    4. RPC Adapter 1.14.27 logeinträge für CUXD RPC Instanz
    UNSOLVED RPC Adapter 1.14.27 logeinträge für CUXD RPC Instanz
    • wendy2702
      habe gerade mal den RPC Adapter auf Version 1.14.27 gebracht.
      Jetzt macht die RPC Instanz für CUXD ständig einen neustart und im log kommen diese Einträge:
      2021-01-10 13:25:31.476  - info: host.iobroker instance system.adapter.hm-rpc.1 started with pid 23406
      2021-01-10 13:25:32.249  - info: hm-rpc.1 (23406) starting. Version 1.14.27 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v12.19.0, js-controller: 3.1.6
      2021-01-10 13:25:32.330  - info: hm-rpc.1 (23406) binrpc server is trying to listen on 192.168.178.18:8701
      2021-01-10 13:25:32.331  - info: hm-rpc.1 (23406) binrpc client is trying to connect to 192.168.178.8:8701/ with ["xmlrpc_bin://192.168.178.18:8701","iobroker:hm-rpc.1"]
      2021-01-10 13:25:32.376  - info: hm-rpc.1 (23406) binrpc -> listDevices 18
      2021-01-10 13:25:32.417  - info: hm-rpc.1 (23406) new CUxD devices/channels after filter: 0
      2021-01-10 13:25:32.417  - info: hm-rpc.1 (23406) Connected
      2021-01-10 13:27:02.430  - error: hm-rpc.1 (23406) uncaught exception: argument 'obj' must be type number, string, boolean or object
      2021-01-10 13:27:02.431  - error: hm-rpc.1 (23406) TypeError: argument 'obj' must be type number, string, boolean or object
          at Object.encodeData (/opt/iobroker/node_modules/binrpc/lib/protocol.js:69:19)
          at Object.encodeArray (/opt/iobroker/node_modules/binrpc/lib/protocol.js:156:44)
          at Object.encodeData (/opt/iobroker/node_modules/binrpc/lib/protocol.js:90:32)
          at Object.encodeResponse (/opt/iobroker/node_modules/binrpc/lib/protocol.js:52:25)
          at /opt/iobroker/node_modules/binrpc/lib/server.js:83:41
          at Server.<anonymous> (/opt/iobroker/node_modules/iobroker.hm-rpc/main.js:924:9)
          at Server.emit (events.js:314:20)
          at Server.handleCall (/opt/iobroker/node_modules/binrpc/lib/server.js:82:24)
          at Socket.<anonymous> (/opt/iobroker/node_modules/binrpc/lib/server.js:59:22)
          at Socket.emit (events.js:314:20)
      2021-01-10 13:27:02.432  - info: hm-rpc.1 (23406) binrpc -> 192.168.178.8:8701/ init ["xmlrpc_bin://192.168.178.18:8701",""]
      2021-01-10 13:27:02.435  - info: hm-rpc.1 (23406) Disconnected
      2021-01-10 13:27:02.441  - info: hm-rpc.1 (23406) terminating
      2021-01-10 13:27:02.442  - info: hm-rpc.1 (23406) Terminated (NO_ERROR): Without reason
      2021-01-10 13:27:02.964  - info: host.iobroker instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
      Liegt das an meiner Config oder ist das ein Bug im Adapter?
      EDIT: Gibt auch schon ein issue von einem anderen User dazu: Issue
      cuxd error rpc upgrade
