    4. Log Meldung von "Something"
      Rushmed Most Active last edited by
      habe gerade in meinem Log Errormeldungen bekommen. In der Quellspalte steht "Something". Kann mir das jemand erklären?
      Something	2021-01-22 18:47:43.864	error	went wrong: sourceId=sonoff.0.WiFi-Plug11.POWER, sourceObj={"_id":"sonoff.0.WiFi-Plug11.POWER","common":{"type":"boolean","role":"switch","read":true,"write":true,"storeMap":true,"name":"WiFi-Plug11
      Something	2021-01-22 18:47:43.863	error	went wrong: sourceId=mihome-vacuum.0.rooms.275001013648.roomClean, sourceObj={"type":"state","common":{"name":"clean Room","type":"boolean","role":"button","read":false,"write":true,"desc":"Start Roo
      Something	2021-01-22 18:47:43.863	error	went wrong: sourceId=mihome-vacuum.0.rooms.275001013621.roomClean, sourceObj={"type":"state","common":{"name":"clean Room","type":"boolean","role":"button","read":false,"write":true,"desc":"Start Roo
      Something	2021-01-22 18:47:43.862	error	went wrong: sourceId=mihome-vacuum.0.rooms.275001013628.roomClean, sourceObj={"type":"state","common":{"name":"clean Room","type":"boolean","role":"button","read":false,"write":true,"desc":"Start Roo
      Something	2021-01-22 18:47:43.862	error	went wrong: sourceId=zigbee.0.7cb03eaa00a98380.state, sourceObj={"type":"state","common":{"name":"Switch state","type":"boolean","read":true,"write":true,"role":"switch"},"native":{},"from":"system.a
      Something	2021-01-22 18:47:43.862	error	went wrong: sourceId=zigbee.0.7cb03eaa00a98380.colortemp, sourceObj={"type":"state","common":{"name":"Color temperature","type":"number","read":true,"write":true,"role":"level.color.temperature"},"na
      Something	2021-01-22 18:47:43.861	error	went wrong: sourceId=zigbee.0.7cb03eaa00a98380.brightness, sourceObj={"type":"state","common":{"name":"Brightness","type":"number","unit":"","read":true,"write":true,"role":"level.dimmer","min":0,"ma
      Something	2021-01-22 18:47:43.861	error	went wrong: sourceId=sonoff.0.WiFi-Plug13.POWER, sourceObj={"_id":"sonoff.0.WiFi-Plug13.POWER","common":{"type":"boolean","role":"switch","read":true,"write":true,"storeMap":true,"name":"WiFi-Plug13
      Something	2021-01-22 18:47:43.861	error	went wrong: sourceId=zigbee.0.ec1bbdfffeb19154.state, sourceObj={"type":"state","common":{"name":"Switch state","type":"boolean","read":true,"write":true,"role":"switch"},"native":{},"from":"system.a
      Something	2021-01-22 18:47:43.860	error	went wrong: sourceId=zigbee.0.ec1bbdfffeb19154.brightness, sourceObj={"type":"state","common":{"name":"Brightness","type":"number","unit":"","read":true,"write":true,"role":"level.dimmer","min":0,"ma
      Something	2021-01-22 18:47:43.860	error	went wrong: sourceId=shelly.0.SHSW-1#8CAAB54BD7A3#1.Relay0.Switch, sourceObj={"type":"state","common":{"type":"boolean","read":true,"write":true,"name":"Switch","role":"switch","def":false,"smartName
      Something	2021-01-22 18:47:43.859	error	went wrong: sourceId=zigbee.0.d0cf5efffe1dc9fc.state, sourceObj={"type":"state","common":{"name":"Switch state","type":"boolean","read":true,"write":true,"role":"switch"},"native":{},"from":"system.a
      Something	2021-01-22 18:47:43.859	error	went wrong: sourceId=zigbee.0.d0cf5efffe1dc9fc.colortemp, sourceObj={"type":"state","common":{"name":"Color temperature","type":"number","read":true,"write":true,"role":"level.color.temperature"},"na
      Something	2021-01-22 18:47:43.858	error	went wrong: sourceId=zigbee.0.d0cf5efffe1dc9fc.brightness, sourceObj={"type":"state","common":{"name":"Brightness","type":"number","unit":"","read":true,"write":true,"role":"level.dimmer","min":0,"ma
      Something	2021-01-22 18:47:43.858	error	went wrong: sourceId=zigbee.0.000b57fffe349293.state, sourceObj={"type":"state","common":{"name":"Switch state","type":"boolean","read":true,"write":true,"role":"switch"},"native":{},"from":"system.a
      Something	2021-01-22 18:47:43.857	error	went wrong: sourceId=zigbee.0.000b57fffe349293.brightness, sourceObj={"type":"state","common":{"name":"Brightness","type":"number","unit":"","read":true,"write":true,"role":"level.dimmer","min":0,"ma
      Something	2021-01-22 18:47:43.857	error	went wrong: sourceId=sonoff.0.WiFi-Plug2.POWER, sourceObj={"_id":"sonoff.0.WiFi-Plug2.POWER","common":{"type":"boolean","role":"switch","read":true,"write":true,"storeMap":true,"name":"WiFi-Plug2 POW
      Something	2021-01-22 18:47:43.856	error	went wrong: sourceId=zigbee.0.ec1bbdfffed4493f.state, sourceObj={"type":"state","common":{"name":"Switch state","type":"boolean","read":true,"write":true,"role":"switch"},"native":{},"from":"system.a
      Something	2021-01-22 18:47:43.845	error	went wrong: sourceId=zigbee.0.ec1bbdfffed4493f.brightness, sourceObj={"type":"state","common":{"name":"Brightness","type":"number","unit":"","read":true,"write":true,"role":"level.dimmer","min":0,"ma
      Something	2021-01-22 18:47:43.844	error	went wrong: sourceId=sonoff.0.WiFi-Plug12.POWER, sourceObj={"_id":"sonoff.0.WiFi-Plug12.POWER","common":{"type":"boolean","role":"switch","read":true,"write":true,"storeMap":true,"name":"WiFi-Plug12
      Something	2021-01-22 18:47:43.843	error	went wrong: sourceId=ping.0.192_168_178_41, sourceObj={"type":"state","common":{"name":"Alive S9-Katy","def":false,"type":"boolean","read":true,"write":false,"role":"indicator.reachable","desc":"Ping
      Something	2021-01-22 18:47:43.830	error	went wrong: sourceId=ping.0.192_168_178_59, sourceObj={"type":"state","common":{"name":"Alive S20u-Achmed","def":false,"type":"boolean","read":true,"write":false,"role":"indicator.reachable","desc":"
      Host 3.2.8
      • UncleSam
        UncleSam Developer @Rushmed last edited by
        @rushmed Poste das mal im js-controller 3.2 Thema. Das ist eine Fehlermeldung, die meiner Meinung nach so eigentlich nicht vorkommen sollte.
        • UncleSam
          UncleSam Developer last edited by UncleSam
          Da sich @Rushmed noch nicht auf dem anderen Thema gemeldet hat, mal ein Ping an @apollon77 : ist das etwas, worüber ihr euch sorgen machen solltet? Sieht aus, als würde etwas ins Log gelangen ohne eine Adapter Instanz davor.
          • apollon77
            apollon77 last edited by
            Ok, das ist ein Log wo der Host namespace fehlt und der passiert wenn Alias definiert ist aber hier irgendwas falsch ist.
            Hilft das weiter?
            Ich kann für das nächste Update die Meldung verbessern ...
              Rushmed Most Active @apollon77 last edited by
              @apollon77 Hier ist mal beispielhaft der RAW Auszug eines Alias DP dessen Ziel auch im Log auftaucht:
                "from": "system.adapter.javascript.0",
                "user": "system.user.admin",
                "ts": 1582405800631,
                "common": {
                  "name": "Robi Essbereich",
                  "type": "boolean",
                  "role": "button",
                  "read": false,
                  "write": true,
                  "smartName": {
                    "de": "Robi Essbereich",
                    "smartType": "BUTTON"
                  "alias": {
                    "id": "mihome-vacuum.0.rooms.275001013628.roomClean"
                "native": {},
                "acl": {
                  "object": 1636,
                  "owner": "system.user.admin",
                  "ownerGroup": "system.group.administrator",
                  "state": 1636
                "_id": "alias.0.Robi Essbereich",
                "type": "state"
              Habe ich hier vll. schon einen offensichtlichen Fehler eingebaut.
              In dem oben geposteten Errorlog sthen tatsächlich genau all meine Aliase.
              • apollon77
                apollon77 @Rushmed last edited by
                @rushmed und wenn du mal den js Controller und so alles neu startest kommen die Meldungen dann wieder?
                  @apollon77 Nein
                  • apollon77
                    @rushmed OK, da hatte sich scheinbar was verschluckt.
                      @apollon77 Ok danke, ich melde mich falls es wieder auftaucht.
                      Könntest du mal nen Blick auf meinen Alias werfen?
                      • apollon77
                        Das Alias ist ok
                        error log something
                        379
