    4. Zigbee adapter stays yellow with CR2652R
    • N
      Neko last edited by
      Hello,
      The ZZH! stick I order, arrived this week. Unfortunately I’m not able to get it running with ioBroker.
      I always receive this error messages:
      zigbee.0 2021-03-18 13:15:36.798 error at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
      zigbee.0 2021-03-18 13:15:36.798 error at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
      zigbee.0 2021-03-18 13:15:36.798 error at SerialPort. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
      zigbee.0 2021-03-18 13:15:36.798 error at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
      zigbee.0 2021-03-18 13:15:36.798 error at new Promise ()
      zigbee.0 2021-03-18 13:15:36.798 error at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
      zigbee.0 2021-03-18 13:15:36.798 error at Generator.next ()
      zigbee.0 2021-03-18 13:15:36.798 error at Znp. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
      zigbee.0 2021-03-18 13:15:36.798 error (2039) Error: Error while opening serialport ‘Error: Error Resource temporarily unavailable Cannot lock port’
      zigbee.0 2021-03-18 13:15:36.797 error (2039) Failed to start Zigbee
      zigbee.0 2021-03-18 13:15:36.573 info (2039) Installed Version: iobroker.zigbee@1.4.4
      zigbee.0 2021-03-18 13:15:36.531 info (2039) Starting Zigbee npm …
      zigbee.0 2021-03-18 13:15:36.529 info (2039) Try to reconnect. 1 attempts left
      zigbee.0 2021-03-18 13:15:26.526 error at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/startZnp.js:25:65)
      zigbee.0 2021-03-18 13:15:26.526 error at Generator.throw ()
      zigbee.0 2021-03-18 13:15:26.526 error at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/startZnp.js:172:23
      zigbee.0 2021-03-18 13:15:26.526 error (2039) Error: Coordinator failed to start, probably the panID is already in use, try a different panID or channel
      zigbee.0 2021-03-18 13:15:26.524 error (2039) Failed to start Zigbee
      What I did:
      • Used my Windows PC and the TI’s Flash Programmer 2 to flash “CC2652R_coordinator_20210120”. It said “successful” and I verified it.
      • Plugged the stick into my Raspberry Pi 4.
      • “ls -l /dev/serial/by-id” send back “usb-1a86_USB_Serial-if00-port0 -> …/…/ttyUSB0” so I use “/dev/serial/by-id/usb-1a86_USB_Serial-if00-port0” as com port in the Zigbee adapter in ioBroker. (I also tried /dev/ttyUSB0 and /dev/ttyAMA0.)
      • I changed the Pan ID several times, I also changed the extended Pan ID. I reinstalled the Zigbee adapter (version 1.44)
      • I unplugged and plugged the stick
      • “test -w /dev/ttyACM0 && echo success || echo failure” was successful and “test -w /dev/ttyUSB0 && echo success || echo failure” was successful
      I have no idea what can I do. Could you please support me?
      Best regards,
      Neko
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi4
      Arbeitsspeicher: 4GB
      Festplattenart: SSD
      Betriebssystem: Raspbian
      Node-Version: 10.x.x
      Nodejs-Version: v12.21.0
      NPM-Version: 6.14.11
      Installationsart: Skript
        Thomas Braun Most Active @Neko last edited by
        @neko
        See
        https://forum.iobroker.net/topic/43371/zzh-stick-läuft-nicht-mit-dem-zigbee-adapter
