    4. [GELÖST] Update von Adaptern führt zu Fehlermeldung
    • G
      GerdSo last edited by
      seit ein paar Wochen habe ich Probleme Adapter zu aktualisieren. Es folgt immer eine Fehlermeldung in der Art: (npm-debug.log)
      0 info it worked if it ends with ok
      1 verbose cli [ 'C:\\Program Files\\nodejs\\node.exe',
      1 verbose cli   'C:\\Users\\Kerstin\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js',
      1 verbose cli   'install',
      1 verbose cli   '--production',
      1 verbose cli   '--prefix',
      1 verbose cli   'C:/Program Files/ioBroker/node_modules/iobroker.ping' ]
      2 info using npm@4.0.0
      3 info using node@v5.9.0
      4 silly loadCurrentTree Starting
      5 silly install loadCurrentTree
      6 silly install readGlobalPackageData
      7 silly fetchPackageMetaData .
      8 silly fetchDirectoryPackageData .
      9 silly install normalizeTree
      10 silly loadCurrentTree Finishing
      11 silly loadIdealTree Starting
      12 silly install loadIdealTree
      13 silly cloneCurrentTree Starting
      14 silly install cloneCurrentTreeToIdealTree
      15 silly cloneCurrentTree Finishing
      16 silly loadShrinkwrap Starting
      17 silly install loadShrinkwrap
      18 silly loadShrinkwrap Finishing
      19 silly loadAllDepsIntoIdealTree Starting
      20 silly install loadAllDepsIntoIdealTree
      21 silly resolveWithNewModule iobroker.core@ checking installable status
      22 silly cache add args [ '.', null ]
      23 verbose cache add spec .
      24 silly cache add parsed spec Result {
      24 silly cache add   raw: '.',
      24 silly cache add   scope: null,
      24 silly cache add   escapedName: null,
      24 silly cache add   name: null,
      24 silly cache add   rawSpec: '.',
      24 silly cache add   spec: 'C:\\Program Files\\ioBroker',
      24 silly cache add   type: 'directory' }
      25 error addLocal Could not install C:\Program Files\ioBroker
      26 silly rollbackFailedOptional Starting
      27 silly rollbackFailedOptional Finishing
      28 silly runTopLevelLifecycles Finishing
      29 silly install printInstalled
      30 verbose stack Error: No version provided in package.json
      30 verbose stack     at C:\Users\Kerstin\AppData\Roaming\npm\node_modules\npm\lib\cache\add-local.js:75:17
      30 verbose stack     at C:\Users\Kerstin\AppData\Roaming\npm\node_modules\npm\node_modules\read-package-json\read-json.js:356:5
      30 verbose stack     at checkBinReferences_ (C:\Users\Kerstin\AppData\Roaming\npm\node_modules\npm\node_modules\read-package-json\read-json.js:320:45)
      30 verbose stack     at final (C:\Users\Kerstin\AppData\Roaming\npm\node_modules\npm\node_modules\read-package-json\read-json.js:354:3)
      30 verbose stack     at then (C:\Users\Kerstin\AppData\Roaming\npm\node_modules\npm\node_modules\read-package-json\read-json.js:124:5)
      30 verbose stack     at ReadFileContext. <anonymous>(C:\Users\Kerstin\AppData\Roaming\npm\node_modules\npm\node_modules\read-package-json\read-json.js:295:20)
      30 verbose stack     at ReadFileContext.callback (C:\Users\Kerstin\AppData\Roaming\npm\node_modules\npm\node_modules\graceful-fs\graceful-fs.js:78:16)
      30 verbose stack     at FSReqWrap.readFileAfterOpen [as oncomplete] (fs.js:324:13)
      31 verbose cwd C:\Program Files\ioBroker
      32 error Windows_NT 10.0.14393
      33 error argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\Kerstin\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js" "install" "--production" "--prefix" "C:/Program Files/ioBroker/node_modules/iobroker.ping"
      34 error node v5.9.0
      35 error npm  v4.0.0
      36 error No version provided in package.json
      37 error If you need help, you may report this error at:
      37 error     <https: github.com/npm/issues="">38 verbose exit [ 1, true ]</https:></anonymous>
      Nachdem Update zeigt die Admin-Oberfläche immer an, dass der zu aktualisierende Adapter nun aktuell ist, was ich sehr in Frage stelle.
      Ich habe keine Idee, was ich machen kann, damit die Aktualisierung wieder korrekt läuft.
      • apollon77
        apollon77 last edited by
        node 5? Ist ne pot. unstable Entwicklerversion.
        AM besten mit node 4 machen!
        • G
          Danke für die schnelle Rückmeldung. Ich melde mich, wenn es damit wieder funktioniert
          • G
            Funktioniert auch nicht:
            c:\Program Files\ioBroker>node node_modules/iobroker.js-controller/iobroker.js add ping
            npm install iobroker.ping --production --prefix "c:/Program Files/ioBroker" (System call)
            host.DauerlaufLaptop install adapter ping
            npm install --production --prefix "c:/Program Files/ioBroker/node_modules/iobroker.ping" (System call)
            npm ERR! addLocal Could not install c:\Program Files\ioBroker
            npm ERR! Windows_NT 10.0.14393
            npm ERR! argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\Kerstin\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js" "install" "--production" "--prefix" "c:/Program Files/ioBroker/node_modules/iobroker.ping"
            npm ERR! node v4.6.2
            npm ERR! npm  v4.0.0
            npm ERR! No version provided in package.json
            npm ERR!
            npm ERR! If you need help, you may report this error at:
            npm ERR!     <https: github.com/npm/issues="">npm ERR! Please include the following file with any support request:
            npm ERR!     c:\Program Files\ioBroker\npm-debug.log
            Cannot install iobroker.ping: 1</https:>
              Auch falsche npm version
              npm i npm@latest-2 -g
              Und danach noch mal probieren
              • G
                Danke, jetzt klappt es wieder
                • G
                  Habe jetzt das Problem, dass die Visualisierung mit vis nicht mehr funktioniert.
                  Auf Windowsrechnern funktioniert es meistens (Edge, Chrome und Firefox geht, IE geht nicht), auf meinem Android-Tablet aber nur mit Firefox und keinem anderen von mir verwendeten Browser, vor allem nicht mit dem Kioskbrowser (Dolphin) den ich bisher verwende.
                  Fehlerbild ist immer das er bei "Loading values" hängenbleibt. Cache löschen etc. hat da nichts gebracht. Die Verifizierung auf einem weiteren Android-Tablet zeigt das identische Fehlerbild.
                  Ich befürchte, dass irgendein Adapter jetzt etwas rumspinnt. Neuinstallation von vis hat nichts gebracht. Irgendwelche Ideen von Eurer Seite?
                    Ist auch web auf dem neuesten Stand?
                    • G
                      Alle Adapter auf dem neuesten Stand, kein Update ausstehend. Habe web jetzt gelöscht und wieder hinzugefügt, Fehler bleibt erhalten
                      • Dutchman
                        @GerdSo:
                        Alle Adapter auf dem neuesten Stand, kein Update ausstehend. Habe web jetzt gelöscht und wieder hinzugefügt, Fehler bleibt erhalten `
                        Das Probleme hatte ich auch auf meinen Windows Mobile, definitive Client Problem und nicht Iobroker/vis sonst ginge aus auch im Firefox nicht 😉
                        • G
                          Glaube nicht an ein Clientproblem, da es gestern Abend noch funktioniert hat und seitdem nur an iobroker geschraubt wurde
                          • G
                            Habe das Problem jetzt gelöst.
                            Alte gesicherte Version des Verzeichnisses node_modules unter iobroker von Anfang des Monats reingespielt, dann iobroker gestartet. Wie erwartet wurden zahlreiche Adapter als updatable gemeldet und vis lief wieder unter allen Browsern und auch in Dolphin unter Android. Auch nach dem upgrade der Adapter funktioniert noch alles.
                            1899
