    3. Entwicklung
    4. Zigbee bleibt gelb nach upgrade auf 1.4
      Mr.X last edited by Mr.X
      nach upgrade des Zigbee Adapter von 1.3.1 auf 1.4 bleibt der Adapter gelb.
      Beim downgraden zurück auf 1.3.1 funktioniert alles wieder.
      Hier was ich schon u. A. mit Hilfe von @Thomas-Braun schon ausgelesen hab und das log beim Starten des Adapters.
      Start Zigbee Adapter:
      Zigbee.0	2020-12-14 10:33:53.419	error	at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/stream/lib/index.js:242:12
      zigbee.0	2020-12-14 10:33:53.419	error	at SerialPort._error (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/stream/lib/index.js:198:14)
      zigbee.0	2020-12-14 10:33:53.419	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
      zigbee.0	2020-12-14 10:33:53.419	error	at __awaiter (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
      zigbee.0	2020-12-14 10:33:53.419	error	at new Promise (<anonymous>)
      zigbee.0	2020-12-14 10:33:53.419	error	at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
      zigbee.0	2020-12-14 10:33:53.419	error	at Generator.next (<anonymous>)
      zigbee.0	2020-12-14 10:33:53.419	error	at Znp.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
      zigbee.0	2020-12-14 10:33:53.419	error	(2014) Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyACM0'
      zigbee.0	2020-12-14 10:33:53.418	error	(2014) Failed to start Zigbee
      zigbee.0	2020-12-14 10:33:53.407	info	(2014) Starting Zigbee npm ...
      zigbee.0	2020-12-14 10:33:53.406	info	(2014) Try to reconnect. 1 attempts left
      zigbee.0	2020-12-14 10:33:43.407	info	(2014) Installed Version: iobroker.zigbee@1.4.0
      crw-rw---- 1 root dialout 166, 0 Dec 15 08:01 /dev/ttyACM0
      pi@raspberrypi:~ $ sudo -u iobroker groups
      iobroker tty dialout audio video bluetooth gpio i2c
      pi@raspberrypi:~ $ who -r
               run-level 5  2020-12-14 22:34
      @Thomas-Braun , was genau passiert hier:
      Würde ich auf RL3 umstellen. Auch wenn das mit deinem 'Problem' nichts zu tun hat:
      sudo systemctl set-default multi-user.target
        Thomas Braun Most Active @Mr.X last edited by
        @Mr-X
        Das knipst den (meist) unnötigen Software-Stack aus, der eine graphische Oberfläche für Maus, Tastatur und Display lokal zur Verfügung stellt. Wenn auf den Rechner nur per SSH zugegriffen wird ist das halt entbehrlich und eine zusätzliche Fehlerquelle und Ressourcenfresser.
          Mr.X @Thomas Braun last edited by
          @Thomas-Braun
          Ok. Ich befürchte, dass es nichts bringt, aber versuch macht klug.
          Suche nach dem Befehl und mache es gleich.
          Dann muss ich noch zurück auf 1.4
            Thomas Braun Most Active @Mr.X last edited by Thomas Braun
            @Mr-X
            Für dein akutes Problem bringt dir das ganz sicher nichts. Aber ist halt Prophylaxe für andere Dinge.
            sudo reboot
            sind die Befehle um RL3 permanent einzurichten.
              Achso OK.
              habe ich mal ausgeführt, aber dann spare ich mir erstmal das Dow und upgrade gehampel.
              Gestern musste ich ein Backup einspielen, weil das dann doch nicht lief.
                @Mr-X
                Willst du dann jetzt noch weiter nach der eigentlichen Ursache schauen?
                  Mr.X @Thomas Braun last edited by Mr.X
                  @Thomas-Braun Eigentlich schon, hast du denn weitere Idee/Ansätze.
                  Habe zwar bei Arteck einen neuen Stick bestellt, aber bis dahin könnte das ganze hier ja funktionieren.
                    @Mr-X
                    Dann müssen wir erstmal schauen, auf was wir da genau rumtanzen:
                    which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs && whoami && who -r
                    sudo apt update
                    sudo apt dist-upgrade
                    iobroker update
                    iobroker upgrade
                      @Thomas-Braun
                      pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs && whoami && who -r
                      /usr/bin/nodejs
                      v12.20.0
                      /usr/bin/node
                      v12.20.0
                      /usr/bin/npm
                      6.14.8
                      nodejs:
                        Installed: 12.20.0-1nodesource1
                        Candidate: 12.20.0-1nodesource1
                        Version table:
                       *** 12.20.0-1nodesource1 500
                              500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                              100 /var/lib/dpkg/status
                           10.21.0~dfsg-1~deb10u1+rpi1 500
                      pi
                      alles andere auch erledigt.
                      dann war der Adapter grün, nichts reagier.
                      Stick abgezogen, gewarten und dann ein reboot.
                      Im log kam zunächst
                      zigbee.0
                      2020-12-15 20:23:33.945
                      info
                      (1806) Installed Version: iobroker.zigbee@1.4.0
                      zigbee.0
                      2020-12-15 20:23:33.701
                      info
                      (1806) Starting Zigbee npm ...
                      zigbee.0
                      2020-12-15 20:23:33.513
                      info
                      (1806) starting. Version 1.4.0 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.20.0, js-controller: 3.1.6
                      Hier dann der letzte log auszug:
                      zigbee.0
                      2020-12-15 20:24:03.934
                      error
                      zigbee.0
                      error
                      zigbee.0
                      error
                      zigbee.0
                      error
                      zigbee.0
                      error
                      zigbee.0
                      error
                      zigbee.0
                      error
                      zigbee.0
                      error
                      zigbee.0
                      error
                      (1806) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
                      zigbee.0
                      2020-12-15 20:24:03.933
                      error
                      (1806) Failed to start Zigbee
                      zigbee.0
                      2020-12-15 20:24:03.721
                      info
                      zigbee.0
                      2020-12-15 20:24:03.706
                      info
                      zigbee.0
                      2020-12-15 20:24:03.705
                      info
                      (1806) Try to reconnect. 1 attempts left
                      zigbee.0
                      2020-12-15 20:23:53.704
                      error
                      at rejected (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:25:65)
                      zigbee.0
                      error
                      at Generator.throw (<anonymous>)
                      zigbee.0
                      error
                      at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:94:31)
                      zigbee.0
                      error
                      (1806) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
                      zigbee.0
                      2020-12-15 20:23:53.703
                      error
                        @Mr-X Lass den Stick immer stecken! Was ist das genau für eine Hardware?
                        lsusb -v
                        Wie verhält es sich, wenn du das System sauber rebootest?
                        sudo reboot
                          @Thomas-Braun
                          Bus 002 Device 002: ID 0781:5581 SanDisk Corp. Ultra
                          Couldn't open device, some information will be missing
                          Device Descriptor:
                            bLength                18
                            bDescriptorType         1
                            bcdUSB               3.00
                            bDeviceClass            0
                            bDeviceSubClass         0
                            bDeviceProtocol         0
                            bMaxPacketSize0         9
                            idVendor           0x0781 SanDisk Corp.
                            idProduct          0x5581 Ultra
                            bcdDevice            1.00
                            iManufacturer           1
                            iProduct                2
                            iSerial                 3
                            bNumConfigurations      1
                            Configuration Descriptor:
                              bLength                 9
                              bDescriptorType         2
                              wTotalLength       0x002c
                              bNumInterfaces          1
                              bConfigurationValue     1
                              iConfiguration          0
                              bmAttributes         0x80
                                (Bus Powered)
                              MaxPower              896mA
                              Interface Descriptor:
                                bLength                 9
                                bDescriptorType         4
                                bInterfaceNumber        0
                                bAlternateSetting       0
                                bNumEndpoints           2
                                bInterfaceClass         8 Mass Storage
                                bInterfaceSubClass      6 SCSI
                                bInterfaceProtocol     80 Bulk-Only
                                iInterface              0
                                Endpoint Descriptor:
                                  bLength                 7
                                  bDescriptorType         5
                                  bEndpointAddress     0x81  EP 1 IN
                                  bmAttributes            2
                                    Transfer Type            Bulk
                                    Synch Type               None
                                    Usage Type               Data
                                  wMaxPacketSize     0x0400  1x 1024 bytes
                                  bInterval               0
                                  bMaxBurst               1
                                  bLength                 7
                                  bDescriptorType         5
                                  bEndpointAddress     0x02  EP 2 OUT
                                  bmAttributes            2
                                    Transfer Type            Bulk
                                    Synch Type               None
                                    Usage Type               Data
                                  bInterval               0
                                  bMaxBurst              15
                          Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                          Device Descriptor:
                            bLength                18
                            bDescriptorType         1
                            bcdUSB               3.00
                            bDeviceClass            9 Hub
                            bDeviceSubClass         0
                            bDeviceProtocol         3
                            bMaxPacketSize0         9
                            idVendor           0x1d6b Linux Foundation
                            idProduct          0x0003 3.0 root hub
                            bcdDevice            5.04
                            iManufacturer           3
                            iProduct                2
                            iSerial                 1
                              bLength                 9
                              bDescriptorType         2
                              wTotalLength       0x001f
                              bNumInterfaces          1
                              iConfiguration          0
                              bmAttributes         0xe0
                                Self Powered
                                Remote Wakeup
                              MaxPower                0mA
                                bLength                 9
                                bDescriptorType         4
                                bInterfaceNumber        0
                                bAlternateSetting       0
                                bNumEndpoints           1
                                bInterfaceClass         9 Hub
                                bInterfaceSubClass      0
                                bInterfaceProtocol      0 Full speed (or root) hub
                                iInterface              0
                                  bLength                 7
                                  bDescriptorType         5
                                  bmAttributes            3
                                    Transfer Type            Interrupt
                                    Synch Type               None
                                    Usage Type               Data
                                  wMaxPacketSize     0x0004  1x 4 bytes
                                  bInterval              12
                                  bMaxBurst               0
                          Bus 001 Device 003: ID 0451:16a8 Texas Instruments, Inc.
                          Device Descriptor:
                            bLength                18
                            bDescriptorType         1
                            bcdUSB               2.00
                            bDeviceClass            2 Communications
                            bDeviceSubClass         0
                            bDeviceProtocol         0
                            bMaxPacketSize0        32
                            idVendor           0x0451 Texas Instruments, Inc.
                            idProduct          0x16a8
                            bcdDevice            0.09
                            iManufacturer           1
                            iProduct                2
                            iSerial                 3
                              bLength                 9
                              bDescriptorType         2
                              wTotalLength       0x0043
                              bNumInterfaces          2
                              iConfiguration          0
                              bmAttributes         0x80
                                (Bus Powered)
                              MaxPower               50mA
                                bLength                 9
                                bDescriptorType         4
                                bInterfaceNumber        0
                                bAlternateSetting       0
                                bNumEndpoints           1
                                bInterfaceClass         2 Communications
                                bInterfaceSubClass      2 Abstract (modem)
                                bInterfaceProtocol      1 AT-commands (v.25ter)
                                iInterface              0
                                CDC Header:
                                  bcdCDC               1.10
                                CDC ACM:
                                  bmCapabilities       0x02
                                    line coding and serial state
                                CDC Union:
                                  bMasterInterface        0
                                  bSlaveInterface         1
                                CDC Call Management:
                                  bmCapabilities       0x00
                                  bDataInterface          1
                                  bLength                 7
                                  bDescriptorType         5
                                  bEndpointAddress     0x82  EP 2 IN
                                  bmAttributes            3
                                    Synch Type               None
                                    Usage Type               Data
                                  wMaxPacketSize     0x0040  1x 64 bytes
                                  bInterval              64
                                bLength                 9
                                bDescriptorType         4
                                bInterfaceNumber        1
                                bAlternateSetting       0
                                bNumEndpoints           2
                                bInterfaceClass        10 CDC Data
                                iInterface              0
                                  bLength                 7
                                  bDescriptorType         5
                                  bEndpointAddress     0x84  EP 4 IN
                                  bmAttributes            2
                                    Transfer Type            Bulk
                                    Synch Type               None
                                    Usage Type               Data
                                  bInterval               0
                                  bLength                 7
                                  bDescriptorType         5
                                  bEndpointAddress     0x04  EP 4 OUT
                                  bmAttributes            2
                                    Transfer Type            Bulk
                                    Synch Type               None
                                    Usage Type               Data
                                  bInterval               0
                          Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
                          Device Descriptor:
                            bLength                18
                            bDescriptorType         1
                            bcdUSB               2.10
                            bDeviceClass            9 Hub
                            bDeviceSubClass         0
                            bDeviceProtocol         1 Single TT
                            bMaxPacketSize0        64
                            idVendor           0x2109 VIA Labs, Inc.
                            idProduct          0x3431 Hub
                            bcdDevice            4.21
                            iManufacturer           0
                            iProduct                1
                            iSerial                 0
                              bLength                 9
                              bDescriptorType         2
                              wTotalLength       0x0019
                              bNumInterfaces          1
                              iConfiguration          0
                              bmAttributes         0xe0
                                Self Powered
                                Remote Wakeup
                              MaxPower              100mA
                                bLength                 9
                                bDescriptorType         4
                                bInterfaceNumber        0
                                bAlternateSetting       0
                                bNumEndpoints           1
                                iInterface              0
                                  bLength                 7
                                  bDescriptorType         5
                                  bmAttributes            3
                                    Synch Type               None
                                    Usage Type               Data
                                  wMaxPacketSize     0x0001  1x 1 bytes
                                  bInterval              12
                          Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                          Device Descriptor:
                            bLength                18
                            bDescriptorType         1
                            bcdUSB               2.00
                            bDeviceClass            9 Hub
                            bDeviceSubClass         0
                            bMaxPacketSize0        64
                            idProduct          0x0002 2.0 root hub
                            bcdDevice            5.04
                            iManufacturer           3
                            iProduct                2
                            iSerial                 1
                              bLength                 9
                              bDescriptorType         2
                              wTotalLength       0x0019
                              bNumInterfaces          1
                              iConfiguration          0
                              bmAttributes         0xe0
                                Self Powered
                                Remote Wakeup
                              MaxPower                0mA
                                bLength                 9
                                bDescriptorType         4
                                bInterfaceNumber        0
                                bAlternateSetting       0
                                bNumEndpoints           1
                                iInterface              0
                                  bLength                 7
                                  bDescriptorType         5
                                  bmAttributes            3
                                    Synch Type               None
                                    Usage Type               Data
                                  bInterval              12
                            Mr.X last edited by
                            Das kommt nach einen reboot im Log:
                            Adapter ist nun grün. aber nach 10min. bis 1 Stunde wird der gelb
                            zigbee.0
                            2020-12-15 21:25:16.898
                            error
                            (1805) Device 0x90fd9ffffe8a09d4 "undefined" not described in statesMapping.
                            zigbee.0
                            2020-12-15 21:25:16.676
                            info
                            (1805) Zigbee started
                            zigbee.0
                            2020-12-15 21:25:16.675
                            info
                            (1805) 0xbc33acfffe0ebcf2 (addr 65202): HG06337 - Lidl Silvercrest smart plug (Router)
                            zigbee.0
                            2020-12-15 21:25:16.667
                            info
                            (1805) 0xbc33acfffe0ebd34 (addr 45265): HG06337 - Lidl Silvercrest smart plug (Router)
                            zigbee.0
                            2020-12-15 21:25:16.664
                            info
                            (1805) 0x842e14fffe556652 (addr 44502): HG06338 - Lidl Silvercrest 3 gang switch, possibly with USB (Router)
                            zigbee.0
                            2020-12-15 21:25:16.661
                            info
                            (1805) 0x0017880108b7ba14 (addr 55123): 8718699673147 - Philips Hue white A60 bulb E27 bluetooth (Router)
                            zigbee.0
                            2020-12-15 21:25:16.659
                            info
                            (1805) 0x90fd9ffffe8a09d4 (addr 21330): Not supported (model undefined)(Unknown)
                            zigbee.0
                            2020-12-15 21:25:16.658
                            info
                            (1805) 0x000b57fffec367c3 (addr 26913): LED1545G12 - IKEA TRADFRI LED bulb E26/E27 980 lumen, dimmable, white spectrum, opal white (Router)
                            zigbee.0
                            2020-12-15 21:25:16.656
                            info
                            (1805) 0x00158d0004041f71 (addr 53371): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                            zigbee.0
                            2020-12-15 21:25:16.654
                            info
                            (1805) 0x005043c903241a3e (addr 47918): HS1SA - HEIMAN Smoke detector (EndDevice)
                            zigbee.0
                            2020-12-15 21:25:16.651
                            info
                            (1805) 0x005043c9032455a3 (addr 41038): HS1SA - HEIMAN Smoke detector (EndDevice)
                            zigbee.0
                            2020-12-15 21:25:16.650
                            info
                            (1805) 0x005043c90324538e (addr 39166): HS1SA - HEIMAN Smoke detector (EndDevice)
                            zigbee.0
                            2020-12-15 21:25:16.648
                            info
                            (1805) 0x005043c903245474 (addr 6269): HS1SA - HEIMAN Smoke detector (EndDevice)
                            zigbee.0
                            2020-12-15 21:25:16.646
                            info
                            (1805) 0x005043c903386694 (addr 44701): HS1SA - HEIMAN Smoke detector (EndDevice)
                            zigbee.0
                            2020-12-15 21:25:16.644
                            info
                            (1805) 0x00158d0004042192 (addr 65354): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                            zigbee.0
                            2020-12-15 21:25:16.643
                            info
                            (1805) 0x000b57fffec1f6ec (addr 28034): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                            zigbee.0
                            2020-12-15 21:25:16.640
                            info
                            (1805) 0x000b57fffe9e650d (addr 38936): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
                            zigbee.0
                            2020-12-15 21:25:16.637
                            info
                            (1805) 0x000b57fffe2b7dea (addr 5574): ICTC-G-1 - IKEA TRADFRI wireless dimmer (EndDevice)
                            zigbee.0
                            2020-12-15 21:25:16.635
                            info
                            (1805) 0x84182600000f74b5 (addr 9139): AC03641 - OSRAM LIGHTIFY LED Classic A60 clear (Router)
                            zigbee.0
                            2020-12-15 21:25:16.633
                            info
                            (1805) 0x90fd9ffffe6d32bc (addr 34524): LED1546G12 - IKEA TRADFRI LED bulb E26/E27 950 lumen, dimmable, white spectrum, clear (Router)
                            zigbee.0
                            2020-12-15 21:25:16.631
                            info
                            (1805) 0x00158d0003f045f4 (addr 42828): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                            zigbee.0
                            2020-12-15 21:25:16.629
                            info
                            (1805) 0x00158d0004252ae8 (addr 42379): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (EndDevice)
                            zigbee.0
                            2020-12-15 21:25:16.627
                            info
                            (1805) 0x00158d000425298b (addr 62172): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (Unknown)
                            zigbee.0
                            2020-12-15 21:25:16.625
                            info
                            (1805) 0x00158d0002a374e8 (addr 51270): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
                            zigbee.0
                            2020-12-15 21:25:16.617
                            info
                            (1805) 0x00158d00041cd4e6 (addr 37917): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                            zigbee.0
                            2020-12-15 21:25:16.603
                            info
                            (1805) Currently 23 devices are joined:
                            zigbee.0
                            2020-12-15 21:25:16.592
                            info
                            (1805) --> transmitPower : high
                            zigbee.0
                            2020-12-15 21:25:16.578
                            info
                            (1805) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20190223}}
                              @Mr-X Das System liegt auf dem SanDisk Datenträger? Boot über USB?
                                @Thomas-Braun Ja, genau.
                                Und grün wurde er erst jetzt nach dem zweiten boot.
                                Momentan geht's, auch die Lidl Sachen.
                                Sobald ich merke dass er aussteigt, kann ich den Log posten.
                                Drehe jetzt ne Runde mit Doggi, und wenn ich wieder komme ist meist alles platt.
                                  @Mr-X Das ist der 2531-Stick, oder? Der kann mit 23 Geräten überfordert sein.
                                    @Thomas-Braun Ja, das stimmt.
                                    Mich wundert aber dass dann mit 1.3.1 alles läuft.
                                    habe jetzt 3 Lidl Sachen angelernt, davor lief alles Tipi topi unter 1.3.1
                                      @Mr-X Kann ja sein, dass die drei neuen Geräte genau die drei sind, bei denen der Stick ausgereizt ist.
                                        @Thomas-Braun und das würde dann die errors kreieren?
                                        Könnte jetzt noch die drei neue löschen und auf 1.4 bleiben.
                                          @Mr-X Nicht alle.
                                            @Thomas-Braun
                                            So, da wären wir wieder.
                                            Ich habe gestern drei Geräte gelöscht. Gestern abend und heute früh vor der Arbeit lief alles.
                                            Nun habe ich eben nachgeschaut: Adapter gelb.
                                            Nach dem Adapter Neustart kommt das:
                                            zigbee.0	2020-12-16 11:19:50.275	info	(1803) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                            zigbee.0	2020-12-16 11:19:50.274	info	(1803) terminating
                                            zigbee.0	2020-12-16 11:19:50.273	error	at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:27:71)
                                            zigbee.0	2020-12-16 11:19:50.273	error	at Generator.next (<anonymous>)
                                            zigbee.0	2020-12-16 11:19:50.273	error	at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:453:28)
                                            zigbee.0	2020-12-16 11:19:50.273	error	at ZStackAdapter.dataRequestExtended (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:800:16)
                                            zigbee.0	2020-12-16 11:19:50.273	error	at __awaiter (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:23:12)
                                            zigbee.0	2020-12-16 11:19:50.273	error	at new Promise (<anonymous>)
                                            zigbee.0	2020-12-16 11:19:50.273	error	at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:804:28)
                                            zigbee.0	2020-12-16 11:19:50.273	error	at Znp.request (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:273:19)
                                            zigbee.0	2020-12-16 11:19:50.273	error	(1803) Failed to stop zigbee (Error: Cannot request when znp has not been initialized yet
                                            zigbee.0	2020-12-16 11:19:50.143	info	(1803) Zigbee: disabling joining new devices.
                                            zigbee.0	2020-12-16 11:19:50.141	info	(1803) cleaned everything up...
                                            zigbee.0	2020-12-16 11:19:50.139	info	(1803) Got terminate signal TERMINATE_YOURSELF
                                            host.raspberrypi	2020-12-16 11:19:50.135	info	stopInstance system.adapter.zigbee.0 send kill signal
                                            host.raspberrypi	2020-12-16 11:19:50.129	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
                                            1.0k
                                            zigbee
                                            1524
