    5. (Gelöst)Fehlermeldung Update des Javasript Adapters 5.0.12
    • N
      nichname last edited by nichname
      Nach dem Update des Javascript Adapters bekomme ich Fehlermeldungen im Log.
      host.raspberrypi	2021-03-09 00:01:31.548	error	instance system.adapter.javascript.1 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.raspberrypi	2021-03-09 00:01:31.547	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
      host.raspberrypi	2021-03-09 00:01:31.547	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
      host.raspberrypi	2021-03-09 00:01:31.546	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
      host.raspberrypi	2021-03-09 00:01:31.546	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
      host.raspberrypi	2021-03-09 00:01:31.546	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
      host.raspberrypi	2021-03-09 00:01:31.545	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
      host.raspberrypi	2021-03-09 00:01:31.545	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:35:24)
      host.raspberrypi	2021-03-09 00:01:31.545	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
      host.raspberrypi	2021-03-09 00:01:31.544	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
      host.raspberrypi	2021-03-09 00:01:31.544	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
      host.raspberrypi	2021-03-09 00:01:31.543	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
      host.raspberrypi	2021-03-09 00:01:31.542	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
      host.raspberrypi	2021-03-09 00:01:31.542	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
      host.raspberrypi	2021-03-09 00:01:31.541	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc/build/index.js:8:16)
      host.raspberrypi	2021-03-09 00:01:31.540	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
      host.raspberrypi	2021-03-09 00:01:31.539	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
      host.raspberrypi	2021-03-09 00:01:31.539	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
      host.raspberrypi	2021-03-09 00:01:31.538	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
      host.raspberrypi	2021-03-09 00:01:31.537	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
      host.raspberrypi	2021-03-09 00:01:31.537	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
      host.raspberrypi	2021-03-09 00:01:31.536	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc/build/server.js:4:10)
      host.raspberrypi	2021-03-09 00:01:31.536	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
      host.raspberrypi	2021-03-09 00:01:31.535	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
      host.raspberrypi	2021-03-09 00:01:31.535	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
      host.raspberrypi	2021-03-09 00:01:31.534	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
      host.raspberrypi	2021-03-09 00:01:31.534	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
      host.raspberrypi	2021-03-09 00:01:31.533	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:963:27)
      host.raspberrypi	2021-03-09 00:01:31.533	error	Caught by controller[0]: at wrapSafe (internal/modules/cjs/loader.js:915:16)
      host.raspberrypi	2021-03-09 00:01:31.532	error	Caught by controller[0]: SyntaxError: Unexpected end of input
      host.raspberrypi	2021-03-09 00:01:31.531	error	Caught by controller[0]:
      host.raspberrypi	2021-03-09 00:01:31.531	error	Caught by controller[0]: getAllCodeActions: function (context) { return codefix.codeFi
      host.raspberrypi	2021-03-09 00:01:31.529	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.javascript/node_modules/typescript/lib/typescript.js:140401
      Auch habe ich ständig bei der Bearbeitung von Scripten die Fehlermeldung Instanz ist deaktiviert.
      Ein Backup habe ich schon eingespielt. Keine Änderung.
      Iobroker läuft... aber ständig hängt der Adapter deaktiviert.
      crunchip UncleSam 2 Replies Last reply Reply Quote 0
      • crunchip
        crunchip Forum Testing Most Active @nichname last edited by
        @nichname deine JavascriptInstanz.0 funktioniert?
        • UncleSam
          UncleSam Developer @nichname last edited by
          @nichname Hast du irgendwo in deinen Scripten Code drin, der wie folgt aussieht?
          • N
            @crunchip Javascript.0 funktioniert genau so wie Javascript.1. Beide mit den selben Fehlern. Alle Scripte Laufen aber es kommen ständig die Fehler.
            • N
              nichname @UncleSam last edited by
              @unclesam Nein, so einen Code habe ich nicht im Script.
              • UncleSam
                @nichname Lädst du irgendwelche weiteren Module?
                • AlCalzone
                  AlCalzone Developer last edited by AlCalzone
                  Die betreffende Zeile kommt direkt aus dem typescript-Modul, welches unter der Haube genutzt wird. Für mich sieht das aus, als wären dessen Dateien kaputt.
                  SD-Karte am Arsch?
                  • Gaspode
                    Gaspode last edited by
                    @nichname
                    Da du den Titel auf "gelöst" geändert hast:
                    Wie hast du das Problem denn gelöst? War der Grund wirklich eine defekte SD-Karte?
                    wendy2702 N 2 Replies Last reply Reply Quote 0
                    • wendy2702
                      wendy2702 @Gaspode last edited by
                      @alexi sagte in (Gelöst)Fehlermeldung Update des Javasript Adapters 5.0.12:
                      @nichname
                      SEHR GUTE FRAGE!
                      • N
                        nichname @Gaspode last edited by nichname
                        Habe das Probelm jetzt durch eine Neuinstallation gelöst.
                        SD Karte war nicht defekt!
                        javascript
                        402
