    4. Sprachbefehle werden nicht ausgeführt (iot)
    • headder
      headder last edited by Negalein
      Hallöchen,
      ich habe seit ein paar Tagen das Problem, dass meine Sprachbefehle nicht mehr umgesetzt werden. Führe die die Scripte manuell aus funktionieren diese. Wenn ich diese per Sprachbefehle ausführen aber leider nicht. Meines wissens habe ich keine Änderungen vorgenommen.
      Im Lopfile sind auch einige Zeilen rot:
      2021-01-10 16:33:21.440  - error: host.raspberrypi Caught by controller[0]: TypeError: Cannot read property 'split' of undefined
      2021-01-10 16:33:21.440  - error: host.raspberrypi Caught by controller[0]:     at checkVersion (/opt/iobroker/node_modules/iobroker.info/main.js:223:23)
      2021-01-10 16:33:21.441  - error: host.raspberrypi Caught by controller[0]:     at checkConditions (/opt/iobroker/node_modules/iobroker.info/main.js:138:25)
      2021-01-10 16:33:21.441  - error: host.raspberrypi Caught by controller[0]:     at Object.keys.forEach.key (/opt/iobroker/node_modules/iobroker.info/main.js:185:46)
      2021-01-10 16:33:21.441  - error: host.raspberrypi Caught by controller[0]:     at Array.forEach (<anonymous>)
      2021-01-10 16:33:21.441  - error: host.raspberrypi Caught by controller[0]:     at messages.forEach.message (/opt/iobroker/node_modules/iobroker.info/main.js:172:57)
      2021-01-10 16:33:21.442  - error: host.raspberrypi Caught by controller[0]:     at Array.forEach (<anonymous>)
      2021-01-10 16:33:21.442  - error: host.raspberrypi Caught by controller[0]:     at instances (/opt/iobroker/node_modules/iobroker.info/main.js:160:26)
      2021-01-10 16:33:21.442  - error: host.raspberrypi Caught by controller[0]:     at adapter.objects.getObjectView (/opt/iobroker/node_modules/iobroker.info/main.js:264:21)
      2021-01-10 16:33:21.442  - error: host.raspberrypi Caught by controller[0]:     at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:96801)
      2021-01-10 16:33:21.443  - error: host.raspberrypi Caught by controller[0]:     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      2021-01-10 16:33:21.444  - info: host.raspberrypi instance system.adapter.info.0 terminated with code 0 (NO_ERROR)
      2021-01-10 16:33:21.444  - info: host.raspberrypi Restart adapter system.adapter.info.0 because enabled
      2021-01-10 16:33:51.467  - info: host.raspberrypi instance system.adapter.info.0 started with pid 10108
      2021-01-10 16:33:58.068  - info: info.0 (10108) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.info, node: v10.18.0
      2021-01-10 16:33:59.094  - info: info.0 (10108) Reading CPU current speed every 3 seconds.
      2021-01-10 16:33:59.159  - info: info.0 (10108) Reading CPU data every 3 seconds.
      2021-01-10 16:33:59.421  - info: info.0 (10108) Reading disk data every 8 seconds.
      2021-01-10 16:33:59.519  - info: info.0 (10108) Reading user data every 8 seconds.
      2021-01-10 16:33:59.609  - info: info.0 (10108) Reading memory data every 3 seconds.
      2021-01-10 16:33:59.956  - info: info.0 (10108) Reading battery data every 8 seconds.
      2021-01-10 16:33:59.965  - info: info.0 (10108) Reading CPU temp data every 3 seconds.
      2021-01-10 16:34:00.149  - info: info.0 (10108) Popup news was read...
      2021-01-10 16:34:00.440  - info: info.0 (10108) Reading process data every 8 seconds.
      2021-01-10 16:34:00.626  - error: info.0 (10108) uncaught exception: Cannot read property 'split' of undefined
      2021-01-10 16:34:00.628  - error: info.0 (10108) TypeError: Cannot read property 'split' of undefined
      2021-01-10 16:34:00.630  - info: info.0 (10108) cleaned everything up...
      2021-01-10 16:34:00.647  - info: info.0 (10108) terminating
      2021-01-10 16:34:00.649  - info: info.0 (10108) Terminated (NO_ERROR): Without reason
      2021-01-10 16:34:01.184  - error: host.raspberrypi Caught by controller[0]: TypeError: Cannot read property 'split' of undefined
      2021-01-10 16:34:01.186  - error: host.raspberrypi Caught by controller[0]:     at checkVersion (/opt/iobroker/node_modules/iobroker.info/main.js:223:23)
      2021-01-10 16:34:01.186  - error: host.raspberrypi Caught by controller[0]:     at checkConditions (/opt/iobroker/node_modules/iobroker.info/main.js:138:25)
      2021-01-10 16:34:01.186  - error: host.raspberrypi Caught by controller[0]:     at Object.keys.forEach.key (/opt/iobroker/node_modules/iobroker.info/main.js:185:46)
      2021-01-10 16:34:01.186  - error: host.raspberrypi Caught by controller[0]:     at Array.forEach (<anonymous>)
      2021-01-10 16:34:01.187  - error: host.raspberrypi Caught by controller[0]:     at messages.forEach.message (/opt/iobroker/node_modules/iobroker.info/main.js:172:57)
      2021-01-10 16:34:01.187  - error: host.raspberrypi Caught by controller[0]:     at Array.forEach (<anonymous>)
      2021-01-10 16:34:01.187  - error: host.raspberrypi Caught by controller[0]:     at instances (/opt/iobroker/node_modules/iobroker.info/main.js:160:26)
      2021-01-10 16:34:01.187  - error: host.raspberrypi Caught by controller[0]:     at adapter.objects.getObjectView (/opt/iobroker/node_modules/iobroker.info/main.js:264:21)
      2021-01-10 16:34:01.187  - error: host.raspberrypi Caught by controller[0]:     at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:96801)
      2021-01-10 16:34:01.188  - error: host.raspberrypi Caught by controller[0]:     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      2021-01-10 16:34:01.188  - info: host.raspberrypi instance system.adapter.info.0 terminated with code 0 (NO_ERROR)
      2021-01-10 16:34:01.188  - info: host.raspberrypi Restart adapter system.adapter.info.0 because enabled
      2021-01-10 16:34:31.323  - info: host.raspberrypi instance system.adapter.info.0 started with pid 10569
      2021-01-10 16:34:38.970  - info: info.0 (10569) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.info, node: v10.18.0
      2021-01-10 16:34:40.197  - info: info.0 (10569) Reading CPU current speed every 3 seconds.
      2021-01-10 16:34:40.264  - info: info.0 (10569) Reading CPU data every 3 seconds.
      2021-01-10 16:34:40.554  - info: info.0 (10569) Reading disk data every 8 seconds.
      2021-01-10 16:34:40.656  - info: info.0 (10569) Reading user data every 8 seconds.
      2021-01-10 16:34:40.729  - info: info.0 (10569) Reading memory data every 3 seconds.
      2021-01-10 16:34:41.106  - info: info.0 (10569) Reading battery data every 8 seconds.
      2021-01-10 16:34:41.114  - info: info.0 (10569) Reading CPU temp data every 3 seconds.
      2021-01-10 16:34:41.308  - info: info.0 (10569) Popup news was read...
      2021-01-10 16:34:41.612  - error: info.0 (10569) uncaught exception: Cannot read property 'split' of undefined
      2021-01-10 16:34:41.614  - error: info.0 (10569) TypeError: Cannot read property 'split' of undefined
      2021-01-10 16:34:41.616  - info: info.0 (10569) cleaned everything up...
      2021-01-10 16:34:41.659  - info: info.0 (10569) Reading process data every 8 seconds.
      2021-01-10 16:34:41.662  - info: info.0 (10569) terminating
      2021-01-10 16:34:41.665  - info: info.0 (10569) Terminated (NO_ERROR): Without reason
      2021-01-10 16:34:42.210  - error: host.raspberrypi Caught by controller[0]: TypeError: Cannot read property 'split' of undefined
      2021-01-10 16:34:42.212  - error: host.raspberrypi Caught by controller[0]:     at checkVersion (/opt/iobroker/node_modules/iobroker.info/main.js:223:23)
      2021-01-10 16:34:42.212  - error: host.raspberrypi Caught by controller[0]:     at checkConditions (/opt/iobroker/node_modules/iobroker.info/main.js:138:25)
      2021-01-10 16:34:42.212  - error: host.raspberrypi Caught by controller[0]:     at Object.keys.forEach.key (/opt/iobroker/node_modules/iobroker.info/main.js:185:46)
      2021-01-10 16:34:42.213  - error: host.raspberrypi Caught by controller[0]:     at Array.forEach (<anonymous>)
      2021-01-10 16:34:42.213  - error: host.raspberrypi Caught by controller[0]:     at messages.forEach.message (/opt/iobroker/node_modules/iobroker.info/main.js:172:57)
      2021-01-10 16:34:42.213  - error: host.raspberrypi Caught by controller[0]:     at instances (/opt/iobroker/node_modules/iobroker.info/main.js:160:26)
      2021-01-10 16:34:42.214  - error: host.raspberrypi Caught by controller[0]:     at adapter.objects.getObjectView (/opt/iobroker/node_modules/iobroker.info/main.js:264:21)
      2021-01-10 16:34:42.214  - error: host.raspberrypi Caught by controller[0]:     at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:96801)
      2021-01-10 16:34:42.214  - error: host.raspberrypi Caught by controller[0]:     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      2021-01-10 16:34:42.215  - info: host.raspberrypi instance system.adapter.info.0 terminated with code 0 (NO_ERROR)
      2021-01-10 16:34:42.215  - info: host.raspberrypi Restart adapter system.adapter.info.0 because enabled
      2021-01-10 16:35:12.234  - info: host.raspberrypi instance system.adapter.info.0 started with pid 1101
      Die maximale Anzahl an Befehlen (20 / Tag) habe ich mit Sicherheit auch nicht erreicht.
      Welche Versionen benötigt ihr zur Prüfung?
      Vielen Dank + viele Grüße
      • Meister Mopper
        Meister Mopper @headder last edited by
        @Patric-Frommeyer Hallo,
        das ganze bitte mal in code tags
        Da bekommt man ja Augen-Aids ...
        headder 2 Replies Last reply Reply Quote 0
        • headder
          headder @Meister Mopper last edited by
          @Meister-Mopper sorry, in was?
          • headder
            Hi Meister Mopper,
            ist es das was du meinst, ist es übersichtlicher?
            host.raspberrypi	2021-01-11 19:03:25.810	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
            host.raspberrypi	2021-01-11 19:03:25.809	error	Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:96801)
            host.raspberrypi	2021-01-11 19:03:25.809	error	Caught by controller[0]: at adapter.objects.getObjectView (/opt/iobroker/node_modules/iobroker.info/main.js:264:21)
            host.raspberrypi	2021-01-11 19:03:25.809	error	Caught by controller[0]: at instances (/opt/iobroker/node_modules/iobroker.info/main.js:160:26)
            host.raspberrypi	2021-01-11 19:03:25.809	error	Caught by controller[0]: at Array.forEach (<anonymous>)
            host.raspberrypi	2021-01-11 19:03:25.809	error	Caught by controller[0]: at messages.forEach.message (/opt/iobroker/node_modules/iobroker.info/main.js:172:57)
            host.raspberrypi	2021-01-11 19:03:25.808	error	Caught by controller[0]: at Object.keys.forEach.key (/opt/iobroker/node_modules/iobroker.info/main.js:185:46)
            host.raspberrypi	2021-01-11 19:03:25.808	error	Caught by controller[0]: at checkConditions (/opt/iobroker/node_modules/iobroker.info/main.js:138:25)
            host.raspberrypi	2021-01-11 19:03:25.808	error	Caught by controller[0]: at checkVersion (/opt/iobroker/node_modules/iobroker.info/main.js:223:23)
            host.raspberrypi	2021-01-11 19:03:25.807	error	Caught by controller[0]: TypeError: Cannot read property 'split' of undefined
            info.0	2021-01-11 19:03:25.216	error	(10878) TypeError: Cannot read property 'split' of undefined at checkVersion (/opt/iobroker/node_modules/iobroker.info/main.js:223:23) at checkConditions (/opt/iobroker/node_modules/iobroker.i
            info.0	2021-01-11 19:03:25.215	error	(10878) uncaught exception: Cannot read property 'split' of undefined
            Besten Dank vorab
            alexa iobroker iot script
