    4. Nuki Adapter Fehler restart endlos
    UNSOLVED Nuki Adapter Fehler restart endlos
      Wing.Stefan last edited by Homoran
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Synology DS 1515+
      Arbeitsspeicher: 16 GB
      Festplattenart: HDD Raid 5
      Betriebssystem: Synology Docker
      Node-Version: 10.x.x
      Nodejs-Version: 12.19.1
      NPM-Version: 6.14.8
      Installationsart: Docker Image / Nuki Adapter
      Image genutzt: Ja
      Ort/Name der Imagedatei: Docker Adapter
      LOG Auszug:
      host.iobroker	2020-11-19 17:20:53.587	info	Restart adapter system.adapter.nuki.0 because enabled
      host.iobroker	2020-11-19 17:20:53.586	info	instance system.adapter.nuki.0 terminated with code 0 (NO_ERROR)
      nuki.0	2020-11-19 17:20:53.066	info	(1651) Terminated (NO_ERROR): Without reason
      nuki.0	2020-11-19 17:20:53.065	info	(1651) terminating
      nuki.0	2020-11-19 17:20:53.047	info	(1651) cleaned everything up...
      nuki.0	2020-11-19 17:20:53.045	error	at IncomingMessage.emit (events.js:326:22)
      nuki.0	2020-11-19 17:20:53.045	error	at Object.onceWrapper (events.js:420:28)
      nuki.0	2020-11-19 17:20:53.045	error	at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1076:12)
      nuki.0	2020-11-19 17:20:53.045	error	at Request.emit (events.js:314:20)
      nuki.0	2020-11-19 17:20:53.045	error	at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1154:10)
      nuki.0	2020-11-19 17:20:53.045	error	at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
      nuki.0	2020-11-19 17:20:53.045	error	at Request._callback (/opt/iobroker/node_modules/iobroker.nuki/main.js:1237:17)
      nuki.0	2020-11-19 17:20:53.045	error	at updateAllLockStates (/opt/iobroker/node_modules/iobroker.nuki/main.js:868:13)
      nuki.0	2020-11-19 17:20:53.045	error	at initNukiDeviceStates (/opt/iobroker/node_modules/iobroker.nuki/main.js:366:19)
      nuki.0	2020-11-19 17:20:53.045	error	(1651) TypeError: Cannot read property 'hasOwnProperty' of undefined
      nuki.0	2020-11-19 17:20:53.043	error	(1651) uncaught exception: Cannot read property 'hasOwnProperty' of undefined
      nuki.0	2020-11-19 17:20:53.030	info	(1651) Lock list requested: http://192.168.1.211:8080/list?ts=2020-11-19T16:20:52Z&rnr=27&hash=8d4adfbb1867f7b3f7226da55f96ffd617b477873796070bbf58ffbe0be42a35
      nuki.0	2020-11-19 17:20:50.033	info	(1651) Bridge Info requested: http://192.168.1.211:8080/info?ts=2020-11-19T16:20:49Z&rnr=25221&hash=6a03fa0219a1393eb33f628427a8e5fd68302623692392d7b653ba29b9a704d9
      nuki.0	2020-11-19 17:20:46.845	info	(1651) starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.nuki, node: v12.19.1, js-controller: 3.1.6
      host.iobroker	2020-11-19 17:20:45.339	info	instance system.adapter.nuki.0 started with pid 1651
      MOD-Edit: Code in code-tags gesetzt!
      Macht er seit kurzem, also ist mir noch nicht so lange aufgefallen.
        Thomas Braun Most Active @Wing.Stefan last edited by
        @Wing-Stefan
        which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
        Bitte Textausgaben auch als Text (in CodeTags) hier rein. Kannst du gleich mal mit dem obigen Befehl üben.
          Wing.Stefan @Thomas Braun last edited by
          @Thomas-Braun said in Nuki Adapter Fehler restart endlos:
          root@iobroker:/opt/iobroker# which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
          /usr/bin/nodejs
          v12.19.1
          /usr/bin/node
          v12.19.1
          /usr/bin/npm
          sudo: Hostname iobroker kann nicht aufgelöst werden: Zu diesem Hostnamen gehört keine Adresse
          sudo: Die Audit-Nachricht kann nicht gesendet werden: Die Operation ist nicht erlaubt
          6.14.8
          nodejs:
            Installiert:           12.19.1-1nodesource1
            Installationskandidat: 12.19.1-1nodesource1
            Versionstabelle:
           *** 12.19.1-1nodesource1 100
                  100 /var/lib/dpkg/status
            Wing.Stefan @Wing.Stefan last edited by Wing.Stefan
            Jetzt hat es irgendwie wieder aufgehört, war jetzt sicher an die 2h wo ich das beobachten konnte. hab vor der ersten Meldung hier adapter gelöscht und neu installiert und ganzen iobroker / synology neu gestartet:
            Aktuell bleibt er wieder grün, das waren die letzten Meldungen: Muss aber sagen das unter Objekte zwar die HAustür vorhanden ist, aber darunter keine Daten sind die ich bis jetzt ausgelesen habe um im Loxone zu sehen welchen Status die Tür hat oder die Batterie genug geladen ist.
            nuki.0	2020-11-19 17:59:08.741	info	(2577) Server listening to http://192.168.1.2:9092
            nuki.0	2020-11-19 17:59:08.733	info	(2577) Callback allready set: http://192.168.1.2:9092/api/nuki.0
            nuki.0	2020-11-19 17:59:06.250	error	(2577) Error: Parse Error: Invalid character in chunk size
            nuki.0	2020-11-19 17:59:06.249	info	(2577) Lock list requested: http://192.168.1.211:8080/list?ts=2020-11-19T16:59:05Z&rnr=65383&hash=3088cc8e26a98a51f66873d2367b1cbc940dead755c488c729b8bf8c55033987
            nuki.0	2020-11-19 17:59:04.187	error	(2577) Error: Parse Error: Invalid character in chunk size
            nuki.0	2020-11-19 17:59:04.186	info	(2577) Bridge Info requested: http://192.168.1.211:8080/info?ts=2020-11-19T16:59:02Z&rnr=61548&hash=06c0a6068702872f6e46c3bdd1ab219d9ce955bf94269763ad32ac2a010cd2ba
            nuki.0	2020-11-19 17:58:59.591	info	(2577) starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.nuki, node: v12.19.1, js-controller: 3.1.6
            host.iobroker	2020-11-19 17:58:58.256	info	instance system.adapter.nuki.0 started with pid 2577
            host.iobroker	2020-11-19 17:58:28.246	info	Restart adapter system.adapter.nuki.0 because enabled
              Weitere Info: Habe unter Objekte alles gelöscht, Nuki Adapter neu gestartet. Objekte passen jetzt aber dafür beginnt das endlose restarten von vorne:
              hier die Loginfo weiter führend nach der Zeile 2 vom vorherigen Posting
              host.iobroker	2020-11-19 18:38:39.457	info	Restart adapter system.adapter.nuki.0 because enabled
              host.iobroker	2020-11-19 18:38:39.456	info	instance system.adapter.nuki.0 terminated with code 0 (NO_ERROR)
              nuki.0	2020-11-19 18:38:38.934	info	(2652) Terminated (NO_ERROR): Without reason
              nuki.0	2020-11-19 18:38:38.932	info	(2652) terminating
              nuki.0	2020-11-19 18:38:38.914	info	(2652) cleaned everything up...
              nuki.0	2020-11-19 18:38:38.913	error	(2652) TypeError: Cannot read property 'hasOwnProperty' of undefined at initNukiDeviceStates (/opt/iobroker/node_modules/iobroker.nuki/main.js:366:19) at updateAllLockStates (/opt/iobroker/nod
              nuki.0	2020-11-19 18:38:38.912	error	(2652) uncaught exception: Cannot read property 'hasOwnProperty' of undefined
              nuki.0	2020-11-19 18:38:38.901	info	(2652) Lock list requested: http://192.168.1.211:8080/list?ts=2020-11-19T17:38:38Z&rnr=32830&hash=00056bc65264d4267f13fec949d3ddc7a457d5225ef1f417ad23f25582e33eff
              nuki.0	2020-11-19 18:38:35.905	info	(2652) Bridge Info requested: http://192.168.1.211:8080/info?ts=2020-11-19T17:38:35Z&rnr=29355&hash=4c020dd7088656906b124832cbb6f2f3bbf15bb42272b56b63b3721490ce7527
              nuki.0	2020-11-19 18:38:32.716	info	(2652) starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.nuki, node: v12.19.1, js-controller: 3.1.6
              host.iobroker	2020-11-19 18:38:31.369	info	instance system.adapter.nuki.0 started with pid 2652
              host.iobroker	2020-11-19 18:38:01.348	info	Restart adapter system.adapter.nuki.0 because enabled
              host.iobroker	2020-11-19 18:38:01.347	info	instance system.adapter.nuki.0 terminated with code 0 (NO_ERROR)
              nuki.0	2020-11-19 18:38:00.830	info	(2637) Terminated (NO_ERROR): Without reason
              nuki.0	2020-11-19 18:38:00.829	info	(2637) terminating
              nuki.0	2020-11-19 18:38:00.811	info	(2637) cleaned everything up...
              nuki.0	2020-11-19 18:38:00.809	error	at IncomingMessage.emit (events.js:326:22)
              nuki.0	2020-11-19 18:38:00.809	error	at Object.onceWrapper (events.js:420:28)
              nuki.0	2020-11-19 18:38:00.809	error	at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1076:12)
              nuki.0	2020-11-19 18:38:00.809	error	at Request.emit (events.js:314:20)
              nuki.0	2020-11-19 18:38:00.809	error	at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1154:10)
              nuki.0	2020-11-19 18:38:00.809	error	at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
              nuki.0	2020-11-19 18:38:00.809	error	at Request._callback (/opt/iobroker/node_modules/iobroker.nuki/main.js:1237:17)
              nuki.0	2020-11-19 18:38:00.809	error	at updateAllLockStates (/opt/iobroker/node_modules/iobroker.nuki/main.js:868:13)
              nuki.0	2020-11-19 18:38:00.809	error	at initNukiDeviceStates (/opt/iobroker/node_modules/iobroker.nuki/main.js:366:19)
              nuki.0	2020-11-19 18:38:00.809	error	(2637) TypeError: Cannot read property 'hasOwnProperty' of undefined
              nuki.0	2020-11-19 18:38:00.808	error	(2637) uncaught exception: Cannot read property 'hasOwnProperty' of undefined
              nuki.0	2020-11-19 18:38:00.797	info	(2637) Lock list requested: http://192.168.1.211:8080/list?ts=2020-11-19T17:38:00Z&rnr=43921&hash=8ac80430bc6d81420bb6a9bb421f75574c109dd51d8e6278aff33987b99e6275
              nuki.0	2020-11-19 18:37:57.763	info	(2637) Bridge Info requested: http://192.168.1.211:8080/info?ts=2020-11-19T17:37:57Z&rnr=33359&hash=5107fc703b3621dee3e84395987cba1c398dd941f0d3d14406a6c4dbb765b708
              nuki.0	2020-11-19 18:37:54.572	info	(2637) starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.nuki, node: v12.19.1, js-controller: 3.1.6
              host.iobroker	2020-11-19 18:37:53.221	info	instance system.adapter.nuki.0 started with pid 2637
              host.iobroker	2020-11-19 18:37:23.209	info	Restart adapter system.adapter.nuki.0 because enabled
              host.iobroker	2020-11-19 18:37:23.208	info	instance system.adapter.nuki.0 terminated with code 0 (NO_ERROR)
              nuki.0	2020-11-19 18:37:22.694	info	(2622) Terminated (NO_ERROR): Without reason
              nuki.0	2020-11-19 18:37:22.693	info	(2622) terminating
              nuki.0	2020-11-19 18:37:22.664	info	(2622) cleaned everything up...
              nuki.0	2020-11-19 18:37:22.662	error	at IncomingMessage.emit (events.js:326:22)
              nuki.0	2020-11-19 18:37:22.662	error	at Object.onceWrapper (events.js:420:28)
              nuki.0	2020-11-19 18:37:22.662	error	at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1076:12)
              nuki.0	2020-11-19 18:37:22.662	error	at Request.emit (events.js:314:20)
              nuki.0	2020-11-19 18:37:22.662	error	at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1154:10)
              nuki.0	2020-11-19 18:37:22.662	error	at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
              nuki.0	2020-11-19 18:37:22.662	error	at Request._callback (/opt/iobroker/node_modules/iobroker.nuki/main.js:1237:17)
              nuki.0	2020-11-19 18:37:22.662	error	at updateAllLockStates (/opt/iobroker/node_modules/iobroker.nuki/main.js:868:13)
              nuki.0	2020-11-19 18:37:22.662	error	at initNukiDeviceStates (/opt/iobroker/node_modules/iobroker.nuki/main.js:366:19)
              nuki.0	2020-11-19 18:37:22.662	error	(2622) TypeError: Cannot read property 'hasOwnProperty' of undefined
              nuki.0	2020-11-19 18:37:22.661	error	(2622) uncaught exception: Cannot read property 'hasOwnProperty' of undefined
              nuki.0	2020-11-19 18:37:22.650	info	(2622) Lock list requested: http://192.168.1.211:8080/list?ts=2020-11-19T17:37:22Z&rnr=18695&hash=3a3bdf6e0a61b6f0d2962d976aa2672cd245903915b8c387f8bf9c62433a73f4
              nuki.0	2020-11-19 18:37:19.655	info	(2622) Bridge Info requested: http://192.168.1.211:8080/info?ts=2020-11-19T17:37:19Z&rnr=5981&hash=b0d3f2741522ac754eaa6966afc51bb8c15e80d5d885565b4e9a131684d85c26
              nuki.0	2020-11-19 18:37:16.465	info	(2622) starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.nuki, node: v12.19.1, js-controller: 3.1.6
              host.iobroker	2020-11-19 18:37:15.097	info	instance system.adapter.nuki.0 started with pid 2622
              host.iobroker	2020-11-19 18:36:45.087	info	Restart adapter system.adapter.nuki.0 because enabled
              host.iobroker	2020-11-19 18:36:45.086	info	instance system.adapter.nuki.0 terminated with code 0 (NO_ERROR)
              nuki.0	2020-11-19 18:36:44.572	info	(2607) Terminated (NO_ERROR): Without reason
              nuki.0	2020-11-19 18:36:44.571	info	(2607) terminating
              nuki.0	2020-11-19 18:36:44.557	info	(2607) cleaned everything up...
              nuki.0	2020-11-19 18:36:44.556	error	at IncomingMessage.emit (events.js:326:22)
              nuki.0	2020-11-19 18:36:44.556	error	at Object.onceWrapper (events.js:420:28)
              nuki.0	2020-11-19 18:36:44.556	error	at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1076:12)
              nuki.0	2020-11-19 18:36:44.556	error	at Request.emit (events.js:314:20)
              nuki.0	2020-11-19 18:36:44.556	error	at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1154:10)
              nuki.0	2020-11-19 18:36:44.556	error	at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
              nuki.0	2020-11-19 18:36:44.556	error	at Request._callback (/opt/iobroker/node_modules/iobroker.nuki/main.js:1237:17)
              nuki.0	2020-11-19 18:36:44.556	error	at updateAllLockStates (/opt/iobroker/node_modules/iobroker.nuki/main.js:868:13)
              nuki.0	2020-11-19 18:36:44.556	error	at initNukiDeviceStates (/opt/iobroker/node_modules/iobroker.nuki/main.js:366:19)
              nuki.0	2020-11-19 18:36:44.556	error	(2607) TypeError: Cannot read property 'hasOwnProperty' of undefined
              nuki.0	2020-11-19 18:36:44.554	error	(2607) uncaught exception: Cannot read property 'hasOwnProperty' of undefined
              nuki.0	2020-11-19 18:36:44.543	info	(2607) Lock list requested: http://192.168.1.211:8080/list?ts=2020-11-19T17:36:44Z&rnr=56058&hash=30bce9b763ae842bf21a57407da098b0baffd4b4e9d69edd889d05641f2f9e6c
              nuki.0	2020-11-19 18:36:41.547	info	(2607) Bridge Info requested: http://192.168.1.211:8080/info?ts=2020-11-19T17:36:41Z&rnr=41508&hash=1737233fe1aeee0d335c5b3fcd5c6537d4fefe922f53b429d62a4e868bb90913
              nuki.0	2020-11-19 18:36:38.359	info	(2607) starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.nuki, node: v12.19.1, js-controller: 3.1.6
              host.iobroker	2020-11-19 18:36:37.052	info	instance system.adapter.nuki.0 started with pid 2607
              host.iobroker	2020-11-19 18:36:07.040	info	Restart adapter system.adapter.nuki.0 because enabled
              host.iobroker	2020-11-19 18:36:07.039	info	instance system.adapter.nuki.0 terminated with code 0 (NO_ERROR)
              nuki.0	2020-11-19 18:36:06.524	info	(2592) Terminated (NO_ERROR): Without reason
              nuki.0	2020-11-19 18:36:06.522	info	(2592) terminating
              javascript.0	2020-11-19 18:36:06.520	warn	(537) at processImmediate (internal/timers.js:461:21)
              javascript.0	2020-11-19 18:36:06.520	warn	(537) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
              javascript.0	2020-11-19 18:36:06.519	warn	(537) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:472:25)
              javascript.0	2020-11-19 18:36:06.519	warn	(537) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1055:38)
              javascript.0	2020-11-19 18:36:06.519	warn	(537) at Object.<anonymous> (script.js.common.Nuki:4:3)
              javascript.0	2020-11-19 18:36:06.518	warn	(537) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1358:20)
              javascript.0	2020-11-19 18:36:06.515	warn	(537) You are assigning a boolean to the state "loxone.0.1652825b-0265-3f49-fffff6d4abfbfbdc.value" which expects a number. Please fix your code to use a number or change the state type to boolean. T
              nuki.0	2020-11-19 18:36:06.501	info	(2592) cleaned everything up...
              nuki.0	2020-11-19 18:36:06.500	error	at IncomingMessage.emit (events.js:326:22)
              nuki.0	2020-11-19 18:36:06.500	error	at Object.onceWrapper (events.js:420:28)
              nuki.0	2020-11-19 18:36:06.500	error	at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1076:12)
              nuki.0	2020-11-19 18:36:06.500	error	at Request.emit (events.js:314:20)
              nuki.0	2020-11-19 18:36:06.500	error	at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1154:10)
              nuki.0	2020-11-19 18:36:06.500	error	at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
              nuki.0	2020-11-19 18:36:06.500	error	at Request._callback (/opt/iobroker/node_modules/iobroker.nuki/main.js:1237:17)
              nuki.0	2020-11-19 18:36:06.500	error	at updateAllLockStates (/opt/iobroker/node_modules/iobroker.nuki/main.js:868:13)
              nuki.0	2020-11-19 18:36:06.500	error	at initNukiDeviceStates (/opt/iobroker/node_modules/iobroker.nuki/main.js:366:19)
              nuki.0	2020-11-19 18:36:06.500	error	(2592) TypeError: Cannot read property 'hasOwnProperty' of undefined
              nuki.0	2020-11-19 18:36:06.498	error	(2592) uncaught exception: Cannot read property 'hasOwnProperty' of undefined
              nuki.0	2020-11-19 18:36:06.486	info	(2592) Lock list requested: http://192.168.1.211:8080/list?ts=2020-11-19T17:36:06Z&rnr=23050&hash=cf3aad1ce21b1c24e37d6bd837b003f4cb9d3b547e1823d4c6c6535ccae51694
              nuki.0	2020-11-19 18:36:03.490	info	(2592) Bridge Info requested: http://192.168.1.211:8080/info?ts=2020-11-19T17:36:03Z&rnr=3468&hash=f6c03952c5e0ddb9c9ace18c2962a6eaf9dfefd24a5e3dfbcba439924108ddd8
              nuki.0	2020-11-19 18:36:00.299	info	(2592) starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.nuki, node: v12.19.1, js-controller: 3.1.6
              host.iobroker	2020-11-19 18:35:59.005	info	instance system.adapter.nuki.0 started with pid 2592
              host.iobroker	2020-11-19 18:35:56.513	info	instance system.adapter.nuki.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              nuki.0	2020-11-19 18:35:55.988	info	(2577) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              nuki.0	2020-11-19 18:35:55.987	info	(2577) terminating
              nuki.0	2020-11-19 18:35:55.986	info	(2577) cleaned everything up...
              nuki.0	2020-11-19 18:35:55.985	info	(2577) Got terminate signal TERMINATE_YOURSELF
              host.iobroker	2020-11-19 18:35:55.980	info	stopInstance system.adapter.nuki.0 send kill signal
              host.iobroker	2020-11-19 18:35:55.974	info	stopInstance system.adapter.nuki.0 (force=false, process=true)
              Vielleicht weiß einer ja was, warum das ist.... Wie gesagt ich kann nicht sagen seit wann, habs nur eben vorhin gemerkt.
                Fehler lag darin, das ich einen 2ten Smart Lock hatte, der aber derzeit nicht aktiv ist, darum startete der endlos um den zu suchen finden.....
                error iobroker nuki
