    4. Fritzbox DECT adapter - permanent Warnung im log
      Frank06347 last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi4
      Arbeitsspeicher: 8GB
      Festplattenart: SD-Karte
      Betriebssystem: Rasbian Buster
      Node-Version: 10.x.x
      Nodejs-Version: v12.21.0
      NPM-Version: 6.14.11
      Installationsart: Skript
      Image genutzt: Nein
      seit dem vorletzten Updaten erhalte ich Fehler bzgl. angelegter Gruppen in FritzDect. Wenn ich die Gruppen in der Fritzdect lösche, sind die Fehler weg.
      Beispiel:
      fritzdect.0 2021-03-16 14:51:30.962 warn (30420) State "fritzdect.0.DECT_grp4A3C94-3C3272356.members" has no existing object, this might lead to an error in future versions
      fritzdect.0 2021-03-16 14:51:30.961 warn (30420) State "fritzdect.0.DECT_grp4A3C94-3C3272356.masterdeviceid" has no existing object, this might lead to an error in future versions
      fritzdect.0 2021-03-16 14:51:30.961 warn (30420) State "fritzdect.0.DECT_grp4A3C94-3C3272356.energy" has no existing object, this might lead to an error in future versions
      fritzdect.0 2021-03-16 14:51:30.961 warn (30420) State "fritzdect.0.DECT_grp4A3C94-3C3272356.power" has no existing object, this might lead to an error in future versions
      fritzdect.0 2021-03-16 14:51:30.958 warn (30420) State "fritzdect.0.DECT_grp4A3C94-3C3272356.voltage" has no existing object, this might lead to an error in future versions
      fritzdect.0 2021-03-16 14:51:30.958 warn (30420) State "fritzdect.0.DECT_grp4A3C94-3C3272356.state" has no existing object, this might lead to an error in future versions
      fritzdect.0 2021-03-16 14:51:30.957 warn (30420) State "fritzdect.0.DECT_grp4A3C94-3C3272356.devicelock" has no existing object, this might lead to an error in future versions
      fritzdect.0 2021-03-16 14:51:30.957 warn (30420) State "fritzdect.0.DECT_grp4A3C94-3C3272356.lock" has no existing object, this might lead to an error in future versions
      fritzdect.0 2021-03-16 14:51:30.954 warn (30420) State "fritzdect.0.DECT_grp4A3C94-3C3272356.mode" has no existing object, this might lead to an error in future versions
      fritzdect.0 2021-03-16 14:51:30.954 warn (30420) State "fritzdect.0.DECT_grp4A3C94-3C3272356.state" has no existing object, this might lead to an error in future versions
      fritzdect.0 2021-03-16 14:51:30.953 warn (30420) State "fritzdect.0.DECT_grp4A3C94-3C3272356.name" has no existing object, this might lead to an error in future versions
      fritzdect.0 2021-03-16 14:51:30.952 warn (30420) State "fritzdect.0.DECT_grp4A3C94-3C3272356.txbusy" has no existing object, this might lead to an error in future versions
      fritzdect.0 2021-03-16 14:51:30.947 warn (30420) State "fritzdect.0.DECT_grp4A3C94-3C3272356.present" has no existing object, this might lead to an error in future versions
      fritzdect.0 2021-03-16 14:51:30.946 warn (30420) State "fritzdect.0.DECT_grp4A3C94-3C3272356.manufacturer" has no existing object, this might lead to an error in future versions
      fritzdect.0 2021-03-16 14:51:30.946 warn (30420) State "fritzdect.0.DECT_grp4A3C94-3C3272356.fwversion" has no existing object, this might lead to an error in future versions
      fritzdect.0 2021-03-16 14:51:30.945 warn (30420) State "fritzdect.0.DECT_grp4A3C94-3C3272356.id" has no existing object, this might lead to an error in future versions
      fritzdect.0 2021-03-16 14:51:30.945 warn (30420) State "fritzdect.0.DECT_grp4A3C94-3C3272356.synchronized" has no existing object, this might lead to an error in future versions
      fritzdect.0 2021-03-16 14:51:21.384 warn (30420) State "fritzdect.0.DECT_grp4A3C94-3C3272356.members" has no existing object, this might lead to an error in future versions
      Die Fehler werden massenhaft im log angezeigt.
      Ich behelfe mich derzeit damit, dass ich die Gruppen in der Fritzdect lösche.
      Hat jemand einen Tipp für mich?
      Viele Grüße
      Frank
      • mickym
        mickym Most Active @Frank06347 last edited by
        @frank06347 Diese Warnungen habe ich derzeit auch - da muss der Entwickler was machen. Blende einfach die Meldungen aus, in dem Du bei der Adapterinstanz die Logstufe auf Error hochsetzt.
