    4. Loxone Adapter Update 2.0.2 Problem
    UNSOLVED Loxone Adapter Update 2.0.2 Problem
      A1uca2d last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Acer Laptop
      Arbeitsspeicher: 4GB
      Festplattenart: 500GB HDD
      Betriebssystem: Windows 10 2004
      Node-Version: 14.8.0
      Nodejs-Version: 14.8.0
      NPM-Version: 6.14.7
      Installationsart: Skript
      Ich habe bei dem Update des Loxone-Adapters von 2.0.1 auf 2.0.2 folgende Fehlermeldung (Das Update wird nicht durchgeführt):
      $ ./iobroker upgrade loxone
      Update loxone from @2.0.1 to @2.0.2
      NPM version: 6.14.7
      npm install iobroker.loxone@2.0.2 --loglevel error (System call)
      npm
       ERR! code EPERMnpm ERR! syscall unlinknpm ERR! path C:\Program Files\iobroker\SmartVdGA\node_modules\.bufferutil.DELETE\prebuilds\win32-x64\node-napi.nodenpm ERR! errno -4048
      npm
      ERR! Error: EPERM: operation not permitted, unlink 'C:\Program Files\iobroker\SmartVdGA\node_modules\.bufferutil.DELETE\prebuilds\win32-x64\node-napi.node'npm ERR!  [OperationalError: EPERM: operation not permitted, unlink 'C:\Program Files\iobroker\SmartVdGA\node_modules\.bufferutil.DELETE\prebuilds\win32-x64\node-napi.node'] {npm ERR!
         cause: [Error: EPERM: operation not permitted, unlink 'C:\Program Files\iobroker\SmartVdGA\node_modules\.bufferutil.DELETE\prebuilds\win32-x64\node-napi.node'] {npm
      ERR!     errno: -4048,npm
       ERR!     code: 'EPERM',npm ERR!     syscall: 'unlink',npm ERR!
           path: 'C:\\Program Files\\iobroker\\SmartVdGA\\node_modules\\.bufferutil.DELETE\\prebuilds\\win32-x64\\node-napi.node'npm ERR!   },npm ERR!   errno: -4048,npm ERR!   code: 'EPERM',npm
      ERR!   syscall: 'unlink',npm ERR!   path: 'C:\\Program Files\\iobroker\\SmartVdGA\\node_modules\\.bufferutil.DELETE\\prebuilds\\win32-x64\\node-napi.node',npm ERR!   parent: 'SmartVdGA'npm
      ERR! }
      npm ERR! npm ERR! The operation was rejected by your operating system.npm ERR! It's possible that the file was already in use (by a text editor or antivirus),npm ERR! or that you lack permissions to access it.npm ERR!
      npm ERR! If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try runningnpm ERR! the command again as root/Administrator.
      npm ERR! A complete log of this run can be found in:npm ERR!     C:\Program Files\iobroker\SmartVdGA\env\npm-cache\_logs\2020-11-03T19_45_37_061Z-debug.log
      ERROR: host.DESKTOP-HFVVAJN(SmartHome) Cannot install iobroker.loxone@2.0.2: 4294963248
      ERROR: process exited with code 25
      Was kann ich machen, um das Update umsetzen zu können?
      Ich muss direkt dazu sagen, dass die Console nicht bei mir funktioniert. (hier gibt es bis jetzt keine Lösung zu).
      Thomas Braun A 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @A1uca2d last edited by
        @A1uca2d
        Was mir direkt auffällt:
        node14 ist noch nicht die empfohlene nodeJS Version.
          A1uca2d @A1uca2d last edited by
          @A1uca2d
          Neues Problem: Nun ist der Loxone Adapter plötzlich nicht mehr installiert.
          Der Adapter wird bei den Instanzen angezeit lässt sich aber nicht starten. eine neu-/zusatzinstallation ist nicht möglich. Folgende Fehlermeldung:
          $ ./iobroker add loxone  --host DESKTOP-HFVVAJN(SmartHome)
          NPM version: 6.14.7
          Der Befehl "node-gyp-build" ist entweder falsch geschrieben oder
          konnte nicht gefunden werden.
          npm
           ERR! code ELIFECYCLEnpm ERR! errno 1
          npm ERR!
           bufferutil@4.0.2 install: `node-gyp-build`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the bufferutil@4.0.2 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
          npm ERR! A complete log of this run can be found in:npm ERR!     C:\Program Files\iobroker\SmartVdGA\env\npm-cache\_logs\2020-11-03T20_24_09_921Z-debug.log
          ERROR: host.DESKTOP-HFVVAJN(SmartHome) Cannot install iobroker.loxone@2.0.2: 1
          Jemand mit einer Idee?
          • UncleSam
            UncleSam Developer @Thomas Braun last edited by
            @Thomas-Braun sagte in Loxone Adapter Update 2.0.2 Problem:
            Ja, das könnte ein Problem sein. Ich meine zwar, dass die Installation auch unter Windows getestet wird, bin mir aber gerade nicht sicher.
            Aber du scheinst gyp nicht installiert zu haben. Das wird benötigt um gewisse Abhängigkeiten zu kompilieren.
            Wir hast du Node installiert? Welche Optionen hast du gewählt?
              A1uca2d @UncleSam last edited by
              @UncleSam
              Ursprünglich habe ich den Win-Installer genutzt für den IOBroker.
              die Version 14.x von Node.js habe ich über Copy-Paste in das IoBroker Verzeichnis installiert.
              Hatte in der Vergangenheit auch nie Probleme damit.
              Liegt das vielleicht an einen Win10 update?
              • UncleSam
                UncleSam Developer @A1uca2d last edited by
                @A1uca2d sagte in Loxone Adapter Update 2.0.2 Problem:
                Uiuiui... das würde ich nie machen. Weder unter Windows noch unter Linux.
                Ich schlage vor: installiere ioBroker mit der Version von Node, die mitgeliefert wird (das ist doch so unter Windows, oder?) und dann lass die Finger von grossen Updates "von Hand".
                Das Problem mit den Berechtigungen kommt wahrscheinlich genau vom rumkopieren.
                  @UncleSam
                  DAs verstehe ich durchaus.
                  Habe mich allerings hierbei einer Anleitung bedient, die in der Vergangenheit auch funktionierte.
                  Dazu möchte ich noch sagen, dass ich das Node.js Update nicht heute gemacht habe sondern vor ca .3 Monaten. Seit dem hat immer alles funktioniert!
                  Muss ich echt mein IOBroker neu aufsetzen?
                  • UncleSam
                    Versuch mal alle Verzeichnisse, die mit .DELETE enden in C:\Program Files\iobroker\SmartVdGA\node_modules\ zu löschen.
                    Und dann mach den Upgrade Befehl von oben mal in einem Kommandofenster mit Admin-Rechten, eventuell hilft das noch.
                      @UncleSam
                      Danke für die Idee.
                      Das hat leider auch nicht funktioniert.
                      Nun habe ich den ganzen IOBroker neu aufgesetzt. Dies hat beim dritten Versuch endlich geklappt und bis jetzt scheint es wieder alles zu laufen. komischer weise war die Instanz von Loxone direkt wieder mit den Einstellungen da. Ich glaube da hat sich die alte Installation irgendwo tiefer verschluckt.
                        @A1uca2d
                        nodeJS wieder so schräg reingekloppt?
                          A1uca2d @Thomas Braun last edited by
                          @Thomas-Braun
                          Coole Formulierung.
                          Nein, habe Node.js ist auf Version 10.17.0 gelassen, wie der win-Installer es aktuell nur hergibt.
                          Mal sehen, wie lange das so bleibt.
                          Beim letzten update von node.js hat es auch fast 3 Monate funktioniert. Ich gehe von einem Problem mit dem Win-Update aus, dass der Laptop zuvor gemacht hatte.
                            @A1uca2d
                            Unter Windows ist das immer so ein Gefrickel mit den node-Updates. Zum Glück habe ich damit nix zu tun.
                            errorproblem loxone adapter update adapter
                            682
