    4. [gelöst]YR.no adapter Verbindungsprobleme
      Tobi68 last edited by Tobi68
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi4
      Arbeitsspeicher: 1GB
      Festplattenart: SD-Karte
      Betriebssystem: Ubuntu
      Node-Version:
      Nodejs-Version: 12.20.0
      NPM-Version: 6.14.8
      Installationsart: Manuell
      Image genutzt: Nein
      Ort/Name der Imagedatei: Link
      Sind die Neustarts normal bei dem Adapter?
      habe ich erst am WE installiert..
      yr.0	2021-03-15 14:06:02.937	info	(10510) got weather data from yr.no
      yr.0	2021-03-15 14:06:02.693	info	(10510) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.yr, node: v12.20.0, js-controller: 3.2.16
      host.IOBroker	2021-03-15 14:06:00.076	info	instance system.adapter.yr.0 started with pid 10510
      host.IOBroker	2021-03-15 13:06:07.938	info	instance system.adapter.yr.0 terminated with code 0 (NO_ERROR)
      yr.0	2021-03-15 13:06:02.875	info	(6724) got weather data from yr.no
      yr.0	2021-03-15 13:06:02.612	info	(6724) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.yr, node: v12.20.0, js-controller: 3.2.16
      host.IOBroker	2021-03-15 13:06:00.084	info	instance system.adapter.yr.0 started with pid 6724
      host.IOBroker	2021-03-15 12:06:14.883	info	instance system.adapter.yr.0 terminated with code 0 (NO_ERROR)
      yr.0	2021-03-15 12:06:09.804	info	(2997) got weather data from yr.no
      yr.0	2021-03-15 12:06:02.596	info	(2997) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.yr, node: v12.20.0, js-controller: 3.2.16
      host.IOBroker	2021-03-15 12:06:00.082	info	instance system.adapter.yr.0 started with pid 2997
      host.IOBroker	2021-03-15 11:06:07.910	info	instance system.adapter.yr.0 terminated with code 0 (NO_ERROR)
      yr.0	2021-03-15 11:06:02.844	info	(31497) got weather data from yr.no
      yr.0	2021-03-15 11:06:02.597	info	(31497) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.yr, node: v12.20.0, js-controller: 3.2.16
      host.IOBroker	2021-03-15 11:06:00.071	info	instance system.adapter.yr.0 started with pid 31497
        Thomas Braun Most Active @Tobi68 last edited by
        @tobi68
        Ja, der Adapter wird nur einmal in der Stunde wach und holt die Wetterdaten ab.
