    4. IoBroker.admin # update auf 0.4.5
    • derAuge
      derAuge last edited by
      Das Update ist ohne Probleme gelaufen.
      admin-0	2015-04-25 08:51:05	info	received all states
      admin-0	2015-04-25 08:51:05	info	received all objects
      admin-0	2015-04-25 08:51:05	info	Use link "http://localhost:8081" to configure.
      admin-0	2015-04-25 08:51:05	info	http server listening on port 8081
      admin-0	2015-04-25 08:51:05	info	requesting all objects
      admin-0	2015-04-25 08:51:05	info	requesting all states
      admin-0	2015-04-25 08:51:05	info	starting. Version 0.4.5 in /opt/iobroker/node_modules/iobroker.admin
      host-raspberrypi	2015-04-25 08:51:00	info	instance system.adapter.admin.0 started with pid 3099
      iobroker	2015-04-25 08:50:59	info	exit 0
      iobroker	2015-04-25 08:50:59	info	Adapter "admin" updated
      iobroker	2015-04-25 08:50:58	info	upload admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
      host-raspberrypi	2015-04-25 08:50:58	info	instance system.adapter.admin.0 terminated with code 0 (OK)
      admin-0	2015-04-25 08:50:58	info	terminating
      iobroker	2015-04-25 08:50:58	info	upload admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
      host-raspberrypi	2015-04-25 08:50:58	info	stopInstance system.adapter.admin.0 killing pid 2099
      admin-0	2015-04-25 08:50:58	info	terminating http server on port 8081
      host-raspberrypi	2015-04-25 08:50:58	info	object change system.adapter.admin.0
      iobroker	2015-04-25 08:50:58	info	got /opt/iobroker/node_modules/iobroker.admin/admin
      iobroker	2015-04-25 08:50:52	info	npm install --production --prefix "/opt/iobroker/node_modules/iobroker.admin" (System call)
      iobroker	2015-04-25 08:46:20	info	npm install iobroker.admin --production --prefix "/opt/iobroker" (System call)
      iobroker	2015-04-25 08:46:18	info	upgrade admin
      host-raspberrypi	2015-04-25 08:45:45	info	Update repository "default" under "conf/sources-dist.json"
      derAuge
        Super 😉
        • derAuge
          Hi
          bei der installation von vis wird diese in die Kategorie Allgemein verschoben und bleibt nicht in Visualisation
          derAuge
            pix last edited by
            bei mir ist jetzt DWD in der Kategorie Wetter und YR.NO nicht mehr. Vorher war es umgekehrt. Es gehören wohl beide in die Kategorie Wetter.
            Homematic passt auch besser in die Kategorie Hardware (wie KNX) und Graphite, Highcharts und Flot (später) in die Kategorie Visualisation. Das Wort Visualisation ist ja eigentlich ein englisches, in deutsch heißt es Visualisierung.
            Pix
              Hallo pix,
              bei mir ist alles so, wie du es willst!?
              Lediglich vis ist nicht unter Visualisierung. Sonst sieht alles gut aus.
