    5. AirSniffer JavaScript?
      acidsubway last edited by acidsubway
      ich habe mir einen AirSniffer gekauft, habe aber keine CCU wo ich den Wiffi-WZ adapter benützen kann.
      https://www.stall.biz/project/der-airsniffer-schlechte-luft-kann-man-messen
      Der Sensor haut aber einen json raus:
      // 20210109115441
      // http://192.168.0.37/?json
        "modultyp": "airsniffer",
        "vars": [
            "name": "1",
            "homematic_name": "as_ip",
            "desc": "ip des airsniffer",
            "type": "string",
            "unit": "",
            "value": "192.168.0.37"
            "name": "2",
            "homematic_name": "as_temp",
            "desc": "Temperatur",
            "type": "number",
            "unit": "gradC",
            "value": "21.2"
            "name": "3",
            "homematic_name": "as_feuchte",
            "desc": "Luftfeuchte",
            "type": "number",
            "unit": "%",
            "value": "27.9"
            "name": "19",
            "homematic_name": "as_taupunkt",
            "desc": "Taupunkt",
            "type": "number",
            "unit": "gradC",
            "value": "1.9"
            "name": "18",
            "homematic_name": "as_feuchte_abs",
            "desc": "Absolutfeuchte",
            "type": "number",
            "unit": "g/m3",
            "value": "5.1"
            "name": "9",
            "homematic_name": "as_baro",
            "desc": "Luftdruck",
            "type": "number",
            "unit": "hPa",
            "value": "1020.74"
            "name": "5",
            "homematic_name": "as_luftdrucktrend",
            "desc": "Luftdrucktrend",
            "type": "string",
            "unit": "",
            "value": "stabil"
            "name": "14",
            "homematic_name": "as_pm10",
            "desc": "Partikel 10",
            "type": "number",
            "unit": "ug/m3",
            "value": "18.7"
            "name": "13",
            "homematic_name": "as_pm2_5",
            "desc": "Partikel 2.5",
            "type": "number",
            "unit": "ug/m3",
            "value": "18.6"
            "name": "12",
            "homematic_name": "as_pm1_0",
            "desc": "Partikel 1.0",
            "type": "number",
            "unit": "ug/m3",
            "value": "9.2"
            "name": "17",
            "homematic_name": "as_iaq10",
            "desc": "IAQ Partikel 10",
            "type": "number",
            "unit": "",
            "value": "17"
            "name": "16",
            "homematic_name": "as_iaq1_0",
            "desc": "IAQ Partikel 2.5",
            "type": "number",
            "unit": "",
            "value": "64"
            "name": "15",
            "homematic_name": "as_iaq2_5",
            "desc": "IAQ Partikel 1.0",
            "type": "number",
            "unit": "",
            "value": "38"
            "name": "25",
            "homematic_name": "as_iaq_co2",
            "desc": "Luftqualitaet",
            "type": "number",
            "unit": "",
            "value": "30.00"
            "name": "24",
            "homematic_name": "as_co2_equ",
            "desc": "Luftqualitaetswert",
            "type": "number",
            "unit": "",
            "value": "540.68"
            "name": "23",
            "homematic_name": "as_IAQ_max",
            "desc": "IAQ max",
            "type": "number",
            "unit": "",
            "value": "64"
            "name": "22",
            "homematic_name": "as_IAQ_max_wertung",
            "desc": "IAQ max Wertung",
            "type": "string",
            "unit": "",
            "value": "gut"
            "name": "21",
            "homematic_name": "as_IAQ_max_note",
            "desc": "IAQ max Note",
            "type": "number",
            "unit": "",
            "value": "2"
            "name": "26",
            "homematic_name": "as_r680_value",
            "desc": "Luftqualitaet R",
            "type": "number",
            "unit": "kOhm",
            "value": "296.38"
        "Systeminfo": {
          "MAC-Adresse": "48:3f:da:44:5a:19",
          "Homematic_CCU_ip": "192.168.0.72",
          "WLAN_ssid": "Jebac2",
          "WLAN_Signal_dBm": "-68",
          "sec_seit_reset": "1019577",
          "firmware": "airsniffer_27"
      Kann man das mit einem JavaScript abfragen und als Datenpunke anzeigen?
      Da ich da keine Ahnung davon habe nehme ich gerne jede Hilfe an.
      MfG
      AcidSubway
      paul53 crunchip 2 Replies Last reply Reply Quote 0
        paul53 @acidsubway last edited by
        @acidsubway sagte:
        Wie kommt der JSON in ioBroker an? In einem Datenpunkt?
          acidsubway @paul53 last edited by
          nein, man kann ihn nur Abfragen mit http://192.168.0.37/?json
          MfG
          • crunchip
            crunchip Forum Testing Most Active @acidsubway last edited by
            @acidsubway sagte in AirSniffer JavaScript?:
            deine "ccu" ist doch in dem Fall der IoBroker, zumindest hab ich das so mit meinem Pulscounter und alle Daten werden mit dem Adapter angelegt.
              acidsubway @crunchip last edited by
              @crunchip
              wie hast du das gemacht?
              A crunchip 2 Replies Last reply Reply Quote 0
                acidsubway @acidsubway last edited by
                ich auch den Adapter wiffi-wz drauf und meinen iobroker als ccu eingestellt, da geht bei mir garnichts, ich habe keine CCU.
                  paul53 @acidsubway last edited by paul53
                  @acidsubway sagte:
                  Vorschlag (nicht getestet):
                  // Airsniffer einlesen und in Datenpunkte schreiben
                  const url = 'http://192.168.0.37/?json';
                  const path = '0_userdata.0.Luftdaten.';
                  schedule('* * * * *', function() { // jede Minute
                      request(url, function(err, response, json) {
                          if(!err && json) {
                              let vars = JSON.parse(json).vars;
                              for(let i = 0; i < vars.length; i++) {
                                  let obj = vars[i];
                                  let id = path + obj.homematic_name;
                                  if(existsState(id)) setState(id, obj.value, true);
                                  else {
                                      let role = 'value';
                                      if(obj.type == 'string') role = 'info';
                                      createState(id, obj.value, {type: obj.type, name: obj.desc, unit: obj.unit.replace('gradC', '°C'), role: role});
                  • crunchip
                    crunchip Forum Testing Most Active @acidsubway last edited by crunchip
                    @acidsubway nach Anleitung eingestellt
                    im Adapter
                    Haupteinstellung
                    • Listen on all Ips
                    Wiffi Geräte
                    Name, Ip deines Gerätes, Zimmer
                    auf deinem Gerät die "CCu" einrichten, mit dem Befehl
                    IpvonGerät/?ccu:myCCU-IP: IPvomIoBroker
                    https://forum.iobroker.net/post/487875
                      @crunchip
                      ich hab ja keine CCU!
                        DANKE PAUL!!!!!!!!!!!!!!!!!! es geht!!!!!!!
                          @acidsubway sagte:
                          es geht!
                          Dann zeige uns mal einen Screenshot der neuen Datenpunkte und markiere das Thema in der Überschrift des ersten Beitrags als [gelöst].
                          • crunchip
                            @acidsubway oh man ich gebs auf🙄
                            ICH HABE EBENFALLS KEINE CCU
                            du kannst dem Gerät die IP deines IOBROKER geben, was die CCU ersetzt
                              @crunchip
                              ich habs nicht hinbekommen, werde deine Posts noch mal durchgehen.
                              hier noch mal ein Fehler der immer wieder aufgetaucht.
                              javascript.0 2021-01-09 14:12:05.537 error (727) Request error: Error: read ECONNRESET
                                @acidsubway sagte:
                                Ist die Abfrage jede Minute vielleicht zu schnell?
                                  der sensor ist nicht der schnellst, obwohl es ein esp8266 ist.
                                  javascript
                                  915
