    4. [zigbee-Adapter] Instanz auf RPi3 Slave will nicht starten
      colgrim last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi3 als Multihost Slave
      Arbeitsspeicher: 1GB
      Festplattenart: SD-Karte
      Betriebssystem: Raspberry Pi OS Buster
      Node-Version: 12.20.2
      Nodejs-Version: 12.20.2
      NPM-Version: 6.14.11
      Image genutzt: Nein
      Moin!
      Ich versuche derzeit denn zigbee Adapter auf nem Raspberry Pi 3 zu installieren. Leider geht er nur auf rot und folgende Einträge im Log werden ausgegeben, mit denen ich wenig anfangen kann.
      host.raspberrypi3	2021-02-15 12:42:44.988	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.raspberrypi3	2021-02-15 12:42:44.988	error	Caught by controller[0]: }
      host.raspberrypi3	2021-02-15 12:42:44.987	error	Caught by controller[0]: ]
      host.raspberrypi3	2021-02-15 12:42:44.987	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.zigbee/main.js'
      host.raspberrypi3	2021-02-15 12:42:44.987	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js',
      host.raspberrypi3	2021-02-15 12:42:44.986	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/dist/index.js',
      host.raspberrypi3	2021-02-15 12:42:44.986	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js',
      host.raspberrypi3	2021-02-15 12:42:44.986	error	Caught by controller[0]: requireStack: [
      host.raspberrypi3	2021-02-15 12:42:44.985	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.raspberrypi3	2021-02-15 12:42:44.985	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19) {
      host.raspberrypi3	2021-02-15 12:42:44.985	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
      host.raspberrypi3	2021-02-15 12:42:44.984	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
      host.raspberrypi3	2021-02-15 12:42:44.984	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
      host.raspberrypi3	2021-02-15 12:42:44.984	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
      host.raspberrypi3	2021-02-15 12:42:44.983	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:48:38)
      host.raspberrypi3	2021-02-15 12:42:44.983	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
      host.raspberrypi3	2021-02-15 12:42:44.983	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
      host.raspberrypi3	2021-02-15 12:42:44.982	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:667:27)
      host.raspberrypi3	2021-02-15 12:42:44.982	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
      host.raspberrypi3	2021-02-15 12:42:44.982	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
      host.raspberrypi3	2021-02-15 12:42:44.982	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js
      host.raspberrypi3	2021-02-15 12:42:44.981	error	Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman/dist/index.js
      host.raspberrypi3	2021-02-15 12:42:44.981	error	Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js
      host.raspberrypi3	2021-02-15 12:42:44.981	error	Caught by controller[0]: Require stack:
      host.raspberrypi3	2021-02-15 12:42:44.980	error	Caught by controller[0]: Error: Cannot find module 'mixin-deep'
      host.raspberrypi3	2021-02-15 12:42:44.980	error	Caught by controller[0]: ^
      host.raspberrypi3	2021-02-15 12:42:44.979	error	Caught by controller[0]: throw err;
      host.raspberrypi3	2021-02-15 12:42:44.978	error	Caught by controller[0]: internal/modules/cjs/loader.js:818
      Habe testweise mal einen anderen Adapter installiert (Deutscher Fahrplan) und der lief. Jemand eine Idee?
