    4. Restore schlägt fehl
    UNSOLVED Restore schlägt fehl
      LJSven last edited by LJSven
      Systemdata Bitte Ausfüllen
      Hardwaresystem: tinkerboard
      Arbeitsspeicher: 2GB
      Festplattenart: SD-Karte
      Betriebssystem: Ubuntu
      Node-Version: 12.20.0
      Nodejs-Version: 12.20.0
      NPM-Version: 6.x.x
      Ich möchte meinen ioBroker aus restore wiederherstellen. Aber es kommt eine Meldung. Was mache ich falsch?
      pi@tinkerboardmaster:/opt/iobroker$ iobroker restore iobroker_2020_12_15-02_00_10_ioBrokerMini_backupiobroker.tar.gz
       Objects 192.168.178.228:45120 Error from InMemDB: Error: Unknown Script f920e95b4d029e06ed62ab6885f33d4fbfacdb20
      iobroker controller daemon is not running
      host.tinkerboardmaster OK.
      <--- Last few GCs --->
      [17199:0x3e35b60]    19144 ms: Mark-sweep 499.7 (501.7) -> 499.7 (501.7) MB, 169.0 / 0.0 ms  (average mu = 0.303, current mu = 0.000) last resort GC in old space requested
      [17199:0x3e35b60]    19377 ms: Mark-sweep 499.7 (501.7) -> 499.7 (501.7) MB, 232.5 / 0.0 ms  (average mu = 0.182, current mu = 0.000) last resort GC in old space requested
      <--- JS stacktrace --->
      ==== JS stack trace =========================================
      Security context: 0x4378ea21 <JSObject>
          0: builtin exit frame: parse(this=0x437865a9 <Object map = 0x45e40a15>,0x39c4008d <Very long string[108752834]>,0x437865a9 <Object map = 0x45e40a15>)
          1: restoreAfterStop [0x37af6111] [/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:627] [bytecode=0x50afd42d offset=168](this=0x34842395 <BackupRestore map = 0x494cf885>,0x317c03c1 <false>,0x34842aa5 <JSFunction (sfi ...
      FATAL ERROR: CALL_AND_RETRY_LAST Allocation failed - JavaScript heap out of memory
      /usr/bin/iobroker: Zeile 8: 17198 Abgebrochen             sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
      pi@tinkerboardmaster:/opt/iobroker$ iobroker restore iobroker_2020_12_14-02_00_10_ioBrokerMini_backupiobroker.tar.gz
      [17369:0x2e6bb60]    36581 ms: Mark-sweep 506.8 (508.0) -> 507.0 (508.8) MB, 438.3 / 0.0 ms  (average mu = 0.105, current mu = 0.052) allocation failure scavenge might not succeed
      Cannot get stack trace in GC.
      FATAL ERROR: MarkCompactCollector: semi-space copy, fallback in old gen Allocation failed - JavaScript heap out of memory
      /usr/bin/iobroker: Zeile 8: 17368 Abgebrochen             sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
      • UncleSam
        UncleSam Developer @LJSven last edited by
        @LJSven sagte in Restore schlägt fehl:
        Scheinbar hast du nicht mehr genug RAM. Was läuft sonst noch auf dem Pi? Hast du einen Desktop am laufen? Ist das System neu aufgesetzt?
        Ein Tipp: wenn nicht unbedingt nötig, würde ich auf Raspberry OS gehen und nicht Ubuntu. Meines Wissens braucht Ubuntu einiges mehr an Platz als Raspberry OS, das extra für den Raspi erstellt wurde.
          LJSven @UncleSam last edited by
          @UncleSam Das ist ein Tinkerboard / das System läuft eigentlich seit einem Jahr. Gestern habe ich ein System Update gemacht. Vermutlich nimmt sich da einer Resourcen. Wie kann ich vorgehen? Selbst wenn der Tinkerboard neu gestartet wurde, lässt sich das Update nicht installieren. Der Iobroker läuft, aber nach dem Neustart fehlen Werte in Datenpunkten. Deshalb wollte ich ein Backup einspielen. Oder gibt es eine andere Möglichkeit die Werte wieder zu bekommen. Habe das Problem gelegentlich, wenn nicht ordentlich neu gestartet wird.
          UncleSam J Homoran 3 Replies Last reply Reply Quote 0
          • UncleSam
            Hast du es mal mit einer neuen SD-Karte versucht? Die könnte beschädigt sein.
            Um zu schauen, was viel RAM/CPU braucht, kannst du mal den Befehl top ausführen und hier hin kopieren.
              Jan1 @LJSven last edited by
              @LJSven
              Wie spielst denn ein Backup ein, mit dem Backitup Adapter?
                LJSven @Jan1 last edited by
                @Jan1 sagte in Restore schlägt fehl:
                @LJSven
                Nein - manuell über iobroker restore „filename“
                  @LJSven
                  Das ist schon mal möglich, wenn man weiß was man tut.
                  Warum nimmst nicht den Adapter dafür der für genau das gemacht wurde und einige Vorteile gegenüber einem "normalen" Backup mit bringt?
                  • UncleSam
                    UncleSam Developer @Jan1 last edited by
                    Er benutzt ja iobroker restore auf der Kommandozeile mit einem Backup das wohl von BackItUp gemacht wurde.
                    L J 2 Replies Last reply Reply Quote 0
                      @UncleSam sagte in Restore schlägt fehl:
                      Genau! Macht es dann Sinn über den Adapter?
                        Jan1 @UncleSam last edited by
                        @UncleSam
                        Das ist eben der falsche Weg und ich glaube, dass da IOBroker noch irgendwie im Hintergrund läuft, was dazu führt, dass sein RAM voll läuft.
                          Jan1 @LJSven last edited by Jan1
                          @LJSven
                          Das macht nicht nur Sinn, sondern sollte so gemacht werden.
                          Und wenn das wirklich sauber sein soll, dann vorher IOBroker Ordner komplett löschen, IOBroker und Backitup Adapter installieren, das Backup in den "Backups" Ordner schieben und über den Adapter restoren.
                          Je nach Umfang des Restor, mal ne Stunde Pause einlegen und freuen, dass das Ding wieder läuft.
                          • UncleSam
                            @Jan1 Das wäre mir neu, aber so oft habe ich Restore noch nicht verwendet.
                            Von https://github.com/simatec/ioBroker.backitup/blob/master/docs/en/backitup.md#4-restore :
                            For all backup types iobroker is stopped during the restore and then automatically restarted.
                            Einzig CCU geht noch nicht.
                              @UncleSam
                              Wenn Du das mit dem Adapter machst auf alle Fälle, nur bei ihm wohl nicht, sonst wäre der RAM nicht voll 😉
                                top - 08:47:00 up  1:03,  2 users,  load average: 0,67, 0,67, 0,87
                                Tasks: 198 total,   3 running, 138 sleeping,   0 stopped,   0 zombie
                                %Cpu(s): 12,1 us,  2,0 sy,  0,0 ni, 85,5 id,  0,0 wa,  0,0 hi,  0,3 si,  0,0 st
                                KiB Mem :  2050804 total,   318224 free,  1332388 used,   400192 buff/cache
                                KiB Swap:  1025400 total,  1011576 free,    13824 used.   781764 avail Mem
                                  PID USER      PR  NI    VIRT    RES    SHR S  %CPU %MEM     TIME+ COMMAND
                                 7272 iobroker  20   0  259616 174584  27400 S  24,6  8,5  19:14.77 node
                                 8429 iobroker  20   0  155476  67448  27184 S   9,8  3,3   3:36.63 node
                                 7573 iobroker  20   0  305680 221256  28464 S   7,9 10,8   6:15.76 node
                                 7333 iobroker  20   0  206284 122936  28580 S   4,6  6,0   0:36.18 node
                                  750 pi        20   0  119672  35412  23832 S   2,6  1,7   1:41.38 deCONZ
                                17654 pi        20   0    8796   2940   2444 R   1,3  0,1   0:00.24 top
                                 1458 asterisk  20   0  230008  58996  31320 S   1,0  2,9   0:58.40 asterisk
                                 7398 iobroker  20   0  146304  54680  27664 S   1,0  2,7   0:36.67 node
                                 7498 iobroker  20   0  148596  58988  27516 S   1,0  2,9   1:53.69 node
                                 8855 iobroker  20   0  146080  61000  27084 S   1,0  3,0   0:43.21 node
                                  355 root      20   0    7204    992    992 S   0,3  0,0   0:12.23 haveged
                                 1554 ntp       20   0    6772   2704   2292 S   0,3  0,1   0:00.53 ntpd
                                 1564 root      20   0  123120  43988  25484 S   0,3  2,1   0:01.31 Xorg
                                 7391 iobroker  20   0  137188  43900  27660 S   0,3  2,1   0:07.14 node
                                 8408 iobroker  20   0  136784  43928  26924 S   0,3  2,1   0:10.76 node
                                 8707 iobroker  20   0  144048  51420  26968 R   0,3  2,5   0:40.09 node
                                 8903 root      20   0       0      0      0 I   0,3  0,0   0:00.36 kworker/2:+
                                J UncleSam 3 Replies Last reply Reply Quote 0
                                  @LJSven
                                  Nur IOBroker frisst hier RAM, wobei das Ding bei 2GB RAM schon SWAPt und das ist früher oder später eh der Tod der SD Karte.
                                  • UncleSam
                                    UncleSam Developer @LJSven last edited by UncleSam
                                    @LJSven Asterisk und XOrg (der Desktop) fressen viel RAM. Ich würde mal auf reine Konsole wechseln (oder brauchst du den Desktop wirklich?) und vor dem Restore Asterisk beenden.
                                      @LJSven Asterisk und XOrg (der Desktop) fressen sehr viel RAM. Ich würde mal auf reine Konsole wechseln (oder brauchst du den Desktop wirklich?) und vor dem Restore Asterisk beenden.
                                      Nein, den Desktop brauche ich gar nicht - wie bekomme ich das weg?
                                      J UncleSam 2 Replies Last reply Reply Quote 0
                                        @UncleSam
                                        Warte mal wenn Thomas einsteigt und was zum Thema Desktop auf nem Linux Server sagt 😉
                                        Wenn da nur IOBroker drauf laufen soll, hat das nix drauf verloren und frisst nur, wobei beim Restor der nicht in die höhe gehen sollte , wenn man alles über die Konsole erledigt, egal wie der Restor durchgeführt wird.
                                          @LJSven
                                          Auf Runlevle 3 wechseln und das nächste Mal beim Ubuntu installieren erst gar nicht aus wählen 😉
                                          • UncleSam
                                            @LJSven Ja, hast Glück, dass Thomas noch nicht wach ist 😛
                                            Bei Ubuntu kannst du es scheinbar so machen:
                                            https://linuxconfig.org/how-to-disable-enable-gui-on-boot-in-ubuntu-20-04-focal-fossa-linux-desktop
                                            sudo systemctl set-default multi-user
                                            L Thomas Braun 2 Replies Last reply Reply Quote 0
                                            restore backup
                                            8015
