    5. (gelöst) mehrere DP toggeln
    • ice987
      ice987 last edited by ice987
      aktuell setzte ich das Widget "materialdesign - Icon List" ein um Farben in einer Tabelle wählen zu können. Jede Farbe darf nur einmal vorkommen, d.h. wenn ein Button gedrückt wird (true) sollen alle anderen Farben (Button) auf "false" springen:
      Widget-Export
      [{"tpl":"tplVis-materialdesign-Icon-List","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","wrapItems":"true","vibrateOnMobilDevices":"","listLayout":"standard","itemLayout":"vertical","buttonLayout":"full","listItemDataMethod":"inputPerEditor","countListItems":"3","listType0":"buttonToggle","showValueLabel0":false,"listType1":"buttonToggle","showValueLabel1":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"maxItemsperRow":"5","itemGaps":"2","labelFontSize":"10","labelFontFamily":"Arial, Helvetica, sans-serif","labelFontColor":"#ffffff","g_listItemCardBackground":false,"titleLayout":"headline6","g_lock":false,"autoLockAfter":"10","lockIconTop":"5","lockIconLeft":"5","lockFilterGrayscale":"30","lockApplyOnlyOnImage":"true","listType2":"text","showValueLabel2":"true","listType3":"text","showValueLabel3":false,"oid0":"0_userdate.0.farbe.gelb","typeButtonToggleValueTrue0":"true","typeButtonToggleValueFalse0":"false","itemBackgroundColor0":"#f59c00","label0":"gelb","listImage0":"check","listImageColor0":"#f59c00","listImageActive0":"check","listImageActiveColor0":"#ff0000","oid1":"0_userdate.0.farbe.orange","typeButtonToggleValueTrue1":"true","typeButtonToggleValueFalse1":"false","label1":"orange","listImage1":"check","listImageActive1":"check","listImageActiveColor1":"#ff0000","listImageActive2":"check","listImageActiveColor2":"#ff0000","typeButtonToggleValueTrue2":"true","typeButtonToggleValueFalse2":"false","label2":"pink","listImageActive3":"check","listImageActiveColor3":"#ff0000","typeButtonToggleValueTrue3":"true","typeButtonToggleValueFalse3":"false","buttonBgColor1":"","listImageColor1":"#ff6600","itemBackgroundColor1":"#ff6600","itemBackgroundColor2":"#e4a7a6","listImageColor2":"#e4a7a6","listImage2":"check","itemBackgroundColor3":"#03933e","label3":"grün","listImage3":"check","listImageColor3":"#03933e","oid2":"0_userdate.0.farbe.pink","oid3":"0_userdate.0.farbe.gruen"},"style":{"left":"52px","top":"341px","width":"275px","height":"55px","z-index":"1"},"widgetSet":"materialdesign"}]
      als JS-Script habe ich das nun bisher sehr umständlich umgesetzt:
      on({id: "0_userdata.0.farbe.gelb", val: true}, function (obj) {
          setState("0_userdata.0.farbe.orange", false);
          setState("0_userdata.0.farbe.pink", false);
          setState("0_userdata.0.farbe.gruen", false);
      on({id: "0_userdata.0.farbe.orange", val: true}, function (obj) {
          setState("0_userdata.0.farbe.gelb", false);
      on({id: "0_userdata.0.farbe.pink", val: true}, function (obj) {
      on({id: "0_userdata.0.farbe.gruen", val: true}, function (obj) {
      welches ist die eleganteste Lösung um dies einfacher zu gestalten? Evtl. hat jemand einen guten Input/Denkanstoss?
      • Asgothian
        Asgothian Developer @ice987 last edited by
        @ice987
        Zumindest ein Denkanstoß, mehr ggf. Später, bin gerade unterwegs.
        Ein Array mit allen gewünschten Datenpunkten definieren.
        Ein trigger auf alle dp‘s, mit change:“gt“ um nur den Wechsel false->true zu fangen.
        In der Funktion durch das Array durch gehen. Wenn Eintrag gleich dem Objekt welches den trigger ausgelöst hat nix tun, sonst value auf True setzen.
          paul53 @Asgothian last edited by
          @Asgothian sagte:
          Etwa so:
          const ids = [
          on({id: ids, change: 'gt'}, function (dp) {
              for(let i = 0; i < ids.length; i++) {
                  if(dp.id != ids[i]) setState(ids[i], false, true);
          Asgothian ice987 2 Replies Last reply Reply Quote 2
          • Asgothian
            Asgothian Developer @paul53 last edited by
            @paul53 sagte in mehrere DP toggeln:
            Etwa so:
            genau so. Danke @paul53
            A.
            • ice987
              ice987 @paul53 last edited by ice987
              @Asgothian
              Vielen Dank für eure Unterstützung!
              zu meinem Verständnis (kopieren kann ja jeder):
              Es wird ein Array generiert mit dem Namen ids, welches alle DP's beinhaltet. Der Inhalt dieses Arrays dient als Wert für den Trigger. Change: 'gt' (gem. Definition: "(greater) New value must be greater than old value (state.val > oldState.val)"): ist somit "true" grösser als "false". Der auslösende DP wird der Funktion mit "dp" übergeben. In der Schlaufe "for" wird bei jedem Element des Arrays geprüft ob der Arrayeintrag dem Auslöser entspricht. Wenn nein dann "setState vom jeweiligen Element auf "false" sonst "true".
                paul53 @ice987 last edited by paul53
                @ice987 sagte:
                Richtig: Wenn nein dann "setState vom jeweiligen Element auf "false", der auslösende Datenpunkt bleibt "true" (wird nicht verändert).
                Ansonsten alles richtig interpretiert.
                javascript
