    2. English
    3. ioBroker general
    4. Can I use RM Mini 3 as IR receiver with broadlink2 adapter?
    • Tomasz Nowak
      Tomasz Nowak last edited by
      Hi.
      I have Broadlink RM Mini 3 and I'm able to learn IR commands and probably send them from ioBroker using Scenes.
      But what I need is to detect that a specific (learned) IR command has been received by Broadlink, so I could publish a message on MQTT broker with MQTT-client adapter? In short: I need to publish MQTT message if I press a IR remote button. I can't find a way how to configure it.
      Albert K 1 Reply Last reply Reply Quote 0
      • Albert K
        Albert K @Tomasz Nowak last edited by
        @Tomasz-Nowak
        I don't have mini, just a RMPro but that shoudn't matter.
        As soon as you have an IR command learned and saved in the broadlink adapter you can set a trigger in a blockly script to fire when you press that button on the remote. What you want the script to do is then pretty much up to you I guess. Sorry, I don't know anything about MQTT.
        Tomasz Nowak 1 Reply Last reply Reply Quote 0
        • Tomasz Nowak
          Tomasz Nowak @Albert K last edited by
          @Albert-K I combined that learned object with MQTT-Client, but it doesn't send anything if I issue this IR command from other remote. And that's what I'd like to do. I don't want to send any commands from Broadlink.
          • Albert K
            Albert K @Tomasz Nowak last edited by Albert K
            @Tomasz-Nowak
            That is not going to work as far as I know. The adapter only helps to relay the sending of IR commands, not the receiving of signals.
            The Broadlink only processes incoming IR signal while learning.
            • MathiasJ
              MathiasJ last edited by
              I use RM Mini and it works fine with the broadlink adapter.
              • Tomasz Nowak
                Tomasz Nowak @MathiasJ last edited by
                @MathiasJ Do you use it to receive IR commands?
                Tomasz Nowak MathiasJ 2 Replies Last reply Reply Quote 0
                • Tomasz Nowak
                  Tomasz Nowak @Tomasz Nowak last edited by
                  Never mind, I've managed to solve this with fakeroku adapter 🙂
                  • MathiasJ
                    MathiasJ @Tomasz Nowak last edited by
                    @Tomasz-Nowak
                    No I send IR commands with it to the TV, HIFI, A/C, 433 MHz Signals to the plugs.....
                    1.2k
                    broadlink broadlink 2 adapter broadlink rm 3 mini broadlink2
