    4. Discovergy Adapter stoppt
    • Smiddi
      Smiddi last edited by Smiddi
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Raspberry Pi4
      Arbeitsspeicher: 4GB
      Festplattenart: SD-Karte
      Betriebssystem: Linux
      Node-Version: 12.20.2
      Nodejs-Version: 12.20.2
      NPM-Version: 6.14.11
      Installationsart: Manuell
      Image genutzt: Ja
      Ort/Name der Imagedatei: Link
      Seit heute morgen werden über den Adapter keine Daten mehr aktualisiert. Nach mehreren reboots stoppt der Adapter, weil er einen "loop" erkannt hat. Laut Adapter Anzeige ist die Verbindung mit Host: "false" und das Lebenszeichen "false".
      Kann mir jemand helfen?
      Hier die Log Daten:
      2021-02-20 11:31:14.925 - info: host.raspberrypi "system.adapter.discovergy.0" disabled
      2021-02-20 11:31:20.138 - info: host.raspberrypi "system.adapter.discovergy.0" enabled
      2021-02-20 11:31:20.340 - info: host.raspberrypi instance system.adapter.discovergy.0 started with pid 2529
      2021-02-20 11:31:21.927 - info: discovergy.0 (2529) starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.discovergy, node: v12.20.2, js-controller: 3.2.16
      2021-02-20 11:31:21.961 - info: discovergy.0 (2529) Discovergy Adapter startet, trying to discover meters associated with your account
      2021-02-20 11:31:22.155 - info: discovergy.0 (2529) Discovergy meter found at your account with serial : 61234139
      2021-02-20 11:31:22.158 - error: discovergy.0 (2529) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-02-20 11:31:22.158 - error: discovergy.0 (2529) unhandled promise rejection: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:31:22.161 - error: discovergy.0 (2529) Error: The state contains the forbidden properties street, streetNumber, zip, city, country!
      at validateSetStateObjectArgument (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5848:23)
      at Discovergy.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5935:21)
      at Request._callback (/opt/iobroker/node_modules/iobroker.discovergy/main.js:90:13)
      at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
      at Request.emit (events.js:314:20)
      at Request. (/opt/iobroker/node_modules/request/request.js:1154:10)
      at IncomingMessage. (/opt/iobroker/node_modules/request/request.js:1076:12)
      at Object.onceWrapper (events.js:420:28)
      at IncomingMessage.emit (events.js:326:22)
      2021-02-20 11:31:22.162 - error: discovergy.0 (2529) The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:31:22.187 - info: discovergy.0 (2529) cleaned everything up...
      2021-02-20 11:31:22.188 - info: discovergy.0 (2529) terminating
      2021-02-20 11:31:22.189 - warn: discovergy.0 (2529) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-02-20 11:31:22.291 - warn: discovergy.0 (2529) State "discovergy.0.61234139.Power_T1_Delivery" has no existing object, this might lead to an error in future versions
      2021-02-20 11:31:22.763 - error: host.raspberrypi instance system.adapter.discovergy.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-02-20 11:31:22.764 - info: host.raspberrypi Restart adapter system.adapter.discovergy.0 because enabled
      2021-02-20 11:31:52.787 - info: host.raspberrypi instance system.adapter.discovergy.0 started with pid 2546
      2021-02-20 11:31:54.375 - info: discovergy.0 (2546) starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.discovergy, node: v12.20.2, js-controller: 3.2.16
      2021-02-20 11:31:54.409 - info: discovergy.0 (2546) Discovergy Adapter startet, trying to discover meters associated with your account
      2021-02-20 11:31:54.589 - info: discovergy.0 (2546) Discovergy meter found at your account with serial : 61234139
      2021-02-20 11:31:54.592 - error: discovergy.0 (2546) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-02-20 11:31:54.592 - error: discovergy.0 (2546) unhandled promise rejection: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:31:54.596 - error: discovergy.0 (2546) Error: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:31:54.596 - error: discovergy.0 (2546) The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:31:54.622 - info: discovergy.0 (2546) cleaned everything up...
      2021-02-20 11:31:54.623 - info: discovergy.0 (2546) terminating
      2021-02-20 11:31:54.624 - warn: discovergy.0 (2546) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-02-20 11:31:54.705 - warn: discovergy.0 (2546) State "discovergy.0.61234139.Power_T1_Delivery" has no existing object, this might lead to an error in future versions
      2021-02-20 11:31:55.195 - error: host.raspberrypi instance system.adapter.discovergy.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-02-20 11:31:55.196 - info: host.raspberrypi Restart adapter system.adapter.discovergy.0 because enabled
      2021-02-20 11:32:25.244 - info: host.raspberrypi instance system.adapter.discovergy.0 started with pid 2631
      2021-02-20 11:32:26.810 - info: discovergy.0 (2631) starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.discovergy, node: v12.20.2, js-controller: 3.2.16
      2021-02-20 11:32:26.842 - info: discovergy.0 (2631) Discovergy Adapter startet, trying to discover meters associated with your account
      2021-02-20 11:32:27.033 - info: discovergy.0 (2631) Discovergy meter found at your account with serial : 61234139
      2021-02-20 11:32:27.036 - error: discovergy.0 (2631) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-02-20 11:32:27.037 - error: discovergy.0 (2631) unhandled promise rejection: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:32:27.041 - error: discovergy.0 (2631) Error: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:32:27.041 - error: discovergy.0 (2631) The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:32:27.148 - info: discovergy.0 (2631) cleaned everything up...
      2021-02-20 11:32:27.150 - info: discovergy.0 (2631) terminating
      2021-02-20 11:32:27.152 - warn: discovergy.0 (2631) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-02-20 11:32:27.180 - warn: discovergy.0 (2631) State "discovergy.0.61234139.Power_T1_Delivery" has no existing object, this might lead to an error in future versions
      2021-02-20 11:32:27.719 - error: host.raspberrypi instance system.adapter.discovergy.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-02-20 11:32:27.720 - info: host.raspberrypi Restart adapter system.adapter.discovergy.0 because enabled
      2021-02-20 11:32:27.720 - warn: host.raspberrypi Do not restart adapter system.adapter.discovergy.0 because restart loop detected
      2021-02-20 11:34:01.215 - info: host.raspberrypi iobroker add discovergy --host raspberrypi
      2021-02-20 11:34:03.087 - info: host.raspberrypi iobroker host.raspberrypi create instance discovergy
      2021-02-20 11:34:03.098 - info: host.raspberrypi iobroker host.raspberrypi object discovergy.1.info.connection created
      2021-02-20 11:34:03.126 - info: host.raspberrypi iobroker host.raspberrypi object discovergy.1.info created
      2021-02-20 11:34:03.158 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.discovergy.1.logLevel created
      2021-02-20 11:34:03.188 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.discovergy.1.sigKill created
      2021-02-20 11:34:03.220 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.discovergy.1.eventLoopLag created
      2021-02-20 11:34:03.251 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.discovergy.1.outputCount created
      2021-02-20 11:34:03.282 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.discovergy.1.inputCount created
      2021-02-20 11:34:03.313 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.discovergy.1.uptime created
      2021-02-20 11:34:03.344 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.discovergy.1.memRss created
      2021-02-20 11:34:03.375 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.discovergy.1.memHeapTotal created
      2021-02-20 11:34:03.407 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.discovergy.1.memHeapUsed created
      2021-02-20 11:34:03.438 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.discovergy.1.cputime created
      2021-02-20 11:34:03.472 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.discovergy.1.cpu created
      2021-02-20 11:34:03.502 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.discovergy.1.compactMode created
      2021-02-20 11:34:03.533 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.discovergy.1.connected created
      2021-02-20 11:34:03.564 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.discovergy.1.alive created
      2021-02-20 11:34:03.598 - info: host.raspberrypi iobroker host.raspberrypi Set default value of discovergy.1.info.connection: false
      2021-02-20 11:34:03.643 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.discovergy.1 created
      2021-02-20 11:34:04.675 - info: host.raspberrypi iobroker exit 0
      2021-02-20 11:34:06.761 - info: host.raspberrypi instance system.adapter.discovergy.1 started with pid 2727
      2021-02-20 11:34:08.546 - info: discovergy.1 (2727) starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.discovergy, node: v12.20.2, js-controller: 3.2.16
      2021-02-20 11:34:08.579 - info: discovergy.1 (2727) Discovergy Adapter startet, trying to discover meters associated with your account
      2021-02-20 11:34:08.580 - error: discovergy.1 (2727) *** Adapter deactivated, credentials missing in Adaptper Settings !!! ***
      2021-02-20 11:34:08.611 - warn: discovergy.1 (2727) State "system.this.discovergy.1.alive" has no existing object, this might lead to an error in future versions
      2021-02-20 11:34:50.063 - info: host.raspberrypi stopInstance system.adapter.discovergy.1 (force=false, process=true)
      2021-02-20 11:34:50.074 - info: host.raspberrypi stopInstance system.adapter.discovergy.1 send kill signal
      2021-02-20 11:34:50.073 - info: discovergy.1 (2727) Got terminate signal TERMINATE_YOURSELF
      2021-02-20 11:34:50.076 - info: discovergy.1 (2727) cleaned everything up...
      2021-02-20 11:34:50.078 - info: discovergy.1 (2727) terminating
      2021-02-20 11:34:50.081 - info: discovergy.1 (2727) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-02-20 11:34:50.708 - info: host.raspberrypi instance system.adapter.discovergy.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-02-20 11:34:53.251 - info: host.raspberrypi instance system.adapter.discovergy.1 started with pid 2813
      2021-02-20 11:34:54.814 - info: discovergy.1 (2813) starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.discovergy, node: v12.20.2, js-controller: 3.2.16
      2021-02-20 11:34:54.847 - info: discovergy.1 (2813) Discovergy Adapter startet, trying to discover meters associated with your account
      2021-02-20 11:34:55.093 - info: discovergy.1 (2813) Discovergy meter found at your account with serial : 61234021
      2021-02-20 11:34:55.096 - error: discovergy.1 (2813) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-02-20 11:34:55.096 - error: discovergy.1 (2813) unhandled promise rejection: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:34:55.100 - error: discovergy.1 (2813) Error: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:34:55.101 - error: discovergy.1 (2813) The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:34:55.236 - warn: discovergy.1 (2813) State "discovergy.1.61234021.info.meterId" has no existing object, this might lead to an error in future versions
      2021-02-20 11:34:55.237 - warn: discovergy.1 (2813) State "discovergy.1.61234021.info.manufacturerId" has no existing object, this might lead to an error in future versions
      2021-02-20 11:34:55.239 - warn: discovergy.1 (2813) State "discovergy.1.61234021.info.serialNumber" has no existing object, this might lead to an error in future versions
      2021-02-20 11:34:55.240 - warn: discovergy.1 (2813) State "discovergy.1.61234021.info.fullSerialNumber" has no existing object, this might lead to an error in future versions
      2021-02-20 11:34:55.241 - warn: discovergy.1 (2813) State "discovergy.1.61234021.info.administrationNumber" has no existing object, this might lead to an error in future versions
      2021-02-20 11:34:55.242 - warn: discovergy.1 (2813) State "discovergy.1.61234021.info.type" has no existing object, this might lead to an error in future versions
      2021-02-20 11:34:55.243 - warn: discovergy.1 (2813) State "discovergy.1.61234021.info.measurementType" has no existing object, this might lead to an error in future versions
      2021-02-20 11:34:55.244 - warn: discovergy.1 (2813) State "discovergy.1.61234021.info.loadProfileType" has no existing object, this might lead to an error in future versions
      2021-02-20 11:34:55.246 - warn: discovergy.1 (2813) State "discovergy.1.61234021.info.scalingFactor" has no existing object, this might lead to an error in future versions
      2021-02-20 11:34:55.247 - warn: discovergy.1 (2813) State "discovergy.1.61234021.info.currentScalingFactor" has no existing object, this might lead to an error in future versions
      2021-02-20 11:34:55.248 - warn: discovergy.1 (2813) State "discovergy.1.61234021.info.voltageScalingFactor" has no existing object, this might lead to an error in future versions
      2021-02-20 11:34:55.249 - warn: discovergy.1 (2813) State "discovergy.1.61234021.info.internalMeters" has no existing object, this might lead to an error in future versions
      2021-02-20 11:34:55.250 - warn: discovergy.1 (2813) State "discovergy.1.61234021.info.firstMeasurementTime" has no existing object, this might lead to an error in future versions
      2021-02-20 11:34:55.251 - warn: discovergy.1 (2813) State "discovergy.1.61234021.info.lastMeasurementTime" has no existing object, this might lead to an error in future versions
      2021-02-20 11:34:55.253 - warn: discovergy.1 (2813) State "discovergy.1.61234021.energyOut" has no existing object, this might lead to an error in future versions
      2021-02-20 11:34:55.254 - warn: discovergy.1 (2813) State "discovergy.1.61234021.voltage1" has no existing object, this might lead to an error in future versions
      2021-02-20 11:34:55.255 - warn: discovergy.1 (2813) State "discovergy.1.61234021.Power_Delivery" has no existing object, this might lead to an error in future versions
      2021-02-20 11:34:55.256 - warn: discovergy.1 (2813) State "discovergy.1.61234021.Power_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:34:55.278 - warn: discovergy.1 (2813) State "discovergy.1.61234021.Power_T3_Delivery" has no existing object, this might lead to an error in future versions
      2021-02-20 11:34:55.279 - warn: discovergy.1 (2813) State "discovergy.1.61234021.Power_T3_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:34:55.280 - warn: discovergy.1 (2813) State "discovergy.1.61234021.Power_T1_Delivery" has no existing object, this might lead to an error in future versions
      2021-02-20 11:34:55.281 - warn: discovergy.1 (2813) State "discovergy.1.61234021.Power_T1_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:34:55.282 - warn: discovergy.1 (2813) State "discovergy.1.61234021.voltage2" has no existing object, this might lead to an error in future versions
      2021-02-20 11:34:55.283 - warn: discovergy.1 (2813) State "discovergy.1.61234021.energy" has no existing object, this might lead to an error in future versions
      2021-02-20 11:34:55.284 - warn: discovergy.1 (2813) State "discovergy.1.61234021.Power_T2_Delivery" has no existing object, this might lead to an error in future versions
      2021-02-20 11:34:55.285 - warn: discovergy.1 (2813) State "discovergy.1.61234021.Power_T2_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:34:55.286 - warn: discovergy.1 (2813) State "discovergy.1.61234021.voltage3" has no existing object, this might lead to an error in future versions
      2021-02-20 11:34:55.496 - info: discovergy.1 (2813) cleaned everything up...
      2021-02-20 11:34:55.499 - info: discovergy.1 (2813) terminating
      2021-02-20 11:34:55.501 - warn: discovergy.1 (2813) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-02-20 11:34:56.090 - error: host.raspberrypi instance system.adapter.discovergy.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-02-20 11:34:56.091 - info: host.raspberrypi Restart adapter system.adapter.discovergy.1 because enabled
      2021-02-20 11:35:26.146 - info: host.raspberrypi instance system.adapter.discovergy.1 started with pid 2899
      2021-02-20 11:35:27.747 - info: discovergy.1 (2899) starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.discovergy, node: v12.20.2, js-controller: 3.2.16
      2021-02-20 11:35:27.781 - info: discovergy.1 (2899) Discovergy Adapter startet, trying to discover meters associated with your account
      2021-02-20 11:35:28.209 - info: discovergy.1 (2899) Discovergy meter found at your account with serial : 61234021
      2021-02-20 11:35:28.212 - error: discovergy.1 (2899) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-02-20 11:35:28.212 - error: discovergy.1 (2899) unhandled promise rejection: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:35:28.216 - error: discovergy.1 (2899) Error: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:35:28.216 - error: discovergy.1 (2899) The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:35:28.260 - info: discovergy.1 (2899) cleaned everything up...
      2021-02-20 11:35:28.262 - info: discovergy.1 (2899) terminating
      2021-02-20 11:35:28.264 - warn: discovergy.1 (2899) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-02-20 11:35:28.337 - warn: discovergy.1 (2899) State "discovergy.1.61234021.Power_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:35:28.338 - warn: discovergy.1 (2899) State "discovergy.1.61234021.Power_T3_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:35:28.339 - warn: discovergy.1 (2899) State "discovergy.1.61234021.Power_T1_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:35:28.340 - warn: discovergy.1 (2899) State "discovergy.1.61234021.Power_T2_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:35:28.850 - error: host.raspberrypi instance system.adapter.discovergy.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-02-20 11:35:28.852 - info: host.raspberrypi Restart adapter system.adapter.discovergy.1 because enabled
      2021-02-20 11:35:58.874 - info: host.raspberrypi instance system.adapter.discovergy.1 started with pid 2914
      2021-02-20 11:36:00.454 - info: discovergy.1 (2914) starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.discovergy, node: v12.20.2, js-controller: 3.2.16
      2021-02-20 11:36:00.488 - info: discovergy.1 (2914) Discovergy Adapter startet, trying to discover meters associated with your account
      2021-02-20 11:36:00.682 - info: discovergy.1 (2914) Discovergy meter found at your account with serial : 61234021
      2021-02-20 11:36:00.684 - error: discovergy.1 (2914) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-02-20 11:36:00.685 - error: discovergy.1 (2914) unhandled promise rejection: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:36:00.688 - error: discovergy.1 (2914) Error: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:36:00.689 - error: discovergy.1 (2914) The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:36:00.722 - info: discovergy.1 (2914) cleaned everything up...
      2021-02-20 11:36:00.723 - info: discovergy.1 (2914) terminating
      2021-02-20 11:36:00.725 - warn: discovergy.1 (2914) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-02-20 11:36:00.811 - warn: discovergy.1 (2914) State "discovergy.1.61234021.Power_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:36:00.812 - warn: discovergy.1 (2914) State "discovergy.1.61234021.Power_T3_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:36:00.813 - warn: discovergy.1 (2914) State "discovergy.1.61234021.Power_T1_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:36:00.814 - warn: discovergy.1 (2914) State "discovergy.1.61234021.Power_T2_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:36:01.300 - error: host.raspberrypi instance system.adapter.discovergy.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-02-20 11:36:01.301 - info: host.raspberrypi Restart adapter system.adapter.discovergy.1 because enabled
      2021-02-20 11:36:01.301 - warn: host.raspberrypi Do not restart adapter system.adapter.discovergy.1 because restart loop detected
      2021-02-20 11:36:11.440 - info: host.raspberrypi iobroker add discovergy --host raspberrypi
      2021-02-20 11:36:13.312 - info: host.raspberrypi iobroker host.raspberrypi create instance discovergy
      2021-02-20 11:36:13.322 - info: host.raspberrypi iobroker host.raspberrypi object discovergy.2.info.connection created
      2021-02-20 11:36:13.351 - info: host.raspberrypi iobroker host.raspberrypi object discovergy.2.info created
      2021-02-20 11:36:13.383 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.discovergy.2.logLevel created
      2021-02-20 11:36:13.415 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.discovergy.2.sigKill created
      2021-02-20 11:36:13.448 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.discovergy.2.eventLoopLag created
      2021-02-20 11:36:13.487 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.discovergy.2.outputCount created
      2021-02-20 11:36:13.522 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.discovergy.2.inputCount created
      2021-02-20 11:36:13.554 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.discovergy.2.uptime created
      2021-02-20 11:36:13.586 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.discovergy.2.memRss created
      2021-02-20 11:36:13.618 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.discovergy.2.memHeapTotal created
      2021-02-20 11:36:13.665 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.discovergy.2.memHeapUsed created
      2021-02-20 11:36:13.703 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.discovergy.2.cputime created
      2021-02-20 11:36:13.735 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.discovergy.2.cpu created
      2021-02-20 11:36:13.768 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.discovergy.2.compactMode created
      2021-02-20 11:36:13.800 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.discovergy.2.connected created
      2021-02-20 11:36:13.832 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.discovergy.2.alive created
      2021-02-20 11:36:13.866 - info: host.raspberrypi iobroker host.raspberrypi Set default value of discovergy.2.info.connection: false
      2021-02-20 11:36:13.908 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.discovergy.2 created
      2021-02-20 11:36:14.933 - info: host.raspberrypi iobroker exit 0
      2021-02-20 11:36:17.030 - info: host.raspberrypi instance system.adapter.discovergy.2 started with pid 2972
      2021-02-20 11:36:18.837 - info: discovergy.2 (2972) starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.discovergy, node: v12.20.2, js-controller: 3.2.16
      2021-02-20 11:36:18.870 - info: discovergy.2 (2972) Discovergy Adapter startet, trying to discover meters associated with your account
      2021-02-20 11:36:18.872 - error: discovergy.2 (2972) *** Adapter deactivated, credentials missing in Adaptper Settings !!! ***
      2021-02-20 11:36:18.903 - warn: discovergy.2 (2972) State "system.this.discovergy.2.alive" has no existing object, this might lead to an error in future versions
      2021-02-20 11:36:23.310 - info: host.raspberrypi stopInstance system.adapter.discovergy.2 (force=false, process=true)
      2021-02-20 11:36:23.319 - info: discovergy.2 (2972) Got terminate signal TERMINATE_YOURSELF
      2021-02-20 11:36:23.320 - info: host.raspberrypi stopInstance system.adapter.discovergy.2 send kill signal
      2021-02-20 11:36:23.321 - info: discovergy.2 (2972) cleaned everything up...
      2021-02-20 11:36:23.322 - info: discovergy.2 (2972) terminating
      2021-02-20 11:36:23.324 - info: discovergy.2 (2972) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-02-20 11:36:23.968 - info: host.raspberrypi instance system.adapter.discovergy.2 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-02-20 11:36:26.444 - info: host.raspberrypi instance system.adapter.discovergy.2 started with pid 2993
      2021-02-20 11:36:28.057 - info: discovergy.2 (2993) starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.discovergy, node: v12.20.2, js-controller: 3.2.16
      2021-02-20 11:36:28.091 - info: discovergy.2 (2993) Discovergy Adapter startet, trying to discover meters associated with your account
      2021-02-20 11:36:28.325 - info: discovergy.2 (2993) Discovergy meter found at your account with serial : 61234139
      2021-02-20 11:36:28.327 - error: discovergy.2 (2993) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-02-20 11:36:28.328 - error: discovergy.2 (2993) unhandled promise rejection: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:36:28.331 - error: discovergy.2 (2993) Error: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:36:28.332 - error: discovergy.2 (2993) The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:36:28.355 - warn: discovergy.2 (2993) State "discovergy.2.61234139.info.meterId" has no existing object, this might lead to an error in future versions
      2021-02-20 11:36:28.356 - warn: discovergy.2 (2993) State "discovergy.2.61234139.info.manufacturerId" has no existing object, this might lead to an error in future versions
      2021-02-20 11:36:28.357 - warn: discovergy.2 (2993) State "discovergy.2.61234139.info.serialNumber" has no existing object, this might lead to an error in future versions
      2021-02-20 11:36:28.358 - warn: discovergy.2 (2993) State "discovergy.2.61234139.info.fullSerialNumber" has no existing object, this might lead to an error in future versions
      2021-02-20 11:36:28.359 - warn: discovergy.2 (2993) State "discovergy.2.61234139.info.administrationNumber" has no existing object, this might lead to an error in future versions
      2021-02-20 11:36:28.360 - warn: discovergy.2 (2993) State "discovergy.2.61234139.info.type" has no existing object, this might lead to an error in future versions
      2021-02-20 11:36:28.360 - warn: discovergy.2 (2993) State "discovergy.2.61234139.info.measurementType" has no existing object, this might lead to an error in future versions
      2021-02-20 11:36:28.361 - warn: discovergy.2 (2993) State "discovergy.2.61234139.info.loadProfileType" has no existing object, this might lead to an error in future versions
      2021-02-20 11:36:28.362 - warn: discovergy.2 (2993) State "discovergy.2.61234139.info.scalingFactor" has no existing object, this might lead to an error in future versions
      2021-02-20 11:36:28.363 - warn: discovergy.2 (2993) State "discovergy.2.61234139.info.currentScalingFactor" has no existing object, this might lead to an error in future versions
      2021-02-20 11:36:28.363 - warn: discovergy.2 (2993) State "discovergy.2.61234139.info.voltageScalingFactor" has no existing object, this might lead to an error in future versions
      2021-02-20 11:36:28.366 - info: discovergy.2 (2993) cleaned everything up...
      2021-02-20 11:36:28.367 - info: discovergy.2 (2993) terminating
      2021-02-20 11:36:28.367 - warn: discovergy.2 (2993) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-02-20 11:36:28.391 - warn: discovergy.2 (2993) State "discovergy.2.61234139.info.internalMeters" has no existing object, this might lead to an error in future versions
      2021-02-20 11:36:28.393 - warn: discovergy.2 (2993) State "discovergy.2.61234139.info.firstMeasurementTime" has no existing object, this might lead to an error in future versions
      2021-02-20 11:36:28.394 - warn: discovergy.2 (2993) State "discovergy.2.61234139.info.lastMeasurementTime" has no existing object, this might lead to an error in future versions
      2021-02-20 11:36:28.480 - warn: discovergy.2 (2993) State "discovergy.2.61234139.energyOut" has no existing object, this might lead to an error in future versions
      2021-02-20 11:36:28.482 - warn: discovergy.2 (2993) State "discovergy.2.61234139.voltage1" has no existing object, this might lead to an error in future versions
      2021-02-20 11:36:28.482 - warn: discovergy.2 (2993) State "discovergy.2.61234139.Power_Delivery" has no existing object, this might lead to an error in future versions
      2021-02-20 11:36:28.483 - warn: discovergy.2 (2993) State "discovergy.2.61234139.Power_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:36:28.484 - warn: discovergy.2 (2993) State "discovergy.2.61234139.Power_T3_Delivery" has no existing object, this might lead to an error in future versions
      2021-02-20 11:36:28.484 - warn: discovergy.2 (2993) State "discovergy.2.61234139.Power_T3_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:36:28.485 - warn: discovergy.2 (2993) State "discovergy.2.61234139.Power_T1_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:36:28.486 - warn: discovergy.2 (2993) State "discovergy.2.61234139.Power_T1_Delivery" has no existing object, this might lead to an error in future versions
      2021-02-20 11:36:28.486 - warn: discovergy.2 (2993) State "discovergy.2.61234139.voltage2" has no existing object, this might lead to an error in future versions
      2021-02-20 11:36:28.487 - warn: discovergy.2 (2993) State "discovergy.2.61234139.energy" has no existing object, this might lead to an error in future versions
      2021-02-20 11:36:28.488 - warn: discovergy.2 (2993) State "discovergy.2.61234139.Power_T2_Delivery" has no existing object, this might lead to an error in future versions
      2021-02-20 11:36:28.489 - warn: discovergy.2 (2993) State "discovergy.2.61234139.Power_T2_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:36:28.502 - warn: discovergy.2 (2993) State "discovergy.2.61234139.voltage3" has no existing object, this might lead to an error in future versions
      2021-02-20 11:36:28.932 - error: host.raspberrypi instance system.adapter.discovergy.2 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-02-20 11:36:28.932 - info: host.raspberrypi Restart adapter system.adapter.discovergy.2 because enabled
      2021-02-20 11:36:58.962 - info: host.raspberrypi instance system.adapter.discovergy.2 started with pid 3038
      2021-02-20 11:37:00.586 - info: discovergy.2 (3038) starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.discovergy, node: v12.20.2, js-controller: 3.2.16
      2021-02-20 11:37:00.620 - info: discovergy.2 (3038) Discovergy Adapter startet, trying to discover meters associated with your account
      2021-02-20 11:37:00.806 - info: discovergy.2 (3038) Discovergy meter found at your account with serial : 61234139
      2021-02-20 11:37:00.808 - error: discovergy.2 (3038) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-02-20 11:37:00.809 - error: discovergy.2 (3038) unhandled promise rejection: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:37:00.812 - error: discovergy.2 (3038) Error: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:37:00.813 - error: discovergy.2 (3038) The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:37:00.839 - info: discovergy.2 (3038) cleaned everything up...
      2021-02-20 11:37:00.840 - info: discovergy.2 (3038) terminating
      2021-02-20 11:37:00.841 - warn: discovergy.2 (3038) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-02-20 11:37:00.938 - warn: discovergy.2 (3038) State "discovergy.2.61234139.Power_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:37:00.939 - warn: discovergy.2 (3038) State "discovergy.2.61234139.Power_T3_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:37:00.940 - warn: discovergy.2 (3038) State "discovergy.2.61234139.Power_T1_Delivery" has no existing object, this might lead to an error in future versions
      2021-02-20 11:37:00.941 - warn: discovergy.2 (3038) State "discovergy.2.61234139.Power_T2_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:37:01.457 - error: host.raspberrypi instance system.adapter.discovergy.2 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-02-20 11:37:01.458 - info: host.raspberrypi Restart adapter system.adapter.discovergy.2 because enabled
      2021-02-20 11:37:31.519 - info: host.raspberrypi instance system.adapter.discovergy.2 started with pid 3095
      2021-02-20 11:37:33.183 - info: discovergy.2 (3095) starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.discovergy, node: v12.20.2, js-controller: 3.2.16
      2021-02-20 11:37:33.218 - info: discovergy.2 (3095) Discovergy Adapter startet, trying to discover meters associated with your account
      2021-02-20 11:37:34.651 - info: discovergy.2 (3095) Discovergy meter found at your account with serial : 61234139
      2021-02-20 11:37:34.654 - error: discovergy.2 (3095) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-02-20 11:37:34.655 - error: discovergy.2 (3095) unhandled promise rejection: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:37:34.660 - error: discovergy.2 (3095) Error: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:37:34.661 - error: discovergy.2 (3095) The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:37:34.706 - info: discovergy.2 (3095) cleaned everything up...
      2021-02-20 11:37:34.707 - info: discovergy.2 (3095) terminating
      2021-02-20 11:37:34.709 - warn: discovergy.2 (3095) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-02-20 11:37:34.795 - warn: discovergy.2 (3095) State "discovergy.2.61234139.Power_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:37:34.796 - warn: discovergy.2 (3095) State "discovergy.2.61234139.Power_T3_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:37:34.797 - warn: discovergy.2 (3095) State "discovergy.2.61234139.Power_T1_Delivery" has no existing object, this might lead to an error in future versions
      2021-02-20 11:37:34.799 - warn: discovergy.2 (3095) State "discovergy.2.61234139.Power_T2_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:37:35.292 - error: host.raspberrypi instance system.adapter.discovergy.2 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-02-20 11:37:35.293 - info: host.raspberrypi Restart adapter system.adapter.discovergy.2 because enabled
      2021-02-20 11:37:35.293 - warn: host.raspberrypi Do not restart adapter system.adapter.discovergy.2 because restart loop detected
      2021-02-20 11:39:33.984 - info: host.raspberrypi instance system.adapter.discovergy.0 started with pid 3274
      2021-02-20 11:39:35.550 - info: discovergy.0 (3274) starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.discovergy, node: v12.20.2, js-controller: 3.2.16
      2021-02-20 11:39:35.663 - info: discovergy.0 (3274) Discovergy Adapter startet, trying to discover meters associated with your account
      2021-02-20 11:39:35.839 - info: discovergy.0 (3274) Discovergy meter found at your account with serial : 61234139
      2021-02-20 11:39:35.842 - error: discovergy.0 (3274) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-02-20 11:39:35.842 - error: discovergy.0 (3274) unhandled promise rejection: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:39:35.846 - error: discovergy.0 (3274) Error: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:39:35.846 - error: discovergy.0 (3274) The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:39:35.872 - info: discovergy.0 (3274) cleaned everything up...
      2021-02-20 11:39:35.873 - info: discovergy.0 (3274) terminating
      2021-02-20 11:39:35.874 - warn: discovergy.0 (3274) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-02-20 11:39:35.947 - warn: discovergy.0 (3274) State "discovergy.0.61234139.Power_T1_Delivery" has no existing object, this might lead to an error in future versions
      2021-02-20 11:39:36.447 - error: host.raspberrypi instance system.adapter.discovergy.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-02-20 11:39:36.448 - info: host.raspberrypi Restart adapter system.adapter.discovergy.0 because enabled
      2021-02-20 11:39:37.489 - info: host.raspberrypi instance system.adapter.discovergy.0 started with pid 3289
      2021-02-20 11:39:39.334 - info: discovergy.0 (3289) starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.discovergy, node: v12.20.2, js-controller: 3.2.16
      2021-02-20 11:39:39.440 - info: discovergy.0 (3289) Discovergy Adapter startet, trying to discover meters associated with your account
      2021-02-20 11:39:40.030 - info: discovergy.0 (3289) Discovergy meter found at your account with serial : 61234139
      2021-02-20 11:39:40.034 - error: discovergy.0 (3289) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-02-20 11:39:40.035 - error: discovergy.0 (3289) unhandled promise rejection: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:39:40.040 - error: discovergy.0 (3289) Error: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:39:40.041 - error: discovergy.0 (3289) The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:39:40.084 - info: discovergy.0 (3289) cleaned everything up...
      2021-02-20 11:39:40.085 - info: discovergy.0 (3289) terminating
      2021-02-20 11:39:40.088 - warn: discovergy.0 (3289) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-02-20 11:39:40.227 - warn: discovergy.0 (3289) State "discovergy.0.61234139.Power_T1_Delivery" has no existing object, this might lead to an error in future versions
      2021-02-20 11:39:40.655 - error: host.raspberrypi instance system.adapter.discovergy.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-02-20 11:39:40.656 - info: host.raspberrypi Restart adapter system.adapter.discovergy.0 because enabled
      2021-02-20 11:39:40.735 - info: host.raspberrypi iobroker del discovergy.2
      2021-02-20 11:39:41.683 - info: host.raspberrypi instance system.adapter.discovergy.0 started with pid 3316
      2021-02-20 11:39:42.573 - info: host.raspberrypi iobroker Delete adapter "discovergy.2"
      2021-02-20 11:39:42.594 - info: host.raspberrypi iobroker host.raspberrypi Counted 1 instances of discovergy.2
      2021-02-20 11:39:42.611 - info: host.raspberrypi iobroker host.raspberrypi Counted 1 devices of discovergy.2
      2021-02-20 11:39:42.631 - info: host.raspberrypi iobroker host.raspberrypi Counted 2 channels of discovergy.2
      2021-02-20 11:39:42.642 - info: host.raspberrypi iobroker host.raspberrypi Counted 25 states of discovergy.2
      2021-02-20 11:39:42.660 - info: host.raspberrypi iobroker host.raspberrypi Counted 14 states of system.adapter.discovergy.2
      2021-02-20 11:39:42.667 - info: host.raspberrypi iobroker host.raspberrypi Counted 28 states (io.discovergy.2.*) from states
      2021-02-20 11:39:42.685 - info: host.raspberrypi iobroker host.raspberrypi Counted 13 states (system.adapter.discovergy.2.*) from states
      2021-02-20 11:39:43.659 - info: host.raspberrypi iobroker host.raspberrypi Deleting 43 object(s).
      2021-02-20 11:39:43.666 - info: discovergy.0 (3316) starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.discovergy, node: v12.20.2, js-controller: 3.2.16
      2021-02-20 11:39:43.804 - info: discovergy.0 (3316) Discovergy Adapter startet, trying to discover meters associated with your account
      2021-02-20 11:39:44.005 - info: discovergy.0 (3316) Discovergy meter found at your account with serial : 61234139
      2021-02-20 11:39:44.007 - error: discovergy.0 (3316) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-02-20 11:39:44.008 - error: discovergy.0 (3316) unhandled promise rejection: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:39:44.012 - error: discovergy.0 (3316) Error: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:39:44.013 - error: discovergy.0 (3316) The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:39:44.099 - info: discovergy.0 (3316) cleaned everything up...
      2021-02-20 11:39:44.101 - info: discovergy.0 (3316) terminating
      2021-02-20 11:39:44.103 - warn: discovergy.0 (3316) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-02-20 11:39:44.281 - warn: discovergy.0 (3316) State "discovergy.0.61234139.Power_T1_Delivery" has no existing object, this might lead to an error in future versions
      2021-02-20 11:39:44.719 - error: host.raspberrypi instance system.adapter.discovergy.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-02-20 11:39:44.720 - info: host.raspberrypi Restart adapter system.adapter.discovergy.0 because enabled
      2021-02-20 11:39:44.721 - warn: host.raspberrypi Do not restart adapter system.adapter.discovergy.0 because restart loop detected
      2021-02-20 11:39:44.734 - info: host.raspberrypi iobroker host.raspberrypi Deleting 41 state(s).
      2021-02-20 11:39:44.745 - info: host.raspberrypi object deleted system.adapter.discovergy.2
      2021-02-20 11:39:45.888 - info: host.raspberrypi iobroker exit 0
      2021-02-20 11:39:59.790 - info: host.raspberrypi instance system.adapter.discovergy.1 started with pid 3360
      2021-02-20 11:40:01.433 - info: discovergy.1 (3360) starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.discovergy, node: v12.20.2, js-controller: 3.2.16
      2021-02-20 11:40:01.539 - info: discovergy.1 (3360) Discovergy Adapter startet, trying to discover meters associated with your account
      2021-02-20 11:40:01.712 - info: discovergy.1 (3360) Discovergy meter found at your account with serial : 61234021
      2021-02-20 11:40:01.715 - error: discovergy.1 (3360) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-02-20 11:40:01.715 - error: discovergy.1 (3360) unhandled promise rejection: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:40:01.718 - error: discovergy.1 (3360) Error: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:40:01.719 - error: discovergy.1 (3360) The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:40:01.748 - info: discovergy.1 (3360) cleaned everything up...
      2021-02-20 11:40:01.749 - info: discovergy.1 (3360) terminating
      2021-02-20 11:40:01.751 - warn: discovergy.1 (3360) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-02-20 11:40:01.837 - warn: discovergy.1 (3360) State "discovergy.1.61234021.Power_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:40:01.838 - warn: discovergy.1 (3360) State "discovergy.1.61234021.Power_T3_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:40:01.839 - warn: discovergy.1 (3360) State "discovergy.1.61234021.Power_T1_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:40:01.841 - warn: discovergy.1 (3360) State "discovergy.1.61234021.Power_T2_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:40:02.375 - error: host.raspberrypi instance system.adapter.discovergy.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-02-20 11:40:02.376 - info: host.raspberrypi Restart adapter system.adapter.discovergy.1 because enabled
      2021-02-20 11:40:03.423 - info: host.raspberrypi instance system.adapter.discovergy.1 started with pid 3375
      2021-02-20 11:40:05.392 - info: discovergy.1 (3375) starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.discovergy, node: v12.20.2, js-controller: 3.2.16
      2021-02-20 11:40:05.498 - info: discovergy.1 (3375) Discovergy Adapter startet, trying to discover meters associated with your account
      2021-02-20 11:40:05.692 - info: discovergy.1 (3375) Discovergy meter found at your account with serial : 61234021
      2021-02-20 11:40:05.695 - error: discovergy.1 (3375) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-02-20 11:40:05.695 - error: discovergy.1 (3375) unhandled promise rejection: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:40:05.699 - error: discovergy.1 (3375) Error: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:40:05.699 - error: discovergy.1 (3375) The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:40:05.806 - warn: discovergy.1 (3375) State "discovergy.1.61234021.Power_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:40:05.807 - warn: discovergy.1 (3375) State "discovergy.1.61234021.Power_T3_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:40:05.808 - warn: discovergy.1 (3375) State "discovergy.1.61234021.Power_T1_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:40:05.811 - info: discovergy.1 (3375) cleaned everything up...
      2021-02-20 11:40:05.812 - info: discovergy.1 (3375) terminating
      2021-02-20 11:40:05.813 - warn: discovergy.1 (3375) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-02-20 11:40:05.825 - warn: discovergy.1 (3375) State "discovergy.1.61234021.Power_T2_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:40:06.449 - error: host.raspberrypi instance system.adapter.discovergy.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-02-20 11:40:06.451 - info: host.raspberrypi Restart adapter system.adapter.discovergy.1 because enabled
      2021-02-20 11:40:07.500 - info: host.raspberrypi instance system.adapter.discovergy.1 started with pid 3390
      2021-02-20 11:40:09.071 - info: discovergy.1 (3390) starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.discovergy, node: v12.20.2, js-controller: 3.2.16
      2021-02-20 11:40:09.177 - info: discovergy.1 (3390) Discovergy Adapter startet, trying to discover meters associated with your account
      2021-02-20 11:40:09.365 - info: discovergy.1 (3390) Discovergy meter found at your account with serial : 61234021
      2021-02-20 11:40:09.368 - error: discovergy.1 (3390) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-02-20 11:40:09.368 - error: discovergy.1 (3390) unhandled promise rejection: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:40:09.372 - error: discovergy.1 (3390) Error: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:40:09.372 - error: discovergy.1 (3390) The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:40:09.399 - info: discovergy.1 (3390) cleaned everything up...
      2021-02-20 11:40:09.400 - info: discovergy.1 (3390) terminating
      2021-02-20 11:40:09.402 - warn: discovergy.1 (3390) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-02-20 11:40:09.482 - warn: discovergy.1 (3390) State "discovergy.1.61234021.Power_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:40:09.483 - warn: discovergy.1 (3390) State "discovergy.1.61234021.Power_T3_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:40:09.484 - warn: discovergy.1 (3390) State "discovergy.1.61234021.Power_T1_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:40:09.485 - warn: discovergy.1 (3390) State "discovergy.1.61234021.Power_T2_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:40:10.034 - error: host.raspberrypi instance system.adapter.discovergy.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-02-20 11:40:10.035 - info: host.raspberrypi Restart adapter system.adapter.discovergy.1 because enabled
      2021-02-20 11:40:10.036 - warn: host.raspberrypi Do not restart adapter system.adapter.discovergy.1 because restart loop detected
      2021-02-20 11:40:15.998 - info: host.raspberrypi instance system.adapter.discovergy.1 started with pid 3441
      2021-02-20 11:40:17.589 - info: discovergy.1 (3441) starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.discovergy, node: v12.20.2, js-controller: 3.2.16
      2021-02-20 11:40:17.695 - info: discovergy.1 (3441) Discovergy Adapter startet, trying to discover meters associated with your account
      2021-02-20 11:40:17.874 - info: discovergy.1 (3441) Discovergy meter found at your account with serial : 61234021
      2021-02-20 11:40:17.876 - error: discovergy.1 (3441) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-02-20 11:40:17.877 - error: discovergy.1 (3441) unhandled promise rejection: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:40:17.880 - error: discovergy.1 (3441) Error: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:40:17.881 - error: discovergy.1 (3441) The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:40:17.912 - info: discovergy.1 (3441) cleaned everything up...
      2021-02-20 11:40:17.913 - info: discovergy.1 (3441) terminating
      2021-02-20 11:40:17.914 - warn: discovergy.1 (3441) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-02-20 11:40:17.999 - warn: discovergy.1 (3441) State "discovergy.1.61234021.Power_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:40:18.001 - warn: discovergy.1 (3441) State "discovergy.1.61234021.Power_T3_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:40:18.002 - warn: discovergy.1 (3441) State "discovergy.1.61234021.Power_T1_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:40:18.003 - warn: discovergy.1 (3441) State "discovergy.1.61234021.Power_T2_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:40:18.494 - error: host.raspberrypi instance system.adapter.discovergy.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-02-20 11:40:18.495 - info: host.raspberrypi Restart adapter system.adapter.discovergy.1 because enabled
      2021-02-20 11:40:19.536 - info: host.raspberrypi instance system.adapter.discovergy.1 started with pid 3456
      2021-02-20 11:40:21.484 - info: discovergy.1 (3456) starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.discovergy, node: v12.20.2, js-controller: 3.2.16
      2021-02-20 11:40:21.592 - info: discovergy.1 (3456) Discovergy Adapter startet, trying to discover meters associated with your account
      2021-02-20 11:40:21.761 - info: discovergy.1 (3456) Discovergy meter found at your account with serial : 61234021
      2021-02-20 11:40:21.763 - error: discovergy.1 (3456) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-02-20 11:40:21.763 - error: discovergy.1 (3456) unhandled promise rejection: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:40:21.767 - error: discovergy.1 (3456) Error: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:40:21.767 - error: discovergy.1 (3456) The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:40:21.814 - info: discovergy.1 (3456) cleaned everything up...
      2021-02-20 11:40:21.815 - info: discovergy.1 (3456) terminating
      2021-02-20 11:40:21.819 - warn: discovergy.1 (3456) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-02-20 11:40:21.879 - warn: discovergy.1 (3456) State "discovergy.1.61234021.Power_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:40:21.880 - warn: discovergy.1 (3456) State "discovergy.1.61234021.Power_T3_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:40:21.881 - warn: discovergy.1 (3456) State "discovergy.1.61234021.Power_T1_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:40:21.882 - warn: discovergy.1 (3456) State "discovergy.1.61234021.Power_T2_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:40:22.388 - error: host.raspberrypi instance system.adapter.discovergy.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-02-20 11:40:22.390 - info: host.raspberrypi Restart adapter system.adapter.discovergy.1 because enabled
      2021-02-20 11:40:23.436 - info: host.raspberrypi instance system.adapter.discovergy.1 started with pid 3471
      2021-02-20 11:40:25.004 - info: discovergy.1 (3471) starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.discovergy, node: v12.20.2, js-controller: 3.2.16
      2021-02-20 11:40:25.109 - info: discovergy.1 (3471) Discovergy Adapter startet, trying to discover meters associated with your account
      2021-02-20 11:40:25.278 - info: discovergy.1 (3471) Discovergy meter found at your account with serial : 61234021
      2021-02-20 11:40:25.280 - error: discovergy.1 (3471) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-02-20 11:40:25.281 - error: discovergy.1 (3471) unhandled promise rejection: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:40:25.284 - error: discovergy.1 (3471) Error: The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:40:25.285 - error: discovergy.1 (3471) The state contains the forbidden properties street, streetNumber, zip, city, country!
      2021-02-20 11:40:25.313 - info: discovergy.1 (3471) cleaned everything up...
      2021-02-20 11:40:25.314 - info: discovergy.1 (3471) terminating
      2021-02-20 11:40:25.317 - warn: discovergy.1 (3471) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-02-20 11:40:25.401 - warn: discovergy.1 (3471) State "discovergy.1.61234021.Power_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:40:25.402 - warn: discovergy.1 (3471) State "discovergy.1.61234021.Power_T3_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:40:25.403 - warn: discovergy.1 (3471) State "discovergy.1.61234021.Power_T1_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:40:25.404 - warn: discovergy.1 (3471) State "discovergy.1.61234021.Power_T2_Consumption" has no existing object, this might lead to an error in future versions
      2021-02-20 11:40:25.945 - error: host.raspberrypi instance system.adapter.discovergy.1 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-02-20 11:40:25.946 - info: host.raspberrypi Restart adapter system.adapter.discovergy.1 because enabled
      2021-02-20 11:40:25.946 - warn: host.raspberrypi Do not restart adapter system.adapter.discovergy.1 because restart loop detected
      2021-02-20 11:40:56.043 - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      MOD EDIT: LOGS BITTE IN CODE TAGS </> POSTEN
      Smiddi 1 Reply Last reply Reply Quote 0
      • Smiddi
        Smiddi @Smiddi last edited by
        [Gelöst]
        Ich habe nun den Beta Adapter 0.5.4 installiert und dieser behebt das Problem.
        [gelöst]
