    4. [fixed] Update heute WEB. Totalausfall iobroker
    • Z
      Zippolighter last edited by
      Hatte heute 2 updates anstehen web und eine VIS Komponente auf meinem Raspi3. Habe Update All gemacht und nichts geht mehr.
      Auch schon neustart vom Raspi und folgendes an der Konsole
      ! ` > Using username "root".
      The programs included with the Debian GNU/Linux system are free software;
      the exact distribution terms for each program are described in the
      individual files in /usr/share/doc/*/copyright.
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      Last login: Sun Nov 6 11:32:50 2016 from 192.168.33.220
      root@raspberrypi3_ioBroker:~# cd opt/iobroker
      -bash: cd: opt/iobroker: Datei oder Verzeichnis nicht gefunden
      root@raspberrypi3_ioBroker:~# cd /opt/iobroker
      root@raspberrypi3_ioBroker:/opt/iobroker# iobroker restart admin
      Adapter "admin.0 restarted.
      root@raspberrypi3_ioBroker:/opt/iobroker# iobroker start
      iobroker controller daemon already running. PID: 728
      root@raspberrypi3_ioBroker:/opt/iobroker# chmod 777 /opt/iobroker/
      root@raspberrypi3_ioBroker:/opt/iobroker# chmod 777 /opt/iobroker/* -R
      root@raspberrypi3_ioBroker:/opt/iobroker# npm install iobroker.js-controller
      npm WARN engine request@2.79.0: wanted: {"node":">= 4"} (current: {"node":"0.12.6","npm":"2.11.2"})
      ursa@0.9.4 install /opt/iobroker/node_modules/iobroker.js-controller/node_modules/letsencrypt/node_modules/rsa-compat/node_modules/ursa
      node-gyp rebuild
      make: Entering directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/letsencrypt/node_modules/rsa-compat/node_modules/ursa/build'
      CXX(target) Release/obj.target/ursaNative/src/ursaNative.o
      SOLINK_MODULE(target) Release/obj.target/ursaNative.node
      COPY Release/ursaNative.node
      make: Leaving directory '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/letsencrypt/node_modules/rsa-compat/node_modules/ursa/build'
      npm ERR! Linux 4.4.13-v7+
      npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.js-controller"
      npm ERR! node v0.12.6
      npm ERR! npm v2.11.2
      npm ERR! code ETIMEDOUT
      npm ERR! errno ETIMEDOUT
      npm ERR! syscall read
      npm ERR! network read ETIMEDOUT
      npm ERR! network This is most likely not a problem with npm itself
      npm ERR! network and is related to network connectivity.
      npm ERR! network In most cases you are behind a proxy or have bad network settings.
      npm ERR! network
      npm ERR! network If you are behind a proxy, please make sure that the
      npm ERR! network 'proxy' config is set properly. See: 'npm help config'
      npm ERR! network
      npm ERR! network
      npm ERR! network
      npm ERR! network
      npm ERR! network
      npm ERR! network
      npm ERR! network
      npm ERR! network
      npm ERR! network
      npm ERR! network
      npm ERR! network
      npm ERR! network
      npm ERR! network
      npm ERR! network
      npm ERR! network
      npm ERR! network
      npm ERR! network
      npm ERR! network
      npm ERR! network
      npm ERR! network
      npm ERR! network
      npm ERR! network
      npm ERR! network 'proxy' config is set properly. See: 'npm help config' `
      Jemand noch Ideen.
      • apollon77
        apollon77 last edited by
        versuchs nochmal. Es gab heute nen GitHub oder NPM Ausfall glaube ich …
        Passierts immer noch?
        • Z
          nach erneutem geht wieder alles
