    4. Fehler beim Dapter installien Screenshot with PhantomJS
      Raspi last edited by
      Moin Leute wollte diesen Adapter installieren,
      dabei bekomme ich diese Meldung, kann mir einer sagen was das soll?
      $ ./iobroker add phantomjs
      npm install iobroker.phantomjs –production --prefix "/opt/iobroker" (System call)
      npm
      WARN deprecated
      node-uuid@1.4.7: use uuid module instead
      Unexpected platform or architecture: linux/armIt seems there is no binary available for your platform/architecture
      Try to install PhantomJS globally
      npm
      ERR! Linux 4.4.34-v7+
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.phantomjs" "--production" "--prefix" "/opt/iobroker"npm
      ERR! node
      v4.6.2npm ERR! npm v2.15.11
      npm ERR! code ELIFECYCLE
      npm ERR! phantomjs-prebuilt@2.1.13 install: node install.js
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the phantomjs-prebuilt@2.1.13 install script 'node install.js'.
      npm ERR! This is most likely a problem with the phantomjs-prebuilt package,
      npm ERR! not with npm itself.
      npm ERR! Tell the author that this fails on your system:
      npm ERR! node install.js
      npm ERR! You can get information on how to open an issue for this project with:
      npm ERR! npm bugs phantomjs-prebuilt
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!
      npm ERR! npm owner ls phantomjs-prebuilt
      npm ERR! There is likely additional logging output above.
      npm ERR! Please include the following file with any support request:
      npm ERR! /npm-debug.log
      ERROR: host.raspberrypi Cannot install iobroker.phantomjs: 1
      ERROR: process exited with code 25
      Benutze einen raspberry pi 2 mit Jessy
      • apollon77
        apollon77 last edited by
        hast du ein Binary namens "node"? Probier mal auf Kommandozeile?
        Wenn nicht versuch mal
        sudo apt-get install nodejs-legacy
        dann nochmal versuchen
          Habe versucht bekomme dabei die folgende Meldung
          root@raspberrypi:~# sudo apt-get install nodejs-legacy
          Paketlisten werden gelesen… Fertig
          Abhängigkeitsbaum wird aufgebaut.
          Statusinformationen werden eingelesen.... Fertig
          Einige Pakete konnten nicht installiert werden. Das kann bedeuten, dass
          Sie eine unmögliche Situation angefordert haben oder, wenn Sie die
          Unstable-Distribution verwenden, dass einige erforderliche Pakete noch
          nicht erstellt wurden oder Incoming noch nicht verlassen haben.
          Die folgenden Informationen helfen Ihnen vielleicht, die Situation zu lösen:
          Die folgenden Pakete haben unerfüllte Abhängigkeiten:
          nodejs-legacy : Hängt ab von: nodejs (>= 0.6.19~dfsg1-3~) soll aber nicht installiert werden
          E: Probleme können nicht korrigiert werden, Sie haben zurückgehaltene defekte Pakete.
          root@raspberrypi:~#
          ein versuch den adapter zu installieren ergab die selber Meldung wie oben
          • apollon77
            Hast du ein Executable namens "node" ?! Ansonsten leg mal nennSymbolischen Link auf "nodejs" an
              damit kann ich leider nicht viel anfagen, kannst du mir das bitte genauer erklären.
              • apollon77
                wenn du an der Kommandozeile "node -v" eingibst was kommt?
                • a200
                  a200 last edited by
                  Ich dachte immer PhantomJS würde schon aus Performance-Gründen nicht auf dem raspi laufen?!
                    das kommt daraus
                    root@raspberrypi:~# node -v
                    v4.6.2
                    root@raspberrypi:~#
                    • apollon77
                      hm … dann weiss ich nicht was es sen kann. Dachte das node Binary wäre nicht da ... sorry für die Verwirrung
                      Wer lesen kann ...
                        @Raspi:
                        das kommt daraus
                        v4.6.2
                        root@raspberrypi:~# `
                        Fergus es. PhantomJS kann nicht auf dem raspi laufen.
                          OK, das ist aber schade…
                          Aus welchen gründe geht das nicht ganz kurz und knap?
                          kann mir vielleicht einer weiter helfen in meinem Vorhaben:
                          Jemand Klingelt > IPCam macht snapshot > versand per mail
                          bis jetzt hab ich dies alles in iobroker node red realiesiert, das wenn jemand klingelt ich schon mal per Twitter / Mail Meldung bekommen.
                          ich möchte das nur noch per Bild dazu bekommen, wer auch geklingelt hat.
                          Ip Cam ist eine kleine Wlan Cam von ebay DIY Z6O6
                          Hat jemand eine Idee
                          • a200
                            a200 last edited by
                            @Raspi:
                            Jemand Klingelt > IPCam macht snapshot > versand per mail `
                            dafür brauchst du kein PhantomJS. PhantomJS ist in der Lage ganze Seiten zu rendern und als Bild ausgeben. Was du brauchst ist ein lokales Abspeichern des Bildes und dann Versand als Attachment. Ich kann dir da leider nicht weiter helfen, aber du solltest deine Vorgehensweise überdenken.
                            Schritt 1 wäre: Kannst du ein Bild von deiner Cam lokal speichern?
                            LG,
                            a200
                              ich verweis mal das thema auf hier, hier habe ich detailiert beschrieben
                              http://forum.iobroker.net/viewtopic.php?p=42448#p42448
                              1454
