    4. Installation schlägt immer fehl..
      timy last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Raspberry 3 B+
      Arbeitsspeicher: 1GB
      Festplattenart: SD-Karte 16Gb
      Betriebssystem: Raspberry
      Node-Version: 12
      Nodejs-Version: 12
      NPM-Version: 6
      Installationsart: wie auf der Homepage Anleitung
      Image genutzt: Nein
      Ort/Name der Imagedatei: kein Image
      Ich bekomme immer diesen Fehler... Danach bricht es ab. System ist auf dem neuesten Stand. Node sowie NBM auch
      Kann damit wenig anfangen...
      Installing ioBroker (3/4)
      In file included from ../../nan/nan.h:56,
      from ../src/main.cpp:3:
      /root/.cache/node-gyp/12.21.0/include/node/node.h:737:43: warning: cast between incompatible function types from ‘void ()(v8::Localv8::Object)’ to ‘node::addon_register_func’ {aka ‘void ()(v8::Localv8::Object, v8::Localv8::Value, void*)’} [-Wcast-function-type]
      (node::addon_register_func) (regfunc),
      /root/.cache/node-gyp/12.21.0/include/node/node.h:771:3: note: in expansion of macro ‘NODE_MODULE_X’
      NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)
      ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
      NODE_MODULE(diskusage, Init)
      from ../src/unix_dgram.cc:5:
      ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
      NODE_MODULE(unix_dgram, Initialize)
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
      uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
      uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
      uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
      uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:271:68: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
      uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:316:68: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
      uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:366:76: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
      uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:412:70: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
      uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
      ../src/serialport.cpp: At global scope:
      ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
      SerialPortParity NAN_INLINE(ToParityEnum(const v8::Localv8::String& v8str)) {
      ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
      SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
      In file included from ../../../nan/nan.h:56,
      from ../src/./serialport.h:6,
      from ../src/serialport.cpp:1:
      /root/.cache/node-gyp/12.21.0/include/node/node.h:737:43: warning: cast between incompatible function types from ‘void ()(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void ()(v8::Localv8::Object)’} to ‘node::addon_register_func’ {aka ‘void ()(v8::Localv8::Object, v8::Localv8::Value, void)’} [-Wcast-function-type]
      ../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’
      NODE_MODULE(serialport, init);
      ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
      ../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
      snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
      ../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
      ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
      ../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
      snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
      ../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
      ATTENTION: Error reporting via Sentry will be activated on next start of ioBroker
      ioBroker wants to make sure to deliver the most stable smart home system.
      To allow this we decided to implement an automatic error and crash reporting solution into the js-controller and also into adapters.
      THIS REPORTING WILL BE ENABLED WITH THE NEXT START OF YOUR IOBROKER!
      For any error that leads to the crash of the js-controller or one of the relevant adapters the error details are send to a server. For the js-controller and core adapters this server is located and operated in germany. For community adapters please check the Github Readme of the affected adapter for details which Sentry server is used.
      If you want to disable the error reporting you can use the command
      'iobroker plugin disable sentry'
      This command will also make sure that no adapter that runs on this host will send crash reporting data to sentry.
        Thomas Braun Most Active @timy last edited by
        @timy sagte in Installation schlägt immer fehl..:
        /root/.ca
        Du hampelst da als root rum.
          timy @Thomas Braun last edited by
          @thomas-braun ist egal ob root oder nicht...
          Fehlermeldung kommt trotzdem
            Thomas Braun Most Active @timy last edited by Thomas Braun
            @timy
            Was machst du denn genau?
            Die Installation erfolgt in einem Einzeiler als user pi.
            Da kann man eigentlich gar nix falsch machen.
            Die Anmeldung als root ist allerdings schon ein grundlegender Fehler. Einfach nicht machen!
              ich habe die Installation so gemacht wie es hier steht für die Beere
              Aber jedesmal kommt Fehler.
              https://www.iobroker.net/#de/documentation/install/linux.md
              Selbst wenn ich es von hier hole geht es nicht.
              https://www.iobroker.net/#de/download
              Die installation vom OS ist frisch ein update wurde auch gemacht.
                @timy
                Mach die Kiste platt und dann NIE als root anmelden.
                Als user pi
                curl -sLf https://iobroker.net/install.sh | bash -
                eingeben, fertig.
                  @thomas-braun habe ich gemacht...
                  Auch Fehler...
                    @timy Das ist Schade.
                    Komplette Ausgabe posten, in CodeTags!
                    Und ich will da nix von /root drin lesen.
                      @thomas-braun mehr zeigt es nicht...
                      Das was ich gepostet habe ist schon komplett
                        @timy Dann nochmal...
                        System plattmachen.
                        System installieren, updaten, rebooten,
                        eingeben, fertig. Nicht root werden. Nie.
                          @thomas-braun den nodejs nicht vorher installieren?
                          Ansonsten einfach nur den curl Befehl?
                            @timy
                            Nur diese eine kleine Zeile. Mehr ist gar nicht erforderlich, auf einem sauberen Grundsystem.
                              @thomas-braun okay.
                              update läuft gerade noch auf neuem System.
                              ich probiere es.
                                Homoran Global Moderator Administrators @timy last edited by
                                Auch Fehler...
                                Vielleicht kann ich da mehr sehen, wenn es in code-tags ist, aber ich meine da ist kein Fehler!
                                  Außer der Installation als root ist da ja auch keiner. 🕶
                                    und wieder der Fehler...
                                    pi@raspberrypi:~ $ curl -sLf https://iobroker.net/install.sh | bash
                                    library: loaded
                                    Library version=2021-01-23
                                        Welcome to the ioBroker installer!
                                        Installer version: 2020-12-07
                                        You might need to enter your password a couple of times.
                                        Installing prerequisites (1/4)
                                    OK:1 http://archive.raspberrypi.org/debian buster InRelease
                                    Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                                    Holen:3 http://packages.microsoft.com/repos/code stable InRelease [10,4 kB]
                                    Holen:4 http://packages.microsoft.com/repos/code stable/main armhf Packages [15,6 kB]
                                    Holen:5 http://packages.microsoft.com/repos/code stable/main arm64 Packages [15,8 kB]
                                    Holen:6 http://packages.microsoft.com/repos/code stable/main amd64 Packages [15,2 kB]
                                    Es wurden 72,0 kB in 2 s geholt (38,1 kB/s).
                                        Node.js not found. Installing...
                                    ## Installing the NodeSource Node.js 12.x repo...
                                    ## Populating apt-get cache...
                                    + apt-get update
                                    OK:1 http://packages.microsoft.com/repos/code stable InRelease
                                    OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                    OK:3 http://archive.raspberrypi.org/debian buster InRelease
                                    ## Confirming "buster" is supported...
                                    + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_12.x/dists/buster/Release'
                                    ## Adding the NodeSource signing key to your keyring...
                                    + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
                                    OK
                                    ## Creating apt sources list file for the NodeSource Node.js 12.x repo...
                                    + echo 'deb https://deb.nodesource.com/node_12.x buster main' > /etc/apt/sources.list.d/nodesource.list
                                    + echo 'deb-src https://deb.nodesource.com/node_12.x buster main' >> /etc/apt/sources.list.d/nodesource.list
                                    ## Running `apt-get update` for you...
                                    + apt-get update
                                    OK:3 http://packages.microsoft.com/repos/code stable InRelease
                                    Holen:4 https://deb.nodesource.com/node_12.x buster InRelease [4.584 B]
                                    Holen:5 https://deb.nodesource.com/node_12.x buster/main armhf Packages [774 B]
                                    Es wurden 5.358 B in 2 s geholt (2.248 B/s).
                                    ## Run `sudo apt-get install -y nodejs` to install Node.js 12.x and npm
                                    ## You may also need development tools to build native addons:
                                         sudo apt-get install gcc g++ make
                                    ## To install the Yarn package manager, run:
                                         curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | sudo apt-key add -
                                         echo "deb https://dl.yarnpkg.com/debian/ stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
                                         sudo apt-get update && sudo apt-get install yarn
                                    Installed nodejs
                                    Node.js Installed successfully!
                                    Changing npm registry to https://registry.npmjs.org
                                    Installed gcc-c++
                                    Installed libavahi-compat-libdnssd-dev
                                    Installed libudev-dev
                                    Installed libpam0g-dev
                                    Installed libcairo2-dev
                                    Installed libpango1.0-dev
                                    Installed libjpeg-dev
                                    Installed libgif-dev
                                    Installed librsvg2-dev
                                        Creating ioBroker user and directory (2/4)
                                    User iobroker created
                                    Created /etc/sudoers.d/iobroker
                                    Directory /opt/iobroker created
                                    /home/pi/.cache/node-gyp/12.21.0/include/node/node.h:737:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                                           (node::addon_register_func) (regfunc),                          \
                                    /home/pi/.cache/node-gyp/12.21.0/include/node/node.h:771:3: note: in expansion of macro ‘NODE_MODULE_X’
                                    ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                    ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                    ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                    ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                    ../src/serialport.cpp:271:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                    ../src/serialport.cpp:316:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                    ../src/serialport.cpp:366:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                    ../src/serialport.cpp:412:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                     SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
                                    /home/pi/.cache/node-gyp/12.21.0/include/node/node.h:737:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                                    Danach habe ich ein reboot durchgeführt aber gestartet wurde da nichts...
                                    Thomas Braun T Homoran 3 Replies Last reply Reply Quote 0
                                      @timy
                                      iobroker status
                                        timy @timy last edited by
                                        habe noch
                                        curl -sL https://iobroker.net/fix.sh | bash -
                                        durchgeführt danach
                                        ibroker start
                                        danach ist es gestartet...
                                        Aber irgendwie schon sehr komisch
                                          @thomas-braun da kam das..
                                          pi@raspberrypi:~ $ iobroker status
                                          -bash: iobroker: Kommando nicht gefunden.
                                          wie gesagt mit der reparatur hat es dann geklappt.
                                            @timy
                                            Der Fixer war vermutlich unnötig.
                                            Aber schadet auch nix.
                                            1527
