    4. Homekit in iobroker auf Synology - Installation bricht ab
      dli last edited by
      leider bekomme bei der Installation des Homekit Adapters folgende Fehlermeldung. (andere Adapter kann ich installieren)
      Ich hoffe auf eure Hilfe, fange gerade erst an mit iobroker und diese Funktion ist für mich sehr wichtig.
      Meine Umgebung:
      • Synology ds214+ (iobroker)
      • CCU2
      <u>hier die Fehlermedlung:</u>
      $ ./iobroker add homekit2
      npm install iobroker.homekit2 –production --prefix "/volume1/homes/admin/opt/iobroker" (System call)
      gyp
      ERR! build error
      gyp ERR! stack Error: not found: make
      gyp ERR! stack at F (/usr/local/lib/node_modules/npm/node_modules/which/which.js:63:19)gyp
      ERR! stack at E (/usr/local/lib/node_modules/npm/node_modules/which/which.js:72:29)gyp
      ERR! stack at /usr/local/lib/node_modules/npm/node_modules/which/which.js:81:16gyp
      ERR! stack at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5gyp ERR! stack
      at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
      gyp ERR! stack at FSReqWrap.oncomplete (fs.js:82:15)gyp ERR! System Linux 3.2.40
      gyp ERR! command "/volume1/@appstore/Node.js_v4/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /volume1/homes/admin/opt/iobroker/node_modules/iobroker.homekit2/node_modules/hap-nodejs/node_modules/curve25519gyp ERR! node -v v4.4.2
      gyp ERR! node-gyp -v v3.3.1
      gyp ERR! not ok
      gyp
      ERR!
      build error
      gyp
      ERR!
      gyp
      ERR! stack
      gyp ERR! stack at E (/usr/local/lib/node_modules/npm/node_modules/which/which.js:72:29)gyp ERR!
      gyp ERR! stack
      at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5gyp ERR! stack at FSReqWrap.oncomplete (fs.js:82:15)
      gyp
      ERR!
      System
      Linux 3.2.40gyp ERR! command "/volume1/@appstore/Node.js_v4/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /volume1/homes/admin/opt/iobroker/node_modules/iobroker.homekit2/node_modules/hap-nodejs/node_modules/ed25519
      gyp ERR! not ok
      gyp
      ERR! build error
      gyp
      ERR! stack Error: not found: makegyp
      ERR! stack
      at F (/usr/local/lib/node_modules/npm/node_modules/which/which.js:63:19)gyp ERR!
      ERR!
      stack at /usr/local/lib/node_modules/npm/node_modules/which/which.js:81:16gyp ERR! stack at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
      gyp ERR! stack at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
      gyp ERR! cwd /volume1/homes/admin/opt/iobroker/node_modules/iobroker.homekit2/node_modules/hap-nodejs/node_modules/mdns
      gyp ERR! not ok
      node-pre-gyp
      ERR! Tried to download(403): https://rvagg-node.s3-us-west-2.amazona ... a32.tar.gz node-pre-gyp ERR! Pre-built binaries not found for bignum@0.12.5 and node@4.4.2 (node-v46 ABI) (falling back to source compile with node-gyp)
      gyp
      ERR!
      build error
      gyp ERR! stack at F (/volume1/@appstore/Node.js_v4/usr/local/lib/node_modules/npm/node_modules/which/which.js:63:19)
      gyp ERR! stack
      at E (/volume1/@appstore/Node.js_v4/usr/local/lib/node_modules/npm/node_modules/which/which.js:72:29)gyp ERR! stack at /volume1/@appstore/Node.js_v4/usr/local/lib/node_modules/npm/node_modules/which/which.js:81:16
      gyp ERR! stack at /volume1/@appstore/Node.js_v4/usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5gyp ERR!
      stack at /volume1/@appstore/Node.js_v4/usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5gyp ERR! stack at FSReqWrap.oncomplete (fs.js:82:15)
      gyp ERR! System
      Linux 3.2.40
      gyp ERR! command "/volume1/@appstore/Node.js_v4/usr/local/bin/node" "/volume1/@appstore/Node.js_v4/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/volume1/homes/admin/opt/iobroker/node_modules/iobroker.homekit2/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/binding/bignum.node" "--module_name=bignum" "--module_path=/volume1/homes/admin/opt/iobroker/node_modules/iobroker.homekit2/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/binding"
      gyp ERR! cwd /volume1/homes/admin/opt/iobroker/node_modules/iobroker.homekit2/node_modules/hap-nodejs/node_modules/srp/node_modules/bignumgyp ERR! node -v v4.4.2
      gyp ERR! not ok
      node-pre-gyp ERR! build error
      node-pre-gyp
      ERR! stack Error: Failed to execute '/volume1/@appstore/Node.js_v4/usr/local/bin/node /volume1/@appstore/Node.js_v4/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/volume1/homes/admin/opt/iobroker/node_modules/iobroker.homekit2/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/binding/bignum.node --module_name=bignum --module_path=/volume1/homes/admin/opt/iobroker/node_modules/iobroker.homekit2/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/binding' (1)node-pre-gyp ERR! stack at ChildProcess. <anonymous>(/volume1/homes/admin/opt/iobroker/node_modules/iobroker.homekit2/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
      node-pre-gyp ERR! stack at emitTwo (events.js:87:13)
      node-pre-gyp
      ERR! stack at ChildProcess.emit (events.js:172:7)node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:827:16)
      node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:5)
      node-pre-gyp
      node-pre-gyp ERR! command "/volume1/@appstore/Node.js_v4/usr/local/bin/node" "/volume1/homes/admin/opt/iobroker/node_modules/iobroker.homekit2/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /volume1/homes/admin/opt/iobroker/node_modules/iobroker.homekit2/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum
      node-pre-gyp ERR! node -v v4.4.2
      node-pre-gyp ERR! node-pre-gyp -v v0.6.32
      node-pre-gyp ERR! not ok
      npm
      ERR!
      Linux 3.2.40
      npm ERR! argv "/volume1/@appstore/Node.js_v4/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.homekit2" "--production" "--prefix" "/volume1/homes/admin/opt/iobroker"npm ERR! node v4.4.2
      npm ERR! npm v2.15.0
      npm
      ERR! code ELIFECYCLE
      npm ERR! curve25519@1.1.0 install: node-gyp rebuild
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the curve25519@1.1.0 install script 'node-gyp rebuild'.
      npm ERR! This is most likely a problem with the curve25519 package,
      npm ERR! not with npm itself.
      npm ERR! Tell the author that this fails on your system:
      npm ERR! node-gyp rebuildnpm ERR! You can get information on how to open an issue for this project with:
      npm ERR! npm bugs curve25519
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!
      npm ERR! npm owner ls curve25519
      npm ERR! There is likely additional logging output above.
      npm ERR! Please include the following file with any support request:
      npm ERR! /volume1/homes/admin/opt/npm-debug.log
      ERROR: host.NAS-Westkirchen Cannot install iobroker.homekit2: 1
      ERROR: process exited with code 25
      Gruß Dennis</anonymous>
        papi last edited by
        Ich habe einen ähnlichen Fehler, nur bei mir ist es GIT, das wohl nicht verfügbar ist.
        GIT habe ich dann mittels Paketzentrum aus der Community nachgereicht, aber das scheint wohl nicht dasselbe zu sein, denn es änderte nichts?
        • apollon77
          apollon77 last edited by
          Du brauchst make und nen Compiler … Musst also "gcc" oder so installieren ...
          Ich fürchte aber das es auch dann, falls Du das per ipkg oder so hinbekommst, nicht weitergeht weil gllaube ich gcc4.8+gebraucht wird, DU den aber für deine Synology nicht bekommst. Hatten ähnliche Probleme schon mit anderen Adaptern ... das sind die Liits des doch nicht "offenen" und "aktuellen" Synology OS unter der Haube" 😞
