    3. Cloud Dienste
    4. IoBroker und Google Assistent/Home
    • Michael Liller
      Michael Liller last edited by wendy2702
      Seit 2 Tagen kommt es zu Verbindungsabbrüchen. Der IOT Adapter ist grün, aber die Anmeldung von iobroker in der google app geht nicht. Verbindungszertifikate erneuert, adapter Restart, Certs gelöscht weil in Log angegeben, nix geht jemand ne Ahnung?
      ![aaf89fb8-9d00-4e82-ba75-f0cf8eceda89-image.png](/assets/uploads/files/1609868181612-aaf89fb8-9d00-4e82-ba75-f0cf8eceda89-image.png) 2021-01-05 00:16:04.040 - warn: iot.0 (2330) [GHOME] No devices defined. Did you add not sensor or indicate states to rooms and enums?
      2021-01-05 00:18:28.133 - warn: iot.0 (2330) [GHOME] No devices defined. Did you add not sensor or indicate states to rooms and enums?
      2021-01-05 02:02:56.444 - info: iot.0 (2330) Connection changed: disconnect
      2021-01-05 02:02:56.445 - info: iot.0 (2330) Connection lost
      2021-01-05 02:03:01.651 - info: iot.0 (2330) Connection changed: connect
      2021-01-05 10:33:36.111 - info: iot.0 (2330) Connection changed: disconnect
      2021-01-05 10:33:36.112 - info: iot.0 (2330) Connection lost
      2021-01-05 10:33:41.333 - info: iot.0 (2330) Connection changed: connect
      2021-01-05 17:55:48.771 - warn: iot.0 (2330) [GHOME] No devices defined. Did you add not sensor or indicate states to rooms and enums?
      2021-01-05 17:56:34.400 - warn: iot.0 (2330) [GHOME] No devices defined. Did you add not sensor or indicate states to rooms and enums?
      2021-01-05 17:58:58.496 - info: iot.0 (2330) Got terminate signal TERMINATE_YOURSELF
      2021-01-05 17:58:58.497 - info: iot.0 (2330) terminating
      2021-01-05 17:58:58.497 - info: iot.0 (2330) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-01-05 17:58:58.540 - info: iot.0 (2330) Connection changed: disconnect
      2021-01-05 17:58:58.541 - info: iot.0 (2330) Connection lost
      2021-01-05 17:58:59.003 - info: host.HomeServer instance system.adapter.iot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-01-05 17:58:59.487 - info: info.0 (29742) starting. Version 1.7.10 in /opt/iobroker/node_modules/iobroker.info, node: v12.20.0, js-controller: 3.1.6
      2021-01-05 17:59:01.647 - info: host.HomeServer instance system.adapter.iot.0 started with pid 30343
      2021-01-05 17:59:02.220 - info: iot.0 (30343) starting. Version 1.8.5 in /opt/iobroker/node_modules/iobroker.iot, node: v12.20.0, js-controller: 3.1.6
      2021-01-05 17:59:02.229 - info: iot.0 (30343) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      2021-01-05 17:59:02.469 - info: iot.0 (30343) Connection changed: connect
      2021-01-05 17:59:44.356 - warn: iot.0 (30343) [GHOME] No devices defined. Did you add not sensor or indicate states to rooms and enums?
      2021-01-05 18:00:52.931 - warn: iot.0 (30343) [GHOME] No devices defined. Did you add not sensor or indicate states to rooms and enums?
      2021-01-05 18:01:01.537 - info: iot.0 (30343) Request google home devices
      2021-01-05 18:01:01.574 - info: iot.0 (30343) [GHOME] alias.0.Jalousien is auto added with type blind.
      2021-01-05 18:01:01.576 - info: iot.0 (30343) [GHOME] alias.0.Rolladen_Bad_Erdgeschoss is auto added with type blind.
      2021-01-05 18:01:01.577 - info: iot.0 (30343) [GHOME] alias.0.Rolladen_Badezimmer is auto added with type blind.
      2021-01-05 18:01:01.579 - info: iot.0 (30343) [GHOME] alias.0.Rolladen_Büro is auto added with type blind.
      2021-01-05 18:01:01.581 - info: iot.0 (30343) [GHOME] alias.0.Rolladen_Esszimmer is auto added with type blind.
      2021-01-05 18:01:01.583 - info: iot.0 (30343) [GHOME] alias.0.Rolladen_Fitness is auto added with type blind.
      2021-01-05 18:01:01.585 - info: iot.0 (30343) [GHOME] alias.0.Rolladen_Gästezimmer is auto added with type blind.
      2021-01-05 18:01:01.586 - info: iot.0 (30343) [GHOME] alias.0.Rolladen_Kind_1 is auto added with type blind.
      2021-01-05 18:01:01.588 - info: iot.0 (30343) [GHOME] alias.0.Rolladen_Küche is auto added with type blind.
      2021-01-05 18:01:01.590 - info: iot.0 (30343) [GHOME] alias.0.Rolladen_Louisa is auto added with type blind.
      2021-01-05 18:01:01.591 - info: iot.0 (30343) [GHOME] alias.0.Rolladen_Schlafzimmer is auto added with type blind.
      2021-01-05 18:01:01.592 - info: iot.0 (30343) [GHOME] alias.0.Rolladen_Wellness is auto added with type blind.
      2021-01-05 18:01:01.592 - info: iot.0 (30343) [GHOME] alias.0.Rolladen_Wohnzimmer is auto added with type blind.
      2021-01-05 18:01:01.595 - info: iot.0 (30343) [GHOME] alias.0.Baum is auto added with type light.
      2021-01-05 18:01:01.599 - info: iot.0 (30343) [GHOME] alias.0.Standlampe_Wohnzimmer is auto added with type light.
      2021-01-05 18:01:12.486 - info: host.HomeServer stopInstance system.adapter.iot.0 (force=false, process=true)
      2021-01-05 18:01:12.487 - info: host.HomeServer stopInstance system.adapter.iot.0 send kill signal
      2021-01-05 18:01:12.489 - info: iot.0 (30343) Got terminate signal TERMINATE_YOURSELF
      2021-01-05 18:01:12.490 - info: iot.0 (30343) terminating
      2021-01-05 18:01:12.490 - info: iot.0 (30343) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-01-05 18:01:12.535 - info: iot.0 (30343) Connection changed: disconnect
      2021-01-05 18:01:12.535 - info: iot.0 (30343) Connection lost
      2021-01-05 18:01:12.996 - info: host.HomeServer instance system.adapter.iot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-01-05 18:01:15.494 - info: host.HomeServer instance system.adapter.iot.0 started with pid 30381
      2021-01-05 18:01:15.904 - info: iot.0 (30381) starting. Version 1.8.5 in /opt/iobroker/node_modules/iobroker.iot, node: v12.20.0, js-controller: 3.1.6
      2021-01-05 18:01:15.912 - info: iot.0 (30381) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      2021-01-05 18:01:17.373 - info: iot.0 (30381) Connection changed: connect
      2021-01-05 18:01:26.200 - info: host.HomeServer stopInstance system.adapter.iot.0 (force=false, process=true)
      2021-01-05 18:01:26.200 - info: host.HomeServer stopInstance system.adapter.iot.0 send kill signal
      2021-01-05 18:01:26.201 - info: iot.0 (30381) Got terminate signal TERMINATE_YOURSELF
      2021-01-05 18:01:26.202 - info: iot.0 (30381) terminating
      2021-01-05 18:01:26.202 - info: iot.0 (30381) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-01-05 18:01:26.241 - info: iot.0 (30381) Connection changed: disconnect
      2021-01-05 18:01:26.241 - info: iot.0 (30381) Connection lost
      2021-01-05 18:01:26.708 - info: host.HomeServer instance system.adapter.iot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-01-05 18:01:29.207 - info: host.HomeServer instance system.adapter.iot.0 started with pid 30399
      2021-01-05 18:01:29.624 - info: iot.0 (30399) starting. Version 1.8.5 in /opt/iobroker/node_modules/iobroker.iot, node: v12.20.0, js-controller: 3.1.6
      2021-01-05 18:01:29.631 - info: iot.0 (30399) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      2021-01-05 18:01:29.970 - info: iot.0 (30399) Connection changed: connect
      2021-01-05 18:01:37.026 - info: host.HomeServer stopInstance system.adapter.iot.0 (force=false, process=true)
      2021-01-05 18:01:37.029 - info: iot.0 (30399) Got terminate signal TERMINATE_YOURSELF
      2021-01-05 18:01:37.026 - info: host.HomeServer stopInstance system.adapter.iot.0 send kill signal
      2021-01-05 18:01:37.030 - info: iot.0 (30399) terminating
      2021-01-05 18:01:37.031 - info: iot.0 (30399) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-01-05 18:01:37.070 - info: iot.0 (30399) Connection changed: disconnect
      2021-01-05 18:01:37.071 - info: iot.0 (30399) Connection lost
      2021-01-05 18:01:37.538 - info: host.HomeServer instance system.adapter.iot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-01-05 18:01:40.032 - info: host.HomeServer instance system.adapter.iot.0 started with pid 30417
      2021-01-05 18:01:40.476 - info: iot.0 (30417) starting. Version 1.8.5 in /opt/iobroker/node_modules/iobroker.iot, node: v12.20.0, js-controller: 3.1.6
      2021-01-05 18:01:40.484 - info: iot.0 (30417) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      2021-01-05 18:01:44.122 - info: iot.0 (30417) Connection changed: connect
      2021-01-05 18:03:23.625 - info: iot.0 (30417) Request google home devices
      2021-01-05 18:03:23.661 - info: iot.0 (30417) [GHOME] alias.0.Jalousien is auto added with type blind.
      2021-01-05 18:03:23.664 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Bad_Erdgeschoss is auto added with type blind.
      2021-01-05 18:03:23.666 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Badezimmer is auto added with type blind.
      2021-01-05 18:03:23.668 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Büro is auto added with type blind.
      2021-01-05 18:03:23.670 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Esszimmer is auto added with type blind.
      2021-01-05 18:03:23.674 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Fitness is auto added with type blind.
      2021-01-05 18:03:23.676 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Gästezimmer is auto added with type blind.
      2021-01-05 18:03:23.677 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Kind_1 is auto added with type blind.
      2021-01-05 18:03:23.679 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Küche is auto added with type blind.
      2021-01-05 18:03:23.680 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Louisa is auto added with type blind.
      2021-01-05 18:03:23.682 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Schlafzimmer is auto added with type blind.
      2021-01-05 18:03:23.683 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Wellness is auto added with type blind.
      2021-01-05 18:03:23.683 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Wohnzimmer is auto added with type blind.
      2021-01-05 18:03:23.686 - info: iot.0 (30417) [GHOME] alias.0.Baum is auto added with type light.
      2021-01-05 18:03:23.688 - info: iot.0 (30417) [GHOME] alias.0.Standlampe_Wohnzimmer is auto added with type light.
      2021-01-05 18:03:32.455 - info: iot.0 (30417) Request google home devices
      2021-01-05 18:03:32.489 - info: iot.0 (30417) [GHOME] alias.0.Jalousien is auto added with type blind.
      2021-01-05 18:03:32.489 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Bad_Erdgeschoss is auto added with type blind.
      2021-01-05 18:03:32.490 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Badezimmer is auto added with type blind.
      2021-01-05 18:03:32.490 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Büro is auto added with type blind.
      2021-01-05 18:03:32.490 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Esszimmer is auto added with type blind.
      2021-01-05 18:03:32.492 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Fitness is auto added with type blind.
      2021-01-05 18:03:32.492 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Gästezimmer is auto added with type blind.
      2021-01-05 18:03:32.492 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Kind_1 is auto added with type blind.
      2021-01-05 18:03:32.493 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Küche is auto added with type blind.
      2021-01-05 18:03:32.493 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Louisa is auto added with type blind.
      2021-01-05 18:03:32.493 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Schlafzimmer is auto added with type blind.
      2021-01-05 18:03:32.494 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Wellness is auto added with type blind.
      2021-01-05 18:03:32.494 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Wohnzimmer is auto added with type blind.
      2021-01-05 18:03:32.494 - info: iot.0 (30417) [GHOME] alias.0.Baum is auto added with type light.
      2021-01-05 18:03:32.495 - info: iot.0 (30417) [GHOME] alias.0.Standlampe_Wohnzimmer is auto added with type light.
      2021-01-05 18:20:57.227 - error: iot.0 (30417) [GHOME] device alias.0.Baum.ACTUAL is unknown to google home
      2021-01-05 18:24:13.435 - info: iot.0 (30417) Request google home devices
      2021-01-05 18:24:13.462 - info: iot.0 (30417) [GHOME] alias.0.Jalousien is auto added with type blind.
      2021-01-05 18:24:13.462 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Bad_Erdgeschoss is auto added with type blind.
      2021-01-05 18:24:13.463 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Badezimmer is auto added with type blind.
      2021-01-05 18:24:13.463 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Büro is auto added with type blind.
      2021-01-05 18:24:13.463 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Esszimmer is auto added with type blind.
      2021-01-05 18:24:13.464 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Fitness is auto added with type blind.
      2021-01-05 18:24:13.465 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Gästezimmer is auto added with type blind.
      2021-01-05 18:24:13.465 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Kind_1 is auto added with type blind.
      2021-01-05 18:24:13.465 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Küche is auto added with type blind.
      2021-01-05 18:24:13.466 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Louisa is auto added with type blind.
      2021-01-05 18:24:13.466 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Schlafzimmer is auto added with type blind.
      2021-01-05 18:24:13.466 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Wellness is auto added with type blind.
      2021-01-05 18:24:13.467 - info: iot.0 (30417) [GHOME] alias.0.Rolladen_Wohnzimmer is auto added with type blind.
      2021-01-05 18:24:13.467 - info: iot.0 (30417) [GHOME] alias.0.Baum is auto added with type light.
      2021-01-05 18:24:13.467 - info: iot.0 (30417) [GHOME] alias.0.Standlampe_Wohnzimmer is auto added with type light.
      2021-01-05 18:24:13.660 - error: iot.0 (30417) [GHOME] Url Key error. Google Request and Response are working. But device states are not reported automatically. If you have pro license please try to delete iot.0.certs: {"error":"Email not found or URL key not found"}
      2021-01-05 18:24:13.661 - warn: iot.0 (30417) [GHOME] Invalid URL Pro key. Status auto-update is disabled you can set states but receive states only manually: {"error":"Email not found or URL key not found"}
      2021-01-05 18:25:30.271 - info: host.HomeServer stopInstance system.adapter.iot.0 (force=false, process=true)
      2021-01-05 18:25:30.274 - info: host.HomeServer stopInstance system.adapter.iot.0 send kill signal
      2021-01-05 18:25:30.275 - info: iot.0 (30417) Got terminate signal TERMINATE_YOURSELF
      2021-01-05 18:25:30.276 - info: iot.0 (30417) terminating
      2021-01-05 18:25:30.276 - info: iot.0 (30417) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-01-05 18:25:30.319 - info: iot.0 (30417) Connection changed: disconnect
      2021-01-05 18:25:30.319 - info: iot.0 (30417) Connection lost
      2021-01-05 18:25:30.786 - info: host.HomeServer instance system.adapter.iot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-01-05 18:25:33.284 - info: host.HomeServer instance system.adapter.iot.0 started with pid 30751
      2021-01-05 18:25:33.651 - info: iot.0 (30751) starting. Version 1.8.5 in /opt/iobroker/node_modules/iobroker.iot, node: v12.20.0, js-controller: 3.1.6
      2021-01-05 18:25:33.663 - info: iot.0 (30751) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      2021-01-05 18:25:34.001 - error: iot.0 (30751) Cannot fetch URL key: "Invalid password or user not exists"
      2021-01-05 18:25:34.001 - error: iot.0 (30751) Cannot read URL key: {"error":"Invalid password or user not exists","time":"2021-01-05T17:25:33.985Z"}
      2021-01-05 18:25:35.354 - info: iot.0 (30751) Connection changed: connect
      2021-01-05 18:26:40.347 - info: host.HomeServer stopInstance system.adapter.iot.0 (force=false, process=true)
      2021-01-05 18:26:40.348 - info: host.HomeServer stopInstance system.adapter.iot.0 send kill signal
      2021-01-05 18:26:40.349 - info: iot.0 (30751) Got terminate signal TERMINATE_YOURSELF
      2021-01-05 18:26:40.349 - info: iot.0 (30751) terminating
      2021-01-05 18:26:40.350 - info: iot.0 (30751) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-01-05 18:26:40.390 - info: iot.0 (30751) Connection changed: disconnect
      2021-01-05 18:26:40.390 - info: iot.0 (30751) Connection lost
      2021-01-05 18:26:40.855 - info: host.HomeServer instance system.adapter.iot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-01-05 18:26:43.354 - info: host.HomeServer instance system.adapter.iot.0 started with pid 30778
      2021-01-05 18:26:43.733 - info: iot.0 (30778) starting. Version 1.8.5 in /opt/iobroker/node_modules/iobroker.iot, node: v12.20.0, js-controller: 3.1.6
      2021-01-05 18:26:43.745 - info: iot.0 (30778) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      2021-01-05 18:26:50.295 - info: iot.0 (30778) Connection changed: connect
      MOD EDIT: Bitte logs in Code Tags posten
      • Meister Mopper
        Meister Mopper @Michael Liller last edited by
        @Michael-Liller Das ist ja eine grauselige Ansicht bitte erstmal alles code tags
        Michael Liller 1 Reply Last reply Reply Quote 0
        • Michael Liller
          Michael Liller @Meister Mopper last edited by
          @Meister-Mopper was Meinst du man kann doch alles lesen und ich habe schon nur das relevante rauskopiert???
          U Thomas Braun 2 Replies Last reply Reply Quote 0
          • U
            uschi08 @Michael Liller last edited by
            @Michael-Liller
            Gibt es denn zur Sache Neuigkeiten? Bei mir ist der iobroker Service im Google Assistant auch verschwunden...Beim Verbinden gibt es auch eine Meldung dass er verbunden wird, dann ist er aber nicht zu sehen. Und die Geräte ebensowenig. Hab es sowohl auf dem Tablet und via Smartphone versucht, ich bekomme die Geräte nicht synchronisiert.
            Lief vorher seit über einem Jahr ohne Probleme..
              Thomas Braun Most Active @Michael Liller last edited by
              @Michael-Liller sagte in IoBroker und Google Assistent/Home:
              Konsolenausgaben in CodeTags </> setzen. Dann kann man das auch lesen.
                bjoernson @uschi08 last edited by bjoernson
                @uschi08
                Ich habe seit heute das selbe Problem. Bis dahin lief alles problemlos. Interessant ist, dass das Problem nicht global auftritt sondern zeitlich versetzt. Funktioniert es bei dir zufälligerweise wieder?
                google home iot pro
