    4. Error: hm-rpc.0 Socket error: Error: read ECONNRESET
    • sissiwup
      sissiwup last edited by
      habe meine Installation umgezogen auf einen neuen Rechner. Alles läuft, nur:
      error: hm-rpc.0 Socket error: Error: read ECONNRESET
      2016-11-19 21:15:11.756  - info: host.zotac object change system.adapter.hm-rpc.0
      2016-11-19 21:15:11.766  - info: hm-rpc.0 xmlrpc -> 192.168.1.11:2001 init ["http://192.168.1.13:2002",""]
      2016-11-19 21:15:11.760  - info: host.zotac stopInstance system.adapter.hm-rpc.0
      2016-11-19 21:15:11.761  - info: host.zotac stopInstance system.adapter.hm-rpc.0 killing pid 7221
      2016-11-19 21:15:14.298  - info: host.zotac instance system.adapter.hm-rpc.0 started with pid 7350
      2016-11-19 21:15:15.437  - info: host.zotac instance system.adapter.hm-rpc.0 terminated with code 7 (Adapter already running)
      2016-11-19 21:15:34.792  - error: hm-rpc.0 init error: Error: read ECONNRESET
      2016-11-19 21:16:02.067  - info: tankerkoenig.0 force terminating adapter after 1 minute
      2016-11-19 21:16:02.611  - info: host.zotac instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
      2016-11-19 21:16:04.865  - error: hm-rpc.0 init error: Error: read ECONNRESET
      2016-11-19 21:16:30.726  - error: hm-rpc.0 init error: Error: read ECONNRESET
      2016-11-19 21:17:06.703  - info: hm-rpc.0 terminating
      2016-11-19 21:17:06.722  - error: host.zotac instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
      2016-11-19 21:17:06.723  - info: host.zotac Restart adapter system.adapter.hm-rpc.0 because enabled
      2016-11-19 21:17:17.188  - error: hm-rpc.0 Socket error: Error: read ECONNRESET
      2016-11-19 21:17:19.461  - info: host.zotac Update repository "default" under "conf/sources-dist.json"
      2016-11-19 21:17:36.798  - info: host.zotac instance system.adapter.hm-rpc.0 started with pid 7481
      2016-11-19 21:17:37.986  - info: hm-rpc.0 starting. Version 1.3.3 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v6.9.1
      2016-11-19 21:17:38.584  - info: hm-rpc.0 binrpc server is trying to listen on 192.168.1.13:2002
      2016-11-19 21:17:38.587  - info: hm-rpc.0 binrpc client is trying to connect to 192.168.1.11:2001 with ["xmlrpc_bin://192.168.1.13:2002","hm-rpc.0"]
      2016-11-19 21:19:25.574  - error: hm-rpc.0 Socket error: Error: read ECONNRESET
      2016-11-19 21:19:34.160  - error: hm-rpc.0 Socket error: Error: read ECONNRESET
      Und der ist natürlich wichtig.
      Hat jemand eine Idee, wodran das liegen kann.
      Neustart, neu installiert habe ich schon …
      • sissiwup
        Ein Neustart der CCU2 hat das Problem behoben.
