    3. Entwicklung
    4. [gelöst] wiffi-wz Adapter: Received data from unregistered
      baluderbär last edited by baluderbär
      bin heute auf den Adapter wiffi-wz gestoßen. Bisher wurden meine Daten der Weatherstation an die CCU geschickt und dann zu ioBroker übertragen. Mit dem Adapter funktioniert es nun auch, jedoch erhalten ich jede Minute eine Warnung (debug-Auszug):
      wiffi-wz.0	2020-12-20 00:41:36.865	debug	(26910) Received states from Wiffi with ip 192.168.xxx.xx and states were updated successfully!
      wiffi-wz.0	2020-12-20 00:41:36.863	debug	(26910) Creating states for wiffi with ip 192.168.xxx.xx, if necessary.
      wiffi-wz.0	2020-12-20 00:41:36.863	warn	(26910) Received data from unregistered Wiffi with ip 192.168.xxx.xx
      wiffi-wz.0	2020-12-20 00:41:36.862	debug	(26910) Received JSON data from Wiffi. Full message: {"modultyp":"weatherman","vars":[{"name":"0","homematic_name":"w_ip","desc":"weatherman_ip","type":"string","unit":"","value":"192.168.xxx.xx"},{"n
      wiffi-wz.0	2020-12-20 00:41:28.908	debug	(26910) system.adapter.admin.0: logging true
      wiffi-wz.0	2020-12-20 00:41:14.824	debug	(26910) system.adapter.admin.0: logging false
      wiffi-wz.0	2020-12-20 00:40:36.178	debug	(26910) Received states from Wiffi with ip 192.168.xxx.xx and states were updated successfully!
      wiffi-wz.0	2020-12-20 00:40:36.176	debug	(26910) Creating states for wiffi with ip 192.168.xxx.xx, if necessary.
      wiffi-wz.0	2020-12-20 00:40:36.175	warn	(26910) Received data from unregistered Wiffi with ip 192.168.xxx.xx
      wiffi-wz.0	2020-12-20 00:40:36.175	debug	(26910) Received JSON data from Wiffi. Full message: {"modultyp":"weatherman","vars":[{"name":"0","homematic_name":"w_ip","desc":"weatherman_ip","type":"string","unit":"","value":"192.168.xxx.xx"},{"
      wiffi-wz.0	2020-12-20 00:39:47.844	debug	(26910) Received states from Wiffi with ip 192.168.xxx.xx and states were updated successfully!
      wiffi-wz.0	2020-12-20 00:39:47.841	debug	(26910) Creating states for wiffi with ip 192.168.xxx.xx, if necessary.
      wiffi-wz.0	2020-12-20 00:39:47.841	warn	(26910) Received data from unregistered Wiffi with ip 192.168.xxx.xx
      wiffi-wz.0	2020-12-20 00:39:47.840	debug	(26910) Received JSON data from Wiffi. Full message: {"modultyp":"weatherman","vars":[{"name":"0","homematic_name":"w_ip","desc":"weatherman_ip","type":"string","unit":"","value":"192.168.xxx.xx"},{"
      wiffi-wz.0	2020-12-20 00:39:40.908	debug	(26910) Create basic states for Wiffi with ip http://192.168.xxx.xx/
      Die empfangenen Daten sehen korrekt aus. Wer weiß wie ich die Warnmeldung weg bekomme bzw. woher die kommen?
      Aktuelle FW am Weatherman:weatherman_156
      wiffi-wz-Adapter: 2.2.0
      Gruß Martin
      G Gargano 2 Replies Last reply Reply Quote 0
      • G
        guergen @baluderbär last edited by
        @baluderbär Wie ist denn der wiffi-wz konfiguriert? Beim Weatherman muss man auch etwas einstellen. Zeig mal die Einstellungen, ich habe seit fast 2 Jahren den Weatherman im Broker
        • Gargano
          Gargano @baluderbär last edited by
          @baluderbär In der Instanz unter Wiffi Geräte einen Namen , IP Adresse und Zimmer eintragen
            baluderbär @guergen last edited by
            @guergen
            Hier meine Einstellung beim wiffi-wz. Unter "lokale Server-IP" habe ich die IP des ioBroker und den "Port" 8181 eingetragen.
            Unter WIFI-Geräte habe ich die IP des Weatherman eingetragen.
            Und hier noch ein Bild vom Weatherman:
            Gargano 1 Reply Last reply Reply Quote 0
            • Gargano
              Gargano @baluderbär last edited by Gargano
              @baluderbär Ich weiß nicht ob der Wiffi Adapzer mit Deiner Einstellung der IP Adresse klarkommt . Ich habe nur die IP eingetragen ohne HTTP://
              also nur 192.168.178.86
                baluderbär @Gargano last edited by
                @Gargano
                Hallo, ich habe mal http:// und den / am Ende gelöscht und nun kommen keine Warnmeldungen mehr. Die Daten kamen zwar vorher schon korrekt, aber wer hat schon gerne Warn- oder Fehlermeldungen im Log 😊
                Vielen Dank
                Gruß Martin
                wiffi-wz
