    4. RangeError nach js update
    • Patrick
      Patrick last edited by
      RangeError: 2016-12-23 10:11:53.683 error at C:\Program Files\IO BROKER\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Sender.js:127:7
      RangeError: 2016-12-23 10:11:53.683 error at C:\Program Files\IO BROKER\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Sender.js:270:10
      RangeError: 2016-12-23 10:11:53.683 error at Sender.flush (C:\Program Files\IO BROKER\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Sender.js:268:3)
      RangeError: 2016-12-23 10:11:53.683 error at C:\Program Files\IO BROKER\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Sender.js:120:10
      RangeError: 2016-12-23 10:11:53.683 error at Sender.applyExtensions (C:\Program Files\IO BROKER\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Sender.js:287:5)
      RangeError: 2016-12-23 10:11:53.683 error at C:\Program Files\IO BROKER\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Sender.js:126:12
      RangeError: 2016-12-23 10:11:53.683 error at Sender.frameAndSend (C:\Program Files\IO BROKER\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Sender.js:166:14)
      RangeError: 2016-12-23 10:11:53.683 error at new Buffer (buffer.js:61:12)
      RangeError: 2016-12-23 10:11:53.683 error at fromString (buffer.js:167:16)
      RangeError: 2016-12-23 10:11:53.683 error at byteLength (buffer.js:319:25)
      RangeError: 2016-12-23 10:11:53.683 error Maximum call stack size exceeded
      uncaught 2016-12-23 10:11:53.679 error exception: Maximum call stack size exceeded
      Morgen
      ich habe seit dem JS update immer mal wider das Problem
      weiß jemand wo das herkommt?
      und was man dagegen unternehmen kann ?
      • Patrick
        ricknetpc 2016-12-23 10:18:47.298 error RangeError: Maximum call stack size exceeded at isFinite (native) at Buffer.write (buffer.js:605:14) at fromString (buffer.js:173:26) at new Buffer (buffer.js:61:12) at Sender.fram
        ricknetpc 2016-12-23 10:18:47.296 error uncaught exception: Maximum call stack size exceeded
          @Patrick:
          Morgen
          und was man dagegen unternehmen kann ? `
          node.js version?
          • Patrick
            @Bluefox:
            @Patrick:
            Morgen
            node.js version? `
            node:4.6.1
            • Patrick
              keiner eine Idee ?
              iobroker	2017-01-09 20:46:57.250	info	_restart
              RangeError:	2017-01-09 20:46:57.247	error	at C:\IOBROKER\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Sender.js:120:10
              RangeError:	2017-01-09 20:46:57.247	error	at Sender.applyExtensions (C:\IOBROKER\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Sender.js:287:5)
              RangeError:	2017-01-09 20:46:57.247	error	at C:\IOBROKER\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Sender.js:127:7
              RangeError:	2017-01-09 20:46:57.247	error	at C:\IOBROKER\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Sender.js:270:10
              RangeError:	2017-01-09 20:46:57.247	error	at Sender.flush (C:\IOBROKER\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Sender.js:268:3)
              RangeError:	2017-01-09 20:46:57.247	error	at C:\IOBROKER\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Sender.js:126:12
              RangeError:	2017-01-09 20:46:57.247	error	at Sender.frameAndSend (C:\IOBROKER\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\node_modules\ws\lib\Sender.js:235:38)
              RangeError:	2017-01-09 20:46:57.247	error	at onEnd (C:\IOBROKER\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io\node_modules\engine.io\lib\transports\websocket.js:118:52)
              RangeError:	2017-01-09 20:46:57.247	error	Maximum call stack size exceeded
              uncaught	2017-01-09 20:46:57.240	error	exception: Maximum call stack size exceeded
              host.DESKTOP-2UOKJ1H	2017-01-09 20:46:51.426	info	instance system.adapter.vis.0 terminated while should be started once
              vis.0	2017-01-09 20:46:50.876	info	Uploaded.
              vis.0	2017-01-09 20:46:44.467	info	600 files uploaded...
              vis.0	2017-01-09 20:46:34.571	info	500 files uploaded...
              web.0	2017-01-09 20:46:28.042	info	2017-01-09T19:46:28.041Z Connected system.user.admin
              vis.0	2017-01-09 20:46:25.336	info	400 files uploaded...
              web.0	2017-01-09 20:46:23.493	info	2017-01-09T19:46:23.493Z Connected system.user.admin
              vis.0	2017-01-09 20:46:18.193	info	300 files uploaded...
              wifilight.0	2017-01-09 20:46:17.239	info	starting. Version 0.0.33 in C:/IOBROKER/ioBroker/node_modules/iobroker.wifilight, node: v4.6.1
              node: 4.6.1
              • Jey Cee
                Ich hab das Problem auch, das kommt wahrscheinlich vom upnp Adapter. Das hatte ich nach einem Adapter Absturz. Nachdem ich den Adapter deaktiviert hab war es weg.
                Am Tag darauf hab ich den Adapter wieder aktiviert und seit dem gehts.
                Bisher hab ich kein Lösung für das Problem, das dürfte gar nicht auftreten.
                Gesendet von meinem m8 mit Tapatalk
                • Patrick
                  hmm
                  dann muss ich wohl damit leben
                  • Jey Cee
                    Zumindest bis ich weiss was ich dagegen unternehmen kann.
                    Du hast geschrieben das es immer mal wieder auftritt. Kannst du mal beobachten ob es nach dem Start des Adapters auftritt oder auch dann wenn der Adapter länger als 60 Minuten gelaufen ist.
                    • Patrick
                      @Jey Cee:
                      Gesendet von meinem m8 mit Tapatalk `
                      nach dem Startet trit kein Problem auf
                      ob es länger wie 60 min durch hält denk ich schon werde es aber noch weiter beobachten
                      • Patrick
                        @Jey Cee:
                        läuft länger wie 2h ohne Störung
                        • Y
                          ykuendig last edited by
                          Habe auch etwas mit upnp Adapter gespielt. Nun bekomme ich auch diese Range Fehler. Plus sowas im Log:
                          raspi3	2017-02-04 14:49:19.451	info	iobroker _restart
                          raspi3	2017-02-04 14:49:19.450	error	RangeError: Maximum call stack size exceeded at new Uint8Array (native) at Buffer.subarray (native) at Buffer.slice (buffer.js:688:23) at fromString (buffer.js:182:21) at new Buffe
                          raspi3	2017-02-04 14:49:19.448	error	uncaught exception: Maximum call stack size exceeded
                          upnp.0	2017-02-04 14:49:18.322	debug	inMem message upnp.0.* upnp.0.192_168_1_108_-_Sonos_PLAY:3.ZonePlayer.Alive
                          Vielleicht hilfts ja jemandem weiter.
                            BlueEssi last edited by
                            Ich habe das Problem auch. Der UPNP ist bei mir auch aktiv. Es tritt in unregelmäßigen Abständen auf. Manche Tage garnicht. Manche Tage 3-4 mal am Tag.
                            • Jey Cee
                              http://forum.iobroker.net/viewtopic.php … 030#p55030
                              2202
