Java-Script Adapter startet ab und an nicht -> DB?
Normaler Start:
2016-11-16 04:05:48.691 - info: javascript.0 terminating 2016-11-16 04:05:48.887 - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 0 (OK) 2016-11-16 04:11:41.818 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 515 2016-11-16 04:12:00.103 - info: javascript.0 starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v4.6.0 2016-11-16 04:12:00.175 - info: javascript.0 requesting all states 2016-11-16 04:12:00.186 - info: javascript.0 requesting all objects 2016-11-16 04:12:09.147 - info: javascript.0 received all states 2016-11-16 04:12:13.740 - info: javascript.0 received all objects 2016-11-16 04:12:18.920 - info: javascript.0 Start javascript script.js.ereignisse 2016-11-16 04:12:20.551 - info: javascript.0 script.js.ereignisse: DeviceST=ST-05:1.STATE
Start ohne Skripte zu initialisieren:
2016-11-17 04:05:43.684 - info: javascript.0 terminating 2016-11-17 04:05:43.916 - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 0 (OK) 2016-11-17 04:11:37.940 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 12174 2016-11-17 04:11:56.047 - info: javascript.0 starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v4.6.0 2016-11-17 04:11:56.129 - info: javascript.0 requesting all states 2016-11-17 04:11:56.140 - info: javascript.0 requesting all objects 2016-11-17 04:12:05.932 - info: javascript.0 received all states 2016-11-17 04:12:10.809 - info: javascript.0 received all objects 2016-11-17 04:13:59.884 - warn: javascript.0 Reconnection to DB. 2016-11-17 04:14:00.630 - warn: javascript.0 Reconnection to DB. 2016-11-17 11:42:06.763 - info: host.raspberrypi object change system.adapter.javascript.0 2016-11-17 11:42:06.790 - info: host.raspberrypi stopInstance system.adapter.javascript.0 2016-11-17 11:42:06.794 - info: host.raspberrypi stopInstance system.adapter.javascript.0 killing pid 12174 2016-11-17 11:42:06.868 - info: javascript.0 terminating 2016-11-17 11:42:06.965 - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 0 (OK) 2016-11-17 11:42:09.386 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 12060 2016-11-17 11:42:14.561 - info: javascript.0 starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v4.6.0 2016-11-17 11:42:14.606 - info: javascript.0 requesting all states 2016-11-17 11:42:14.613 - info: javascript.0 requesting all objects 2016-11-17 11:42:20.738 - info: javascript.0 received all states 2016-11-17 11:42:24.296 - info: javascript.0 received all objects 2016-11-17 11:42:24.423 - info: javascript.0 Start javascript script.js.ereignisse 2016-11-17 11:42:25.198 - info: javascript.0 script.js.ereignisse: DeviceST=ST-05:1.STATE
(um 11.42 habe ich dann einen Restart des Script-Adapters gemacht. Er wird aber normal als running, ohne Probleme angezeigt)
=> Hat das warn: Reconnection to DB etwas zu sagen?
Normaler Start:
=> Hat das warn: Reconnection to DB etwas zu sagen? `
Vermutlich ist der Adapter am Start so mit Skripten beschäftigt, dass er keine Zeit zum Kommunizieren hat. Und die Verbindung zum Controller wird abgebrochen.Versuche ein paar Intensivskripte mit setTimeout zu versehen.
habe jetzt mal das "servicemeldungen" von paul53 deaktiviert.
Kann sein, das seit dem ich das nutze, die Fehler auftauchen.
Werde das mal beobachten. Danke für den Tipp.
Aktuell läuft er. Ich werde es weiter beobachten.
