    4. Seit ical 1.7.5 funktioniert Kalender nicht mehr
    UNSOLVED Seit ical 1.7.5 funktioniert Kalender nicht mehr
    • SBorg
      SBorg Forum Testing Most Active last edited by
      Mit 1.7.5 und 1.8.0 geht einer meiner Kalender nicht mehr.
      Log, danach nichts mehr:
      ical.1	2020-11-14 16:36:18.908	debug	(25417) File read successfully http://192.168.1.30:32500/Kalender2020.ics
      ical.1	2020-11-14 16:36:18.894	silly	(25417) States system redis pmessage system.adapter.ical.1.logLevel/system.adapter.ical.1.logLevel:{"val":"silly","ack":true,"ts":1605368178860,"q":0,"from":"system.adapter.ical.1","lc":1605368178860
      ical.1	2020-11-14 16:36:18.866	debug	(25417) reading calendar from URL: http://192.168.1.30:32500/Kalender2020.ics, color: #000000
      ical.1	2020-11-14 16:36:18.811	info	(25417) starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.ical, node: v12.19.0, js-controller: 3.1.6
      ical.1	2020-11-14 16:36:18.610	debug	(25417) Plugin sentry Initialize Plugin (enabled=true)
      ical.1	2020-11-14 16:36:12.922	debug	(25417) statesDB connected
      ical.1	2020-11-14 16:36:12.922	debug	(25417) States connected to redis: 127.0.0.1:9000
      ical.1	2020-11-14 16:36:12.907	debug	(25417) States create System PubSub Client
      ical.1	2020-11-14 16:36:12.895	debug	(25417) States create User PubSub Client
      ical.1	2020-11-14 16:36:12.889	debug	(25417) Redis States: Use Redis connection: 127.0.0.1:9000
      ical.1	2020-11-14 16:36:12.887	debug	(25417) objectDB connected
      ical.1	2020-11-14 16:36:12.885	debug	(25417) Objects connected to redis: 127.0.0.1:9001
      ical.1	2020-11-14 16:36:12.646	debug	(25417) Objects client initialize lua scripts
      ical.1	2020-11-14 16:36:12.646	debug	(25417) Objects create User PubSub Client
      ical.1	2020-11-14 16:36:12.645	debug	(25417) Objects create System PubSub Client
      ical.1	2020-11-14 16:36:11.446	debug	(25417) Objects client ready ... initialize now
      ical.1	2020-11-14 16:36:10.940	debug	(25417) Redis Objects: Use Redis connection: 127.0.0.1:9001
      Mit 1.7.4 funktioniert der Kalender noch. Beispiel:
      BEGIN:VEVENT
      CATEGORIES:Abfallkalender 2020
      CLASS:PUBLIC
      CREATED:20200111T095953Z
      DTSTAMP:20200111T103410Z
      DTSTART:20201223T070000
      DTEND:20201223T180000
      LAST-MODIFIED:20200111T100157Z
      PRIORITY:5
      SEQUENCE:0
      SUMMARY:<span style="color: grey">Restmülltonne</span>
      TRANSP:TRANSPARENT
      UID:ical-202087469
      END:VEVENT
      Kann es sein, dass in der SUMMARY stört? Falls ja, gewollt oder Mistake 🙂
      • Chaot
        Chaot @SBorg last edited by
        @SBorg Bei mir funktioniert der Kalender einwandfrei.
        Dein Log verstehe ich aber nicht. Der meldet doch in der letzten Zeile
        Also funktioniert er doch. Oder sehe ich das falsch?
        • SBorg
          SBorg Forum Testing Most Active @Chaot last edited by
          @Chaot 3 funktionieren auch noch, nur der vierte obige ließt ihn ein, meldet keinerlei Fehler, aber leider auch keinerlei Termine mehr 🙂
          Selber Kalender funktioniert mit 1.7.4 aber noch ohne jegliche Änderung.
          Chaot O 2 Replies Last reply Reply Quote 0
          • Chaot
            @SBorg Was steht denn in den Objekten drin? Hast du die mal Instanz mal neu gestartet?
            Wenn 3 Kalenderinstanzen funktionieren und eine nicht denke ich mal das da die ankommenden Daten nicht passen.
            Hast du die Einstellungen der Instanz geprüft?
            Dein Beispielkalender zeigt ein Ereignis am 23.12.2020. Geht deine Kalendereinstellung so weit vor?
            In den Änderungen fallen mir auch ein Punkt auf auf den du deine Eingangsdatei prüfen solltest:
            Only handle events with a start date
            • 4
              4-Real last edited by 4-Real
              Ich klinke mich mal mit ein..
              Meine Kalendar werden zwar regelmäßig aktualisiert, und auch in meiner VIS Angezeigt.
              Habe vier ICAL Instanzen um zu trennen.
              Lasse in meiner VIS immer nur 2 Termine anzeigen. Sobald in meinem gesamten Icloud Kalender nur noch 2 Einträge vorhanden sind, ich den letzten dann z.B. Lösche, wird der Eintrag der nur noch als einziger vorhandenen ist, doppelt in meiner VIS angezeigt.
              Beispiel:
              2 Termine:
              -Arzt
              -Auto
              Es sind, außer diesen beiden, keine weiteren Einträge fürs restliche Jahr vorhanden.
              Lösche ich nun aber den Termin Auto, also den letzten, das im gesamten restlichen Jahr nur noch Arzt ansteht, wird komischerweise Arzt doppelt in meiner VIS angezeigt..
              Hat jemand auch dieses Problem?
              • O
                Oli @SBorg last edited by
                @SBorg
                Hast du das Problem bei dir lösen können? Habe nämlich das gleiche Phänomen
                • SBorg
                  SBorg Forum Testing Most Active @Oli last edited by SBorg
                  @Oli Ja, konnte ich. Bis 1.7.4 waren die "" kein Problem, seit 1.7.5 hängt sich aber bei mir der kpl. Ical weg und produziert 100% Systemlast (fiel mir gar nicht auf).
                  Da es bei mir "nur" der Müllkalender ist (=erscheint 1x jährlich) patche ich mir mittels sed die SUMMARY zu Recht:
                  falsch, hängt seit > 1.7.5
                  funktioniert:
                  SUMMARY:<span style='color: grey'>Restmülltonne</span>
                  • O
                    @SBorg
                    Super danke, werde ich testen, bei mir ist es auch der Müllkalender
                    ical adapter
