    4. ZZH! Stick läuft nicht mit dem Zigbee Adapter
    • N
      Neko last edited by Neko
      Hallo, ich bekomme den Electrolama ZZH! Zigbee Stick (CC2652R) auf meinem Pi nicht ans laufen.
      Der Adapter bleibt gelb und ich habe folgende Meldungen im Log:
      zigbee.0 2021-03-18 13:15:36.798 error at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
      zigbee.0 2021-03-18 13:15:36.798 error at SerialPort. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
      zigbee.0 2021-03-18 13:15:36.798 error at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
      zigbee.0 2021-03-18 13:15:36.798 error at new Promise ()
      zigbee.0 2021-03-18 13:15:36.798 error at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
      zigbee.0 2021-03-18 13:15:36.798 error at Generator.next ()
      zigbee.0 2021-03-18 13:15:36.798 error at Znp. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
      zigbee.0 2021-03-18 13:15:36.798 error (2039) Error: Error while opening serialport ‘Error: Error Resource temporarily unavailable Cannot lock port’
      zigbee.0 2021-03-18 13:15:36.797 error (2039) Failed to start Zigbee
      zigbee.0 2021-03-18 13:15:36.573 info (2039) Installed Version: iobroker.zigbee@1.4.4
      zigbee.0 2021-03-18 13:15:36.531 info (2039) Starting Zigbee npm …
      zigbee.0 2021-03-18 13:15:36.529 info (2039) Try to reconnect. 1 attempts left
      zigbee.0 2021-03-18 13:15:26.526 error at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/startZnp.js:25:65)
      zigbee.0 2021-03-18 13:15:26.526 error at Generator.throw ()
      zigbee.0 2021-03-18 13:15:26.526 error at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/startZnp.js:172:23
      zigbee.0 2021-03-18 13:15:26.526 error (2039) Error: Coordinator failed to start, probably the panID is already in use, try a different panID or channel
      zigbee.0 2021-03-18 13:15:26.524 error (2039) Failed to start Zigbee
      Was ich bis jetzt gemacht habe:
      • Auf dem Windows PC mit TI’s Flash Programmer 2 “CC2652R_coordinator_20210120” geflasht und verifiziert.
      • “ls -l /dev/serial/by-id” liefert “usb-1a86_USB_Serial-if00-port0 -> …/…/ttyUSB0” also habe ich im Adapter “/dev/serial/by-id/usb-1a86_USB_Serial-if00-port0” als Com Anschluss genommen (Ich habe auch /dev/ttyUSB0 und /dev/ttyAMA0 versucht)
      • Pan ID mehrfach geändert, auch die Extended Pan ID. Zigbee Adapter neu installiert (Vers. 1,44)
      • Den Stick abgezogen und neu eingesteckt.
      • “test -w /dev/ttyACM0 && echo success || echo failure” liefert successful
        “test -w /dev/ttyUSB0 && echo success || echo failure” liefert successful
      Ich bin mit meinem Latein echt am Ende, wäre schön, wenn ihr mir helfen könntet.
      Gruss,
      Neko
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi4
      Arbeitsspeicher: 4GB
      Festplattenart: SSD
      Betriebssystem: Raspbian
      Node-Version: 10.x.x
      Nodejs-Version: v12.21.0
      NPM-Version: 6.14.11
      Installationsart: Skript
      • Asgothian
        Asgothian Developer @Neko last edited by
        @neko sagte in ZZH! Stick läuft nicht mit dem Zigbee Adapter:
        Das System beschwert sich darüber das es bereits ein Netz mit den gleichen Parametern gibt. Bitte folgendes Tun:
        • den Adapter anhalten
        • die Datei nvbackup.json im Verzeichnis /opt/iobroker/iobroker-data/zigbee_0 löschen
        • die Datein shepherd.db im gleichen Verzeichnis umbenennen.
        • den Stick abziehen
        • 30 sekunden warten
        • den Stick wieder einstecken
        • den Adapter starten.
        A.
        • N
          Neko @Asgothian last edited by
          @asgothian said in ZZH! Stick läuft nicht mit dem Zigbee Adapter:
          Das Verzeichnis ist leer.
          • Asgothian
            @neko
            Diese Meldung deutet darauf hin das der Zigbee Stick den Aufbau des Netzes verweigert.
            Hast du noch eine andere Instanz laufen ?
            A.
            N 2 Replies Last reply Reply Quote 0
            • N
              @asgothian Nein, von dem Zigbee Adapter nicht. Ich habe allerdings noch einen Tradfri Adapter laufen.
              • Asgothian
                @neko zeig mal bitte einen Screenshot von der Konfiguration
                A.
                • N
                  @asgothian Meinst du die Einstellungen im Zigbee Adapter oder meine Instanzen?
                  • N
                    @neko
                    Meine Vermutung wäre, dass das hier das Problem ist.
                    Den Tradfri Adapter hatte ich schon ausgeschaltet und auch die PanID mehrfach gewechselt. Ist aber nur eine Vermutung, ich bin für jeden Tipp dankbar.
                    • Asgothian
                      @neko
                      Ich meinte schon die Einstellungen des Zigbee Adapters.
                      und die Meldung mit dem cannot lock port kommt nach dem Versuch das Netz aufzubauen (Siehe Timestamp der Log Meldungen
                      A.
                      • N
                        @asgothian Hier die Einstellungen:
                        Eine Sache ist mir noch aufgefallen, wenn ich auf "Speichen und Schließen" klicke, bekomme ich immer die Meldung "Bitte bestätigen - Einige Daten wurden nicht gespeichert. Verwerfen?" Wenn ich ok klicke und dann nachsehe, sind die Einstellungen trotzdem gespeichert.
                          arteck Developer Most Active @Neko last edited by
                          @neko ich habe eine Vermutung..
                          der Tradfri baut ein Netz auf.. auch wen ndu diesen Abschaltest laufen die Router weiter und senden eine PANID..
                          der Zigbee Adapter merkt es und macht sein Netz nicht auf..
                          du könntest wenn es nicht viel Mühe macht ..
                          Tradfri Adapter abschalten
                          alle Router (Geräte die am Strom hängen) vom Netz trennen..nicht nur abschalten sonder acht trennen (Bulbs rausschrauben, Plug rausziehen)
                          dann Zigbee Adapter starten
                          • N
                            Neko @arteck last edited by
                            @arteck Ich habe das gerade mal ausprobiert keine Änderung, gleiche Fehlermeldung.
                            Welches ist eigentlich die aktuelle, stabile Version vom Zigbee Adapter? Ich habe gerade mal von stabil auf beta gestellt und jetzt wird mir angezeigt, Aktuell: 1.1.1 und installiert: 1.4.4 Kann es sein, dass da mit Stabil und Beta was durcheinander gekommen ist und ich da eine Beta vom Adapter installiert habe?
                            • N
                              @arteck Ich habe gerade noch folgendes Probiert, den 1.4.4 Adapter deinstalliert und den 1.1.1 installiert. Tradfri ist noch aus, trotzdem bekomme ich noch folgenden Meldungen:
                              zigbee.0	2021-03-19 11:49:26.335	error	at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
                              zigbee.0	2021-03-19 11:49:26.335	error	at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
                              zigbee.0	2021-03-19 11:49:26.335	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:111:49)
                              zigbee.0	2021-03-19 11:49:26.335	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:4:12)
                              zigbee.0	2021-03-19 11:49:26.335	error	at new Promise (<anonymous>)
                              zigbee.0	2021-03-19 11:49:26.335	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:8:71
                              zigbee.0	2021-03-19 11:49:26.335	error	at Generator.next (<anonymous>)
                              zigbee.0	2021-03-19 11:49:26.335	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:113:32)
                              zigbee.0	2021-03-19 11:49:26.335	error	(5545) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
                              zigbee.0	2021-03-19 11:49:26.333	error	(5545) Failed to start Zigbee
                              zigbee.0	2021-03-19 11:49:26.081	info	(5545) Starting Zigbee...
                              zigbee.0	2021-03-19 11:49:26.081	info	(5545) Try to reconnect. 1 attempts left
                              zigbee.0	2021-03-19 11:49:16.079	error	at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/startZnp.js:6:65)
                              zigbee.0	2021-03-19 11:49:16.079	error	at Generator.throw (<anonymous>)
                              zigbee.0	2021-03-19 11:49:16.079	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/startZnp.js:158:23
                              zigbee.0	2021-03-19 11:49:16.079	error	(5545) Error: Coordinator failed to start, probably the panID is already in use, try a different panID or channel
                              zigbee.0	2021-03-19 11:49:16.078	error	(5545) Failed to start Zigbee
                              zigbee.0	2021-03-19 11:48:10.693	info	(5545) Starting Zigbee...
                              zigbee.0	2021-03-19 11:48:10.653	info	(5545) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.21.0, js-controller: 3.2.16
                              host.raspberrypi	2021-03-19 11:48:08.966	info	instance system.adapter.zigbee.0 started with pid 5545
                              Kann es sein, dass dort vielleicht noch etwas mit Stick auf Betriebssystem Ebene nicht stimmt? Das der Serial Port nicht richtig konfiguriert ist oder sowas?
                              Thomas Braun Asgothian 2 Replies Last reply Reply Quote 0
                                Thomas Braun Most Active @Neko last edited by
                                @neko
                                Ist eigentlich der Serial Port im Raspi aktiv?
                                Kann man in
                                sudo raspi-config
                                irgendwo schauen.
                                • N
                                  Neko @Thomas Braun last edited by
                                  @thomas-braun Also in der Config wurde er mir jetzt als "active" angezeigt. Die Frage ist halt ob ich ihn damit jetzt angeschaltet habe oder ob er schon an war.
                                  Jedenfalls weiterhin keine Änderung...
                                  • Asgothian
                                    Nein kann es nicht.
                                    Diese Meldung
                                    besagt eindeutig das es eine Kommunikation zwischen dem Koordinator und dem Adapter gegeben hat. Damit ist die serielle Schnittstelle aussen vor.
                                    Das blockieren der Schnittstelle ist darauf zurück zu führen das die Bibliothek die Schnittstelle nicht so schnell wieder frei gibt wie der Adapter versucht das ganze neu zu initialisieren.
                                    A.
                                    • N
                                      @asgothian
                                      Ok, und was kann man da machen?
                                      • Asgothian
                                        @neko Ich würde an dieser Stelle die Vermutung äussern das der Stick nicht ok ist. Immerhin verweigert er systematisch den Aufbau eines Zigbee Netzes.
                                        A.
                                        • N
                                          @asgothian Ja, ich fürchte es fast auch...
                                          Von Electrolama gibt es ein Skript um zu testen, ob der Stick richtig geflasht ist: https://gist.github.com/omerk/0ee0e447a9e36786b4ff71d8f8126a23
                                          Allerdings bekomme ich dieses nicht ans laufen. Ich bekomme immer die Meldung "ModuleNotFoundError: No module named 'serial'". Ich habe dann auch schon pyserial installiert, aber das änderte auch nichts. Irgendwie stoße ich da an meine Grenzen. 😞
                                          • N
                                            @asgothian Also, der Stick ist in Ordnung. Damit ich mir nicht meinen ganzen Raspberry zumülle, habe ich auf dem Windows Rechner Zigbee2MQTT installiert und in iobroker einen MQTT Server aufgesetzt. Mit diesem Setup konnte ich Sensoren pairen und Werte abgreifen.
                                            Mit anderen Worten, der Stick funktioniert, es muss ein Problem mit dem Raspberry oder iobroker sein.
                                            3650
