    4. Unbekannte Fehlermeldung "iobroker upgrade self"
      A Former User last edited by
      Moin Moin,
      Ist diese Fehlermeldung beachtenswert ?
      und wenn, was kann ich tun ?
      LG
      pi@RP4-ioBroker:/opt/iobroker $ iobroker upgrade self
      Update js-controller from @3.2.12 to @3.2.13
      NPM version: 6.14.10
      npm install iobroker.js-controller@3.2.13 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
      Package pixman-1 was not found in the pkg-config search path.
      Perhaps you should add the directory containing `pixman-1.pc'
      to the PKG_CONFIG_PATH environment variable
      No package 'pixman-1' found
      gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
      gyp ERR! configure error
      gyp ERR! stack Error: `gyp` failed with exit code: 1
      gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
      gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
      gyp ERR! System Linux 5.4.83-v7l+
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=7" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
      gyp ERR! cwd /opt/iobroker/node_modules/canvas
      gyp ERR! node -v v12.20.1
      gyp ERR! node-gyp -v v5.1.0
      gyp ERR! not ok
      node-pre-gyp ERR! build error
      node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=7 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
      node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
      node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
      node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1022:16)
      node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:287:5)
      node-pre-gyp ERR! System Linux 5.4.83-v7l+
      node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
      node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
      node-pre-gyp ERR! node -v v12.20.1
      node-pre-gyp ERR! node-pre-gyp -v v0.11.0
      node-pre-gyp ERR! not ok
      Starting node restart.js
        Thomas Braun Most Active @Guest last edited by Thomas Braun
        @blechsoldat
        sudo apt update
        sudo apt install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev libpixman-1-dev
        Und dann würde ich das Gesamtpaket updaten. Da kam gestern ein wichtiges Kernelupdate für die Raspberry Pies rein.
          A Former User @Thomas Braun last edited by
          Danke schön.
          Im Moment gibt es keine Updates für meinen ioBroker.
          Ich werde das hier updaten wenn die Fehlermeldungen weg sind.
          Deine beiden "Befehle" sind ohne Fehler durchgelaufen.
          LG
            @blechsoldat
            Ich meine auch das OS.
            Mit
            sudo apt update
            sudo apt dist-upgrade
            sudo reboot
            müsste da noch einiges aktualisiert werden.
              Das wird (wurde) vorher gemacht.
              Allerdings ohne Reboot. Das nur wenn mich das System dazu auffordert.
              Nun, in diesem falle, habe ich es trotzdem gemacht.
              [vor deinem Vorschlag wurde das ausgeführt]
              sudo apt update
              sudo apt full-upgrade -y
              sudo reboot
                @blechsoldat sagte in Unbekannte Fehlermeldung "iobroker upgrade self":
                Die Aufforderung kommt im Falle eines Kernelupdates aber nicht.
                uname -a
                Müsste irgendwas mit Kernel 5.10 kommen.
                  pi@RP4-ioBroker:~ $ uname -a
                  Linux RP4-ioBroker 5.10.11-v7l+ #1399 SMP Thu Jan 28 12:09:48 GMT 2021 armv7l GNU/Linux
                  passt.
