    4. Iobroker.admin reinstall
      TeraX last edited by
      ich habe versehentlich beim Aufruf des Fragezeichens mit einem Tablet beim .admin Adapter den iobroker.admin gelöscht (es kam keine weitere Sicherheitsabfrage!)
      Nun habe ich kein Zugriff mehr auf die Weboberfläche, kann den Adapter aber auch nicht per shell installieren.
      Habt Ihr noch ein Lösung parat?
      Das ganze läuft auf einem Rasp Pi B.
      Linux raspberrypi 3.18.7+ #755 PREEMPT Thu Feb 12 17:14:31 GMT 2015 armv6l
      The programs included with the Debian GNU/Linux system are free software;
      the exact distribution terms for each program are described in the
      individual files in /usr/share/doc/*/copyright.
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      Last login: Sat May  2 18:45:58 2015 from android
      pi@raspberrypi ~ $ su -
      root@raspberrypi:~# npm install --production --prefix "/opt/iobroker/node_modules/iobroker.admin"
      npm ERR! install Couldn't read dependencies
      npm ERR! package.json ENOENT, open '/opt/iobroker/node_modules/iobroker.admin/package.json'
      npm ERR! package.json This is most likely not a problem with npm itself.
      npm ERR! package.json npm can't find a package.json file in your current directory.
      npm ERR! System Linux 3.18.7+
      npm ERR! command "/usr/local/bin/node" "/usr/local/bin/npm" "install" "--production" "--prefix" "/opt/iobroker/node_modules/iobroker.admin"
      npm ERR! cwd /root
      npm ERR! node -v v0.10.22
      npm ERR! npm -v 1.3.14
      npm ERR! path /opt/iobroker/node_modules/iobroker.admin/package.json
      npm ERR! code ENOPACKAGEJSON
      npm ERR! errno 34
      npm ERR!
      npm ERR! Additional logging details can be found in:
      npm ERR!     /root/npm-debug.log
      npm ERR! not ok code 0
      root@raspberrypi:~# npm install iobroker.admin
      npm http GET https://registry.npmjs.org/iobroker.admin
      npm http 304 https://registry.npmjs.org/iobroker.admin
      npm http GET https://registry.npmjs.org/xtend
      npm http GET https://registry.npmjs.org/express-session
      npm http GET https://registry.npmjs.org/passport-local
      npm http GET https://registry.npmjs.org/connect-flash
      npm http GET https://registry.npmjs.org/request
      npm http GET https://registry.npmjs.org/socket.io
      npm http GET https://registry.npmjs.org/cookie-parser
      npm http GET https://registry.npmjs.org/body-parser
      npm http 304 https://registry.npmjs.org/express-session
      npm http 304 https://registry.npmjs.org/passport-local
      npm http 304 https://registry.npmjs.org/xtend
      npm http 304 https://registry.npmjs.org/request
      npm http 304 https://registry.npmjs.org/socket.io
      npm http 304 https://registry.npmjs.org/connect-flash
      npm http 304 https://registry.npmjs.org/cookie-parser
      npm http 304 https://registry.npmjs.org/body-parser
      npm http GET https://registry.npmjs.org/passport-strategy
      npm http GET https://registry.npmjs.org/cookie/0.1.2
      npm http GET https://registry.npmjs.org/cookie-signature/1.0.6
      npm http 304 https://registry.npmjs.org/passport-strategy
      npm http 304 https://registry.npmjs.org/cookie/0.1.2
      npm http 304 https://registry.npmjs.org/cookie-signature/1.0.6
      npm http GET https://registry.npmjs.org/utils-merge/1.0.0
      npm http GET https://registry.npmjs.org/crc/3.2.1
      npm http GET https://registry.npmjs.org/debug
      npm http GET https://registry.npmjs.org/depd
      npm http GET https://registry.npmjs.org/on-headers
      npm http GET https://registry.npmjs.org/parseurl
      npm http GET https://registry.npmjs.org/uid-safe/1.1.0
      npm http GET https://registry.npmjs.org/bytes/1.0.0
      npm http GET https://registry.npmjs.org/content-type
      npm http GET https://registry.npmjs.org/iconv-lite/0.4.8
      npm http GET https://registry.npmjs.org/on-finished
      npm http GET https://registry.npmjs.org/qs/2.4.1
      npm http GET https://registry.npmjs.org/raw-body/1.3.4
      npm http GET https://registry.npmjs.org/type-is
      npm http 304 https://registry.npmjs.org/utils-merge/1.0.0
      npm http 304 https://registry.npmjs.org/crc/3.2.1
      npm http 304 https://registry.npmjs.org/debug
      npm http 304 https://registry.npmjs.org/parseurl
      npm http 304 https://registry.npmjs.org/depd
      npm http 304 https://registry.npmjs.org/on-headers
      npm http 304 https://registry.npmjs.org/content-type
      npm http 304 https://registry.npmjs.org/iconv-lite/0.4.8
      npm http 304 https://registry.npmjs.org/on-finished
      npm http 304 https://registry.npmjs.org/qs/2.4.1
      npm http 304 https://registry.npmjs.org/uid-safe/1.1.0
      npm http 304 https://registry.npmjs.org/bytes/1.0.0
      npm http 304 https://registry.npmjs.org/type-is
      npm http 304 https://registry.npmjs.org/raw-body/1.3.4
      npm http GET https://registry.npmjs.org/pause/0.0.1
      npm http 304 https://registry.npmjs.org/pause/0.0.1
      npm http GET https://registry.npmjs.org/socket.io-adapter/0.3.1
      npm http GET https://registry.npmjs.org/has-binary-data/0.1.3
      npm http GET https://registry.npmjs.org/debug/2.1.0
      npm http GET https://registry.npmjs.org/engine.io/1.5.1
      npm http GET https://registry.npmjs.org/socket.io-parser/2.2.4
      npm http GET https://registry.npmjs.org/socket.io-client/1.3.5
      npm http 304 https://registry.npmjs.org/socket.io-adapter/0.3.1
      npm http 304 https://registry.npmjs.org/engine.io/1.5.1
      npm http 304 https://registry.npmjs.org/has-binary-data/0.1.3
      npm http 304 https://registry.npmjs.org/socket.io-parser/2.2.4
      npm http 304 https://registry.npmjs.org/debug/2.1.0
      npm http 304 https://registry.npmjs.org/socket.io-client/1.3.5
      npm http GET https://registry.npmjs.org/base64-url/1.2.1
      npm http GET https://registry.npmjs.org/native-or-bluebird
      npm http 304 https://registry.npmjs.org/native-or-bluebird
      npm http 304 https://registry.npmjs.org/base64-url/1.2.1
      npm http GET https://registry.npmjs.org/ee-first/1.1.0
      npm http GET https://registry.npmjs.org/media-typer/0.3.0
      npm http GET https://registry.npmjs.org/mime-types
      npm http 304 https://registry.npmjs.org/ee-first/1.1.0
      npm http 304 https://registry.npmjs.org/mime-types
      npm http 304 https://registry.npmjs.org/media-typer/0.3.0
      npm http GET https://registry.npmjs.org/debug/1.0.2
      npm http GET https://registry.npmjs.org/socket.io-parser/2.2.2
      npm http GET https://registry.npmjs.org/object-keys/1.0.1
      npm http 304 https://registry.npmjs.org/debug/1.0.2
      npm http 304 https://registry.npmjs.org/socket.io-parser/2.2.2
      npm http 304 https://registry.npmjs.org/object-keys/1.0.1
      npm http GET https://registry.npmjs.org/ms/0.7.0
      npm http 304 https://registry.npmjs.org/ms/0.7.0
      npm http GET https://registry.npmjs.org/ms/0.6.2
      npm http 304 https://registry.npmjs.org/ms/0.6.2
      npm http GET https://registry.npmjs.org/mime-db
      npm http GET https://registry.npmjs.org/isarray/0.0.1
      npm http 304 https://registry.npmjs.org/mime-db
      npm http 304 https://registry.npmjs.org/isarray/0.0.1
      npm http GET https://registry.npmjs.org/send/0.12.2
      npm http GET https://registry.npmjs.org/serve-static
      npm http GET https://registry.npmjs.org/vary
      npm http GET https://registry.npmjs.org/accepts
      npm http GET https://registry.npmjs.org/content-disposition/0.5.0
      npm http GET https://registry.npmjs.org/escape-html/1.0.1
      npm http GET https://registry.npmjs.org/etag
      npm http GET https://registry.npmjs.org/finalhandler/0.3.4
      npm http GET https://registry.npmjs.org/fresh/0.2.4
      npm http GET https://registry.npmjs.org/merge-descriptors/1.0.0
      npm http GET https://registry.npmjs.org/methods
      npm http GET https://registry.npmjs.org/path-to-regexp/0.1.3
      npm http GET https://registry.npmjs.org/proxy-addr
      npm http GET https://registry.npmjs.org/range-parser
      npm http 304 https://registry.npmjs.org/send/0.12.2
      npm http 304 https://registry.npmjs.org/vary
      npm http 304 https://registry.npmjs.org/accepts
      npm http 304 https://registry.npmjs.org/serve-static
      npm http 304 https://registry.npmjs.org/content-disposition/0.5.0
      npm http 304 https://registry.npmjs.org/escape-html/1.0.1
      npm http 304 https://registry.npmjs.org/etag
      npm http 304 https://registry.npmjs.org/finalhandler/0.3.4
      npm http 304 https://registry.npmjs.org/fresh/0.2.4
      npm http 304 https://registry.npmjs.org/merge-descriptors/1.0.0
      npm http 304 https://registry.npmjs.org/methods
      npm http 304 https://registry.npmjs.org/path-to-regexp/0.1.3
      npm http 304 https://registry.npmjs.org/proxy-addr
      npm http 304 https://registry.npmjs.org/range-parser
      npm http GET https://registry.npmjs.org/bl
      npm http GET https://registry.npmjs.org/caseless
      npm http GET https://registry.npmjs.org/forever-agent
      npm http GET https://registry.npmjs.org/form-data
      npm http GET https://registry.npmjs.org/json-stringify-safe
      npm http GET https://registry.npmjs.org/node-uuid
      npm http GET https://registry.npmjs.org/tunnel-agent
      npm http GET https://registry.npmjs.org/tough-cookie
      npm http GET https://registry.npmjs.org/http-signature
      npm http GET https://registry.npmjs.org/oauth-sign
      npm http GET https://registry.npmjs.org/hawk
      npm http GET https://registry.npmjs.org/aws-sign2
      npm http GET https://registry.npmjs.org/stringstream
      npm http GET https://registry.npmjs.org/combined-stream
      npm http GET https://registry.npmjs.org/isstream
      npm http GET https://registry.npmjs.org/har-validator
      npm http 304 https://registry.npmjs.org/bl
      npm http 304 https://registry.npmjs.org/caseless
      npm http 304 https://registry.npmjs.org/form-data
      npm http 304 https://registry.npmjs.org/json-stringify-safe
      npm http 304 https://registry.npmjs.org/node-uuid
      npm http 304 https://registry.npmjs.org/forever-agent
      npm http 304 https://registry.npmjs.org/tunnel-agent
      npm http 304 https://registry.npmjs.org/tough-cookie
      npm http 304 https://registry.npmjs.org/http-signature
      npm http 304 https://registry.npmjs.org/oauth-sign
      npm http 304 https://registry.npmjs.org/hawk
      npm http 304 https://registry.npmjs.org/aws-sign2
      npm http 304 https://registry.npmjs.org/stringstream
      npm http 304 https://registry.npmjs.org/combined-stream
      npm http 304 https://registry.npmjs.org/isstream
      npm http 304 https://registry.npmjs.org/har-validator
      npm http GET https://registry.npmjs.org/debug/0.7.4
      npm http GET https://registry.npmjs.org/json3/3.2.6
      npm http GET https://registry.npmjs.org/component-emitter/1.1.2
      npm http GET https://registry.npmjs.org/benchmark/1.0.0
      npm http GET https://registry.npmjs.org/debug/1.0.3
      npm http GET https://registry.npmjs.org/ws/0.5.0
      npm http GET https://registry.npmjs.org/engine.io-parser/1.2.1
      npm http GET https://registry.npmjs.org/base64id/0.1.0
      npm http 304 https://registry.npmjs.org/component-emitter/1.1.2
      npm http 304 https://registry.npmjs.org/debug/0.7.4
      npm http 304 https://registry.npmjs.org/benchmark/1.0.0
      npm http 304 https://registry.npmjs.org/json3/3.2.6
      npm http 304 https://registry.npmjs.org/debug/1.0.3
      npm http 304 https://registry.npmjs.org/ws/0.5.0
      npm http 304 https://registry.npmjs.org/engine.io-parser/1.2.1
      npm http 304 https://registry.npmjs.org/base64id/0.1.0
      npm http GET https://registry.npmjs.org/negotiator/0.5.1
      npm http GET https://registry.npmjs.org/forwarded
      npm http GET https://registry.npmjs.org/ipaddr.js/0.1.9
      npm http 304 https://registry.npmjs.org/forwarded
      npm http 304 https://registry.npmjs.org/negotiator/0.5.1
      npm http 304 https://registry.npmjs.org/ipaddr.js/0.1.9
      npm http GET https://registry.npmjs.org/delayed-stream/0.0.5
      npm http 304 https://registry.npmjs.org/delayed-stream/0.0.5
      npm http GET https://registry.npmjs.org/async
      npm http GET https://registry.npmjs.org/destroy/1.0.3
      npm http GET https://registry.npmjs.org/mime/1.3.4
      npm http 304 https://registry.npmjs.org/async
      npm http 304 https://registry.npmjs.org/destroy/1.0.3
      npm http 304 https://registry.npmjs.org/mime/1.3.4
      npm http GET https://registry.npmjs.org/readable-stream
      npm http 304 https://registry.npmjs.org/readable-stream
      npm http GET https://registry.npmjs.org/assert-plus
      npm http GET https://registry.npmjs.org/asn1/0.1.11
      npm http GET https://registry.npmjs.org/ctype/0.5.3
      npm http 304 https://registry.npmjs.org/assert-plus
      npm http 304 https://registry.npmjs.org/asn1/0.1.11
      npm http 304 https://registry.npmjs.org/ctype/0.5.3
      npm http GET https://registry.npmjs.org/after/0.8.1
      npm http GET https://registry.npmjs.org/blob/0.0.2
      npm http GET https://registry.npmjs.org/base64-arraybuffer/0.1.2
      npm http GET https://registry.npmjs.org/arraybuffer.slice/0.0.6
      npm http GET https://registry.npmjs.org/has-binary/0.1.5
      npm http GET https://registry.npmjs.org/utf8/2.0.0
      npm http 304 https://registry.npmjs.org/after/0.8.1
      npm http 304 https://registry.npmjs.org/arraybuffer.slice/0.0.6
      npm http 304 https://registry.npmjs.org/base64-arraybuffer/0.1.2
      npm http 304 https://registry.npmjs.org/blob/0.0.2
      npm http 304 https://registry.npmjs.org/utf8/2.0.0
      npm http 304 https://registry.npmjs.org/has-binary/0.1.5
      npm http GET https://registry.npmjs.org/has-binary/0.1.6
      npm http GET https://registry.npmjs.org/engine.io-client/1.5.1
      npm http GET https://registry.npmjs.org/component-bind/1.0.0
      npm http GET https://registry.npmjs.org/object-component/0.0.3
      npm http GET https://registry.npmjs.org/parseuri/0.0.2
      npm http GET https://registry.npmjs.org/indexof/0.0.1
      npm http GET https://registry.npmjs.org/to-array/0.1.3
      npm http GET https://registry.npmjs.org/backo2/1.0.2
      npm http GET https://registry.npmjs.org/chalk
      npm http GET https://registry.npmjs.org/commander
      npm http GET https://registry.npmjs.org/is-my-json-valid
      npm http GET https://registry.npmjs.org/bluebird
      npm http 304 https://registry.npmjs.org/component-bind/1.0.0
      npm http 304 https://registry.npmjs.org/engine.io-client/1.5.1
      npm http 304 https://registry.npmjs.org/has-binary/0.1.6
      npm http 304 https://registry.npmjs.org/parseuri/0.0.2
      npm http 304 https://registry.npmjs.org/indexof/0.0.1
      npm http 304 https://registry.npmjs.org/to-array/0.1.3
      npm http 304 https://registry.npmjs.org/object-component/0.0.3
      npm http 304 https://registry.npmjs.org/backo2/1.0.2
      npm http 304 https://registry.npmjs.org/chalk
      npm http 304 https://registry.npmjs.org/commander
      npm http 304 https://registry.npmjs.org/is-my-json-valid
      npm http 304 https://registry.npmjs.org/bluebird
      npm http GET https://registry.npmjs.org/better-assert
      npm http GET https://registry.npmjs.org/supports-color
      npm http GET https://registry.npmjs.org/ansi-styles
      npm http GET https://registry.npmjs.org/escape-string-regexp
      npm http GET https://registry.npmjs.org/has-ansi
      npm http GET https://registry.npmjs.org/strip-ansi
      npm http 304 https://registry.npmjs.org/better-assert
      npm http 304 https://registry.npmjs.org/strip-ansi
      npm http 304 https://registry.npmjs.org/ansi-styles
      npm http 304 https://registry.npmjs.org/escape-string-regexp
      npm http 304 https://registry.npmjs.org/has-ansi
      npm http 304 https://registry.npmjs.org/supports-color
      npm http GET https://registry.npmjs.org/graceful-readlink
      npm http 304 https://registry.npmjs.org/graceful-readlink
      npm http GET https://registry.npmjs.org/core-util-is
      npm http GET https://registry.npmjs.org/string_decoder
      npm http GET https://registry.npmjs.org/inherits
      npm http GET https://registry.npmjs.org/ansi-regex
      npm http GET https://registry.npmjs.org/get-stdin
      npm http 304 https://registry.npmjs.org/string_decoder
      npm http 304 https://registry.npmjs.org/get-stdin
      npm http 304 https://registry.npmjs.org/core-util-is
      npm http GET https://registry.npmjs.org/nan
      npm http GET https://registry.npmjs.org/options
      npm http GET https://registry.npmjs.org/ultron
      npm http 304 https://registry.npmjs.org/inherits
      npm http 304 https://registry.npmjs.org/ultron
      npm http 304 https://registry.npmjs.org/nan
      npm http 304 https://registry.npmjs.org/options
      npm http 304 https://registry.npmjs.org/ansi-regex
      npm http GET https://registry.npmjs.org/callsite/1.0.0
      npm http 304 https://registry.npmjs.org/callsite/1.0.0
      npm http GET https://registry.npmjs.org/parsejson/0.0.1
      npm http GET https://registry.npmjs.org/parseqs/0.0.2
      npm http GET https://registry.npmjs.org/component-inherit/0.0.3
      npm http GET https://registry.npmjs.org/has-cors/1.0.3
      npm http GET https://registry.npmjs.org/ws/0.4.31
      npm http GET https://github.com/rase-/node-XMLHttpRequest/archive/a6b6f2.tar.gz
      npm http GET https://registry.npmjs.org/debug/1.0.4
      npm http GET https://registry.npmjs.org/parseuri/0.0.4
      npm http 304 https://registry.npmjs.org/parseqs/0.0.2
      npm http 304 https://registry.npmjs.org/has-cors/1.0.3
      npm http 304 https://registry.npmjs.org/component-inherit/0.0.3
      npm http 304 https://registry.npmjs.org/parsejson/0.0.1
      npm http 304 https://registry.npmjs.org/debug/1.0.4
      npm http 304 https://registry.npmjs.org/ws/0.4.31
      npm http 304 https://registry.npmjs.org/parseuri/0.0.4
      npm http 200 https://github.com/rase-/node-XMLHttpRequest/archive/a6b6f2.tar.gz
      npm http GET https://registry.npmjs.org/generate-function
      npm http GET https://registry.npmjs.org/generate-object-property
      npm http GET https://registry.npmjs.org/jsonpointer
      npm http 304 https://registry.npmjs.org/generate-function
      > ws@0.5.0 install /root/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws
      > (node-gyp rebuild 2> builderror.log) || (exit 0)
      make: Entering directory '/root/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/build'
        CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
        SOLINK_MODULE(target) Release/obj.target/bufferutil.node
        SOLINK_MODULE(target) Release/obj.target/bufferutil.node: Finished
        COPY Release/bufferutil.node
        CXX(target) Release/obj.target/validation/src/validation.o
        SOLINK_MODULE(target) Release/obj.target/validation.node
        SOLINK_MODULE(target) Release/obj.target/validation.node: Finished
        COPY Release/validation.node
      make: Leaving directory '/root/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/build'
      npm http 304 https://registry.npmjs.org/generate-object-property
      npm http 304 https://registry.npmjs.org/jsonpointer
      npm http GET https://registry.npmjs.org/hoek
      npm http GET https://registry.npmjs.org/boom
      npm http GET https://registry.npmjs.org/cryptiles
      npm http GET https://registry.npmjs.org/sntp
      npm http 304 https://registry.npmjs.org/hoek
      npm http 304 https://registry.npmjs.org/boom
      npm http 304 https://registry.npmjs.org/cryptiles
      npm http 304 https://registry.npmjs.org/sntp
      npm http GET https://registry.npmjs.org/is-property
      npm http 304 https://registry.npmjs.org/is-property
      npm http GET https://github.com/component/global/archive/v2.0.1.tar.gz
      npm http 200 https://github.com/component/global/archive/v2.0.1.tar.gz
      npm http GET https://registry.npmjs.org/tinycolor
      npm http 304 https://registry.npmjs.org/tinycolor
      > ws@0.4.31 install /root/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws
      make: Entering directory '/root/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/build'
      make: Leaving directory '/root/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/build'
      iobroker.admin@0.4.6 node_modules/iobroker.admin
      ├── connect-flash@0.1.1
      ├── xtend@4.0.0
      ├── passport-local@1.0.0 (passport-strategy@1.0.0)
      ├── cookie-parser@1.3.4 (cookie-signature@1.0.6, cookie@0.1.2)
      ├── passport@0.2.1 (pause@0.0.1, passport-strategy@1.0.0)
      ├── express-session@1.11.1 (utils-merge@1.0.0, on-headers@1.0.0, parseurl@1.3.0, cookie-signature@1.0.6, cookie@0.1.2, depd@1.0.1, uid-safe@1.1.0, crc@3.2.1, debug@2.1.3)
      ├── body-parser@1.12.3 (content-type@1.0.1, bytes@1.0.0, raw-body@1.3.4, on-finished@2.2.1, qs@2.4.1, depd@1.0.1, debug@2.1.3, type-is@1.6.1, iconv-lite@0.4.8)
      ├── express@4.12.3 (merge-descriptors@1.0.0, utils-merge@1.0.0, cookie-signature@1.0.6, methods@1.1.1, cookie@0.1.2, fresh@0.2.4, escape-html@1.0.1, range-parser@1.0.2, content-type@1.0.1, finalhandler@0.3.4, vary@1.0.0, parseurl@1.3.0, serve-static@1.9.2, content-disposition@0.5.0, path-to-regexp@0.1.3, depd@1.0.1, on-finished@2.2.1, qs@2.4.1, debug@2.1.3, etag@1.5.1, proxy-addr@1.0.7, send@0.12.2, type-is@1.6.1, accepts@1.2.5)
      ├── request@2.55.0 (caseless@0.9.0, json-stringify-safe@5.0.0, aws-sign2@0.5.0, forever-agent@0.6.1, stringstream@0.0.4, oauth-sign@0.6.0, tunnel-agent@0.4.0, isstream@0.1.2, node-uuid@1.4.3, combined-stream@0.0.7, form-data@0.2.0, qs@2.4.1, mime-types@2.0.10, http-signature@0.10.1, bl@0.9.4, tough-cookie@1.1.0, hawk@2.3.1, har-validator@1.7.0)
      └── socket.io@1.3.5 (debug@2.1.0, has-binary-data@0.1.3, socket.io-adapter@0.3.1, engine.io@1.5.1, socket.io-parser@2.2.4, socket.io-client@1.3.5)
      root@raspberrypi:~#
        Npm install iobroker.admin
        Oder
        ./iobroker add admin
        Bin mir da nicht sicher.
        Aber eins muss klappen.
        Das ganze natürlich in /opt/iobroker
        Gesendet von meinem Cynus T7 mit Tapatalk
          puh klappt wieder!
          Vielen Dank!
          ".iobroker add admin" hat geklappt. Mit npm hatte ich leider immer den Fehler vom ersten Post.
          Also Vorsicht mit Wurstfingern auf den Tablet 😉
          Gruss
          Daniel
