    4. Rflink update 1.06
    Rflink update 1.06
      stephan61 last edited by
      Hallo wollte rflink über github updaten bekommen folgende Fehlermeldung
      ERR! Tried to download(404): https://github.com/EmergingTechnologyAd … arm.tar.gz node-pre-gyp ERR! Pre-built binaries no
      iobroker 2016-11-29 18:09:13.964 info node-pre-gyp
      Gruß Stephan
        Und?
        Was passierte dann?
        ich denke, das iobroker anschließend das nicht gefundene Paket selbst gebaut hat.
        • lobomau
          lobomau last edited by
          Bei mir hat Update auf 1.0.6 über github auch nicht funktioniert.
          iobroker	2016-11-29 21:06:19.137	info	exit 0
          iobroker	2016-11-29 21:06:19.049	info	upload [0] rflink.admin /opt/iobroker/node_modules/iobroker.rflink/admin/index.html index.html text/html
          iobroker	2016-11-29 21:06:18.986	info	upload [1] rflink.admin /opt/iobroker/node_modules/iobroker.rflink/admin/parse.js parse.js application/javascript
          iobroker	2016-11-29 21:06:18.894	info	upload [2] rflink.admin /opt/iobroker/node_modules/iobroker.rflink/admin/rflink.png rflink.png image/png
          iobroker	2016-11-29 21:06:18.868	info	got /opt/iobroker/node_modules/iobroker.rflink/admin
          iobroker	2016-11-29 21:06:18.744	info	└── serialport@2.1.2 (bindings@1.2.1, sf@0.1.7, nan@2.2.1, bluebird@3.4.6, optimist@0.6.1, object.assign@4.0.4)
          iobroker	2016-11-29 21:06:18.744	info	iobroker.rflink@1.0.5 opt/iobroker/node_modules/iobroker.rflink├── request@2.79.0 (tunnel-agent@0.4.3, aws-sign2@0.6.0, forever-agent@0.6.1, oauth-sign@0.8.2, caseless@0.11.0, is-typedarray@1.0.0, st
          iobroker	2016-11-29 21:06:18.374	info	npm WARN unmet dependency which is version 2.1.2
          iobroker	2016-11-29 21:06:18.374	info	npm WARN unmet dependency /opt/iobroker/node_modules/iobroker.rflink/node_modules/avrgirl-arduino requires serialport@'^4.0.1' but will loadnpm WARN unmet dependency /opt/iobroker/node_modules/iobrok
          iobroker	2016-11-29 21:06:08.693	info	[serialport] Success: "/opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport/build/Release/serialport.node" is installed via remote
          iobroker	2016-11-29 21:06:05.776	info	> node-pre-gyp install --fallback-to-build
          iobroker	2016-11-29 21:06:05.776	info	> serialport@2.1.2 install /opt/iobroker/node_modules/iobroker.rflink/node_modules/serialport
          iobroker	2016-11-29 21:05:56.199	info	optional dep failed, continuing avrgirl-arduino@1.11.5
          iobroker	2016-11-29 21:05:56.198	info	npm WARN
          iobroker	2016-11-29 21:05:56.087	info	npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git://github.com/noopkat/js-stk500v1.git /root/.npm/_git-remotes/git-github-com-noopkat-js-stk500v1-git-8fb2e015: undefined
          iobroker	2016-11-29 21:05:56.086	info	npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git://github.com/noopkat/js-stk500v1.git /root/.npm/_git-remotes/git-github-com-noopkat-js-stk500v1-git-8fb2e015: undefined
          iobroker	2016-11-29 21:05:56.082	info	npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git://github.com/noopkat/browser-serialport.git /root/.npm/_git-remotes/git-github-com-noopkat-browser-serialport-git-acc322c
          iobroker	2016-11-29 21:05:56.081	info	npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror git://github.com/noopkat/browser-serialport.git /root/.npm/_git-remotes/git-github-com-noopkat-browser-serialport-git-acc322c
          iobroker	2016-11-29 21:05:55.972	info	npm WARN addRemoteGit git://github.com/noopkat/js-stk500v1.git#avrgirl resetting remote /root/.npm/_git-remotes/git-github-com-noopkat-js-stk500v1-git-8fb2e015 because of error: { [Error: not found:
          iobroker	2016-11-29 21:05:55.972	info	npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:82:15)
          iobroker	2016-11-29 21:05:55.972	info	WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/acc
          iobroker	2016-11-29 21:05:55.971	info	npm
          iobroker	2016-11-29 21:05:55.971	info	npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
          iobroker	2016-11-29 21:05:55.971	info	npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
          iobroker	2016-11-29 21:05:55.971	info	npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
          iobroker	2016-11-29 21:05:55.971	info	npm WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
          iobroker	2016-11-29 21:05:55.969	info	npm WARN addRemoteGit git://github.com/noopkat/browser-serialport.git#api-updates resetting remote /root/.npm/_git-remotes/git-github-com-noopkat-browser-serialport-git-acc322cb because of error: { [
          iobroker	2016-11-29 21:05:55.969	info	npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:82:15)
          iobroker	2016-11-29 21:05:55.969	info	npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
          iobroker	2016-11-29 21:05:55.969	info	npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
          iobroker	2016-11-29 21:05:55.969	info	npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
          iobroker	2016-11-29 21:05:55.969	info	npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
          iobroker	2016-11-29 21:05:55.969	info	npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
          iobroker	2016-11-29 21:05:55.969	info	WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
          iobroker	2016-11-29 21:05:55.962	info	npm
          iobroker	2016-11-29 21:05:46.666	info	npm install https://github.com/ioBroker/ioBroker.rflink/tarball/master --production --prefix "/opt/iobroker" (System call)
          iobroker	2016-11-29 21:05:46.462	info	install https://github.com/ioBroker/ioBroker.rflink/tarball/master
          iobroker	2016-11-29 21:05:45.780	info	url "https://github.com/ioBroker/ioBroker.rflink/tarball/master" rflink --debug
          81.0k
