0 (4081) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_10_19-14_11_38.tar.gz success
      2020-10-19 14:11:40.115 - debug: zigbee.0 (4081) system.adapter.admin.0: logging false
      2020-10-19 14:11:41.182 - debug: zigbee.0 (4081) system.adapter.admin.0: logging true
      2020-10-19 14:11:42.922 - debug: zigbee.0 (4081) User stateChange zigbee.0.000b57fffebcfc39.state {"val":false,"ack":false,"ts":1603131102918,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1603078200014}
      2020-10-19 14:11:42.924 - debug: zigbee.0 (4081) User stateChange zigbee.0.90fd9ffffe2bad6b.state {"val":false,"ack":false,"ts":1603131102918,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1603129197774}
      2020-10-19 14:11:42.926 - debug: zigbee.0 (4081) User stateChange zigbee.0.d0cf5efffe7d475c.state {"val":false,"ack":false,"ts":1603131102919,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1603078200014}
      2020-10-19 14:11:42.929 - debug: zigbee.0 (4081) User stateChange zigbee.0.d0cf5efffedaa37c.state {"val":false,"ack":false,"ts":1603131102919,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1603078200014}
      2020-10-19 14:11:42.931 - debug: zigbee.0 (4081) Change state 'state' at device 0x000b57fffebcfc39 type 'LED1622G12'
      2020-10-19 14:11:42.931 - debug: zigbee.0 (4081) Change state 'state' at device 0x90fd9ffffe2bad6b type 'LED1622G12'
      2020-10-19 14:11:42.932 - debug: zigbee.0 (4081) State changes. dev: 0x000b57fffebcfc39 model: LED1622G12 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"value":false,"index":0,"timeout":0}] opt: {"state":false}
      2020-10-19 14:11:42.933 - debug: zigbee.0 (4081) State changes. dev: 0x90fd9ffffe2bad6b model: LED1622G12 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"value":false,"index":0,"timeout":0}] opt: {"state":false}
      2020-10-19 14:11:42.933 - debug: zigbee.0 (4081) entity: undefined
      2020-10-19 14:11:42.934 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2020-10-19 14:11:42.934 - error: zigbee.0 (4081) unhandled promise rejection: Cannot read property 'getEntries' of null
      2020-10-19 14:11:42.934 - error: zigbee.0 (4081) TypeError: Cannot read property 'getEntries' of null
      at Function.byIeeeAddr (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:222:16)
      at Controller.getDeviceByIeeeAddr (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:264:31)
      at ZigbeeController.resolveEntity (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:233:52)
      at Zigbee.publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:313:48)
      at StatesController.emit (events.js:314:20)
      at StatesController.publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:142:14)
      at processTicksAndRejections (internal/process/task_queues.js:97:5)
      2020-10-19 14:11:42.935 - info: zigbee.0 (4081) cleaned everything up...
      2020-10-19 14:11:42.935 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2020-10-19 14:11:42.935 - error: zigbee.0 (4081) unhandled promise rejection: Cannot read property 'mapped' of undefined
      2020-10-19 14:11:42.936 - error: zigbee.0 (4081) TypeError: Cannot read property 'mapped' of undefined
      at Zigbee.publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:315:36)
      2020-10-19 14:11:42.936 - info: zigbee.0 (4081) Zigbee: disabling joining new devices.
      2020-10-19 14:11:42.937 - error: zigbee.0 (4081) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
      at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:76:55)
      at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:88:15)
      at Controller.databaseSave (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:219:45)
      at Controller. (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:200:18)
      at Generator.next ()
      at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:27:71
      at new Promise ()
      at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:23:12)
      at Controller.stop (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:199:16)
      at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:308:33))
      2020-10-19 14:11:42.939 - debug: zigbee.0 (4081) Change state 'state' at device 0xd0cf5efffe7d475c type 'LED1622G12'
      2020-10-19 14:11:42.939 - debug: zigbee.0 (4081) Change state 'state' at device 0xd0cf5efffedaa37c type 'LED1622G12'
      2020-10-19 14:11:42.940 - debug: zigbee.0 (4081) State changes. dev: 0xd0cf5efffe7d475c model: LED1622G12 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"value":false,"index":0,"timeout":0}] opt: {"state":false}
      2020-10-19 14:11:42.940 - debug: zigbee.0 (4081) State changes. dev: 0xd0cf5efffedaa37c model: LED1622G12 states: [{"stateDesc":{"id":"state","name":"Switch state","role":"switch","write":true,"read":true,"type":"boolean","inOptions":true},"value":false,"index":0,"timeout":0}] opt: {"state":false}
      2020-10-19 14:11:42.941 - debug: zigbee.0 (4081) entity: undefined
      2020-10-19 14:11:42.941 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2020-10-19 14:11:42.942 - error: zigbee.0 (4081) unhandled promise rejection: Cannot read property 'mapped' of undefined
      2020-10-19 14:11:42.942 - error: zigbee.0 (4081) TypeError: Cannot read property 'mapped' of undefined
      2020-10-19 14:11:42.942 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2020-10-19 14:11:42.944 - info: zigbee.0 (4081) terminating
      2020-10-19 14:11:42.945 - info: zigbee.0 (4081) Terminated (NO_ERROR): Without reason
      2020-10-19 14:11:48.898 - info: host.AP-Tiny instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
      2020-10-19 14:11:48.899 - info: host.AP-Tiny Restart adapter system.adapter.zigbee.0 because enabled
      zigbee
