    4. IoBroker down - Cannot read system
      Prince3k last edited by Prince3k
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi 4
      Arbeitsspeicher: 4 GB
      Node-Version: 10.24.0
      Nodejs-Version: 10.24.0
      NPM-Version: 6.14.11
      Installationsart: Skript
      Image genutzt: Ja
      Ich habe plötzlich von jetzt auf gleich keinen Zugriff mehr auf ioBroker.
      Folgendes habe ich bereits versucht ( alles aus anderen Threads hier im Forum 😞
      iobroker list instances
       Cannot read system.config: null (OK when migrating or restoring)
      + instance is alive
      pi@raspberrypi4-iob:~ $ sudo -H -u iobroker npm install iobroker.js-controller
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://git                                   hub.com/request/request/issues/3142
      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
      npm WARN checkPermissions Missing write access to /home/pi
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/ch                                   okidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@                                   2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}                                   )
      npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
      npm WARN pi No description
      npm WARN pi No repository field.
      npm WARN pi No README data
      npm WARN pi No license field.
      npm ERR! code EACCES
      npm ERR! syscall access
      npm ERR! path /home/pi
      npm ERR! errno -13
      npm ERR! Error: EACCES: permission denied, access '/home/pi'
      npm ERR!  { [Error: EACCES: permission denied, access '/home/pi']
      npm ERR!   stack: 'Error: EACCES: permission denied, access \'/home/pi\'',
      npm ERR!   errno: -13,
      npm ERR!   code: 'EACCES',
      npm ERR!   syscall: 'access',
      npm ERR!   path: '/home/pi' }
      npm ERR!
      npm ERR! The operation was rejected by your operating system.
      npm ERR! It is likely you do not have the permissions to access this file as the                                    current user
      npm ERR!
      npm ERR! If you believe this might be a permissions issue, please double-check t                                   he
      npm ERR! permissions of the file and its containing directories, or try running
      npm ERR! the command again as root/Administrator.
      npm ERR!     /home/iobroker/.npm/_logs/2021-03-02T12_07_04_601Z-debug.log
      pi@raspberrypi4-iob:~ $ which nodejs && nodejs -v && which node && node -v && wh                                   ich npm && npm -v && apt policy nodejs
      /usr/bin/nodejs
      v10.24.0
      /usr/bin/node
      v10.24.0
      /usr/bin/npm
      6.14.11
      nodejs:
        Installiert:           10.24.0-1nodesource1
        Installationskandidat: 10.24.0-1nodesource1
        Versionstabelle:
       *** 10.24.0-1nodesource1 500
              500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
              100 /var/lib/dpkg/status
           10.24.0~dfsg-1~deb10u1 500
      pi@raspberrypi4-iob:~ $ iobroker list adapters
       Cannot find view "system" for search "host"
      system.adapter.admin                   : admin          - v4.1.13
      pi@raspberrypi4-iob:~ $ dmesg
      [    0.000000] Booting Linux on physical CPU 0x0
      [    0.000000] Linux version 5.4.72-v7l+ (dom@buildbot) (gcc version 9.3.0 (Ubun                                   tu 9.3.0-17ubuntu1~20.04)) #1356 SMP Thu Oct 22 13:57:51 BST 2020
      [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
      [    0.000000] CPU: div instructions available: patching division code
      [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
      [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
      [    0.000000] Memory policy: Data cache writealloc
      [    0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, s                                   ize 256 MiB
      [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id share                                   d-dma-pool
      [    0.000000] On node 0 totalpages: 1012736
      [    0.000000]   DMA zone: 2304 pages used for memmap
      [    0.000000]   DMA zone: 0 pages reserved
      [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
      [    0.000000]   HighMem zone: 816128 pages, LIFO batch:63
      [    0.000000] percpu: Embedded 20 pages/cpu s49804 r8192 d23924 u81920
      [    0.000000] pcpu-alloc: s49804 r8192 d23924 u81920 alloc=20*4096
      [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
      [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1010432
      [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835                                   .enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1                                     smsc95xx.macaddr=DC:A6:32:19:03:5B vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0                                   x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=                                   6d49409f-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
      [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes,                                    linear)
      [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, li                                   near)
      [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
      [    0.000000] software IO TLB: mapped [mem 0x17cc0000-0x1bcc0000] (64MB)
      [    0.000000] Memory: 3655596K/4050944K available (10240K kernel code, 745K rwd                                   ata, 2836K rodata, 2048K init, 856K bss, 133204K reserved, 262144K cma-reserved,                                    3264512K highmem)
      [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
      [    0.000000] ftrace: allocating 31086 entries in 61 pages
      [    0.000000] rcu: Hierarchical RCU implementation.
      [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jif                                   fies.
      [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
      [    0.000000] GIC: Using split EOI/Deactivate mode
      [    0.000000] random: get_random_bytes called from start_kernel+0x338/0x520 wit                                   h crng_init=0
      [    0.000007] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2                                   147483647500ns
      [    0.000030] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_                                   idle_ns: 1911260446275 ns
      [    0.000110] bcm2835: system timer (irq = 17)
      [    0.000754] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
      [    0.000773] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles:                                    0xc743ce346, max_idle_ns: 440795203123 ns
      [    0.000792] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 43980                                   46511102ns
      [    0.000808] Switching to timer-based delay loop, resolution 18ns
      [    0.001043] Console: colour dummy device 80x30
      [    0.001547] printk: console [tty1] enabled
      [    0.001610] Calibrating delay loop (skipped), value calculated using timer fr                                   equency.. 108.00 BogoMIPS (lpj=540000)
      [    0.001652] pid_max: default: 32768 minimum: 301
      [    0.001813] LSM: Security Framework initializing
      [    0.002016] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linea                                   r)
      [    0.002058] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes,                                    linear)
      [    0.003327] Disabling memory control group subsystem
      [    0.003467] CPU: Testing write buffer coherency: ok
      [    0.003984] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [    0.004909] Setting up static identity map for 0x200000 - 0x20003c
      [    0.005135] rcu: Hierarchical SRCU implementation.
      [    0.005829] smp: Bringing up secondary CPUs ...
      [    0.007030] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [    0.008346] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
      [    0.009603] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
      [    0.009760] smp: Brought up 1 node, 4 CPUs
      [    0.009833] SMP: Total of 4 processors activated (432.00 BogoMIPS).
      [    0.009859] CPU: All CPU(s) started in HYP mode.
      [    0.009883] CPU: Virtualization extensions available.
      [    0.010746] devtmpfs: initialized
      [    0.024222] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8                                    rev 0
      [    0.024492] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma                                   x_idle_ns: 19112604462750000 ns
      [    0.024543] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
      [    0.031259] pinctrl core: initialized pinctrl subsystem
      [    0.032285] NET: Registered protocol family 16
      [    0.036189] DMA: preallocated 1024 KiB pool for atomic coherent allocations
      [    0.036783] audit: initializing netlink subsys (disabled)
      [    0.037049] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=                                   0 res=1
      [    0.038153] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint                                    registers.
      [    0.038189] hw-breakpoint: maximum watchpoint size is 8 bytes.
      [    0.038523] Serial: AMBA PL011 UART driver
      [    0.042057] bcm2835-mbox fe00b880.mailbox: mailbox enabled
      [    0.060830] raspberrypi-firmware soc:firmware: Attached to firmware from 2020                                   -10-22 13:59, variant start
      [    0.070845] raspberrypi-firmware soc:firmware: Firmware hash is 74e754ff8947c                                   58d2773253f77f6f68a303188f8
      [    0.126259] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
      [    0.131377] vgaarb: loaded
      [    0.131857] SCSI subsystem initialized
      [    0.132093] usbcore: registered new interface driver usbfs
      [    0.132166] usbcore: registered new interface driver hub
      [    0.132313] usbcore: registered new device driver usb
      [    0.132665] usb_phy_generic phy: phy supply vcc not found, using dummy regula                                   tor
      [    0.134512] clocksource: Switched to clocksource arch_sys_counter
      [    0.841815] VFS: Disk quotas dquot_6.6.0
      [    0.841940] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
      [    0.842156] FS-Cache: Loaded
      [    0.842375] CacheFiles: Loaded
      [    0.852675] thermal_sys: Registered thermal governor 'step_wise'
      [    0.853043] NET: Registered protocol family 2
      [    0.853811] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144                                    bytes, linear)
      [    0.853864] TCP established hash table entries: 8192 (order: 3, 32768 bytes,                                    linear)
      [    0.853940] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
      [    0.854021] TCP: Hash tables configured (established 8192 bind 8192)
      [    0.854183] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
      [    0.854236] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
      [    0.854690] NET: Registered protocol family 1
      [    0.855585] RPC: Registered named UNIX socket transport module.
      [    0.855615] RPC: Registered udp transport module.
      [    0.855641] RPC: Registered tcp transport module.
      [    0.855666] RPC: Registered tcp NFSv4.1 backchannel transport module.
      [    0.855701] PCI: CLS 0 bytes, default 64
      [    0.857598] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counte                                   rs available
      [    0.859798] Initialise system trusted keyrings
      [    0.860057] workingset: timestamp_bits=14 max_order=20 bucket_order=6
      [    0.870957] FS-Cache: Netfs 'nfs' registered for caching
      [    0.871706] NFS: Registering the id_resolver key type
      [    0.871753] Key type id_resolver registered
      [    0.871780] Key type id_legacy registered
      [    0.871815] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
      [    0.872910] Key type asymmetric registered
      [    0.872940] Asymmetric key parser 'x509' registered
      [    0.873147] bounce: pool size: 64 pages
      [    0.873201] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2                                   49)
      [    0.873453] io scheduler mq-deadline registered
      [    0.873482] io scheduler kyber registered
      [    0.877537] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
      [    0.877581] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500                                   000, using [bus 00-ff]
      [    0.877686] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x0603ffffff -> 0                                   x00f8000000
      [    0.877778] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0                                   x0000000000
      [    0.936659] brcm-pcie fd500000.pcie: link up, 5 GT/s x1 (SSC)
      [    0.936992] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
      [    0.937027] pci_bus 0000:00: root bus resource [bus 00-ff]
      [    0.937062] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff]                                    (bus address [0xf8000000-0xfbffffff])
      [    0.937142] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
      [    0.937428] pci 0000:00:00.0: PME# supported from D0 D3hot
      [    0.940704] PCI: bus0: Fast back to back transfers disabled
      [    0.940743] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), rec                                   onfiguring
      [    0.940986] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
      [    0.941087] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
      [    0.941365] pci 0000:01:00.0: PME# supported from D0 D3cold
      [    0.944569] PCI: bus1: Fast back to back transfers disabled
      [    0.944604] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
      [    0.944659] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
      [    0.944697] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64                                   bit]
      [    0.944757] pci 0000:00:00.0: PCI bridge to [bus 01]
      [    0.944795] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
      [    0.945126] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
      [    0.945384] pcieport 0000:00:00.0: PME: Signaling with IRQ 55
      [    0.945804] pcieport 0000:00:00.0: AER: enabled with IRQ 55
      [    0.946133] pci 0000:01:00.0: enabling device (0140 -> 0142)
      [    0.953011] iproc-rng200 fe104000.rng: hwrng registered
      [    0.953362] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000                                   000(1024 MiB)
      [    0.954026] vc-sm: Videocore shared memory driver
      [    0.954673] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe2                                   00000
      [    0.966840] brd: module loaded
      [    0.979176] loop: module loaded
      [    0.980608] Loading iSCSI transport class v2.0-870.
      [    0.982594] libphy: Fixed MDIO Bus: probed
      [    0.983243] bcmgenet fd580000.ethernet: failed to get enet clock
      [    0.983279] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
      [    0.983317] bcmgenet fd580000.ethernet: failed to get enet-wol clock
      [    0.983354] bcmgenet fd580000.ethernet: failed to get enet-eee clock
      [    0.983396] bcmgenet: Skipping UMAC reset
      [    0.994554] libphy: bcmgenet MII bus: probed
      [    1.074646] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
      [    1.075679] usbcore: registered new interface driver r8152
      [    1.075761] usbcore: registered new interface driver lan78xx
      [    1.075833] usbcore: registered new interface driver smsc95xx
      [    1.076197] xhci_hcd 0000:01:00.0: xHCI Host Controller
      [    1.076246] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus numbe                                   r 1
      [    1.078708] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 qu                                   irks 0x0000001000000890
      [    1.079683] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bc                                   dDevice= 5.04
      [    1.079723] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=                                   1
      [    1.079758] usb usb1: Product: xHCI Host Controller
      [    1.079787] usb usb1: Manufacturer: Linux 5.4.72-v7l+ xhci-hcd
      [    1.079816] usb usb1: SerialNumber: 0000:01:00.0
      [    1.080442] hub 1-0:1.0: USB hub found
      [    1.080537] hub 1-0:1.0: 1 port detected
      [    1.081067] xhci_hcd 0000:01:00.0: xHCI Host Controller
      [    1.081108] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus numbe                                   r 2
      [    1.081150] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
      [    1.081626] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bc                                   dDevice= 5.04
      [    1.081664] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=                                   1
      [    1.081698] usb usb2: Product: xHCI Host Controller
      [    1.081726] usb usb2: Manufacturer: Linux 5.4.72-v7l+ xhci-hcd
      [    1.081756] usb usb2: SerialNumber: 0000:01:00.0
      [    1.082357] hub 2-0:1.0: USB hub found
      [    1.082454] hub 2-0:1.0: 4 ports detected
      [    1.083891] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
      [    1.084198] dwc_otg: FIQ enabled
      [    1.084210] dwc_otg: NAK holdoff enabled
      [    1.084223] dwc_otg: FIQ split-transaction FSM enabled
      [    1.084238] Module dwc_common_port init
      [    1.084740] usbcore: registered new interface driver uas
      [    1.084864] usbcore: registered new interface driver usb-storage
      [    1.085076] mousedev: PS/2 mouse device common for all mice
      [    1.086958] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
      [    1.090404] sdhci: Secure Digital Host Controller Interface driver
      [    1.090435] sdhci: Copyright(c) Pierre Ossman
      [    1.091060] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
      [    1.091644] sdhci-pltfm: SDHCI platform and OF driver helper
      [    1.095486] ledtrig-cpu: registered to indicate activity on CPUs
      [    1.095812] hidraw: raw HID events driver (C) Jiri Kosina
      [    1.096026] usbcore: registered new interface driver usbhid
      [    1.096054] usbhid: USB HID core driver
      [    1.097098] vchiq: vchiq_init_state: slot_zero = (ptrval)
      [    1.099042] [vc_sm_connected_init]: start
      [    1.107926] [vc_sm_connected_init]: end - returning 0
      [    1.110167] Initializing XFRM netlink socket
      [    1.110221] NET: Registered protocol family 17
      [    1.110339] Key type dns_resolver registered
      [    1.110740] Registering SWP/SWPB emulation handler
      [    1.111072] registered taskstats version 1
      [    1.111106] Loading compiled-in X.509 certificates
      [    1.111660] Key type ._fscrypt registered
      [    1.111688] Key type .fscrypt registered
      [    1.122454] uart-pl011 fe201000.serial: cts_event_workaround enabled
      [    1.122548] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 29, base_baud                                    = 0) is a PL011 rev2
      [    1.128690] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains drive                                   r
      [    1.129708] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
      [    1.129741] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
      [    1.178783] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
      [    1.180460] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
      [    1.182140] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
      [    1.185120] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
      [    1.186811] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
      [    1.194200] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using A                                   DMA
      [    1.197181] of_cfs_init
      [    1.197461] of_cfs_init: OK
      [    1.198530] Waiting for root device PARTUUID=6d49409f-02...
      [    1.233200] random: fast init done
      [    1.255791] mmc1: new high speed SDIO card at address 0001
      [    1.299997] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
      [    1.300929] mmcblk0: mmc0:aaaa SC32G 29.7 GiB
      [    1.303991]  mmcblk0: p1 p2
      [    1.331105] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O                                   pts: (null)
      [    1.331218] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [    1.344862] devtmpfs: mounted
      [    1.353636] Freeing unused kernel memory: 2048K
      [    1.354829] Run /sbin/init as init process
      [    1.444572] usb 1-1: new high-speed USB device number 2 using xhci_hcd
      [    1.626969] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcd                                   Device= 4.20
      [    1.627014] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
      [    1.627046] usb 1-1: Product: USB2.0 Hub
      [    1.628792] hub 1-1:1.0: USB hub found
      [    1.629094] hub 1-1:1.0: 4 ports detected
      [    1.954574] usb 1-1.3: new full-speed USB device number 3 using xhci_hcd
      [    2.093398] usb 1-1.3: New USB device found, idVendor=0451, idProduct=16a8, b                                   cdDevice= 0.09
      [    2.093442] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber                                   =3
      [    2.093476] usb 1-1.3: Product: TI CC2531 USB CDC
      [    2.093505] usb 1-1.3: Manufacturer: Texas Instruments
      [    2.093533] usb 1-1.3: SerialNumber: __0X00124B001936648E
      [    2.211353] systemd[1]: System time before build time, advancing clock.
      [    2.357422] NET: Registered protocol family 10
      [    2.358759] Segment Routing with IPv6
      [    2.408605] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SEL                                   INUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +                                   XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybr                                   id)
      [    2.409421] systemd[1]: Detected architecture arm.
      [    2.467705] systemd[1]: Set hostname to <raspberrypi4-iob>.
      [    3.399376] random: systemd: uninitialized urandom read (16 bytes read)
      [    3.412900] random: systemd: uninitialized urandom read (16 bytes read)
      [    3.416276] systemd[1]: Created slice system-systemd\x2dfsck.slice.
      [    3.417000] random: systemd: uninitialized urandom read (16 bytes read)
      [    3.417384] systemd[1]: Listening on initctl Compatibility Named Pipe.
      [    3.418745] systemd[1]: Listening on Journal Audit Socket.
      [    3.420419] systemd[1]: Created slice User and Session Slice.
      [    3.421541] systemd[1]: Listening on Journal Socket (/dev/log).
      [    3.422725] systemd[1]: Listening on Journal Socket.
      [    3.428762] systemd[1]: Mounting RPC Pipe File System...
      [    4.176752] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      [    4.309084] systemd-journald[117]: Received request to flush runtime journal                                    from PID 1
      [    5.007129] vc_sm_cma: module is from the staging directory, the quality is u                                   nknown, you have been warned.
      [    5.009237] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
      [    5.009259] [vc_sm_connected_init]: start
      [    5.017306] [vc_sm_connected_init]: installed successfully
      [    5.061918] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Reg                                   isters at 0xfeb00000 length 0x00010000
      [    5.062368] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised                                   : Registers at 0xfeb10000 length 0x00001000
      [    5.062828] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Reg                                   isters at 0xfeb20000 length 0x00010000
      [    5.063316] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Regis                                   ters at 0xfeb30000 length 0x00010000
      [    5.138762] mc: Linux media interface: v0.10
      [    5.150946] snd_bcm2835: module is from the staging directory, the quality is                                    unknown, you have been warned.
      [    5.170754] bcm2835_audio bcm2835_audio: card created with 8 channels
      [    5.287967] videodev: Linux video capture interface: v2.00
      [    5.370621] bcm2835_mmal_vchiq: module is from the staging directory, the qua                                   lity is unknown, you have been warned.
      [    5.370626] bcm2835_mmal_vchiq: module is from the staging directory, the qua                                   lity is unknown, you have been warned.
      [    5.394354] bcm2835_isp: module is from the staging directory, the quality is                                    unknown, you have been warned.
      [    5.405883] bcm2835_codec: module is from the staging directory, the quality                                    is unknown, you have been warned.
      [    5.406364] bcm2835_v4l2: module is from the staging directory, the quality i                                   s unknown, you have been warned.
      [    5.418158] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev                                   /video13
      [    5.418701] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /de                                   v/video14
      [    5.419143] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /de                                   v/video15
      [    5.419516] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/                                   video16
      [    5.419543] bcm2835-isp bcm2835-isp: Register output node 0 with media contro                                   ller
      [    5.419565] bcm2835-isp bcm2835-isp: Register capture node 1 with media contr                                   oller
      [    5.419591] bcm2835-isp bcm2835-isp: Register capture node 2 with media contr                                   oller
      [    5.419621] bcm2835-isp bcm2835-isp: Register capture node 3 with media contr                                   oller
      [    5.419878] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
      [    5.437539] cfg80211: Loading compiled-in X.509 certificates for regulatory d                                   atabase
      [    5.442331] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
      [    5.442397] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
      [    5.453346] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
      [    5.453394] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
      [    5.470957] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
      [    5.470999] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
      [    5.491291] [drm] No displays found. Consider forcing hotplug if HDMI is atta                                   ched
      [    5.491407] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
      [    5.491428] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
      [    5.491441] [drm] No driver support for vblank timestamp query.
      [    5.491453] [drm] Setting vblank_disable_immediate to false because get_vblan                                   k_timestamp == NULL
      [    5.495207] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
      [    5.510696] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
      [    5.562994] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      [    5.628134] brcmfmac: F1 signature read @0x18000000=0x15264345
      [    5.643064] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio f                                   or chip BCM4345/6
      [    5.644022] usbcore: registered new interface driver brcmfmac
      [    5.670980] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455                                   -sdio.raspberrypi,4-model-b.txt failed with error -2
      [    5.753938] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
      [    5.759007] usbcore: registered new interface driver cdc_acm
      [    5.759023] cdc_acm: USB Abstract Control Model driver for USB modems and ISD                                   N adapters
      [    5.917215] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio f                                   or chip BCM4345/6
      [    5.932604] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 23                                    2020 02:19:54 version 7.45.206 (r725000 CY) FWID 01-88ee44ea
      [    7.850982] uart-pl011 fe201000.serial: no DMA platform data
      [    7.869209] random: crng init done
      [    7.869226] random: 7 urandom warning(s) missed due to ratelimiting
      [    8.037420] 8021q: 802.1Q VLAN Support v1.8
      [    8.294560] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:1                                   02396k SSFS
      [    8.316946] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
      [    8.575027] bcmgenet: Skipping UMAC reset
      [    8.576582] bcmgenet fd580000.ethernet: configuring instance for external RGM                                   II
      [    8.576790] bcmgenet fd580000.ethernet eth0: Link is Down
      [   13.754779] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow c                                   ontrol rx/tx
      [   13.754830] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
      [   14.750114] Bluetooth: Core ver 2.22
      [   14.750202] NET: Registered protocol family 31
      [   14.750216] Bluetooth: HCI device and connection manager initialized
      [   14.750537] Bluetooth: HCI socket layer initialized
      [   14.750557] Bluetooth: L2CAP socket layer initialized
      [   14.750590] Bluetooth: SCO socket layer initialized
      [   14.762805] Bluetooth: HCI UART driver ver 2.3
      [   14.762824] Bluetooth: HCI UART protocol H4 registered
      [   14.762948] Bluetooth: HCI UART protocol Three-wire (H5) registered
      [   14.766955] Bluetooth: HCI UART protocol Broadcom registered
      [   15.033764] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
      [   15.033771] Bluetooth: BNEP filters: protocol multicast
      [   15.033784] Bluetooth: BNEP socket layer initialized
      [   15.038098] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net                                   .ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
      [ 2045.501499] printk: systemd: 37 output lines suppressed due to ratelimiting
      [ 2045.522694] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SEL                                   INUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +                                   XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybr                                   id)
      [ 2045.523012] systemd[1]: Detected architecture arm.
      [ 2046.092216] systemd-journald[117]: Received SIGTERM from PID 1 (systemd).
      [ 2046.095875] systemd[1]: Stopping Journal Service...
      [ 2046.097391] systemd[1]: systemd-journald.service: Succeeded.
      [ 2046.098454] systemd[1]: Stopped Journal Service.
      [ 2046.104672] systemd[1]: Starting Journal Service...
      [ 2046.139706] systemd[1]: Started Journal Service.
      [ 2230.288949] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:1                                   02396k SSFS
      pi@raspberrypi4-iob:/opt/iobroker $ iobroker fix
      library: loaded
      Library version=2021-01-23
          Welcome to the ioBroker installation fixer!
          Script version: 2020-12-07
          You might need to enter your password a couple of times.
          Installing prerequisites (1/3)
      OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
      OK:2 http://archive.raspberrypi.org/debian buster InRelease
      OK:3 https://deb.nodesource.com/node_10.x buster InRelease
      Installed gcc-c++
          Checking ioBroker user and directory permissions (2/3)
      Created /etc/sudoers.d/iobroker
          Checking autostart (3/3)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      auch nach einem abschließenden Reboot hat das nix gebracht
      • wendy2702
        wendy2702 @Prince3k last edited by
        @prince3k Kleinen Fehler gemacht beim installieren JS Controller:
        so wäre richtig
        cd /opt/iobroker
          Prince3k @wendy2702 last edited by
          @wendy2702 said in IoBroker down - Cannot read system:
          so wäre richtig
          cd /opt/iobroker
          auch hiernach kommt immer die selbe Fehlermeldung:
          pi@raspberrypi4-iob:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
          npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
          > iobroker.js-controller@3.2.16 preinstall /opt/iobroker/node_modules/iobroker.js-controller
          > node lib/preinstallCheck.js
          NPM version: 6.14.11
          > iobroker.js-controller@3.2.16 install /opt/iobroker/node_modules/iobroker.js-controller
          > node iobroker.js setup first
          object 0_userdata.0.example_state created
          object 0_userdata.0 created
          object alias.0 created
          object system.certificates created
          object system.repositories created
          object system.config created
          object enum.functions created
          object enum.rooms created
          object system.group.user created
          object system.group.administrator created
          object _design/system created
          Renamed repository "default to "stable"
          Renamed repository "latest to "beta"
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
          + iobroker.js-controller@3.2.16
          added 1 package from 1 contributor and updated 12 packages in 46.366s
          22 packages are looking for funding
            run `npm fund` for details
          mikeal created this issue in request/request
          open Request’s Past, Present and Future #3142
          • wendy2702
            @prince3k
              @wendy2702
              pi@raspberrypi4-iob:/opt/iobroker $ iobroker list instances
              + instance is alive
              pi@raspberrypi4-iob:/opt/iobroker $ iobroker list adapters
              • wendy2702
                wendy2702 @Prince3k last edited by wendy2702
                @prince3k Ich hoffe für dich das du ein Backup hast.
                Wie es aussieht ist dein Installation schlicht und ergreifend weg.
                EDIT: BITTE DAS FILE "package.json" mal hochladen. Liegt in /opt/iobroker/
                wenn du jetzt
                iobroker add admin
                machst, dann
                iobroker start admin
                Wirst du wahrscheinlich nur eine leere Admin Seite sehen.
                Kannst du mal
                ls -la /opt/iobroker/node_modules/
                machen
                P 2 Replies Last reply Reply Quote 0
                  @wendy2702 package.json
                  • wendy2702
                    @prince3k Auch noch bitte den Inhalt von:
                    ls -la /opt/iobroker/iobroker-data/
                      @wendy2702
                      Ich habe mal was mit Backitup auf meiner Google Drive gesichert, aber noch nie wiederhergestellt, schau ich mir gleich mal an, denn du hast Recht. Nachdem ich die Schritte gemacht habe, hatte ich leider eine leere Adminseite.
                      pi@raspberrypi4-iob:/opt/iobroker $ ls -la /opt/iobroker/node_modules/
                      insgesamt 4048
                      drwxrwxrwx+ 999 iobroker iobroker 36864 Mär  2 17:47 .
                      drwxrwxrwx+   9 iobroker iobroker  4096 Mär  2 13:52 ..
                      drwxrwxr-x+   2 iobroker iobroker  4096 Jun  6  2020 abbrev
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 abort-controller
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 accepts
                      drwxrwxr-x+   3 iobroker iobroker  4096 Jan 22 23:02 acme-http-01-standalone
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 after
                      drwxrwxr-x+   4 iobroker iobroker  4096 Mai 16  2020 agent-base
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 ajv
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-bgblack
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-bgblue
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-bgcyan
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-bggreen
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-bgmagenta
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-bgred
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-bgwhite
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-bgyellow
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-black
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-blue
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-bold
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-colors
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-cyan
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-dim
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-gray
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-green
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-grey
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-hidden
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-inverse
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-italic
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-magenta
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-red
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-regex
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-reset
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-strikethrough
                      drwxrwxr-x+   3 iobroker iobroker  4096 Jan  8 19:29 ansi-styles
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-underline
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-white
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-wrap
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ansi-yellow
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt 13  2019 anymatch
                      drwxrwxr-x+   3 iobroker iobroker  4096 Mai 20  2020 @apollon
                      drwxrwxr-x+   4 iobroker iobroker  4096 Feb 22 21:28 append-field
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 aproba
                      drwxrwxr-x+   4 iobroker iobroker  4096 Okt 23  2019 archy
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 are-we-there-yet
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 arraybuffer.slice
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 array-each
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 30  2019 array-ext
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 array-find
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 array-find-index
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 array-flatten
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 array-slice
                      drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 array-sort
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 array-unique
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 arr-diff
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 arr-flatten
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 arrify
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 arr-swap
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 arr-union
                      drwxrwxr-x+   2 iobroker iobroker  4096 Mai 21  2020 asap
                      drwxrwxrwx+   4 iobroker iobroker  4096 Okt  3  2019 ascli
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 asn1
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 assert-plus
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 assign-symbols
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 async
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 asynckit
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 async-limiter
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 async-retry
                      drwxrwxr-x+   2 iobroker iobroker  4096 Dez  5 21:35 at-least-node
                      drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 atob
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 authenticate-pam
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 autobind-decorator
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 aws4
                      drwxrwxrwx+  10 iobroker iobroker  4096 Sep 28  2019 aws-sdk
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 aws-sign2
                      drwxrwxrwx+   5 iobroker iobroker  4096 Okt  2  2019 axios
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 babel
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 backo2
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 balanced-match
                      drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 base
                      drwxrwxr-x+   2 iobroker iobroker  4096 Feb 22 20:58 base-64
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 base64-arraybuffer
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 base64id
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 base64-js
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 basic-auth
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 bcrypt-pbkdf
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 better-assert
                      drwxrwxr-x+   3 iobroker iobroker  4096 Dez  5 21:35 bignumber.js
                      drwxrwxrwx+   2 iobroker iobroker  4096 Mär  2 17:47 .bin
                      drwxrwxrwx+   6 iobroker iobroker  4096 Okt  2  2019 binary-data
                      drwxrwxr-x+   2 iobroker iobroker  4096 Jan 22 23:02 binary-extensions
                      drwxrwxr-x+   2 iobroker iobroker  4096 Feb 20  2020 bindings
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 bl
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 blob
                      drwxrwxr-x+   3 iobroker iobroker  4096 Dez 13  2019 bluebird
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 body-parser
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 bottlejs
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 brace-expansion
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt 13  2019 braces
                      drwxrwxr-x+   6 iobroker iobroker  4096 Jan 23 17:04 bring-shopping
                      drwxrwxr-x+   5 iobroker iobroker  4096 Jul 13  2020 buffer
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 buffer-alloc
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 buffer-alloc-unsafe
                      drwxrwxr-x+   2 iobroker iobroker  4096 Dez  2 19:06 buffer-crc32
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 buffer-equal-constant-time
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 buffer-fill
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 buffer-from
                      drwxrwxr-x+   6 iobroker iobroker  4096 Dez  5 21:38 bufferutil
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 buffer-xor
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 busboy
                      drwxrwxrwx+   8 iobroker iobroker  4096 Okt  3  2019 bytebuffer
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 bytes
                      drwxrwxr-x+   3 iobroker iobroker  4096 Feb  3 22:08 cacheable-lookup
                      drwxrwxrwx+   4 iobroker iobroker  4096 Okt  2  2019 cacheable-request
                      drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 cache-base
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 callback-stream
                      drwxrwxr-x+   4 iobroker iobroker  4096 Feb 22 20:58 call-bind
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 callsite
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 camelcase
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt  2  2019 camelcase-keys
                      drwxrwxr-x+   8 iobroker iobroker  4096 Jun  6  2020 canvas
                      drwxrwxr-x+   3 iobroker iobroker  4096 Jul 13  2020 capitalize
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 caseless
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 castv2
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 castv2-client
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 castv2-player
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 cert-info
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 charenc
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 choices-separator
                      drwxrwxr-x+   5 iobroker iobroker  4096 Jan 22 23:02 chokidar
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 chownr
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 circular-json
                      drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 class-utils
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 cli
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 cliui
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 clone-deep
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 cloneextend
                      drwxrwxrwx+   4 iobroker iobroker  4096 Mai 20  2020 clone-response
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt 13  2019 cluster-key-slot
                      drwxrwxr-x+   6 iobroker iobroker  4096 Jul 13  2020 coap
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 coap-packet
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 code-point-at
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 coffee-compiler
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 coffee-script
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 collection-visit
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt 13  2019 color
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 color-convert
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 color-name
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 colors
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt 13  2019 colorspace
                      drwxrwxr-x+   2 iobroker iobroker  4096 Jan 22 23:02 color-string
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 color-support
                      drwxrwxrwx+   5 iobroker iobroker  4096 Okt  3  2019 colour
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 combined-stream
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 commander
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 commist
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 component-bind
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 component-emitter
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 component-inherit
                      drwxrwxr-x+   4 iobroker iobroker  4096 Feb 22 21:28 compose-middleware
                      drwxrwxr-x+   3 iobroker iobroker  4096 Feb 22 21:28 compressible
                      drwxrwxr-x+   3 iobroker iobroker  4096 Feb 22 21:28 compression
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 concat-map
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 concat-stream
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 connect
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 connect-flash
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 console-control-strings
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 content-disposition
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 content-type
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 cookie
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 cookie-parser
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 cookie-signature
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 copy-descriptor
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 copy-props
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 core-util-is
                      drwxrwxr-x+   4 iobroker iobroker  4096 Feb 22 21:28 crc
                      drwxrwxrwx+   5 iobroker iobroker  4096 Okt  3  2019 cron
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 cron-parser
                      drwxrwxr-x+   4 iobroker iobroker  4096 Mai 20  2020 cross-spawn
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 crypt
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 crypto-js
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 currently-unhandled
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 cycle
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 d
                      drwxrwxr-x+   3 iobroker iobroker  4096 Jul  7  2020 @dabh
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 daemonize2
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 dashdash
                      drwxrwxr-x+   2 iobroker iobroker  4096 Dez  2 19:06 debounce
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 debug
                      drwxrwxr-x+   4 iobroker iobroker  4096 Mai 16  2020 decache
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 decamelize
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt  2  2019 decamelize-keys
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 decode-uri-component
                      drwxrwxr-x+   2 iobroker iobroker  4096 Mai 20  2020 decompress-response
                      drwxrwxr-x+   3 iobroker iobroker  4096 Mai 16  2020 deep-clone
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 deep-equal
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 deep-extend
                      drwxrwxrwx+   4 iobroker iobroker  4096 Okt  3  2019 deep-is
                      drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 default-compare
                      drwxrwxr-x+   2 iobroker iobroker  4096 Mai 20  2020 default-gateway
                      drwxrwxr-x+   3 iobroker iobroker  4096 Mai 20  2020 defer-to-connect
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 define-properties
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 define-property
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 delayed-stream
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 delegates
                      drwxrwxr-x+   2 iobroker iobroker  4096 Jan 22 23:02 denque
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 depd
                      drwxrwxr-x+   3 iobroker iobroker  4096 Feb 22 21:28 @destinationstransfers
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 destroy
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 detect-file
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 detect-libc
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 dev-null
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 dgram
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 dicer
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 dijkstrajs
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 diskusage
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 dns-packet
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt  2  2019 dns-socket
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 doorbot
                      drwxrwxr-x+   4 iobroker iobroker  4096 Mai 20  2020 dotenv
                      drwxrwxr-x+   6 iobroker iobroker  4096 Feb 22 20:58 dropbox-v2-api
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 duplexer
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 duplexer3
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 duplexify
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 each-props
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 ecc-jsbn
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 ecdsa-sig-formatter
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 eckles
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ee-first
                      drwxrwxr-x+   3 iobroker iobroker  4096 Dez  5 21:57 emoji-regex
                      drwxrwxr-x+   2 iobroker iobroker  4096 Jul  7  2020 enabled
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 encodeurl
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 end-of-stream
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 engine.io
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 engine.io-client
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 engine.io-parser
                      drwxrwxrwx+   4 iobroker iobroker  4096 Okt  3  2019 ent
                      drwxrwxrwx+   7 iobroker iobroker  4096 Sep 28  2019 epoll
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 error-ex
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 error-symbol
                      drwxrwxrwx+  17 iobroker iobroker  4096 Sep 28  2019 es5-ext
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 es6-iterator
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 es6-map
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 es6-promise
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 es6-promisify
                      drwxrwxrwx+   7 iobroker iobroker  4096 Sep 28  2019 es6-set
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 es6-symbol
                      drwxrwxr-x+   4 iobroker iobroker  4096 Dez  5 21:57 escalade
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 escape-html
                      drwxrwxrwx+   4 iobroker iobroker  4096 Okt  3  2019 escodegen
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt  2  2019 esm
                      drwxrwxrwx+   4 iobroker iobroker  4096 Okt  3  2019 esprima
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  3  2019 estraverse
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt  3  2019 esutils
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 etag
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 event-emitter
                      drwxrwxr-x+   3 iobroker iobroker  4096 Dez  5 21:57 eventemitter3
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 events
                      drwxrwxrwx+   4 iobroker iobroker  4096 Okt 13  2019 event-stream
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 event-target-shim
                      drwxrwxr-x+   4 iobroker iobroker  4096 Mai 20  2020 execa
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 exit
                      drwxrwxr-x+   4 iobroker iobroker  4096 Okt 23  2019 expand-brackets
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 expand-template
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 expand-tilde
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 express
                      drwxrwxr-x+   3 iobroker iobroker  4096 Feb 22 21:28 express-basic-auth
                      drwxrwxr-x+   4 iobroker iobroker  4096 Feb 22 21:28 express-dynamic-middleware
                      drwxrwxr-x+   4 iobroker iobroker  4096 Feb 22 21:28 expresse
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 express-fileupload
                      drwxrwxr-x+   3 iobroker iobroker  4096 Feb 22 21:28 express-list-endpoints
                      drwxrwxr-x+   3 iobroker iobroker  4096 Feb 22 21:28 express-rate-limit
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 express-session
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 extend
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 extend-shallow
                      drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 extglob
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 extsprintf
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 eyes
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 fancy-log
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 fast-deep-equal
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 fast-json-stable-stringify
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  3  2019 fast-levenshtein
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt 13  2019 fast-safe-stringify
                      drwxrwxr-x+   3 iobroker iobroker  4096 Jul 13  2020 fastseries
                      drwxrwxr-x+   2 iobroker iobroker  4096 Dez  5 21:35 fast-text-encoding
                      drwxrwxr-x+   3 iobroker iobroker  4096 Feb 22 20:58 fast-xml-parser
                      drwxrwxr-x+   4 iobroker iobroker  4096 Jul  7  2020 fecha
                      drwxrwxr-x+   3 iobroker iobroker  4096 Mai 20  2020 ffmpeg-for-homebridge
                      drwxrwxr-x+   3 iobroker iobroker  4096 Feb 20  2020 file-stream-rotator
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 file-uri-to-path
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt 13  2019 fill-range
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 finalhandler
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 find-up
                      drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 findup-sync
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 fined
                      drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 flagged-respawn
                      drwxrwxr-x+   2 iobroker iobroker  4096 Jul  7  2020 fn.name
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 follow-redirects
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 forever-agent
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 for-in
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 form-data
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 for-own
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 forwarded
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 fragment-cache
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 fresh
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt 13  2019 from
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 fs-constants
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 fs-extra
                      drwxrwxr-x+   2 iobroker iobroker  4096 Feb 20  2020 fs-minipass
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 fs.realpath
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 ftp
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ftp-response-parser
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 function-bind
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 gauge
                      drwxrwxr-x+   3 iobroker iobroker  4096 Feb 22 20:58 gaxios
                      drwxrwxr-x+   3 iobroker iobroker  4096 Dez  5 21:35 gcp-metadata
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 generate-function
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 get-caller-file
                      drwxrwxr-x+   4 iobroker iobroker  4096 Feb 22 20:58 get-intrinsic
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 getpass
                      drwxrwxr-x+   2 iobroker iobroker  4096 Mai 20  2020 get-port
                      drwxrwxrwx+   2 iobroker iobroker  4096 Dez 25  2019 get-stream
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 get-value
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 github-from-package
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 glob
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 global-modules
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 global-prefix
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 glob-parent
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 glob-stream
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 glogg
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 glossy
                      drwxrwxr-x+   3 iobroker iobroker  4096 Feb 22 20:59 googleapis
                      drwxrwxr-x+   4 iobroker iobroker  4096 Feb 22 20:58 googleapis-common
                      drwxrwxr-x+   4 iobroker iobroker  4096 Feb 22 20:59 google-auth-library
                      drwxrwxrwx+   6 iobroker iobroker  4096 Okt  3  2019 @google-cloud
                      drwxrwxrwx+   4 iobroker iobroker  4096 Okt  3  2019 google-gax
                      drwxrwxr-x+   3 iobroker iobroker  4096 Feb 22 20:58 google-p12-pem
                      drwxrwxrwx+   4 iobroker iobroker  4096 Okt  3  2019 google-proto-files
                      drwxrwxrwx+   4 iobroker iobroker  4096 Okt  2  2019 got
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 graceful-fs
                      drwxrwxr-x+   3 iobroker iobroker  4096 Jan 22 23:02 @greenlock
                      drwxrwxr-x+   2 iobroker iobroker  4096 Jan 22 23:02 greenlock
                      drwxrwxr-x+   2 iobroker iobroker  4096 Jan 22 23:02 greenlock-express
                      drwxrwxr-x+   2 iobroker iobroker  4096 Jan 22 23:02 greenlock-manager-fs
                      drwxrwxr-x+   2 iobroker iobroker  4096 Nov  6  2019 greenlock-store-fs
                      drwxrwxrwx+   4 iobroker iobroker  4096 Okt  3  2019 @grpc
                      drwxrwxrwx+   6 iobroker iobroker  4096 Okt  3  2019 grpc
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt  3  2019 grpc-gcp
                      drwxrwxr-x+   4 iobroker iobroker  4096 Feb 22 20:58 gtoken
                      drwxrwxr-x+   6 iobroker iobroker  4096 Okt 23  2019 gulp-cli
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 gulplog
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 @harmonyhub
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 harmonyhubws
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 har-schema
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 har-validator
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 has
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 has-binary
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 has-binary2
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 has-cors
                      drwxrwxr-x+   4 iobroker iobroker  4096 Feb 22 20:58 has-symbols
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 has-unicode
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 has-value
                      drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 has-values
                      drwxrwxr-x+   4 iobroker iobroker  4096 Feb 22 20:58 he
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 help-me
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 hoek
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 homedir-polyfill
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 hosted-git-info
                      drwxrwxr-x+   4 iobroker iobroker  4096 Feb 22 20:58 hot-patcher
                      drwxrwxr-x+   4 iobroker iobroker  4096 Feb  3 22:08 http2-wrapper
                      drwxrwxr-x+   2 iobroker iobroker  4096 Mai 20  2020 http-cache-semantics
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 http-errors
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 http-headers
                      drwxrwxr-x+   7 iobroker iobroker  4096 Dez  5 21:57 http-mitm-proxy
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 http-signature
                      drwxrwxr-x+   4 iobroker iobroker  4096 Mai 16  2020 https-proxy-agent
                      drwxrwxr-x+   3 iobroker iobroker  4096 Dez 25  2019 human-signals
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 i
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 iconv-lite
                      drwxrwxrwx+   6 iobroker iobroker  4096 Sep 28  2019 icy
                      drwxrwxr-x+   2 iobroker iobroker  4096 Dez 13  2019 ieee754
                      drwxrwxr-x+   2 iobroker iobroker  4096 Jun  6  2020 ignore-walk
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 immediate
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 indent-string
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 indexof
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 inflight
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 info-symbol
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 inherits
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ini
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 interpret
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 invert-kv
                      drwxrwxrwx+  10 iobroker iobroker  4096 Feb 12 18:34 @iobroker
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 iobroker
                      drwxrwxr-x+   8 iobroker iobroker  4096 Jan  8 21:51 iobroker.admin
                      drwxrwxr-x+   7 iobroker iobroker  4096 Feb 22 20:59 iobroker.backitup
                      drwxrwxr-x+   7 iobroker iobroker  4096 Jan 23 17:04 iobroker.bring
                      drwxrwxr-x+   7 iobroker iobroker  4096 Okt 23  2019 iobroker.chromecast
                      drwxrwxr-x+   7 iobroker iobroker  4096 Jan  8 19:27 iobroker.cloud
                      drwxrwxr-x+   6 iobroker iobroker  4096 Jan 23 17:05 iobroker.denon
                      drwxrwxr-x+   5 iobroker iobroker  4096 Jan 23 17:09 iobroker.discovery
                      drwxrwxr-x+   6 iobroker iobroker  4096 Jan 23 17:11 iobroker.dwd
                      drwxrwxr-x+   5 iobroker iobroker  4096 Mai 20  2020 iobroker.feiertage
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 iobroker.fritzbox
                      drwxrwxr-x+   7 iobroker iobroker  4096 Jan  8 18:32 iobroker.fritzdect
                      drwxrwxr-x+   6 iobroker iobroker  4096 Jan 23 17:10 iobroker.fronius
                      drwxrwxrwx+   6 iobroker iobroker  4096 Okt  3  2019 iobroker.gardena
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 iobroker.harmony
                      drwxrwxr-x+   8 iobroker iobroker  4096 Feb 22 21:49 iobroker.history
                      drwxrwxr-x+   5 iobroker iobroker  4096 Jan 22 23:59 iobroker.ical
                      drwxrwxr-x+   7 iobroker iobroker  4096 Jul 13  2020 iobroker.info
                      drwxrwxr-x+   8 iobroker iobroker  4096 Jan 11 21:04 iobroker.iqontrol
                      drwxrwxr-x+   7 iobroker iobroker  4096 Jan 23 01:00 iobroker.javascript
                      drwxrwxr-x+   6 iobroker iobroker  4096 Mär  2 18:50 iobroker.js-controller
                      drwxrwxr-x+   5 iobroker iobroker  4096 Dez  5 21:38 iobroker.lgtv
                      drwxrwxr-x+   7 iobroker iobroker  4096 Feb  9 21:58 iobroker.mihome
                      drwxrwxr-x+   6 iobroker iobroker  4096 Feb 22 21:09 iobroker.mihome-vacuum
                      drwxrwxr-x+   7 iobroker iobroker  4096 Jan 23 01:02 iobroker.mobile
                      drwxrwxr-x+   6 iobroker iobroker  4096 Mai 20  2020 iobroker.moma
                      drwxrwxr-x+   7 iobroker iobroker  4096 Jul 13  2020 iobroker.mqtt
                      drwxrwxr-x+   6 iobroker iobroker  4096 Mai 20  2020 iobroker.mqtt-client
                      drwxrwxr-x+   8 iobroker iobroker  4096 Feb  3 22:08 iobroker.nuki-extended
                      drwxrwxr-x+   5 iobroker iobroker  4096 Jul 12  2020 iobroker.ping
                      drwxrwxr-x+   5 iobroker iobroker  4096 Mai 20  2020 iobroker.pushover
                      drwxrwxr-x+   9 iobroker iobroker  4096 Jul 12  2020 iobroker.ring
                      drwxrwxr-x+   6 iobroker iobroker  4096 Mai 20  2020 iobroker.rpi2
                      drwxrwxr-x+   9 iobroker iobroker  4096 Jan  8 18:30 iobroker.sayit
                      drwxrwxr-x+   5 iobroker iobroker  4096 Jan 23 16:54 iobroker.schoolfree
                      drwxrwxr-x+   8 iobroker iobroker  4096 Feb 22 21:11 iobroker.shelly
                      drwxrwxr-x+   6 iobroker iobroker  4096 Jan 23 17:12 iobroker.shuttercontrol
                      drwxrwxr-x+   6 iobroker iobroker  4096 Jul 13  2020 iobroker.simple-api
                      drwxrwxr-x+   5 iobroker iobroker  4096 Jul 13  2020 iobroker.socketio
                      drwxrwxr-x+   5 iobroker iobroker  4096 Dez 13  2019 iobroker.sonoff
                      drwxrwxr-x+   6 iobroker iobroker  4096 Jan  8 19:29 iobroker.statistics
                      drwxrwxr-x+   6 iobroker iobroker  4096 Mai 20  2020 iobroker.tankerkoenig
                      drwxrwxrwx+   7 iobroker iobroker  4096 Sep 28  2019 iobroker.terminal
                      drwxrwxr-x+   6 iobroker iobroker  4096 Jan 23 16:58 iobroker.tesla-motors
                      drwxrwxr-x+   6 iobroker iobroker  4096 Feb  9 22:00 iobroker.tuya
                      drwxrwxr-x+   8 iobroker iobroker  4096 Jan 23 17:00 iobroker.vis
                      drwxrwxr-x+   7 iobroker iobroker  4096 Dez 12  2019 iobroker.vis-bars
                      drwxrwxr-x+   7 iobroker iobroker  4096 Dez  5 21:42 iobroker.vis-hqwidgets
                      drwxrwxr-x+   7 iobroker iobroker  4096 Jan  8 19:47 iobroker.vis-map
                      drwxrwxr-x+   7 iobroker iobroker  4096 Dez 12  2019 iobroker.vis-material
                      drwxrwxr-x+   7 iobroker iobroker  4096 Dez 12  2019 iobroker.vis-metro
                      drwxrwxr-x+   5 iobroker iobroker  4096 Jan 23 17:02 iobroker.web
                      drwxrwxr-x+   7 iobroker iobroker  4096 Mai 20  2020 iobroker.wifilight
                      drwxrwxrwx+   5 iobroker iobroker  4096 Okt  6  2019 iobroker.wlanthermo-nano
                      drwxrwxr-x+   7 iobroker iobroker  4096 Dez 13  2019 iobroker.yeelight-2
                      drwxrwxr-x+  10 iobroker iobroker  4096 Feb 26 22:19 iobroker.zigbee
                      drwxrwxr-x+   4 iobroker iobroker  4096 Mär  2 17:47 ioredis
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 ip
                      drwxrwxrwx+   5 iobroker iobroker  4096 Okt  2  2019 ip2buf
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 ipaddr.js
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 ip-regex
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 is
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 is-absolute
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 is-accessor-descriptor
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 isarray
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 is-arrayish
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt 13  2019 is-binary-path
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 is-buffer
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 is-data-descriptor
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 is-descriptor
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 isemail
                      drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 isexe
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 is-extendable
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 is-extglob
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 is-fullwidth-code-point
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 is-glob
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 is-ip
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 is-nan
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 is-negated-glob
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 is-number
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 isobject
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 is-plain-obj
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 is-plain-object
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 is-property
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 is-relative
                      drwxrwxrwx+   5 iobroker iobroker  4096 Okt  2  2019 is-ssh
                      drwxrwxr-x+   2 iobroker iobroker  4096 Jul  7  2020 is-stream
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 isstream
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  3  2019 is-stream-ended
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 is-stun
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 is-typedarray
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 is-unc-path
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 is-utf8
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 is-windows
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 jmespath
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 joi
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 jsbn
                      drwxrwxrwx+   4 iobroker iobroker  4096 Jan  8 18:29 jsftp
                      drwxrwxr-x+   5 iobroker iobroker  4096 Jul 13  2020 jshashes
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 json3
                      drwxrwxr-x+   2 iobroker iobroker  4096 Jan 23 00:59 jsonata
                      drwxrwxr-x+   3 iobroker iobroker  4096 Dez  5 21:35 json-bigint
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt  2  2019 json-buffer
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 jsonfile
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 json-parse-better-errors
                      drwxrwxrwx+   8 iobroker iobroker  4096 Okt  3  2019 jsonpath
                      drwxrwxrwx+   9 iobroker iobroker  4096 Sep 28  2019 json-schema
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 json-schema-traverse
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 json-stable-stringify-without-jsonify
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 json-stringify-safe
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 jsonwebtoken
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 jsprim
                      drwxrwxr-x+   6 iobroker iobroker  4096 Feb 12 18:34 jszip
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 jwa
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 jws
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 keychain
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 keypairs
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt  2  2019 keyv
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 kind-of
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 koalas
                      drwxrwxr-x+   2 iobroker iobroker  4096 Jul  7  2020 kuler
                      drwxrwxr-x+   3 iobroker iobroker  4096 Feb 22 20:58 layerr
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 lazy-cache
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 lcid
                      drwxrwxrwx+   5 iobroker iobroker  4096 Jan 22 23:02 le-acme-core
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 le-challenge-fs
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 le-sni-auto
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 leven
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt  3  2019 levn
                      drwxrwxr-x+   3 iobroker iobroker  4096 Dez  5 21:38 lgtv2
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 lie
                      drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 liftoff
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 loadavg-windows
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 load-json-file
                      drwxrwxr-x+   9 iobroker iobroker  4096 Sep 18 22:55 localforage
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt 13  2019 locate-path
                      drwxrwxrwx+   3 iobroker iobroker 20480 Sep 28  2019 lodash
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 lodash.assign
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  3  2019 lodash.at
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  3  2019 lodash.camelcase
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  3  2019 lodash.clone
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 lodash.compose
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt 13  2019 lodash.defaults
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 lodash.first
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 lodash.flatten
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  3  2019 lodash.has
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 lodash.includes
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 lodash.isboolean
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 lodash.isfunction
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 lodash.isinteger
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 lodash.isnumber
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 lodash.isobject
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 lodash.isplainobject
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 lodash.isstring
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 lodash.mapkeys
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  3  2019 lodash.merge
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 lodash.once
                      drwxrwxr-x+   5 iobroker iobroker  4096 Jan 22 23:02 logform
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 log-ok
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 log-utils
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 long
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 long-timeout
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 loud-rejection
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 lowercase-keys
                      drwxrwxr-x+   3 iobroker iobroker  4096 Jul 13  2020 lru-cache
                      drwxrwxr-x+   2 iobroker iobroker  4096 Nov 25  2019 lru_map
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 luxon
                      drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 make-iterator
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 map-cache
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 map-obj
                      drwxrwxrwx+   4 iobroker iobroker  4096 Okt 13  2019 map-stream
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 map-visit
                      drwxrwxr-x+   4 iobroker iobroker  4096 Okt 23  2019 matchdep
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 md5
                      drwxrwxr-x+  10 iobroker iobroker  4096 Jan  8 18:29 mdns
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 mdns-discovery
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 media-typer
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt  2  2019 meow
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 merge-descriptors
                      drwxrwxr-x+   2 iobroker iobroker  4096 Dez 25  2019 merge-stream
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 methods
                      drwxrwxr-x+   4 iobroker iobroker  4096 Okt 23  2019 micromatch
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 mime
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 mime-db
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 mime-types
                      drwxrwxr-x+   2 iobroker iobroker  4096 Dez 25  2019 mimic-fn
                      drwxrwxr-x+   2 iobroker iobroker  4096 Mai 20  2020 mimic-response
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 minimatch
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 minimist
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt  2  2019 minimist-options
                      drwxrwxr-x+   2 iobroker iobroker  4096 Mai 16  2020 minipass
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt 13  2019 minizlib
                      drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 mixin-deep
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 mixin-object
                      drwxrwxrwx+   6 iobroker iobroker  4096 Sep 28  2019 mkdirp
                      drwxrwxr-x+   2 iobroker iobroker  4096 Mai 19  2020 mkdirp-classic
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 moment
                      drwxrwxr-x+   4 iobroker iobroker  4096 Okt 23  2019 moment-timezone
                      drwxrwxrwx+  10 iobroker iobroker  4096 Sep 28  2019 mqtt
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 mqtt-connection
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 mqtt-packet
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ms
                      drwxrwxr-x+   5 iobroker iobroker  4096 Feb 22 21:28 multer
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 multicast-dns
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 mute-stdout
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt 13  2019 mute-stream
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 nan
                      drwxrwxr-x+   4 iobroker iobroker  4096 Okt 23  2019 nanomatch
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 napi-build-utils
                      drwxrwxr-x+   4 iobroker iobroker  4096 Mai 20  2020 nat-puncher
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 ncp
                      drwxrwxr-x+   8 iobroker iobroker  4096 Feb  9 21:59 needle
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 negotiator
                      drwxrwxr-x+   3 iobroker iobroker  4096 Feb 22 20:58 nested-property
                      drwxrwxrwx+   6 iobroker iobroker  4096 Sep 28  2019 netmask
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 next-line
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 next-tick
                      drwxrwxr-x+   3 iobroker iobroker  4096 Dez 22  2019 node-abi
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 node.extend
                      drwxrwxr-x+   3 iobroker iobroker  4096 Dez  5 21:35 node-fetch
                      drwxrwxr-x+   5 iobroker iobroker  4096 Jan 22 23:02 node-forge
                      drwxrwxr-x+   2 iobroker iobroker  4096 Mai 20  2020 node-gyp-build
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 node-ical
                      drwxrwxr-x+   5 iobroker iobroker  4096 Dez 25  2019 node-machine-id
                      drwxrwxr-x+   4 iobroker iobroker  4096 Jan 23 17:08 node-mndp
                      drwxrwxr-x+   5 iobroker iobroker  4096 Jun  6  2020 node-pre-gyp
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt  3  2019 node-record-lpcm16
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 node-rest-client
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 node-schedule
                      drwxrwxrwx+   8 iobroker iobroker  4096 Sep 28  2019 node-ssdp
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 node-wol
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 noop-logger
                      drwxrwxr-x+   4 iobroker iobroker  4096 Jun  6  2020 nopt
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 normalize-package-data
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt 13  2019 normalize-path
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 normalize-url
                      drwxrwxr-x+   2 iobroker iobroker  4096 Jun  6  2020 npm-bundled
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 npmlog
                      drwxrwxr-x+   4 iobroker iobroker  4096 Jun  6  2020 npm-normalize-package-bin
                      drwxrwxr-x+   2 iobroker iobroker  4096 Jun  6  2020 npm-packlist
                      drwxrwxr-x+   2 iobroker iobroker  4096 Dez 25  2019 npm-run-path
                      drwxrwxr-x+   6 iobroker iobroker  4096 Feb  3 22:08 nuki-bridge-api
                      drwxrwxr-x+   5 iobroker iobroker  4096 Feb  3 22:08 nuki-web-api
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 number-is-nan
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 oauth-sign
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 object-assign
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 object-component
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 object-copy
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 object.defaults
                      drwxrwxr-x+   3 iobroker iobroker  4096 Jan 22 23:02 object-hash
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 object-keys
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 object.map
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 object.pick
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 object-visit
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 once
                      drwxrwxr-x+   2 iobroker iobroker  4096 Jul  7  2020 one-time
                      drwxrwxr-x+   2 iobroker iobroker  4096 Dez 25  2019 onetime
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 on-finished
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 on-headers
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 optimist
                      drwxrwxr-x+   3 iobroker iobroker  4096 Mai 16  2020 optionator
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 options
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  3  2019 optjs
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 ordered-read-streams
                      drwxrwxr-x+   2 iobroker iobroker  4096 Jun  6  2020 osenv
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 os-homedir
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 os-locale
                      drwxrwxr-x+   2 iobroker iobroker  4096 Jun  6  2020 os-tmpdir
                      drwxrwxr-x+   4 iobroker iobroker  4096 Feb 20  2020 pako
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 parse-filepath
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 parse-json
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 parsejson
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 parse-listing
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 parse-node-version
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 parse-passwd
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt  2  2019 parse-path
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 parseqs
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 parseuri
                      drwxrwxrwx+   4 iobroker iobroker  4096 Okt  2  2019 parse-url
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 parseurl
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 pascalcase
                      drwxrwxr-x+   3 iobroker iobroker  4096 Feb 22  2020 passport
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 passport-local
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 passport.socketio
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 passport-strategy
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 path-dirname
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 path-exists
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 path-is-absolute
                      drwxrwxr-x+   2 iobroker iobroker  4096 Dez 25  2019 path-key
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 path-parse
                      drwxrwxr-x+   3 iobroker iobroker  4096 Feb 22 20:58 path-posix
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 path-root
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 path-root-regex
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 path-to-regexp
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 path-type
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 pause
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt 13  2019 pause-stream
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 p-cancelable
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 performance-now
                      drwxrwxr-x+   2 iobroker iobroker  4096 Mai 27  2020 persist-path
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 p-finally
                      drwxrwxr-x+   3 iobroker iobroker  4096 Mai 16  2020 picomatch
                      drwxrwxr-x+   4 iobroker iobroker  4096 Jan 22 23:02 pidusage
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 pify
                      drwxrwxr-x+   5 iobroker iobroker  4096 Feb 22 21:11 ping
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 pinkie
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 pinkie-promise
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 playlist-parser
                      drwxrwxr-x+   2 iobroker iobroker  4096 Jan 23 17:14 p-limit
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt 13  2019 p-locate
                      drwxrwxr-x+   2 iobroker iobroker  4096 Jan 22 23:02 p-map
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 pngjs
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 pointer-symbol
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 posix-character-classes
                      drwxrwxr-x+   3 iobroker iobroker  4096 Dez  5 21:57 p-queue
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt 28  2019 prebuild-install
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt  3  2019 prelude-ls
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 prepend-http
                      drwxrwxr-x+   2 iobroker iobroker  4096 Mai 19  2020 p-retry
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 pretty-hrtime
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 process-nextick-args
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 promirepl
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 promiscuous
                      drwxrwxr-x+   7 iobroker iobroker  4096 Mai 21  2020 promise
                      drwxrwxr-x+   2 iobroker iobroker  4096 Jan 22 23:02 promisify-child-process
                      drwxrwxr-x+   8 iobroker iobroker  4096 Jan 22 23:02 prompt
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 prompt-actions
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 prompt-base
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 prompt-checkbox
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 prompt-choices
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 prompt-list
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 prompt-question
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 prompt-radio
                      drwxrwxrwx+  12 iobroker iobroker  4096 Sep 28  2019 @protobufjs
                      drwxrwxrwx+  10 iobroker iobroker  4096 Sep 28  2019 protobufjs
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt  2  2019 protocols
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 proxy-addr
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 psl
                      drwxrwxr-x+   2 iobroker iobroker  4096 Mai 19  2020 p-timeout
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt 13  2019 p-try
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 public-ip
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 28  2019 pump
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt 28  2019 pumpify
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 punycode
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 pushover-notifications
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 q
                      drwxrwxr-x+   7 iobroker iobroker  4096 Nov 25  2019 qrcode
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 qs
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 querystring
                      drwxrwxr-x+   2 iobroker iobroker  4096 Feb  3 22:08 querystringify
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 quick-lru
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 radio-symbol
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 random-bytes
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 range-parser
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 rasha
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 raw-body
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 rc
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 read
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 readable-stream
                      drwxrwxr-x+   2 iobroker iobroker  4096 Jan 22 23:02 readdirp
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt 13  2019 readline-sync
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 readline-ui
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 readline-utils
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 read-pkg
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 read-pkg-up
                      drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 rechoir
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 redent
                      drwxrwxr-x+   2 iobroker iobroker  4096 Jan 22 23:02 redirect-https
                      drwxrwxr-x+   3 iobroker iobroker  4096 Feb 12 18:34 redis-commands
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt 13  2019 redis-errors
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt 13  2019 redis-parser
                      drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 regex-not
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 reinterval
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 remove-trailing-separator
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 repeat-element
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 repeat-string
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 replace-homedir
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 request
                      drwxrwxr-x+   3 iobroker iobroker  4096 Feb  3 22:08 request-promise
                      drwxrwxr-x+   5 iobroker iobroker  4096 Jan 23 17:04 request-promise-core
                      drwxrwxr-x+   3 iobroker iobroker  4096 Jan 23 17:04 request-promise-native
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 require-directory
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 require-main-filename
                      drwxrwxr-x+   2 iobroker iobroker  4096 Feb  3 22:08 requires-port
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 resolve
                      drwxrwxr-x+   2 iobroker iobroker  4096 Feb  3 22:08 resolve-alpn
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 resolve-dir
                      drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 resolve-url
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt 13  2019 respjs
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt  2  2019 responselike
                      drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 ret
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 retry
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt  3  2019 retry-request
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 revalidator
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 rimraf
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 ring-api
                      drwxrwxrwx+   4 iobroker iobroker  4096 Okt  2  2019 ring-client-api
                      drwxrwxrwx+  13 iobroker iobroker  4096 Jan 22 23:02 @root
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 rpi-gpio
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 rrule
                      drwxrwxr-x+   7 iobroker iobroker  4096 Jan 22 23:02 rsa-compat
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt  2  2019 rtsp-server
                      drwxrwxrwx+   5 iobroker iobroker  4096 Okt  2  2019 rtsp-stream
                      drwxrwxr-x+   4 iobroker iobroker  4096 Mai 20  2020 rtsp-streaming-server
                      drwxrwxr-x+  20 iobroker iobroker  4096 Mai 20  2020 rxjs
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 safe-buffer
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 safer-buffer
                      drwxrwxr-x+   4 iobroker iobroker  4096 Okt 23  2019 safe-regex
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 safe-replace
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 sax
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 @schmupu
                      drwxrwxr-x+   3 iobroker iobroker  4096 Mai 20  2020 sdp
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 semaphore
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 semver
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 semver-greatest-satisfied-range
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 send
                      drwxrwxr-x+  10 iobroker iobroker  4096 Mär  2 17:47 @sentry
                      drwxrwxr-x+   5 iobroker iobroker  4096 Jan 22 23:02 seq-logging
                      drwxrwxrwx+  13 iobroker iobroker  4096 Jan 23 17:08 @serialport
                      drwxrwxrwx+   7 iobroker iobroker  4096 Sep 28  2019 serialport
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 serve-static
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 set-blocking
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 set-getter
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 set-immediate-shim
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 setprototypeof
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 set-value
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 shallow-clone
                      drwxrwxr-x+   2 iobroker iobroker  4096 Dez 25  2019 shebang-command
                      drwxrwxr-x+   2 iobroker iobroker  4096 Dez 25  2019 shebang-regex
                      drwxrwxr-x+   3 iobroker iobroker  4096 Nov 29 20:49 shelly-iot
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 signal-exit
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 simple-concat
                      drwxrwxrwx+   3 iobroker iobroker  4096 Mai 20  2020 simple-get
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt 13  2019 simple-swizzle
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt  2  2019 @sindresorhus
                      drwxrwxrwx+   7 iobroker iobroker  4096 Okt  2  2019 sip
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 sip.js
                      drwxrwxr-x+   5 iobroker iobroker  4096 Mai 19  2020 slip
                      drwxrwxr-x+   4 iobroker iobroker  4096 Okt 23  2019 snapdragon
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 snapdragon-node
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 snapdragon-util
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 socket.io
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 socket.io-adapter
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 socket.io-client
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 socket.io-parser
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 sorted-array-functions
                      drwxrwxrwx+   4 iobroker iobroker  4096 Okt  3  2019 source-map
                      drwxrwxr-x+   4 iobroker iobroker  4096 Okt 23  2019 source-map-resolve
                      drwxrwxr-x+   2 iobroker iobroker  4096 Mai 19  2020 source-map-support
                      drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 source-map-url
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 sparkles
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 spdx-correct
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 spdx-exceptions
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 spdx-expression-parse
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 spdx-license-ids
                      drwxrwxrwx+   4 iobroker iobroker  4096 Okt 13  2019 split
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 split2
                      drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 split-string
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 sprintf-js
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 sshpk
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 stackback
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 stack-trace
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt 13  2019 standard-as-callback
                      drwxrwxrwx+   4 iobroker iobroker  4096 Okt  3  2019 static-eval
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 static-extend
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 statuses
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 stealthy-require
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 stream-combiner
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  3  2019 stream-events
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 streamifier
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 stream-parser
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 streamsearch
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 stream-shift
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 string_decoder
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 string-width
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 strip-ansi
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 strip-bom
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 strip-color
                      drwxrwxr-x+   2 iobroker iobroker  4096 Dez 25  2019 strip-final-newline
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 strip-indent
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 strip-json-comments
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 strip-lines
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  3  2019 stubs
                      drwxrwxrwx+   6 iobroker iobroker  4096 Okt  2  2019 stun
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 success-symbol
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 suncalc2
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 sver-compat
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 sync-exec
                      drwxrwxr-x+   3 iobroker iobroker  4096 Mai 20  2020 systeminformation
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt  2  2019 @szmarczak
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 tableify
                      drwxrwxr-x+   4 iobroker iobroker  4096 Mai 16  2020 tar
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 tar-fs
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 targz
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 tar-stream
                      drwxrwxr-x+   2 iobroker iobroker  4096 Nov 29 20:49 tcp-ping
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 terminal-paginator
                      drwxrwxr-x+   7 iobroker iobroker  4096 Jan 23 16:58 teslajs
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt 13  2019 text-hex
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 through
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 through2
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 through2-filter
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 thunky
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 time-constants
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 timeout-as-promise
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 time-stamp
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 to-absolute-glob
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 to-array
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 to-buffer
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 toggle-array
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 toidentifier
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 to-object-path
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 topo
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 to-readable-stream
                      drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 to-regex
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt 13  2019 to-regex-range
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 tough-cookie
                      drwxrwxr-x+   2 iobroker iobroker  4096 Mai 20  2020 treemap-js
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 trim-newlines
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt 13  2019 triple-beam
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 tslib
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 tunnel-agent
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt  2  2019 turbo-crc32
                      drwxrwxr-x+   4 iobroker iobroker  4096 Feb  9 22:00 tuyapi
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 tweetnacl
                      drwxrwxrwx+  26 iobroker iobroker  4096 Sep 28  2019 type
                      drwxrwxrwx+   3 iobroker iobroker  4096 Okt  3  2019 type-check
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 typedarray
                      drwxrwxr-x+   3 iobroker iobroker  4096 Mai 27  2020 typedarray-to-buffer
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 type-is
                      drwxrwxrwx+  15 iobroker iobroker  4096 Feb 22 21:28 @types
                      drwxrwxr-x+   5 iobroker iobroker  4096 Jan 23 00:59 typescript
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 uid-number
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 uid-safe
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 ultron
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 unc-path-regex
                      drwxrwxr-x+   5 iobroker iobroker  4096 Nov 29 20:49 underscore
                      drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 union-value
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 unique-stream
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 universalify
                      drwxrwxr-x+   6 iobroker iobroker  4096 Feb 20  2020 unix-dgram
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 unorm
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 unpipe
                      drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 unset-value
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 uri-js
                      drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 urix
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 url
                      drwxrwxr-x+   5 iobroker iobroker  4096 Feb 22 20:58 url-join
                      drwxrwxr-x+   3 iobroker iobroker  4096 Feb  3 22:08 url-parse
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt  2  2019 url-parse-lax
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 url-template
                      drwxrwxrwx+   6 iobroker iobroker  4096 Sep 28  2019 ursa-optional
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 use
                      drwxrwxr-x+   5 iobroker iobroker  4096 Mai 20  2020 utf-8-validate
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 util
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 util-deprecate
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 utile
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 utils-merge
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 uuid
                      drwxrwxr-x+   2 iobroker iobroker  4096 Okt 23  2019 v8flags
                      drwxrwxr-x+  12 iobroker iobroker  4096 Feb 22 21:28 valetudo
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 validate-npm-package-license
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 vary
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 verror
                      drwxrwxr-x+   4 iobroker iobroker  4096 Jan 23 00:59 virtual-tsc
                      drwxrwxr-x+   4 iobroker iobroker  4096 Mai 19  2020 vm2
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 wake_on_lan
                      drwxrwxrwx+   4 iobroker iobroker  4096 Okt  3  2019 walkdir
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 warning-symbol
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 weak-daemon
                      drwxrwxr-x+   6 iobroker iobroker  4096 Feb 22 20:59 webdav
                      drwxrwxr-x+   5 iobroker iobroker  4096 Dez  5 21:38 websocket
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 websocket-stream
                      drwxrwxr-x+   3 iobroker iobroker  4096 Okt 23  2019 which
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 which-module
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 which-pm-runs
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 why-is-node-running
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 wide-align
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 window-size
                      drwxrwxr-x+   5 iobroker iobroker  4096 Jul  7  2020 winston
                      drwxrwxr-x+   3 iobroker iobroker  4096 Jul  7  2020 winston-daily-rotate-file
                      drwxrwxr-x+   3 iobroker iobroker  4096 Jan 22 23:02 winston-seq-updated
                      drwxrwxr-x+   4 iobroker iobroker  4096 Mai 16  2020 winston-syslog
                      drwxrwxr-x+   5 iobroker iobroker  4096 Jul  7  2020 winston-transport
                      drwxrwxr-x+   2 iobroker iobroker  4096 Mai 16  2020 word-wrap
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 wordwrap
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 wrap-ansi
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 wrappy
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 ws
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 wtf-8
                      drwxrwxr-x+   4 iobroker iobroker  4096 Mai 20  2020 xml2js
                      drwxrwxr-x+   2 iobroker iobroker  4096 Jul 12  2020 xml2json-light
                      drwxrwxr-x+   6 iobroker iobroker  4096 Mai 20  2020 xmlbuilder
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 xmldom
                      drwxrwxr-x+   3 iobroker iobroker  4096 Mai 20  2020 xmlhttprequest
                      drwxrwxrwx+   5 iobroker iobroker  4096 Sep 28  2019 xmlhttprequest-ssl
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 xregexp
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 xtend
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 y18n
                      drwxrwxr-x+   3 iobroker iobroker  4096 Mai 27  2020 yaeti
                      drwxrwxrwx+   2 iobroker iobroker  4096 Okt 13  2019 yallist
                      drwxrwxrwx+   4 iobroker iobroker  4096 Sep 28  2019 yargs
                      drwxrwxrwx+   3 iobroker iobroker  4096 Sep 28  2019 yargs-parser
                      drwxrwxrwx+   2 iobroker iobroker  4096 Sep 28  2019 yeast
                      drwxrwxr-x+   6 iobroker iobroker  4096 Feb 26 22:19 zigbee-herdsman
                      drwxrwxr-x+   5 iobroker iobroker  4096 Feb 26 22:19 zigbee-herdsman-converters
                      drwxrwxr-x+   5 iobroker iobroker  4096 Mai 20  2020 zlib
                        Prince3k @wendy2702 last edited by
                        @wendy2702
                        pi@raspberrypi4-iob:/opt/iobroker $ ls -la /opt/iobroker/iobroker-data/
                        insgesamt 6720
                        drwxrwxrwx+ 10 iobroker iobroker    4096 Mär  2 18:55 .
                        drwxrwxrwx+  9 iobroker iobroker    4096 Mär  2 13:52 ..
                        drwxrwxrwx+  2 iobroker iobroker    4096 Mär  2 17:56 backup-objects
                        drwxrwxrwx+ 68 iobroker iobroker    4096 Feb 22 21:49 files
                        drwxrwxr-x+  2 iobroker iobroker    4096 Feb 22 21:51 history
                        -rwxrwxrwx+  1 iobroker iobroker    3931 Okt 23  2019 iobroker.json
                        drwxrwxr-x+  2 iobroker iobroker    4096 Mai 27  2020 lgtv_0
                        -rw-rwxr--+  1 iobroker iobroker     110 Mär  2 13:38 notifications.json
                        -rw-rw-r--+  1 iobroker iobroker 2020884 Mär  2 18:51 objects.json
                        -rw-rw-r--+  1 iobroker iobroker 2019897 Mär  2 18:51 objects.json.bak
                        drwxrwxr-x+  2 iobroker iobroker    4096 Jan  8 18:30 sayit
                        -rw-rw-r--+  1 iobroker iobroker 1391842 Mär  2 18:55 states.json
                        -rw-rw-r--+  1 iobroker iobroker 1391846 Mär  2 18:54 states.json.bak
                        drwxrwxr-x+  4 iobroker iobroker    4096 Okt 23  2019 tuya_0
                        drwxrwxrwx+  2 iobroker iobroker    4096 Feb 28 23:20 zigbee_0
                        drwxrwxr-x+  2 iobroker iobroker    4096 Feb 26 22:27 zigbee_1
                        • wendy2702
                          wendy2702 @Prince3k last edited by
                          @prince3k
                          Kannst du mal ein
                          iobroker upload all
                          probieren was dann kommt?
                            @wendy2702
                            Gerne, biete mich auch als Versuchskannichnen an 🙂
                            Vielen vielen Dank schon einmal vorab für die Hilfe und Unterstützung.
                            pi@raspberrypi4-iob:/opt/iobroker $ iobroker upload all
                            upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/words.js words.js application/javascript
                            upload [70] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/hostInfo.js lib/js/hostInfo.js application/javascript
                            upload [60] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/bootstrap.min.js lib/js/bootstrap.min.js application/javascript
                            upload [50] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/slackware.png lib/img/logos/slackware.png image/png
                            upload [40] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/manjaro.png lib/img/logos/manjaro.png image/png
                            upload [30] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/logos/coreos.png lib/img/logos/coreos.png image/png
                            upload [20] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/disk.png lib/img/icons/disk.png image/png
                            upload [19] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/cpu.png lib/img/icons/cpu.png image/png
                            upload [18] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/icons/battery.png lib/img/icons/battery.png image/png
                            upload [17] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/sechand.png lib/img/clock/sechand.png image/png
                            upload [16] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/minhand.png lib/img/clock/minhand.png image/png
                            upload [15] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/hourhand.png lib/img/clock/hourhand.png image/png
                            upload [14] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/img/clock/clockface.png lib/img/clock/clockface.png image/png
                            upload [13] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff2 lib/fonts/fontawesome-webfont.woff2 font/woff2
                            upload [12] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.woff lib/fonts/fontawesome-webfont.woff font/woff
                            upload [11] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.ttf lib/fonts/fontawesome-webfont.ttf font/ttf
                            upload [10] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.svg lib/fonts/fontawesome-webfont.svg image/svg+xml
                            upload [9] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/fontawesome-webfont.eot lib/fonts/fontawesome-webfont.eot application/vnd.ms-fontobject
                            upload [8] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/fonts/FontAwesome.otf lib/fonts/FontAwesome.otf font/otf
                            upload [7] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/data/infoData.json lib/data/infoData.json application/json
                            upload [6] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/simplemde.min.css lib/css/simplemde.min.css text/css
                            upload [5] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/info.css lib/css/info.css text/css
                            upload [4] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/font-awesome.min.css lib/css/font-awesome.min.css text/css
                            upload [3] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/chartist.min.css lib/css/chartist.min.css text/css
                            upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
                            upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/info.png info.png image/png
                            upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
                            upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                            upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                            upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                            upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                            upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                            upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                            upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
                            upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
                            upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
                            upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                            Totalausfall wendy2702 2 Replies Last reply Reply Quote 0
                            • Totalausfall
                              Totalausfall @Prince3k last edited by
                              @prince3k
                              Ich hatte vorhin genau das gleiche Problem. Von jetzt auf gleich ging gar nichts mehr.
                              Hab IoBroker aus Verzweifelung dann gelöscht, neu installiert und das Backup über den Adapter eingespielt.
                              Allerdings ist da immer noch was im argen. Bspw. werden mir unter "Adapter" nur meine installierten Adapter angezeigt, weiter nichts.
                              Hab von Linux, bzw. was Programmierung angeht, absolut keinen Plan, also werd ich leider nicht hilfreich sein^^ Finds nur interessant, dass wir beide ungefähr zu gleichen Zeit das selbe Problem bekommen haben 😕
                                Homoran Global Moderator Administrators @Totalausfall last edited by
                                @danny-killig sagte in IoBroker down - Cannot read system:
                                dann hast du (oder dein provider) wahrscheinlich ein Netzwerkproblem.
                                nochmal den reload button anklicken und sehen was im log steht
                                Totalausfall 1 Reply Last reply Reply Quote 0
                                • Totalausfall
                                  Totalausfall @Homoran last edited by
                                  okay, hat jetzt funktioniert. Danke!
                                  Hab schon mehrfach aktualisiert und neu gestartet aber bislang hat sich nichts getan. Kurios manchmal...
                                  • wendy2702
                                    @prince3k sagte in IoBroker down - Cannot read system:
                                    Kannst du mal schauen ob du unter
                                    ls -la iobroker-data/backup-objects/
                                    was liegen hast?
                                      @wendy2702
                                      ich hatte nun das backup wieder eingespielt und gleich zu Beginn kam folgendes:
                                      [DEBUG] [iobroker] Start ioBroker Restore ...
                                      [DEBUG] [iobroker] iobroker controller daemon is not running
                                      [DEBUG] [iobroker] host.raspberrypi4-iob OK.
                                      [DEBUG] [iobroker] host.raspberrypi4-iob Clear all objects and states...
                                      [DEBUG] [iobroker] clean 545 objects...
                                      [DEBUG] [iobroker] Server Objects 127.0.0.1:37894 Error from InMemDB: Error: Object is marked as non deletable
                                      [ERROR] [iobroker] [Not critical] Cannot delete object 0_userdata.0: {"command":{"name":"del","args":["cfg.o.0_userdata.0"]}}
                                      [ERROR] [iobroker] [Not critical] Cannot delete object alias.0: {"command":{"name":"del","args":["cfg.o.alias.0"]}}
                                      [ERROR] [iobroker] [Not critical] Cannot delete object enum.functions: {"command":{"name":"del","args":["cfg.o.enum.functions"]}}
                                      [ERROR] [iobroker] [Not critical] Cannot delete object enum.rooms: {"command":{"name":"del","args":["cfg.o.enum.rooms"]}}
                                      [ERROR] [iobroker] [Not critical] Cannot delete object system.config: {"command":{"name":"del","args":["cfg.o.system.config"]}}
                                      [ERROR] [iobroker] [Not critical] Cannot delete object system.repositories: {"command":{"name":"del","args":["cfg.o.system.repositories"]}}
                                      Danach lief alles durch.
                                      ls -la iobroker-data/backup-objects/ spuckt folgendes aus:
                                      pi@raspberrypi4-iob:/opt/iobroker $ ls -la iobroker-data/backup-objects/
                                      insgesamt 38640
                                      drwxrwxrwx+  2 iobroker iobroker    4096 Mär  2 19:32 .
                                      drwxrwxrwx+ 10 iobroker iobroker    4096 Mär  2 19:54 ..
                                      -rw-rwxr--+  1 iobroker iobroker 1802812 Feb 27 16:32 2021-02-27_16-32_objects.j                       son.gz
                                      -rw-rwxr--+  1 iobroker iobroker 1802810 Feb 27 18:32 2021-02-27_18-32_objects.j                       son.gz
                                      -rw-rwxr--+  1 iobroker iobroker 1802809 Feb 27 20:32 2021-02-27_20-32_objects.j                       son.gz
                                      -rw-rwxr--+  1 iobroker iobroker 1803544 Feb 27 22:32 2021-02-27_22-32_objects.j                       son.gz
                                      -rw-rwxr--+  1 iobroker iobroker 1803557 Feb 28 00:32 2021-02-28_00-32_objects.j                       son.gz
                                      -rw-rwxr--+  1 iobroker iobroker 1803561 Feb 28 02:32 2021-02-28_02-32_objects.j                       son.gz
                                      -rw-rwxr--+  1 iobroker iobroker  343303 Feb 28 02:45 2021-02-28_02-45_states.js                       on.gz
                                      -rw-rwxr--+  1 iobroker iobroker 1803550 Feb 28 04:32 2021-02-28_04-32_objects.j                       son.gz
                                      -rw-rwxr--+  1 iobroker iobroker  343258 Feb 28 04:45 2021-02-28_04-45_states.js                       on.gz
                                      -rw-rwxr--+  1 iobroker iobroker 1803601 Feb 28 06:32 2021-02-28_06-32_objects.j                       son.gz
                                      -rw-rwxr--+  1 iobroker iobroker  343413 Feb 28 06:46 2021-02-28_06-46_states.js                       on.gz
                                      -rw-rwxr--+  1 iobroker iobroker 1803559 Feb 28 08:32 2021-02-28_08-32_objects.j                       son.gz
                                      -rw-rwxr--+  1 iobroker iobroker  343086 Feb 28 08:46 2021-02-28_08-46_states.js                       on.gz
                                      -rw-rwxr--+  1 iobroker iobroker 1803524 Feb 28 10:32 2021-02-28_10-32_objects.j                       son.gz
                                      -rw-rwxr--+  1 iobroker iobroker  343412 Feb 28 10:47 2021-02-28_10-47_states.js                       on.gz
                                      -rw-rwxr--+  1 iobroker iobroker 1803506 Feb 28 12:32 2021-02-28_12-32_objects.j                       son.gz
                                      -rw-rwxr--+  1 iobroker iobroker  343333 Feb 28 12:47 2021-02-28_12-47_states.js                       on.gz
                                      -rw-rwxr--+  1 iobroker iobroker 1803505 Feb 28 14:32 2021-02-28_14-32_objects.j                       son.gz
                                      -rw-rwxr--+  1 iobroker iobroker  343362 Feb 28 14:47 2021-02-28_14-47_states.js                       on.gz
                                      -rw-rwxr--+  1 iobroker iobroker 1803495 Feb 28 16:32 2021-02-28_16-32_objects.j                       son.gz
                                      -rw-rwxr--+  1 iobroker iobroker  343043 Feb 28 16:48 2021-02-28_16-48_states.js                       on.gz
                                      -rw-rwxr--+  1 iobroker iobroker 1803541 Feb 28 18:32 2021-02-28_18-32_objects.j                       son.gz
                                      -rw-rwxr--+  1 iobroker iobroker  343621 Feb 28 18:48 2021-02-28_18-48_states.js                       on.gz
                                      -rw-rwxr--+  1 iobroker iobroker 1803534 Feb 28 20:32 2021-02-28_20-32_objects.j                       son.gz
                                      -rw-rwxr--+  1 iobroker iobroker  343259 Feb 28 20:49 2021-02-28_20-49_states.js                       on.gz
                                      -rw-rwxr--+  1 iobroker iobroker 1804845 Feb 28 22:32 2021-02-28_22-32_objects.j                       son.gz
                                      -rw-rwxr--+  1 iobroker iobroker  343315 Feb 28 22:49 2021-02-28_22-49_states.js                       on.gz
                                      -rw-rwxr--+  1 iobroker iobroker    3515 Feb 28 23:55 2021-02-28_23-55_objects.j                       son.gz
                                      -rw-rwxr--+  1 iobroker iobroker  343377 Mär  1 21:58 2021-03-01_21-58_states.js                       on.gz
                                      -rw-rwxr--+  1 iobroker iobroker    3518 Mär  1 22:14 2021-03-01_22-14_objects.j                       son.gz
                                      -rw-rwxr--+  1 iobroker iobroker  343412 Mär  1 22:18 2021-03-01_22-18_states.js                       on.gz
                                      -rw-rwxr--+  1 iobroker iobroker    3518 Mär  1 22:21 2021-03-01_22-21_objects.j                       son.gz
                                      -rw-rwxr--+  1 iobroker iobroker  342361 Mär  1 22:22 2021-03-01_22-22_states.js                       on.gz
                                      -rw-rwxr--+  1 iobroker iobroker  342358 Mär  1 23:11 2021-03-01_23-11_states.js                       on.gz
                                      -rw-rwxr--+  1 iobroker iobroker  342358 Mär  2 13:06 2021-03-02_13-06_states.js                       on.gz
                                      -rw-rwxr--+  1 iobroker iobroker   11306 Mär  2 13:18 2021-03-02_13-18_objects.j                       son.gz
                                      -rw-rwxr--+  1 iobroker iobroker  342362 Mär  2 13:18 2021-03-02_13-18_states.js                       on.gz
                                      -rw-rwxr--+  1 iobroker iobroker  342347 Mär  2 13:40 2021-03-02_13-40_states.js                       on.gz
                                      -rw-rwxr--+  1 iobroker iobroker  342347 Mär  2 13:46 2021-03-02_13-46_states.js                       on.gz
                                      -rw-rw-r--+  1 iobroker iobroker   11307 Mär  2 13:55 2021-03-02_13-55_objects.j                       son.gz
                                      -rw-rw-r--+  1 iobroker iobroker  342342 Mär  2 13:56 2021-03-02_13-56_states.js                       on.gz
                                      -rw-rw-r--+  1 iobroker iobroker  342363 Mär  2 15:56 2021-03-02_15-56_states.js                       on.gz
                                      -rw-rw-r--+  1 iobroker iobroker   14327 Mär  2 17:47 2021-03-02_17-47_objects.j                       son.gz
                                      -rw-rw-r--+  1 iobroker iobroker  342375 Mär  2 17:56 2021-03-02_17-56_states.js                       on.gz
                                      -rw-rw-r--+  1 iobroker iobroker  612535 Mär  2 19:26 2021-03-02_19-26_objects.j                       son.gz
                                      -rw-rw-r--+  1 iobroker iobroker  344607 Mär  2 19:27 2021-03-02_19-27_states.js                       on.gz
                                      -rw-rw-r--+  1 iobroker iobroker 1725614 Mär  2 19:32 2021-03-02_19-32_objects.j                       son.gz
                                      -rw-rw-r--+  1 iobroker iobroker  343410 Mär  2 19:32 2021-03-02_19-32_states.js                       on.gz
                                      • wendy2702
                                        @prince3k Schon ewig kein restore mehr benötigt (klopfe auf Holz), keine Ahnung ob das beim restore normale Errors sind weil er ja von der leeren ioBroker installation auf dein Backup umbaut.
                                        Wenn du nochmal ein Problem wie heute bekommst kann man versuchen aus dem Backup in diesem Ordner das System wieder herzustellen.
                                          @wendy2702 ich sehe aber nach dem restore immer jedoch nur die 3 instanzen : admin, backitup und info, was mache ich falsch ?
                                          • wendy2702
                                            @prince3k wie machst du den restore?
                                            Backitup Adapter oder manuel?
                                            berechtigungen cannot read system iobroker startet nicht
                                            3183
