    4. Adapter update - npm ERR! Maximum call stack size exceeded
    UNSOLVED Adapter update - npm ERR! Maximum call stack size exceeded
    • X
      xawa last edited by xawa
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Raspberry PI 4
      Arbeitsspeicher: 4GB
      Festplattenart: SD-Karte
      Betriebssystem: raspian
      Node-Version: v12.20.0
      Nodejs-Version: v12.20.0
      NPM-Version: 6.14.8
      Installationsart: Skript
      Image genutzt: Nein
      Ort/Name der Imagedatei: Link
      Hallo Leute, hab immer mal Probleme beim updaten meiner Adapter. Egal bei welchem, es kommt immer die Meldung, dass das Update erfolgreich war, allerdings wird das update auf die neue Version danach immer noch angeboten.
      $ ./iobroker upgrade ical
      Update ical from @1.8.2 to @1.8.3
      NPM version: 6.14.8
      npm install iobroker.ical@1.8.3 --loglevel error --prefix "/opt/iobroker" (System call)
      npm
      npm ERR! A complete log of this run can be found in:npm ERR!
      /home/iobroker/.npm/_logs/2020-12-25T17_26_06_134Z-debug.log
      upload [4] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/words.js words.js application/javascript
      upload [3] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/index_m.html index_m.html text/html
      upload [2] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/index.html index.html text/html
      upload [1] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/img/info-big.png img/info-big.png image/png
      upload [0] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/ical.png ical.png image/png
      Adapter "ical" updated
      process exited with code 0
      Als Fehler erscheint ERR! Maximum call stack size exceeded und im /home/iobroker/.npm/_logs/2020-12-25T17_26_06_134Z-debug.log ganz unten steht:
      4629 verbose stack RangeError: Maximum call stack size exceeded
      4629 verbose stack at RegExp.test (<anonymous>)
      4629 verbose stack at isDepOptional (/usr/lib/node_modules/npm/lib/install/deps.js:432:45)
      4629 verbose stack at failedDependency (/usr/lib/node_modules/npm/lib/install/deps.js:441:9)
      4629 verbose stack at failedDependency (/usr/lib/node_modules/npm/lib/install/deps.js:457:9)
      4630 verbose cwd /opt/iobroker
      4631 verbose Linux 5.4.79-v7l+
      4632 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.ical@1.8.3" "--loglevel" "error" "--prefix" "/opt/iobroker"
      4633 verbose node v12.20.0
      4634 verbose npm v6.14.8
      4635 error Maximum call stack size exceeded
      4636 verbose exit [ 1, true ]
      Vg, Andi
      Segway 1 Reply Last reply Reply Quote 0
      • Segway
        Segway @xawa last edited by
        @xawa
        Mhh zuschreibst kein Image benutzt, okay.
        Welche OS denn genommen und wie installiert ?
        Welches Script von wo hast du zum installieren von IoB genommen ?
        X 1 Reply Last reply Reply Quote 0
        • X
          xawa @Segway last edited by
          @Segway Hi Segway, mit "Raspberry Pi OS using Raspberry Pi Imager" von https://www.raspberrypi.org/software/
          Adapter-Updates haben bis vor 2 Wochen prima funktioniert.
          cat /etc/os-release
          PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
          NAME="Raspbian GNU/Linux"
          VERSION_ID="10"
          VERSION="10 (buster)"
          VERSION_CODENAME=buster
          ID=raspbian
          ID_LIKE=debian
          HOME_URL="http://www.raspbian.org/"
          SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
          BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
          Installation von ioBroker hab ich folgendermaßen gemacht:
          sudo apt-get --purge remove node
          sudo apt-get --purge remove nodejs
          sudo apt-get autoremove
          curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash -
          sudo apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev libpam0g-dev nodejs
          curl -sL https://iobroker.net/install.sh | bash -
          MichMein Segway 2 Replies Last reply Reply Quote 0
          • MichMein
            MichMein @xawa last edited by
            @xawa npm ist in der V6.14.10 verfügbar, Du hast noch .8
            Vielleicht hilft das bei Deinem Problem.
              Thomas Braun Most Active @MichMein last edited by Thomas Braun
              @MichMein Nein, das zerschießt dir ggf. nur die Paketdatenbank.
              Zuerst
              cd /opt/iobroker
              npm cache clean --force
              mal probieren. Wenn das nicht funktioniert
              cd /opt/iobroker
              npm rebuild
              MichMein X 2 Replies Last reply Reply Quote 0
              • MichMein
                MichMein @Thomas Braun last edited by
                @Thomas-Braun Was genau heißt das? 🤔
                  @MichMein Das heißt, wenn du npm aus sich selber heraus global installierst/updatest, dann landet das in /usr/local/bin und es wird nicht mehr die aus dem nodejs-Paket beigepackte Version aufgerufen. npm müsste dann immer manuell auf Stand gehalten werden. Das will man eigentlich nicht.
                  MichMein 1 Reply Last reply Reply Quote 0
                  • MichMein
                    @Thomas-Braun ich habe mein npm gestern wegen der js-Controller Problematik händisch upgedatet und es sieht so aus,
                    pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                    /usr/bin/nodejs
                    v12.20.0
                    /usr/bin/node
                    v12.20.0
                    /usr/bin/npm
                    6.14.10
                    nodejs:
                      Installed: 12.20.0-1nodesource1
                      Candidate: 12.20.0-1nodesource1
                      Version table:
                     *** 12.20.0-1nodesource1 500
                            500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                            100 /var/lib/dpkg/status
                         10.21.0~dfsg-1~deb10u1+rpi1 500
                    pi@raspberrypi:~ $
                    Das sieht für mich erstmal nicht falsch aus, oder?
                      @MichMein Ja, das schaut okay aus. Würde dir halt beim nächsten Upgrade von nodeJS über den Paketmanager dann wieder mit dessen Version drübergebügelt werden.
                      Das gewählte Verzeichnis hängt davon ab mit welchen Rechten das manuelle Upgrade angestoßen wird.
                      • MichMein
                        @Thomas-Braun ok fein, ich werde mal abwarten bis es soweit und dann schauen.
                        Danke und nen schönen Weihnachtstag noch 🌲
                        • Segway
                          @xawa sagte in Adapter update - npm ERR! Maximum call stack size exceeded:
                          Das kann ich so nicht in der Anleitung finden. Dort steht lediglich:
                          sudo apt install -y nodejs
                          sudo reboot
                          Thomas Braun X 2 Replies Last reply Reply Quote 0
                            Thomas Braun Most Active @Segway last edited by
                            @Segway
                            Und genau genommen ist auch dieses Vorgehen nicht erforderlich, wenn man den Installer-Einzeiler aka Installer Skript nutzt.
                            • Segway
                              Segway @Thomas Braun last edited by
                              @Thomas-Braun sagte in Adapter update - npm ERR! Maximum call stack size exceeded:
                              @Segway
                              Okay, dann müsste die Doku überarbeitet werden.
                              Ist mir persönlich NEU, dass das installer script auch prüft auf nodejs.
                              J Homoran 2 Replies Last reply Reply Quote 0
                                Jan1 @Segway last edited by
                                @Segway
                                Ja die wird wohl auch hoffentlich bald angepasst und ja das Script installiert Node 12 gleich mit, weshalb sich die nanuelle Installation erübrigt hat.
                                • X
                                  @Segway
                                  ja den Befehl hab ich aus dem ioBroker Master-Kurs von Matthias Kleine. Aber ich glaube nicht, das der Probleme macht, da die Adapter-Updates bis vor ca. 2 Wochen ja schon rund 6 Wochen problemlos gelaufen sind.
                                  Könnte es sein, dass es mit Github zu tun hat.
                                  Ich expermimentiere gerade etwas mit der Entwicklung eines eigenen Adapters rum und habe mal testweise einen erstellt, der nur eine Testvariable anlegt (ja ich weiß, auf einem Produktivsystem..... ) Schande über mein Haupt!!!
                                  npx @iobroker/create-adapter
                                  In dem Verzeichnis habe ich auch mit github gearbeitet und irgendwie habe ich das Gefühl, dass die Probleme weg sind, wenn ich alle Objekte, die Instanz und den Adapter wieder deinstalliere.
                                  Was meint ihr?
                                    Thomas Braun Most Active @xawa last edited by
                                    @xawa Das kann sein. Du scheinst da eine Schleife drin zu haben und die frisst den Speicher auf.
                                    • X
                                      xawa @Thomas Braun last edited by
                                      Zuerst
                                      cd /opt/iobroker
                                      cd /opt/iobroker
                                      npm rebuild
                                      Danke, Thomas-Braun
                                        Homoran Global Moderator Administrators @Segway last edited by Homoran
                                        @Segway sagte in Adapter update - npm ERR! Maximum call stack size exceeded:
                                        ist schon länger so.
                                        steht so in der Doku!
                                        https://github.com/ioBroker/ioBroker.docs/blob/master/docs/de/install/linux.md#installation-nodejs
                                        J Segway 2 Replies Last reply Reply Quote 0
                                          Jan1 @Homoran last edited by
                                          @Homoran
                                          Oh das ist Mist, hier auf ne Doku auf Github hinzuweisen und die allgemein gebräuchliche oben verlinkte damit als ausgemustert zu entlarven. Das sollte schleunigst auf eine Stand gebracht werden.
                                            Homoran Global Moderator Administrators @Jan1 last edited by Homoran
                                            @Jan1 sagte in Adapter update - npm ERR! Maximum call stack size exceeded:
                                            Das ist der Quelltext für die oben verlinkte.
                                            Auf Github wird das geändert und jeder kann eine Änderung durchführen bzw. veranlassen, damit viele Augen eine korrekte Doku ermöglichen
                                            adapter update error
                                            1722
