    4. IoBroker defekt nach Stromausfall.
    • mfuhr
      mfuhr last edited by Homoran
      Hallo Community.
      Mein IoBroker Webinterface ist nicht mehr erreichbar nach einem Stromausfall könnt Ihr mir weiterhelfen?
      Meine Konfiguration:
      IoBroker Installation in einem Lxc Container auf Proxmox.
      IpAdresse anpingbar.
      node -v gibt V12.21.0 zurück
      nodejs -v gibt V12.21.0 zurück
      npm -v gibt 6.14.11 zurück
      Ausgabe des IoBroker Status Befehls:
      root@IoBrokerProd:/opt/iobroker# iobroker status
      Cannot read system.config: null (OK when migrating or restoring)
      Cannot find view "system" for search "host"
      iobroker is running on this host
      Objects type: file
      States type: file
      Bei tail /opt/iobroker/log/iobroker.current.log
      root@IoBrokerProd:/opt/iobroker/log# tail iobroker.current.log
      2021-03-23 12:57:42.619  - info: host.IoBrokerProd connected to Objects and States
      2021-03-23 12:57:42.813  - info: host.IoBrokerProd added notifications configuration of host
      2021-03-23 12:57:42.821  - error: host.IoBrokerProd Cannot find view "system" for search "instance"
      2021-03-23 12:57:42.821  - error: host.IoBrokerPro```
      d Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
      2021-03-23 12:57:42.867  - info: host.IoBrokerProd Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2021-03-23 12:57:42.869  - error: host.IoBrokerProd Cannot find view "system" for search "host"
      2021-03-23 12:57:42.893  - error: host.IoBrokerProd Cannot find view "system" for search "state"
      2021-03-23 12:57:42.893  - error: host.IoBrokerProd Cannot find view "system" for search "instance"
      2021-03-23 12:57:42.893  - error: host.IoBrokerProd Could not collect system.host.IoBrokerProd states to check for obsolete states: Error: Cannot find view "system"
      2021-03-23 12:57:42.893  - error: host.IoBrokerProd _design/system missing - call node iobroker.js setup
      MOD-Edit: Code in code-tags gesetzt!
      Kann mir da jemand weiterhelfen? Ich möchte ungern alles neu bauen, vor allem ist meine Sicherung schon etwas älter.
      Mario
        Homoran Global Moderator Administrators @mfuhr last edited by
        @mfuhr sagte in IoBroker defekt nach Stromausfall.:
        dann ist wohl die Obects.db hin:
        https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host?_=1616505579254
        mfuhr 2 Replies Last reply Reply Quote 0
        • mfuhr
          mfuhr @Homoran last edited by
          Danke vorab für deine Hilfe, ich werde mich mal durch hangeln und schauen ob die angegebene Lösung für mich funktioniert.
          • mfuhr
            Hallo, hat alles funktioniert, der IoBroker läuft wieder.
            Ich hätte zu der Hilfe noch einen Nachtrag.
            Nach dem zurück spielen der Objekte und Stats gehörten die Dateien dem Benutzer Root der Start des IoBroker Dienstes funktionierte dann nicht, ich habe nach dem zurückspielen der Konfigurationsdatei noch folgendes gemacht.
            chown iobroker:iobroker states.json
            chown iobroker:iobroker objects.json
            anschließend habe ich noch ...
            chmod 777 states.json
            chmod 777 objetcs.json
            Ausgeführt.
            Mit Linux Rechten kenne ich mich nicht besonders aus, vielleicht war 777 etwas too much, läuft aber damit.
              Thomas Braun Most Active @mfuhr last edited by Thomas Braun
              @mfuhr
              Dann schmeiß den
              iobroker fix
              noch hinterher.
              Und meld dich nicht als root an! (Außer das System gibt keine gescheite user her (docker auf synology)).
              Dann hast du auch nicht so'n Hantier mit den Rechten.
              mfuhr 1 Reply Last reply Reply Quote 0
                diese Hilfe ist bereits "hundertmal" getestet worden.
                Wenn du damit Probleme hattest, ist entweder bei deiner Installtion etwas krumm, oder du hast es nicht richtig durchgeführt.
                Möglich, weil ....
                root@IoBrokerProd:
                du als Root unterwegs bist, was du icht solltest
                • mfuhr
                  mfuhr @Thomas Braun last edited by
                  Danke, habe ich ausgeführt scheint alles zu funktionieren.
