    3. Tester
    4. Test Adapter Traccar v0.0.x
    • IdleBit
      IdleBit last edited by IdleBit
      Aktuelle Test Version 0.0.7
      Veröffentlichungsdatum 11.01.2021
      Github Link https://github.com/o0shojo0o/ioBroker.traccar
      Dieser Adapter importiert in Echtzeit die Positions- und die erweiterten Daten aus Traccar und stellt diese in ioBroker zu Verfügung.
      07fecbac-80e0-4618-828c-cdd458033b75-image.png c5b7e81e-2803-4777-a35d-d8e038e0d75a-image.png
      JohGre M 2 Replies Last reply Reply Quote 2
      • JohGre
        JohGre @IdleBit last edited by
        @idlebit Hab den Adapter seit heute laufen und er funktioniert tadellos. Danke dafür.
          ManfredHi @IdleBit last edited by ManfredHi
          @idlebit
          Hallo. Mit dem neuen Traccar Server 5.2 dürft es ein Problem mit iobroker geben, da der Adapter nicht mehr richtig startet.
          Laut traccar-Entwickler dürfte das am iobroker liegen.
          Der Fehler im Log-File:
          traccar.0
          2022-07-20 08:15:45.170    info    Connect to server over websocket connection.
          traccar.0
          2022-07-20 08:15:45.162    error    device.geofenceIds is not iterable
          traccar.0
          2022-07-20 08:15:45.162    error    TypeError: device.geofenceIds is not iterable at Traccar.getGeofencesState (/opt/iobroker/node_modules/iobroker.traccar/main.js:273:41) at Traccar.processData (/opt/iobroker/node_modules/iobroker.traccar/main.js:195:47) at Traccar.getTraccarDataOverAPI (/opt/iobroker/node_modules/iobroker.traccar/main.js:268:14) at processTicksAndRejections (node:internal/process/task_queues:96:5) at async Traccar.onReady (/opt/iobroker/node_modules/iobroker.traccar/main.js:61:13)
          traccar.0
          2022-07-20 08:15:45.161    error    unhandled promise rejection: device.geofenceIds is not iterable
          traccar.0
          2022-07-20 08:15:45.160    error    Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          traccar.0
          2022-07-20 08:15:45.027    info    starting. Version 0.0.11 (non-npm: o0shojo0o/ioBroker.traccar) in /opt/iobroker/node_modules/iobroker.traccar, node: v16.15.1, js-controller: 4.0.23
          Hier noch der Link zum traccar-Forums beitrag: https://www.traccar.org/forums/topic/iobroker-v51-geofence/#post-73205
          IdleBit 1 Reply Last reply Reply Quote 0
          • IdleBit
            IdleBit @ManfredHi last edited by
            @manfredh-1 teste mal die Gitversion -> https://github.com/o0shojo0o/ioBroker.traccar
              @idlebit said in Test Adapter Traccar v0.0.x:
              Super danke für die rasche Antwort. Die Gitversion funktioniert einwandfrei.
              Hat aber die selbe Versionsnummer.
              • IdleBit
                @manfredh-1 Ja das ist richtig da ich noch keine neue Version rausgeben habe, werde ich aber gleich nachholen 😉
                • liv-in-sky
                  liv-in-sky last edited by
                  @arteck
                  moin moin,
                  habe jetzt erstmal alles vorbereitet (clients umgestellt,...) um deine neue version zu testen - werde nachher mal eine testfahrt machen um dir feedback zu geben.
                  was aber jetzt schon sichtbar ist, ist folgende meldung: kommt bei all diesen datenpunkten - habe alle dp gelöscht und neu anlegen lassen
                  traccar.1
                  2023-10-28 05:58:59.061	info	State value to set for "traccar.1.geofences.6.last_update" has to be type "string" but received type "number"
                  traccar.1
                  2023-10-28 05:58:59.060	info	State value to set for "traccar.1.geofences.5.last_update" has to be type "string" but received type "number"
                  traccar.1
                  2023-10-28 05:58:59.060	info	State value to set for "traccar.1.geofences.4.last_update" has to be type "string" but received type "number"
                  traccar.1
                  2023-10-28 05:58:59.060	info	State value to set for "traccar.1.geofences.3.last_update" has to be type "string" but received type "number"
                  traccar.1
                  2023-10-28 05:58:59.059	info	State value to set for "traccar.1.geofences.2.last_update" has to be type "string" but received type "number"
                  traccar.1
                  2023-10-28 05:58:59.059	info	State value to set for "traccar.1.devices.2.last_update" has to be type "string" but received type "number"
                  traccar.1
                  2023-10-28 05:58:59.059	info	State value to set for "traccar.1.devices.3.last_update" has to be type "string" but received type "number"
                  traccar.1
                  2023-10-28 05:58:59.058	info	State value to set for "traccar.1.devices.2.last_update" has to be type "string" but received type "number"
                  traccar.1
                  2023-10-28 05:58:59.050	info	State value to set for "traccar.1.devices.1.last_update" has to be type "string" but received type "number"
                  traccar.1
                  2023-10-28 05:58:58.755	info	Connect to server over websocket connection.
                  traccar.1
                  2023-10-28 05:58:58.549	info	starting. Version 1.1.3 (non-npm: arteck/ioBroker.traccar#b51ac9173cba2d182177d0742dce731caaf57eda) in /opt/iobroker/node_modules/iobroker.traccar, node: v18.17.1, js-controller: 5.0.12
                  traccar.0
                  2023-10-28 05:58:58.462	info	State value to set for "traccar.0.geofences.37.last_update" has to be type "string" but received type "number"
                  traccar.0
                  2023-10-28 05:58:58.462	info	State value to set for "traccar.0.geofences.36.last_update" has to be type "string" but received type "number"
                  traccar.0
                  2023-10-28 05:58:58.462	info	State value to set for "traccar.0.geofences.35.last_update" has to be type "string" but received type "number"
                  traccar.0
                  2023-10-28 05:58:58.462	info	State value to set for "traccar.0.geofences.34.last_update" has to be type "string" but received type "number"
                  traccar.0
                  2023-10-28 05:58:58.462	info	State value to set for "traccar.0.geofences.33.last_update" has to be type "string" but received type "number"
                  traccar.0
                  2023-10-28 05:58:58.462	info	State value to set for "traccar.0.geofences.32.last_update" has to be type "string" but received type "number"
                  traccar.0
                  2023-10-28 05:58:58.461	info	State value to set for "traccar.0.geofences.30.last_update" has to be type "string" but received type "number"
                  traccar.0
                  2023-10-28 05:58:58.433	info	State value to set for "traccar.0.geofences.29.last_update" has to be type "string" but received type "number"
                  traccar.0
                  2023-10-28 05:58:58.433	info	State value to set for "traccar.0.geofences.28.last_update" has to be type "string" but received type "number"
                    arteck Developer Most Active @liv-in-sky last edited by arteck
                    @liv-in-sky jo korrigiert..komisch dass du die meldung bekommst und ich nicht..
                    M liv-in-sky 2 Replies Last reply Reply Quote 0
                      MartyBr @arteck last edited by
                      @arteck Ich habe gestern auch den Adapter installiert. Er liefert auch Werte von dem Traccar-Server.
                      Ich habe eine Frage zu dem Adapter. Wo sehe ich die Änderungen? In Github sehe ich keine aktuellen Zeiten. Wie kann ich die neue Version installieren? Latest oder per Github?
                      • liv-in-sky
                        liv-in-sky @arteck last edited by liv-in-sky
                        @arteck bin noch am testen - sieht ganz gut aus - leider wird die total_distance hochgezählt, obwohl ich gerade daheim stehe - ist kein adapter thema - liegt wohl am handy - suche gerade lösung
                        State value to set for "traccar.1.geofences.26.last_update" has to be type "string" but received type "number"
                        die meldung verstehe ich eh nicht - da steht ein datum drin - kein timestamp - ist aber immer noch da
                          @liv-in-sky ja musst du den DP mal löschen..
                            arteck Developer Most Active @MartyBr last edited by
                            @martybr erstmal nur bei mir https://github.com/arteck/ioBroker.traccar
                            • liv-in-sky
                              @arteck wie oben erwähnt - hatte ich schon gemacht
                                @liv-in-sky ach seh ich erst jetzt.. ist er andere DP.. jetzt nochmal von GIT
                                die total_distance kommt vom Server da rechnen wir nix
                                liv-in-sky 3 Replies Last reply Reply Quote 0
                                • liv-in-sky
                                  @arteck sagte in Test Adapter Traccar v0.0.x:
                                  total_distance
                                  ja - ich weiß - konte das über eine einstellung beenden
                                  <entry key='filter.distance'>20</entry>
                                   <entry key='filter.enable'>true</entry>
                                  • liv-in-sky
                                    jetzt is es weg - mercy
                                    • liv-in-sky
                                      @arteck
                                      also momentan sieht es ganz gut aus - der letzte fahrtest und mein script hat seine aufgabe erfüllt
                                      vielen dank, dass du dir die zeit genommen hast - werde ab montag weiter beobachten , wenn wieder "on-tour"
                                      so sieht die history aus für geofencies:
                                      also keine andauernden updates auf diesen dp 🙂
                                        @liv-in-sky das klingt doch schon mal gut.. ich schieb es mal ins normal repo
                                        • BananaJoe
                                          Ich bin gerade dabei mich darin einzuarbeiten.
                                          Es gibt ja einen Datenpunkt in dem steht innerhalb welches Geofencing das Gerät sich befindet:
                                          traccar.0.devices.1.geofences_string
                                          Da steht bei mir nun z.B. Wohnort drin.
                                          Meine Tochter bewegt sich nun schon zum 3 Geofence und unter Ihrem Gerät ändert sich nichts, also am
                                          Umgekehrt sollte wohl bei den Geofences stehen wer gerade dort ist:
                                          Aber dort habe ich auch nie etwas gesehen.
                                          Muss ich auf der Traccar-Seite noch etwas einstellen?
                                          Danke!
                                          • liv-in-sky
                                            liv-in-sky @BananaJoe last edited by liv-in-sky
                                            @bananajoe du musst im traccar server das geofence definieren und dann beim benutzer (handy) dieses geofence noch auswählen
                                            also die geofencies müssen auch dem handy zugewiesen werden
                                            31.7k
                                            79.8k
                                            adapter test traccar
                                            15
                                            88
                                            5976
