    4. Verbindungsprobleme mit Fritzbox
    SOLVED Verbindungsprobleme mit Fritzbox
      A Former User last edited by
      Seit einigen Tagen hakelt es bei Verbindung zur Fritz box.
      Bevor ich morgen ein Backup auf die Fritz box zurück hole und mir damit eventuell neue Problem auflade frage ich lieber bei euch noch mal nach. So sieht das aus:
      tr-064.0	2020-10-31 19:26:19.107	info	(15855) starting. Version 4.1.0 in /opt/iobroker/node_modules/iobroker.tr-064, node: v12.19.0, js-controller: 3.1.6
      tr-064.0	2020-10-31 19:26:19.019	info	(15855) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      tr-064.0	2020-10-31 19:25:47.465	warn	(15816) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
      tr-064.0	2020-10-31 19:25:47.465	error	(15816) ~
      tr-064.0	2020-10-31 19:25:47.465	error	(15816) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
      tr-064.0	2020-10-31 19:25:47.464	error	(15816) ~~ Fatal error. Can not connect to your FritzBox.
      tr-064.0	2020-10-31 19:25:47.463	error	(15816) Error: connect ETIMEDOUT 192.168.0.1:49000 - {"errno":"ETIMEDOUT","code":"ETIMEDOUT","syscall":"connect","address":"192.168.0.1","port":49000}
      tr-064.0	2020-10-31 19:23:40.131	info	(15816) starting. Version 4.1.0 in /opt/iobroker/node_modules/iobroker.tr-064, node: v12.19.0, js-controller: 3.1.6
      tr-064.0	2020-10-31 19:23:40.083	info	(15816) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      tr-064.0	2020-10-31 19:23:08.617	warn	(15795) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
      tr-064.0	2020-10-31 19:23:08.617	error	(15795) ~
      tr-064.0	2020-10-31 19:23:08.617	error	(15795) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
      tr-064.0	2020-10-31 19:23:08.616	error	(15795) ~~ Fatal error. Can not connect to your FritzBox.
      tr-064.0	2020-10-31 19:23:08.616	error	(15795) Error: connect ETIMEDOUT 192.168.0.1:49000 - {"errno":"ETIMEDOUT","code":"ETIMEDOUT","syscall":"connect","address":"192.168.0.1","port":49000}
      tr-064.0	2020-10-31 19:21:01.348	info	(15795) starting. Version 4.1.0 in /opt/iobroker/node_modules/iobroker.tr-064, node: v12.19.0, js-controller: 3.1.6
      tr-064.0	2020-10-31 19:21:01.301	info	(15795) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      • IOBroker läuft unter Docker.
      • Fritzbox ist per Ping von der Shell IOBroker aus erreichbar.*
      • Heimnetzfreigabe ist erteilt:
        • Zugriff für Anwendungen zulassen
        • Statusinformationen über UPnP übertragen
      • Anmeldung erfolgt mit FRITZ!Box-Benutzernamen und Kennwort
      • Benutzernamen und Passwort neu vergeben
      • Fritzbox neu gestartet.
      • Adapter und Docker neu gestertet-
      Diese Adapter laufen:
      Fritzbox; Fritzdect.
      diese nicht: ( liefen aber mal !)
      fb-checkpresence, tr-064 V4.1.0
      LGKlaus
      Ralla66 Thomas Braun crunchip 3 Replies Last reply Reply Quote 0
      • Ralla66
        Ralla66 Most Active @Guest last edited by Ralla66
        @biker sagte in Verbindungsprobleme mit Fritzbox:
        Das lass mal sein kommt ja vom tr-064.
        Da hat der Adapter ein Prob aber deine Fritte nicht.
          Thomas Braun Most Active @Guest last edited by Thomas Braun
          @biker
          192.168.0.1
          Ist die richtige IP?
          Unverändert liegt die Box auf
          192.168.178.1
            A Former User @Thomas Braun last edited by
            @Thomas-Braun sagte in Verbindungsprobleme mit Fritzbox:
            192.168.0.1
            ja immer schon bei mir auf 192.168.0.1 ...
            • crunchip
              crunchip Forum Testing Most Active @Guest last edited by
              @biker hatte ich auch vor kurzem, habe in der Instanz, die IP erneut eingegeben und gespeichert, danach lief es wieder
                A Former User @crunchip last edited by
                @crunchip
                hatte gelesen, das Neueingabe von Passwort erfolgreich war. habe ich gemacht
                Nun auch noch die Adressen neu eingegeben und gespeichert ..
                Leider ohne Erfolg .
                host.iobroker	2020-10-31 20:55:37.296	error	instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                tr-064.0	2020-10-31 20:55:36.778	warn	(17034) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                tr-064.0	2020-10-31 20:55:36.777	error	(17034) ~
                tr-064.0	2020-10-31 20:55:36.777	error	(17034) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                tr-064.0	2020-10-31 20:55:36.776	error	(17034) ~~ Fatal error. Can not connect to your FritzBox.
                tr-064.0	2020-10-31 20:55:36.775	error	(17034) Error: connect ETIMEDOUT 192.168.0.1:49000 - {"errno":"ETIMEDOUT","code":"ETIMEDOUT","syscall":"connect","address":"192.168.0.1","port":49000}
                • Ralla66
                  @biker
                  Adapter IP auf xxx.xxx.xxx.1 schlimmer geht nicht,
                  Thomas Braun ? 2 Replies Last reply Reply Quote 0
                    Thomas Braun Most Active @Ralla66 last edited by
                    @Ralla66 Warum?
                      A Former User @Ralla66 last edited by
                      @Ralla66 sagte in Verbindungsprobleme mit Fritzbox:
                      @biker
                      Wahrscheinlich geht es besser, bin geeigneteren Adressvergaben gegenüber offen ?
                      Aber ist das denn wirklich so Fatal bzw- Ursache des Problems ?
                      Thomas Braun Negalein 2 Replies Last reply Reply Quote 0
                        @biker Welche Firmware läuft auf der Kiste?
                          FRITZ!OS: 07.20 -
                          • dslraser
                            dslraser Forum Testing Most Active last edited by dslraser
                            hier war was ähnliches. Lösung steht auch da.
                            https://forum.iobroker.net/post/512369
                            Lösung war, bei jeder Änderung im Adapter das Kennwort vom User der Fritte neu von Hand in den Adaptereinstellungen eingeben.
                            Edit: vorher vielleicht die Fritte auch neu starten, so wie es in der Fehlermeldung steht.
                            ? Thomas Braun 2 Replies Last reply Reply Quote 0
                              A Former User @dslraser last edited by
                              @dslraser sagte in Verbindungsprobleme mit Fritzbox:
                              • Negalein
                                Negalein Global Moderator @Guest last edited by
                                Nein, ist es ganz sicher nicht
                                  Thomas Braun Most Active @dslraser last edited by
                                  @dslraser Witzigerweise war auch dort das Gateway nicht unter 192.168.178.1
                                  • dslraser
                                    dslraser Forum Testing Most Active @Thomas Braun last edited by
                                    stimmt, ist es bei mir aber auch nicht und es funktioniert.
                                      @dslraser Muss es ja auch.
                                      Warum .1 jetzt 'schlimm' sein soll muss @Ralla66 aber auch nochmal erläutern.
                                      • Ralla66
                                        Ralla66 Most Active @Thomas Braun last edited by Ralla66
                                        @Thomas-Braun
                                        weil meist auf 1 der Router liegt.
                                        Ich vermeide deswegen 1.
                                        Nicht Tragisch wenn xxx.xxx.anders.1 ist.
                                          Thomas Braun Most Active @Ralla66 last edited by Thomas Braun
                                          @Ralla66 Die fragliche FritzBox ist ja auch der Router. Nehme ich jedenfalls stark an.
                                            A Former User @Negalein last edited by
                                            @Negalein sagte in Verbindungsprobleme mit Fritzbox:
                                            danke !
                                            fritzbox 7590
                                            1203
