    4. Backitup Backup wird nicht erzeugt
      Rushmed Most Active last edited by
      ich hab gerade festgestellt dass keine ioBroker Backups meh erstellt werden.
      Hier der Log:
      Started iobroker ...
      [DEBUG] [iobroker] start with {"type":"creator","time":"03:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"googledrive":{"enabled":true,"type":"storage","source":"local","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":false,"dir":"/ioBroker Backup","dirMinimal":"/backupDir/minimal"},"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"30","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"30","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":true,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
      [DEBUG] [iobroker] - host.Smartazamba 5299 states saved
      [DEBUG] [iobroker] - host.Smartazamba 10290 objects saved
      [ERROR] [iobroker] - host.Smartazamba Backup not created: Error: host.Smartazamba /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/.json is not a valid json file
      [DEBUG] [iobroker] - done
      [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/iobroker_2021_03_21-20_06_11_backupiobroker.tar.gz" not found
      [DEBUG] [googledrive] - done
      [DEBUG] [googledrive] start with {"type":"storage","source":"local","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":false,"dir":"/ioBroker Backup","dirMinimal":"/backupDir/minimal","deleteBackupAfter":0}
      [DEBUG] [clean] - done
      [DEBUG] [telegram] - [iobroker] used Telegram-Instance: telegram.0
      [DEBUG] [telegram] - done
      [DEBUG] [telegram] start with {"type":"creator","time":"03:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"googledrive":{"enabled":true,"type":"storage","source":"local","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":false,"dir":"/ioBroker Backup","dirMinimal":"/backupDir/minimal"},"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"30","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"30","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":true,"telegramWaiting":0,"systemLang":"de","time":"21. Maerz 2021 um 20:06 Uhr"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
      [DEBUG] [historyHTML] - new history html values created
      [DEBUG] [historyHTML] - done
      [DEBUG] [historyJSON] - new history json values created
      [DEBUG] [historyJSON] - done
      [DEBUG] [historyHTML] start with {"type":"creator","time":"03:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"googledrive":{"enabled":true,"type":"storage","source":"local","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":false,"dir":"/ioBroker Backup","dirMinimal":"/backupDir/minimal"},"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"30","systemLang":"de","time":"21. Maerz 2021 um 20:06 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"30","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":true,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
      [DEBUG] [historyJSON] start with {"type":"creator","time":"03:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"googledrive":{"enabled":true,"type":"storage","source":"local","debugging":true,"deleteOldBackup":true,"accessJson":"****","ownDir":false,"dir":"/ioBroker Backup","dirMinimal":"/backupDir/minimal"},"dir":"/opt/iobroker","historyHTML":{"enabled":true,"type":"message","entriesNumber":"30","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"30","systemLang":"de","time":"21. Maerz 2021 um 20:06 Uhr"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":true,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
      [EXIT] 26
      Das Problem ist wohl:
      Die Datei kann ich in dem Ordner nicht finden. Ich hatte den Adapter son lange deinstalliert. Auch eine erneute Installation konnte den Fehler nicht lösen.
      Die Backups von Zigbee, InfluxDB und Grafana funktionieren.
      Adapterversion 2.0.5
      Wie kann ich das Problem lösen?
      Thomas Braun simatec 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Rushmed last edited by
        @rushmed sagte in Backitup Backup wird nicht erzeugt:
        sudo rm /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/.json
          Rushmed Most Active @Thomas Braun last edited by Rushmed
          @thomas-braun Danke aber so scheint die Datei auch nicht auffindbar.
          pi@Smartazamba:~ $ sudo rm /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/.json
          rm: das Entfernen von '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/0_userdata.0/minukodu/.json' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
          Edit:
          Ich habe jetzt den ioBroker folder nach minukodu durchsucht und konnte die Datei finden und löschen.
          Jetzt gehts wieder.
          Danke!
            @rushmed
            Und wo lag die Datei?
              @thomas-braun \opt\iobroker\iobroker-data\files\0_userdata.0
                @rushmed
                Tipp am Rande: Erfahrungsgemäß ist zu 'geraden' Uhrzeiten auf den CloudDrives viel los, ich würde also das Backup nicht um 3 Uhr laufen lassen sondern um 3:34 oder sowas 'krummen'.
                  @thomas-braun Klingt plausibel, ich stells um. Danke
                  • simatec
                    simatec Developer Most Active @Rushmed last edited by
                    Ich habe hier jetzt schon mehrfach gelesen, dass dieser Adapter minukodu hier Probleme verursacht.
                    Falls den wer nutzt, macht da beim Entwickler bitte mal ein Issue auf und postet dort den Fehler Log.
                    backitup backup error
