    4. Plötzliche adapter fehler
      Billy 0 last edited by Billy 0
      Systemdata Bitte Ausfüllen
      Hardwaresystem: NUC/Pi3/etc. Pi 4b
      Arbeitsspeicher: 1GB 4GB
      Festplattenart: SD-Karte/SSD/HDD SD
      Betriebssystem: Ubuntu/Windows/Mac Debian
      Node-Version: 10.x.x 12.20.1
      Nodejs-Version: 10.x.x 12.20.1
      NPM-Version: 6.x.x 6.xx
      Installationsart: Skript/Manuell Manuell
      Image genutzt: Ja/Nein Nein
      Ort/Name der Imagedatei: Link
      Hi, ich habe nach einem Neustart das Problem das ein paar instanzen nicht grün werden .
      folgendes wird im Log ausgegeben:
      host.raspberrypi	2021-02-21 11:45:18.154	error	instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.raspberrypi	2021-02-21 11:45:18.154	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
      host.raspberrypi	2021-02-21 11:45:18.154	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
      host.raspberrypi	2021-02-21 11:45:18.154	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
      host.raspberrypi	2021-02-21 11:45:18.154	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
      host.raspberrypi	2021-02-21 11:45:18.153	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
      host.raspberrypi	2021-02-21 11:45:18.153	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
      host.raspberrypi	2021-02-21 11:45:18.153	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:1932:5)
      host.raspberrypi	2021-02-21 11:45:18.153	error	Caught by controller[0]: at startAdapter (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:479:15)
      host.raspberrypi	2021-02-21 11:45:18.153	error	Caught by controller[0]: at new Adapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:393:32)
      host.raspberrypi	2021-02-21 11:45:18.153	error	Caught by controller[0]: at JSON.parse (<anonymous>)
      host.raspberrypi	2021-02-21 11:45:18.152	error	Caught by controller[0]: SyntaxError: Unexpected token $ in JSON at position 8443
      host.raspberrypi	2021-02-21 11:45:18.152	error	Caught by controller[0]: ^
      host.raspberrypi	2021-02-21 11:45:18.152	error	Caught by controller[0]: }$
      host.raspberrypi	2021-02-21 11:45:18.152	error	Caught by controller[0]: undefined:155
      host.raspberrypi	2021-02-21 11:45:16.722	info	instance system.adapter.mihome-vacuum.0 started with pid 25670
      host.raspberrypi	2021-02-21 11:45:16.487	info	Restart adapter system.adapter.ping.0 because enabled
      Betroffen sind der mii vacuum adapter, der Ping adapter und der Fronius adapter. Vor dem Neustart lief alles reibungslos.
      Ich hoffe mir kann jemand Helfen!
      Besten dank
        Thomas Braun Most Active @Billy 0 last edited by Thomas Braun
        @billy-0
        dmesg | grep -i ext4
        sagt?
          Billy 0 @Thomas Braun last edited by
          pi@raspberrypi:~ $ dmesg | grep -i ext4
          [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:50:FA:7C vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=115200 console=tty1 root=PARTUUID=fee304eb-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
          [    1.383751] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
          [    1.383841] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [    4.899179] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
          pi@raspberrypi:~ $
            @billy-0
            Okay, das ist sauber.
            iobroker -v
            iobroker status
            iobroker update
            iobroker upgrade
              pi@raspberrypi:~ $ iobroker -v
              3.1.6
              pi@raspberrypi:~ $ iobroker status
              At least one iobroker host is running.
              Objects type: file
              States  type: file
                @billy-0
                iobroker stop
                iobroker update
                iobroker upgrade self
                iobroker upgrade
                iobroker start
                  @billy-0
                  which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                    zu spät, update läuft schon ohne iobroker stop
                      @billy-0
                      Das macht nix.
                      Nur das
                      erfordert zuvor den Stop des Servers.
                        Billy 0 @Thomas Braun last edited by Negalein
                        Adapter "fritzbox"       is not installed.
                        Adapter "fritzdect"      is up to date.
                        (node:12578) UnhandledPromiseRejectionWarning: SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931
                            at parse (<anonymous>)
                            at Object.Module._extensions..json (internal/modules/cjs/loader.js:1041:22)
                            at Module.require (internal/modules/cjs/loader.js:887:19)
                            at require (internal/modules/cjs/helpers.js:74:18)
                            at Upgrade.upgradeAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:237:27)
                            at Upgrade.upgradeAdapterHelper (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:50:14)
                            at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:57:41)
                            at processImmediate (internal/timers.js:461:21)
                        (node:12578) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                        (node:12578) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                        scheinabgebrochen zu haben
                          Billy 0 @Billy 0 last edited by
                          @billy-0
                          Adapter "foobar2000"     is not installed.
                          Uncaught Rejection: SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931
                              at Upgrade.upgradeAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:279:27)
                              at Upgrade.upgradeAdapterHelper (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:68:14)
                              at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:75:41)
                          pi@raspberrypi:~ $
                          dasselbe...
                            @billy-0
                              pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                              /usr/bin/nodejs
                              v12.20.1
                              /usr/bin/node
                              v12.20.1
                              /usr/bin/npm
                              7.5.4
                              nodejs:
                                Installed: 12.20.1-1nodesource1
                                Candidate: 12.20.2-1nodesource1
                                Version table:
                                   12.20.2-1nodesource1 500
                                      500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                               *** 12.20.1-1nodesource1 100
                                      100 /var/lib/dpkg/status
                                   10.23.1~dfsg-1~deb10u1 500
                              pi@raspberrypi:~ $
                              npm hab ich eben ausversehen update gemacht
                                @billy-0 sagte in Plötzliche adapter fehler:
                                Das solltest du wieder rückgängig machen. npm@7 passt nicht zum ioBroker.
                                sudo apt update
                                sudo apt upgrade
                                  @thomas-braun Ok ist durchgelaufen
                                  /usr/bin/nodejs
                                  v12.20.2
                                  /usr/bin/node
                                  v12.20.2
                                  /usr/bin/npm
                                  6.14.11
                                  nodejs:
                                    Installed: 12.20.2-1nodesource1
                                    Version table:
                                   *** 12.20.2-1nodesource1 500
                                  pi@raspberrypi:~ $
                                    @billy-0 log vom broker
                                    host.raspberrypi-Server	2021-02-21 12:49:06.918	error	Cannot parse /opt/iobroker/iobroker-data/files/mihome-vacuum.admin/_data.json: /opt/iobroker/iobroker-data/files/mihome-vacuum.admin/_data.json: Unexpected token b in JSON at position 2195
                                      @billy-0 beim upgrade self bleibts beim fehler
                                      Thomas Braun B 2 Replies Last reply Reply Quote 0
                                        @billy-0
                                        Lösch den Adapter mal und installier den danach neu.
                                          Hmm, habe gerade festgestellt das mir die betreffenden Adapter gar nicht mehr in der Adapter ansicht vom iobroker angezeigt werden. Sind nur in der Instanzen ansicht sichtbar... Hilft uns das weiter?
                                            @thomas-braun finde nix zum neu installieren!?
                                            807
