    4. Zigbee Adapter startet nicht
      consoleman last edited by consoleman
      ich hoffe mir kann jemand helfen..... Habe heute meinen CC2531 Stick erhalten und wollte den Zigbee Adapter installieren. Das hat auch geklappt, nur leider startet der nicht mit folgendem Log:
      ioBroker läuft auf einem RPi 3
      host.raspberrypi 2021-03-09 15:50:25.285 error instance system.adapter.zigbee.0 terminated with code 1 ()
      Caught 2021-03-09 15:50:25.285 error by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:520:3)
      Caught 2021-03-09 15:50:25.284 error by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:528:12)
      Caught 2021-03-09 15:50:25.284 error by controller[0]: at Module.load (internal/modules/cjs/loader.js:589:32)
      Caught 2021-03-09 15:50:25.284 error by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:689:10)
      Caught 2021-03-09 15:50:25.284 error by controller[0]: at Module._compile (internal/modules/cjs/loader.js:678:30)
      Caught 2021-03-09 15:50:25.284 error by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/@iobroker/adapter-core/build/index.js:29:54)
      Caught 2021-03-09 15:50:25.284 error by controller[0]: at require (internal/modules/cjs/helpers.js:20:18)
      Caught 2021-03-09 15:50:25.284 error by controller[0]: at Module.require (internal/modules/cjs/loader.js:626:17)
      Caught 2021-03-09 15:50:25.283 error by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:497:25)
      Caught 2021-03-09 15:50:25.283 error by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:571:15)
      Caught 2021-03-09 15:50:25.283 error by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/exitCodes'
      Caught 2021-03-09 15:50:25.283 error by controller[0]: ^
      Caught 2021-03-09 15:50:25.283 error by controller[0]: throw err;
      Caught 2021-03-09 15:50:25.281 error by controller[0]: internal/modules/cjs/loader.js:573
      Ich bin nicht wirklich der Linux Held und hilflos....
      Asgothian arteck 2 Replies Last reply Reply Quote 0
      • Asgothian
        Asgothian Developer @consoleman last edited by
        @consoleman
        • Bitte Logs immer in code Tags (</>) setzen
        • Welchen Adapter hast du installiert (version) ?
        • Welches OS ?
        • Welche NodeJS Version
        • Welche JS Controller version
        • Gab es Meldungen bei der Installation ?
        A.
        C Asgothian 2 Replies Last reply Reply Quote 0
          arteck Developer Most Active @consoleman last edited by
          @consoleman sagte in Zigbee Adapter startet nicht:
          und meine Glaskugel ist zur Zeit zur politur...
            consoleman @Asgothian last edited by
            @asgothian said in Zigbee Adapter startet nicht:
            @consoleman
            • Welches OS ?
            A.
            Sorry, war nicht mein Plan jemanden zu ärgern.
            Adapter Version 1.4.4
            Raspberian auf RPi3
            NodeJS 10.0.0
            So wie es aussieht ist der JS Controller nicht installiert?
            • Asgothian
              Asgothian Developer @Asgothian last edited by
              @asgothian sagte in Zigbee Adapter startet nicht:
              Diese Beiden Fragen solltest Du noch beantworten.
              Wenn Du keinen JS Controller hast läuft dein ioBroker nicht.
              Wenn Du Node 10.0.0 hast dann stimmt da auch was nicht.
              A.
                Thomas Braun Most Active @consoleman last edited by Thomas Braun
                @consoleman
                iobroker -v
                which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                Bei dem Nickname dürfte die Bedienung via shell ja kein Thema sein.
                  consoleman @Thomas Braun last edited by consoleman
                  6.4.1
                  nodejs:
                    Installed: 10.24.0-1nodesource1
                    Candidate: 10.24.0-1nodesource1
                    Version table:
                   *** 10.24.0-1nodesource1 500
                          500 https://deb.nodesource.com/node_10.x stretch/main armhf Packages
                          100 /var/lib/dpkg/status
                       8.11.1~dfsg-2~bpo9+1 500
                          500 http://archive.raspberrypi.org/debian stretch/main armhf Packages     4.8.2~dfsg-1 500
                          500 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
                  Iobroker 1.5.14
                    Homoran Global Moderator Administrators @consoleman last edited by
                    @consoleman das ist aber nicht der vollständige Output
                      consoleman @Homoran last edited by
                      /usr/bin/nodejs
                      v10.24.0
                      /home/pi/.nvm/versions/node/v10.15.2/bin/node
                      v10.15.2
                      /home/pi/.nvm/versions/node/v10.15.2/bin/npm
                      6.4.1
                      nodejs:
                        Version table:
                        @consoleman Node-Installation ist komplett krumm.
                          @thomas-braun said in Zigbee Adapter startet nicht:
                          Ok, wie behebe ich das?
                            @consoleman
                            https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                            Oder durch den Werkzeugkasten aus meiner Signatur buddeln.
                              Ok.... aber was genau meinst du mit "krumm", grundsätzlich läuft ja iobroker und Homebridge Problemlos.
                                @consoleman
                                Trotzdem krumm. Hast du das HowTo gelesen? Da steht drin wie das richtig aussehen muss.
                                  usr/bin/nodejs
                                  v12.21.0
                                  /usr/bin/node
                                  v12.21.0
                                  /usr/bin/npm
                                  7.6.2
                                  nodejs:
                                    Installed: 12.21.0-1nodesource1
                                    Candidate: 12.21.0-1nodesource1
                                    Version table:
                                   *** 12.21.0-1nodesource1 500
                                          500 https://deb.nodesource.com/node_12.x stretch/main armhf Packages
                                  Besser oder?
                                  Mein Problem mit dem Zigbee Adapter hat es jedoch nicht gelöst.
                                  Gibt es weitere Tipps?
                                    @consoleman
                                    npm dürfte nicht 7 sein
                                    Und du hast ernsthaft einen 1er ioBroker?
                                    iobroker -v
                                      pi@raspberrypi:~ $ iobroker -v
                                      1.5.14
                                        @consoleman Mittlerweile sind wir bei 3.2.16
                                        Bring das System in die Jetzt-Zeit. Mit npm@6.
                                          was genau meinst du mit npm@6 ?
                                            @consoleman Deine Version von npm ist zu neu, die funktioniert mit ioBroker noch nicht vernünftig. Installier eine Version aus der 6er-Reihe.
                                            Reinstall von node über apt spült automatisch eine passende Version auf das System.
                                            Wenn das sauber ist installier iobroker 3.2.16
                                            1300
