    5. (gelöst)Supergau Java
    • ostseereiter
      ostseereiter last edited by ostseereiter
      Hallo Freunde,
      Heute habe ich mein System wieder mal auf Vordermann gebracht.Wie immer läuft nicht alles reibungslos ab mein javascribt funktioniert nicht das ist natürlich der Supergau. Script Engine ist die 4.8.4
      starte ich java dann bleibt es eine weile grün wird aber wieder rot.
      javascript.0	2020-11-01 14:52:46.261	info	(6812) Start javascript script.js.Skripte.AV-Receiver.AV_Blueray_ein_aus
      javascript.0	2020-11-01 14:52:43.469	info	(6812) received all states
      javascript.0	2020-11-01 14:52:39.813	info	(6812) received all objects
      javascript.0	2020-11-01 14:52:29.583	info	(6812) requesting all objects
      javascript.0	2020-11-01 14:52:29.524	info	(6812) requesting all states
      javascript.0	2020-11-01 14:52:29.153	info	(6812) starting. Version 4.8.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.19.0, js-controller: 3.1.6
      javascript.0	2020-11-01 14:48:24.307	info	(1417) Start javascript script.js.Skripte.AV-Receiver.AV_Blueray_ein_aus
      javascript.0	2020-11-01 14:48:21.708	info	(1417) received all states
      javascript.0	2020-11-01 14:48:16.288	info	(1417) received all objects
      javascript.0	2020-11-01 14:48:08.267	info	(1417) requesting all objects
      javascript.0	2020-11-01 14:48:08.263	info	(1417) requesting all states
      javascript.0	2020-11-01 14:48:07.953	info	(1417) starting. Version 4.8.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.19.0, js-controller: 3.1.6
      javascript.0	2020-11-01 14:44:31.140	info	(28786) Start javascript script.js.Skripte.AV-Receiver.AV_Blueray_ein_aus
      javascript.0	2020-11-01 14:44:30.228	info	(28786) received all states
      javascript.0	2020-11-01 14:44:28.980	info	(28786) received all objects
      javascript.0	2020-11-01 14:44:23.467	info	(28786) requesting all objects
      javascript.0	2020-11-01 14:44:23.464	info	(28786) requesting all states
      javascript.0	2020-11-01 14:44:23.223	info	(28786) starting. Version 4.8.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.19.0, js-controller: 3.1.6
      und in den Scripten sagt er mir Instanz deaktiviert.
      Woran kann das liegen?
        Thomas Braun Most Active @ostseereiter last edited by Thomas Braun
        @ostseereiter
        iobroker list instances
        iobroker list adapters
        Die Meldungen im log zeigen keinen Fehler.
        node ist aber sauber installiert?
        • ostseereiter
          ostseereiter @Thomas Braun last edited by
          @Thomas-Braun
          t: 8081, bind: 0.0.0.0 (SSL), run as: admin
            system.adapter.alarm.0                 : alarm                 - disabled
          + system.adapter.alexa2.0                : alexa2                -  enabled
            system.adapter.amazon-dash.0           : amazon-dash           - disabled
          + system.adapter.backitup.0              : backitup              -  enabled
          + system.adapter.bring.0                 : bring                 -  enabled
          + system.adapter.broadlink2.0            : broadlink2            -  enabled
          + system.adapter.broadlink2.1            : broadlink2            -  enabled
          + system.adapter.cloud.0                 : cloud                 -  enabled
            system.adapter.daswetter.0             : daswetter             -  enabled
            system.adapter.devices.0               : devices               -  enabled
          + system.adapter.discovery.0             : discovery             -  enabled
            system.adapter.dwd.0                   : dwd                   -  enabled
            system.adapter.emby.0                  : emby                  - disabled
            system.adapter.feiertage.0             : feiertage             -  enabled
            system.adapter.flot.0                  : flot                  -  enabled
          + system.adapter.fritzbox.0              : fritzbox              -  enabled
          + system.adapter.fullybrowser.0          : fullybrowser          -  enabled
          + system.adapter.harmony.0               : harmony               -  enabled
            system.adapter.heatingcontrol.0        : heatingcontrol        - disabled
          + system.adapter.history.0               : history               -  enabled
          + system.adapter.hm-rega.0               : hm-rega               -  enabled
          + system.adapter.hm-rpc.0                : hm-rpc                -  enabled, por        t: 0
            system.adapter.ical.0                  : ical                  -  enabled
            system.adapter.icons-icons8.0          : icons-icons8          -  enabled
            system.adapter.icons-mfd-png.0         : icons-mfd-png         -  enabled
          + system.adapter.influxdb.0              : influxdb              -  enabled, por        t: 8086
          + system.adapter.info.0                  : info                  -  enabled
          + system.adapter.iot.0                   : iot                   -  enabled
          + system.adapter.iqontrol.0              : iqontrol              -  enabled
            system.adapter.javascript.0            : javascript            -  enabled
          + system.adapter.kodi.0                  : kodi                  -  enabled, por        t: 9090
          + system.adapter.kodi.1                  : kodi                  -  enabled, por        t: 9090
          + system.adapter.mihome.0                : mihome                -  enabled, por        t: 9898, bind: 0.0.0.0
            system.adapter.mobile.0                : mobile                -  enabled
            system.adapter.mqtt.0                  : mqtt                  - disabled, por        t: 1886, bind: 0.0.0.0
            system.adapter.nina.0                  : nina                  - disabled
          + system.adapter.node-red.0              : node-red              -  enabled, por        t: 1880, bind: 0.0.0.0
            system.adapter.odl.0                   : odl                   -  enabled
          + system.adapter.onkyo.0                 : onkyo                 -  enabled
          + system.adapter.pi-hole.0               : pi-hole               -  enabled
          + system.adapter.ping.0                  : ping                  -  enabled
          + system.adapter.pollenflug.0            : pollenflug            -  enabled
            system.adapter.radar2.0                : radar2                - disabled
            system.adapter.rickshaw.0              : rickshaw              -  enabled
          + system.adapter.scenes.0                : scenes                -  enabled
            system.adapter.schoolfree.0            : schoolfree            -  enabled
          + system.adapter.shelly.0                : shelly                -  enabled, por        t: 1882, bind: 0.0.0.0
          + system.adapter.sonoff.0                : sonoff                -  enabled, por        t: 1883, bind: 0.0.0.0
          + system.adapter.sourceanalytix.0        : sourceanalytix        -  enabled
            system.adapter.statistics.0            : statistics            - disabled
          + system.adapter.tankerkoenig.0          : tankerkoenig          -  enabled
          + system.adapter.telegram.0              : telegram              -  enabled, por        t: 8443, bind: 0.0.0.0
          + system.adapter.terminal.0              : terminal              -  enabled, por        t: 8088, bind: 0.0.0.0, run as: admin
          + system.adapter.text2command.0          : text2command          -  enabled
          + system.adapter.tr-064.0                : tr-064                -  enabled
            system.adapter.tvspielfilm.0           : tvspielfilm           -  enabled
          + system.adapter.virtualpowermeter.0     : virtualpowermeter     -  enabled
            system.adapter.vis-bars.0              : vis-bars              -  enabled
            system.adapter.vis-canvas-gauges.0     : vis-canvas-gauges     -  enabled
            system.adapter.vis-colorpicker.0       : vis-colorpicker       -  enabled
            system.adapter.vis-fancyswitch.0       : vis-fancyswitch       -  enabled
            system.adapter.vis-hqwidgets.0         : vis-hqwidgets         -  enabled
            system.adapter.vis-jqui-mfd.0          : vis-jqui-mfd          -  enabled
            system.adapter.vis-justgage.0          : vis-justgage          -  enabled
            system.adapter.vis-keyboard.0          : vis-keyboard          -  enabled
            system.adapter.vis-metro.0             : vis-metro             -  enabled
            system.adapter.vis-players.0           : vis-players           -  enabled
            system.adapter.vis-rgraph.0            : vis-rgraph            -  enabled
            system.adapter.vis-timeandweather.0    : vis-timeandweather    -  enabled
            system.adapter.vis.0                   : vis                   -  enabled
            system.adapter.vodafone-speedtest.0    : vodafone-speedtest    - disabled
          + system.adapter.web.0                   : web                   -  enabled, por        t: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.yeelight-2.0            : yeelight-2            -  enabled
          + system.adapter.zigbee.0                : zigbee                -  enabled, por        t: /dev/ttyACM0
          andy@debianhp:/opt/iobroker$ iobroker list adapters
          system.adapter.admin                   : admin          - v4.0.10
          system.adapter.alarm                   : alarm          - v1.2.4
          system.adapter.alexa2                  : alexa2         - v3.3.1
          system.adapter.amazon-dash             : amazon-dash    - v1.1.0
          system.adapter.backitup                : backitup       - v1.6.7
          system.adapter.ble                     : ble            - v0.11.8
          system.adapter.bring                   : bring          - v1.7.2
          system.adapter.broadlink               : broadlink      - v0.1.1
          system.adapter.broadlink2              : broadlink2     - v2.0.3
          system.adapter.cloud                   : cloud          - v3.0.4
          system.adapter.daswetter               : daswetter      - v3.0.4
          system.adapter.devices                 : devices        - v0.3.6
          system.adapter.discovergy              : discovergy     - v0.5.4
          system.adapter.discovery               : discovery      - v2.3.7
          system.adapter.dwd                     : dwd            - v2.4.10
          system.adapter.emby                    : emby           - v1.0.2
          system.adapter.feiertage               : feiertage      - v1.0.19
          system.adapter.firetv                  : firetv         - v1.0.0
          system.adapter.flot                    : flot           - v1.9.2
          system.adapter.fritzbox                : fritzbox       - v0.2.1
          system.adapter.fullybrowser            : fullybrowser   - v2.0.1
          system.adapter.habpanel                : habpanel       - v0.4.3
          system.adapter.harmony                 : harmony        - v1.2.2
          system.adapter.heatingcontrol          : heatingcontrol - v1.0.0
          system.adapter.history                 : history        - v1.9.10
          system.adapter.hm-rega                 : hm-rega        - v2.6.21
          system.adapter.hm-rpc                  : hm-rpc         - v1.14.24
          system.adapter.hmm                     : hmm            - v1.0.1
          system.adapter.ical                    : ical           - v1.7.4
          system.adapter.icons-icons8            : icons-icons8   - v0.0.1
          system.adapter.icons-material-png      : icons-material-png - v0.1.0
          system.adapter.icons-mfd-png           : icons-mfd-png  - v1.0.2
          system.adapter.influxdb                : influxdb       - v1.9.1
          system.adapter.info                    : info           - v1.7.2
          system.adapter.iot                     : iot            - v1.5.3
          system.adapter.iqontrol                : iqontrol       - v1.3.3
          system.adapter.javascript              : javascript     - v4.8.4
          system.adapter.kodi                    : kodi           - v2.0.4
          system.adapter.mihome                  : mihome         - v1.3.0
          system.adapter.mobile                  : mobile         - v1.0.1
          system.adapter.mqtt                    : mqtt           - v2.1.9
          system.adapter.nina                    : nina           - v0.0.23
          system.adapter.node-red                : node-red       - v1.17.2
          system.adapter.odl                     : odl            - v1.0.5
          system.adapter.onkyo                   : onkyo          - v2.0.3
          system.adapter.openweathermap          : openweathermap - v0.1.0
          system.adapter.pi-hole                 : pi-hole        - v1.3.1
          system.adapter.ping                    : ping           - v1.4.8
          system.adapter.pollenflug              : pollenflug     - v1.0.6
          system.adapter.radar2                  : radar2         - v1.0.7
          system.adapter.rickshaw                : rickshaw       - v1.0.0
          system.adapter.scenes                  : scenes         - v2.1.7
          system.adapter.schoolfree              : schoolfree     - v0.6.3
          system.adapter.shelly                  : shelly         - v4.0.3
          system.adapter.simple-api              : simple-api     - v2.4.6
          system.adapter.socketio                : socketio       - v3.0.13
          system.adapter.sonoff                  : sonoff         - v2.3.3
          system.adapter.sourceanalytix          : sourceanalytix - v0.4.8-alpha.x
          system.adapter.squeezebox              : squeezebox     - v0.2.1
          system.adapter.statistics              : statistics     - v0.2.2
          system.adapter.tankerkoenig            : tankerkoenig   - v2.0.9
          system.adapter.telegram                : telegram       - v1.5.9
          system.adapter.terminal                : terminal       - v0.1.2
          system.adapter.text2command            : text2command   - v1.3.0
          system.adapter.tr-064                  : tr-064         - v4.0.9
          system.adapter.tvspielfilm             : tvspielfilm    - v2.0.1
          system.adapter.virtualpowermeter       : virtualpowermeter - v1.2.1
          system.adapter.vis                     : vis            - v1.2.12
          system.adapter.vis-bars                : vis-bars       - v0.1.4
          system.adapter.vis-beta                : vis-beta       - v0.12.11
          system.adapter.vis-canvas-gauges       : vis-canvas-gauges - v0.1.5
          system.adapter.vis-colorpicker         : vis-colorpicker - v1.2.0
          system.adapter.vis-fancyswitch         : vis-fancyswitch - v1.1.0
          system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.4
          system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
          system.adapter.vis-justgage            : vis-justgage   - v1.0.2
          system.adapter.vis-keyboard            : vis-keyboard   - v0.0.2
          system.adapter.vis-metro               : vis-metro      - v1.1.2
          system.adapter.vis-players             : vis-players    - v0.1.6
          system.adapter.vis-rgraph              : vis-rgraph     - v0.0.2
          system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
          system.adapter.vodafone-speedtest      : vodafone-speedtest - v0.0.4
          system.adapter.weatherunderground      : weatherunderground - v3.2.1
          system.adapter.web                     : web            - v3.0.13
          system.adapter.wifilight               : wifilight      - v0.2.0
          system.adapter.yeelight-2              : yeelight-2     - v1.0.3
          system.adapter.zigbee                  : zigbee         - v1.2.1
            fastfoot @ostseereiter last edited by
            @ostseereiter Könnte am Skript AV-Receiver.AV_Blueray_ein_aus liegen
            Und Javascript ist nicht Java und hat auch nichts damit zu tun!
              Thomas Braun Most Active @fastfoot last edited by
              @ostseereiter
              Knipps das Receiver skript mal aus.
              node ist gerade?
              which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
              • ostseereiter
                @Thomas-Braun
                andy@debianhp:~$ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                /usr/bin/nodejs
                v12.19.0
                /usr/bin/node
                v12.19.0
                /usr/bin/npm
                6.14.8
                nodejs:
                  Installiert:           12.19.0-1nodesource1
                  Installationskandidat: 12.19.0-1nodesource1
                  Versionstabelle:
                 *** 12.19.0-1nodesource1 500
                        500 https://deb.nodesource.com/node_12.x stretch/main amd64 Packages
                        100 /var/lib/dpkg/status
                     4.8.2~dfsg-1 500
                        500 http://ftp.de.debian.org/debian stretch/main amd64 Packages
                andy@de
                ostseereiter Thomas Braun 2 Replies Last reply Reply Quote 0
                • ostseereiter
                  ostseereiter @ostseereiter last edited by
                  @ostseereiter habe das Script aus aber keine Veränderung
                    @ostseereiter Dann könnte in dem blueray-Skript Code drin sein, der in aktuellem javaskript vor die Wand fährt.
                    Auch wenn da im error log nichts entsprechendes auftaucht.
                      @ostseereiter
                      iobroker start javascript
                      • ostseereiter
                        @Thomas-Braun sagte in Supergau Java:
                        bleibt rot
                        andy@debianhp:~$ cd /opt/iobroker
                        andy@debianhp:/opt/iobroker$ iobroker start javascript
                        [sudo] Passwort für andy:
                          @ostseereiter sagte in Supergau Java:
                          Das ist allerdings auch merkwürdig.
                          Ich werde da nie nach meinem PW gefragt.
                            @ostseereiter
                            iobroker stop
                            iobroker fix
                            iobroker start
                              Homoran Global Moderator Administrators @ostseereiter last edited by Homoran
                              Wie meinen?
                              Die Aussage "Instanz ist deaktiviert" kann auch eine alternativer Fakt sein.
                              Wenn dein js-Adapter "nach einiger Zeit" auf rot geht, ist die Frage was du mit einiger Zeit meinst und ist das jetzt schon wieder so?
                                und er hat ja noch nicht mal sudo im Befehl drin
                                (ganz abgesehen davon , dass iobroker-Befehle kein sudo benötigen)
                                Da ist etwas oberfaul
                                • ostseereiter
                                  ostseereiter @Homoran last edited by
                                  @Homoran so wie ich versuche meine Scripte zu bearbeiten. aber auch wenn die Intanz grün ist tut sich nichts die Scripte werden nicht ausgeführt.
                                    woran machst du das fest?
                                    für den Fixer musst du ja iobroker anhalten, mal sehen was sich nach dem Neustart tut
                                    • ostseereiter
                                      @Homoran am gefühl
                                      • ostseereiter
                                        @Thomas-Braun
                                        OK:1 http://security.debian.org/debian-security stretch/updates InRelease
                                        Ign:2 http://ftp.de.debian.org/debian stretch InRelease
                                        OK:3 http://ftp.de.debian.org/debian stretch-updates InRelease
                                        OK:4 http://ftp.de.debian.org/debian stretch Release
                                        OK:5 https://deb.nodesource.com/node_12.x stretch InRelease
                                        Installed gcc-c++
                                            Checking ioBroker user and directory permissions (2/3)
                                        Created /etc/sudoers.d/iobroker
                                            Checking autostart (3/3)
                                        Enabling autostart...
                                        Autostart enabled!
                                            Your installation was fixed successfully
                                            Run iobroker start to start ioBroker again!
                                        root@debianhp:/opt/iobroker#
                                          root@debianhp
                                          Murks. Sein lassen.
                                          • ostseereiter
                                            @Thomas-Braun was meinst
                                            sudo muss ich schon benutzen bei manchen befehlen
                                            1.0k
                                            javascript
                                            5119
