    4. Zigbee Problem nach Neustart
    UNSOLVED Zigbee Problem nach Neustart
      ma last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Beelink U55
      Arbeitsspeicher: 8GB
      Festplattenart: SSD
      Betriebssystem: Ubuntu 20.04.1 LTS
      Node-Version: 12.19.0
      Nodejs-Version: 12.19.0
      NPM-Version: 6.14.8
      Installationsart: Skript
      Image genutzt: Nein
      Zigbee Adapter Version 1.2.1
      Zigbee Coordinator CC2538+CC2592 PA
      Ort/Name der Imagedatei: -
      2020-11-08 10:53:00.375 - error: zigbee.0 (2737) Failed to start Zigbee
      2020-11-08 10:53:00.377 - error: zigbee.0 (2737) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
      at ZStackAdapter. (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:89:31)
      at Generator.throw ()
      at rejected (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:25:65)
      2020-11-08 10:53:10.650 - error: zigbee.0 (2737) Failed to start Zigbee
      2020-11-08 10:53:10.651 - error: zigbee.0 (2737) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
      at Znp. (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
      at Generator.next ()
      at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
      at new Promise ()
      at __awaiter (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
      at SerialPort. (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
      at SerialPort._error (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/stream/lib/index.js:198:14)
      at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/stream/lib/index.js:242:12
      Die oben stehenden Fehlermeldungen bekomme ich nach dem Neustart meines iobroker Host.
      Scheinbar kann die Verbindung zum CC2538+CC2592 PA nicht aufgebaut werden ?
      Ich kann das Problem lösen indem ich den Adapter manuell Neustarte, danach funktioniert alles wieder problemlos.
      Komisch ist das das Problem nur nach einem Neustart auftritt ansonsten habe ich keine Probleme mit dem CC2538+CC2592 PA oder Adapter.
      Hat vlt. jemand ähnliche Probleme oder sogar eine Lösung ?
      Grundsätzlich kein großes Problem da es nur nach Neustart Probleme gibt aber trotzdem würde ich gerne verstehen woran das liegt.
      ostseereiter Asgothian 2 Replies Last reply Reply Quote 0
      • ostseereiter
        ostseereiter @ma last edited by
        @ma Das ist nach einen Neustart so manchmaal muss man auch den Stick abziehen
        • Asgothian
          Asgothian Developer @ma last edited by
          @ma Wenn das Problem auftritt solltest du schauen ob noch ein Prozess die serielle Schnittstelle blockiert hat. Das ist (laut Meldung die Ursache dafür das der Adapter nicht gestartet werden kann.
          A.
          adapter errorproblem zigbee zigbee 3.0
