    5. [gelöst] Script nicht kompilierbar
      SumoMike last edited by SumoMike
      ich möchte langsam mit JavaScript anfangen. Leider bekomme ich die Grundbefehle nicht kompiliert.
      Eine Neuinstallation von JavaScript hat auch nicht geholfen.
      Beispiel Script:
      setState('javascript.1.Script.Testpunkt', false );
      Den Datenpunkt habe ich vorab in der Testinstance (Instance 1) als Logikwert angelegt.
      Fehlermeldung:
      javascript.1	2021-01-30 17:25:36.577	error	(7919) at processTicksAndRejections (internal/process/task_queues.js:97:5)
      javascript.1	2021-01-30 17:25:36.577	error	(7919) at runMicrotasks (<anonymous>)
      javascript.1	2021-01-30 17:25:36.577	error	(7919) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
      javascript.1	2021-01-30 17:25:36.577	error	(7919) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      javascript.1	2021-01-30 17:25:36.576	error	(7919) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:616:17
      javascript.1	2021-01-30 17:25:36.576	error	(7919) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1140:17
      javascript.1	2021-01-30 17:25:36.576	error	(7919) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1559:17
      javascript.1	2021-01-30 17:25:36.576	error	(7919) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1503:37)
      javascript.1	2021-01-30 17:25:36.575	error	(7919) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1280:28)
      javascript.1	2021-01-30 17:25:36.575	error	(7919) at Object.createScript (vm.js:261:10)
      javascript.1	2021-01-30 17:25:36.575	error	(7919) at new Script (vm.js:88:7)
      javascript.1	2021-01-30 17:25:36.574	error	(7919) SyntaxError: Invalid or unexpected token
      javascript.1	2021-01-30 17:25:36.574	error	(7919) ^^
      javascript.1	2021-01-30 17:25:36.574	error	(7919) /*
      javascript.1	2021-01-30 17:25:36.573	error	at script.js.System.Datenpunkte_erstellen:280
      javascript.1	2021-01-30 17:25:36.573	error	(7919) script.js.System.Datenpunkte_erstellen compile failed:
      javascript.1	2021-01-30 17:25:36.570	info	(7919) Start javascript script.js.System.Datenpunkte_erstellen
      javascript.1	2021-01-30 17:25:35.275	info	(7919) Stop script script.js.System.Datenpunkte_erstellen
      Die Fehlermeldung ist bei allen Befehlen identisch. Wo liegt der Fehler bei meinen Instancen?
      Viele Grüße
      Sumo
      Homoran liv-in-sky 3 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @SumoMike last edited by
        @sumomike sagte in Script nicht kompilierbar:
        was steht denn da?
        • liv-in-sky
          liv-in-sky @SumoMike last edited by
          @sumomike glaube auch nicht, dass der datenpunkt der fehler ist - das wäre ein warning
            @Homoran
            Das steht im Script Log:
            17:56:38.019	info	javascript.1 (7919) Start javascript script.js.System.Datenpunkte_erstellen
            17:56:38.024	error	javascript.1 (7919) script.js.System.Datenpunkte_erstellen compile failed: at script.js.System.Datenpunkte_erstellen:280
            @liv-in-sky denke auch nicht, dass es am Datenpunkt oder Script liegt, weil es ein übernommenes Beispiel ist. Ich finde allerdings den Fehler nicht. Kann irgendetwas falsch einstellen/ installieren? Ich habe bisher nur im Blockly gearbeitet. Das funktioniert auch.
            liv-in-sky paul53 Homoran 3 Replies Last reply Reply Quote 0
            • liv-in-sky
              @sumomike poste mal das ganze script - dann ist's leichter
                paul53 @SumoMike last edited by
                @sumomike sagte: compile failed: at script.js.System.Datenpunkte_erstellen:280
                Was steht im Skript "System.Datenpunkte_erstellen" in Zeile 280 und in den Zeilen davor ?
                  interessant ist was in Zeile 280 des genannten Skripts steht
                  • liv-in-sky
                    @sumomike nur zur vollständigkeit 🙂 - damit die frage mal jeder gestellt hat
                    was steht um zeile 280 - plus/minus 5 zeilen
                      @Homoran @liv-in-sky @paul53 das Skript besteht nur aus diesen einen Befehl. Ab Zeile 2 steht nichts mehr drin.
                        paul53 @SumoMike last edited by paul53
                        @sumomike sagte: das Skript besteht nur aus diesen einen Befehl.
                        Das Skript "System.Datenpunkte_erstellen"? Der Compiler denkt sich so etwas nicht aus.
                        Schau mal im Tab "Objekte" (im Experten-Modus) unter script.js.
                          Hast du noch ein Skript mit dieser Bezeichnung?
                          Vielleicht im Verzeichnis GLOBAL???
                            @paul53 ich habe alle Skripte gelöscht und JS neu installiert (nur noch eine Instance). Das Fehlerbild ist identisch. Auch Blockly Skripte schmeißen jetzt den Fehler.
                            Beispiel Blockly:
                            createState("Blockly_Datenpunkt", false, function () {
                            @Homoran Global ist auch geleert. Kann man den Skript Odner auch per ssh löschen? Mir fehlen sonst die Ideen in welche Zeile 280 der JS Dapter schauen kann.
                              Homoran Global Moderator Administrators @SumoMike last edited by Homoran
                              Dann machen wir es mal Schritt für Schritt:
                              Hast du ein Skript mit der Bezeichnung System.Datenpunkte_erstellen?
                              Mach es wie Paul gesagt hat:
                              @paul53 sagte in Script nicht kompilierbar:
                                @sumomike
                                Tab "Objekte" im Experten-Modus: Gibt es unter "script.js" einen Ordner/channel "System"?
                                  Problem gelöst. Ich habe den Browsercache geleert. Jetzt funktionieren die Blockly und JS-Skripte.
                                  Den Zusammenhang verstehe ich allerdings nicht.
                                  393
