    4. Iobroker backitup error.. Wo liegt das problem
    • Fred Freund
      Fred Freund last edited by Fred Freund
      einige Access Permissions und Konfigurationsfehler habe ich gefunden und ausgebessert.
      2021-03-23 20:46:25.638 - error: backitup.0 (5704) [iobroker] error on backup process: Error when executing script "zigbee": ReferenceError: timer is not defined Please check the config of backitup and execute "iobroker fix"
      2021-03-23 20:46:25.807 - error: backitup.0 (5704) [iobroker] Error: EACCES: permission denied, mkdir '/opt/iobroker/backups/grafana_tmp/dashboards'
      2021-03-23 20:46:25.811 - error: backitup.0 (5704) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2021-03-23 20:46:25.811 - error: backitup.0 (5704) unhandled promise rejection: callback is not a function
      2021-03-23 20:46:25.813 - error: backitup.0 (5704) TypeError: callback is not a function
      at Object.command (/opt/iobroker/node_modules/iobroker.backitup/lib/scripts/36-grafana.js:270:9)
      at Immediate.executeScripts (/opt/iobroker/node_modules/iobroker.backitup/lib/execute.js:359:26)
      at processImmediate (internal/timers.js:463:21)
      2021-03-23 20:46:25.814 - error: backitup.0 (5704) callback is not a function
      2021-03-23 20:46:25.836 - info: backitup.0 (5704) cleaned everything up...
      2021-03-23 20:46:25.837 - info: backitup.0 (5704) terminating
      2021-03-23 20:46:25.839 - warn: backitup.0 (5704) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2021-03-23 20:46:26.485 - error: host.broker1 Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2021-03-23 20:46:26.486 - error: host.broker1 Caught by controller[1]: TypeError: callback is not a function
      2021-03-23 20:46:26.486 - error: host.broker1 Caught by controller[1]: at Object.command (/opt/iobroker/node_modules/iobroker.backitup/lib/scripts/36-grafana.js:270:9)
      2021-03-23 20:46:26.487 - error: host.broker1 Caught by controller[1]: at Immediate.executeScripts (/opt/iobroker/node_modules/iobroker.backitup/lib/execute.js:359:26)
      2021-03-23 20:46:26.487 - error: host.broker1 Caught by controller[1]: at processImmediate (internal/timers.js:463:21)
      2021-03-23 20:46:26.488 - error: host.broker1 instance system.adapter.backitup.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2021-03-23 20:46:26.488 - info: host.broker1 Restart adapter system.adapter.backitup.0 because enabled
      2021-03-23 20:46:56.527 - info: host.broker1 instance system.adapter.backitup.0 started with pid 6348
      2021-03-23 20:46:59.926 - info: backitup.0 (6348) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.21.0, js-controller: 3.2.16
      2021-03-23 20:47:00.019 - info: backitup.0 (6348) [iobroker] backup was activated at 02:40 every 1 day(s)
      Könnt ihr mir bitte sagen was hier schief läuft?
      welcher timer im zigbee soll das sein
      Erste Zeile!
      Thx
        Thomas Braun Most Active @Fred Freund last edited by
        @fred-freund sagte in Iobroker backitup error.. Wo liegt das problem:
        iobroker fix
        mal ausgeführt? Ansonsten bräuchte man wohl auch die Konfiguration der einzelnen Backupvarianten, denke ich.
        Fred Freund 1 Reply Last reply Reply Quote 1
        • Fred Freund
          Fred Freund @Thomas Braun last edited by
          Jetzt startet der iobroker 8081nicht mehr, node red lauft aber auf 1880..
          1882 läuft auch nur der Admin nicht..
          Denke habe den unabsichtlich deaktiviert.. Wie drehe ich den wieder auf?
            @fred-freund
            Was haste denn nun gemacht?
            iobroker status
            iobroker list adapters
            iobroker list instances
            Fred Freund 1 Reply Last reply Reply Quote 0
            • Fred Freund
              Fred Freund @Thomas Braun last edited by Fred Freund
              Gefunden
              iobroker start admin
              Iobroker fix sagte soll alle adapter disable setzen.. Irrtümlich admin erwischt
              🙂 als erstes. LETZTES!
              Man soll nicht Sowas mit einem Tablett machen.
                Thomas Braun Most Active @Fred Freund last edited by Thomas Braun
                @fred-freund Der fixer sagt, man soll den kompletten iobroker stoppen, nicht nur die Instanzen. Jedenfalls ist das damit gemeint...
                iobroker stop
                ist dein Freund.
                • Fred Freund
                  io.javascript.0
                   io.mqtt.0
                   io.ping.0
                   io.rpi2.0
                   io.web.0
                   io.zigbee.0
                   io.zwave2.0
                  Please stop them first and try again!
                  Z. Bsp.
                  Soll jetzt backitup neu installieren nochmal fix...
                  Kann in opt/iobroker/backup keine Ordner anlegen
                  OK bis auf
                  Started iobroker ...
                  [DEBUG] [mount] - mount successfully completed
                  [DEBUG] [mount] - done
                  [DEBUG] [iobroker] - host.broker1 1195 states saved
                  [DEBUG] [iobroker] - host.broker1 1570 objects saved
                  [ERROR] [iobroker] - host.broker1 Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: Error: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2021_03_23-22_18_13_backupiobroker.tar.gz'
                  [ERROR] [iobroker] - host.broker1 Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                    ls -la /opt/iobroker/backups/
                    • Fred Freund
                      drwxrwxr-x+ 2 iobroker iobroker    4096 Mar 23 20:32 .
                      drwxrwxr-x+ 6 iobroker iobroker    4096 Mar 23 21:57 ..
                      -rw-rwxr--+ 1 iobroker iobroker 3339610 Mar  9 21:18 2021_03_09-21_18_54_backupiobroker.tar.gz
                      -rw-rwxr--+ 1 iobroker iobroker       0 Mar 23 19:58 historyDB_2021_03_23-19_58_43_backupiobroker.tar.gz
                      -rw-rwxr--+ 1 iobroker iobroker       0 Mar 23 20:04 historyDB_2021_03_23-20_04_53_backupiobroker.tar.gz
                      -rw-rwxr--+ 1 iobroker iobroker       0 Mar 23 20:06 historyDB_2021_03_23-20_06_28_backupiobroker.tar.gz
                      -rw-rwxr--+ 1 iobroker iobroker       0 Mar 23 20:31 historyDB_2021_03_23-20_31_53_backupiobroker.tar.gz
                      -rw-rwxr--+ 1 iobroker iobroker       0 Mar 23 20:32 historyDB_2021_03_23-20_32_47_backupiobroker.tar.gz
                      -rw-rwxr--+ 1 iobroker iobroker     991 Mar 23 19:58 influxDB_2021_03_23-19_58_42_backupiobroker.tar.gz
                      -rw-rwxr--+ 1 iobroker iobroker     991 Mar 23 20:04 influxDB_2021_03_23-20_04_52_Iobroker1_backupiobroker.tar.gz
                      -rw-rwxr--+ 1 iobroker iobroker     990 Mar 23 20:06 influxDB_2021_03_23-20_06_27_Iobroker1_backupiobroker.tar.gz
                      -rw-rwxr--+ 1 iobroker iobroker     989 Mar 23 20:31 influxDB_2021_03_23-20_31_52_backupiobroker.tar.gz
                      -rw-rwxr--+ 1 iobroker iobroker     990 Mar 23 20:32 influxDB_2021_03_23-20_32_46_backupiobroker.tar.gz
                      -rw-rwxr--+ 1 iobroker iobroker 3516990 Mar 23 19:58 iobroker_2021_03_23-19_58_36_backupiobroker.tar.gz
                      -rw-rwxr--+ 1 iobroker iobroker 3517122 Mar 23 20:04 iobroker_2021_03_23-20_04_46_Iobroker1_backupiobroker.tar.gz
                      -rw-rwxr--+ 1 iobroker iobroker 3517072 Mar 23 20:06 iobroker_2021_03_23-20_06_20_Iobroker1_backupiobroker.tar.gz
                      -rw-rwxr--+ 1 iobroker iobroker 3517129 Mar 23 20:31 iobroker_2021_03_23-20_31_45_backupiobroker.tar.gz
                      -rw-rwxr--+ 1 iobroker iobroker 3517069 Mar 23 20:32 iobroker_2021_03_23-20_32_40_backupiobroker.tar.gz
                      -rw-rwxr--+ 1 iobroker iobroker   83731 Mar 23 19:58 zigbee.0_2021_03_23-19_58_43_backupiobroker.tar.gz
                      -rw-rwxr--+ 1 iobroker iobroker   83731 Mar 23 20:04 zigbee.0_2021_03_23-20_04_53_backupiobroker.tar.gz
                      -rw-rwxr--+ 1 iobroker iobroker   83731 Mar 23 20:06 zigbee.0_2021_03_23-20_06_28_backupiobroker.tar.gz
                      -rw-rwxr--+ 1 iobroker iobroker   83736 Mar 23 20:31 zigbee.0_2021_03_23-20_31_53_backupiobroker.tar.gz
                      -rw-rwxr--+ 1 iobroker iobroker   83736 Mar 23 20:32 zigbee.0_2021_03_23-20_32_47_backupiobroker.tar.gz
                      -rw-rwxr--+ 1 iobroker iobroker    1669 Mar 23 19:58 zigbee.1_2021_03_23-19_58_43_backupiobroker.tar.gz
                      -rw-rwxr--+ 1 iobroker iobroker    1669 Mar 23 20:04 zigbee.1_2021_03_23-20_04_53_backupiobroker.tar.gz
                      -rw-rwxr--+ 1 iobroker iobroker    1669 Mar 23 20:06 zigbee.1_2021_03_23-20_06_28_backupiobroker.tar.gz
                      -rw-rwxr--+ 1 iobroker iobroker    1669 Mar 23 20:31 zigbee.1_2021_03_23-20_31_53_backupiobroker.tar.gz
                      -rw-rwxr--+ 1 iobroker iobroker    1669 Mar 23 20:32 zigbee.1_2021_03_23-20_32_47_backupiobroker.tar.gz
                      -rw-rwxr--+ 1 iobroker iobroker       0 Mar 23 19:58 zigbee.2_2021_03_23-19_58_43_backupiobroker.tar.gz
                      -rw-rwxr--+ 1 iobroker iobroker       0 Mar 23 20:04 zigbee.2_2021_03_23-20_04_53_backupiobroker.tar.gz
                      -rw-rwxr--+ 1 iobroker iobroker       0 Mar 23 20:06 zigbee.2_2021_03_23-20_06_28_backupiobroker.tar.gz
                      -rw-rwxr--+ 1 iobroker iobroker       0 Mar 23 20:31 zigbee.2_2021_03_23-20_31_53_backupiobroker.tar.gz
                      -rw-rwxr--+ 1 iobroker iobroker       0 Mar 23 20:32 zigbee.2_2021_03_23-20_32_47_backupiobroker.tar.gz
                      Ist da jetzt auch Node red backed up, Dh. Die Flows???
                      Danke!
                        @fred-freund
                        Die Datei gibt es ja auch gar nicht. Kann es sein, dass du den Backup-Vorgang im laufenden Betrieb abgeschossen hast?
                        • Fred Freund
                          @thomas-braun eigentlich habe ich Nas gewählt.
                          Hier das Nas verzeichnis..
                          Ein altes ist manuell gemacht.. Auch die flows.. Etc.
                          -rwxr--r--  1 1000 1000 3339610 Mär  9 21:25 2021_03_09-21_18_54_backupiobroker.tar.gz
                          -rwxr--r--  1 1000 1000  697099 Nov 28 15:27 CC2531ZNP-Prod.hex
                          -rwxr--r--  1 1000 1000   18318 Mär  9 21:30 flows.json
                          drwxr-xr-x  2 1000 1000    4096 Mär 23 22:22 grafana_tmp
                          -rw-r--r--  1 1000 1000       0 Mär 23 20:36 historyDB_2021_03_23-20_36_04_backupiobroker.tar.gz
                          -rw-r--r--  1 1000 1000       0 Mär 23 20:46 historyDB_2021_03_23-20_46_25_backupiobroker.tar.gz
                          -rw-r--r--  1 1000 1000       0 Mär 23 21:59 historyDB_2021_03_23-21_59_26_backupiobroker.tar.gz
                          -rw-r--r--  1 1000 1000       0 Mär 23 22:02 historyDB_2021_03_23-22_02_05_backupiobroker.tar.gz
                          -rwxr--r--  1 1000 1000       0 Mär 23 22:05 historyDB_2021_03_23-22_05_32_backupiobroker.tar.gz
                          -rwxr--r--  1 1000 1000     977 Mär 23 22:05 influxDB_2021_03_23-22_05_31_backupiobroker.tar.gz
                          -rw-r--r--  1 1000 1000       0 Mär 23 20:36 iobroker_2021_03_23-20_35_58_backupiobroker.tar.gz
                          -rw-r--r--  1 1000 1000       0 Mär 23 20:46 iobroker_2021_03_23-20_46_19_backupiobroker.tar.gz
                          -rw-r--r--  1 1000 1000       0 Mär 23 21:59 iobroker_2021_03_23-21_59_20_backupiobroker.tar.gz
                          -rw-r--r--  1 1000 1000       0 Mär 23 22:02 iobroker_2021_03_23-22_01_59_backupiobroker.tar.gz
                          -rwxr--r--  1 1000 1000 3520194 Mär 23 22:05 iobroker_2021_03_23-22_05_24_backupiobroker.tar.gz
                          -rw-r--r--  1 1000 1000       0 Mär 23 22:16 iobroker_2021_03_23-22_16_39_backupiobroker.tar.gz
                          -rw-r--r--  1 1000 1000       0 Mär 23 22:18 iobroker_2021_03_23-22_18_13_backupiobroker.tar.gz
                          -rw-r--r--  1 1000 1000       0 Mär 23 22:22 iobroker_2021_03_23-22_22_44_backupiobroker.tar.gz
                          -rwxr--r--  1 1000 1000  585004 Mär 13 21:29 iobroker.current.log
                          -rwxrwxr--+ 1 1000 1000   92404 Mär 14 13:43 iobroker.rtf
                          -rw-rw-r--  1 1000 1000       0 Mär 23 22:37 txt.txt
                          -rw-r--r--  1 1000 1000       0 Mär 23 20:36 zigbee.0_2021_03_23-20_36_04_backupiobroker.tar.gz
                          -rw-r--r--  1 1000 1000       0 Mär 23 20:46 zigbee.0_2021_03_23-20_46_25_backupiobroker.tar.gz
                          -rw-r--r--  1 1000 1000       0 Mär 23 21:59 zigbee.0_2021_03_23-21_59_27_backupiobroker.tar.gz
                          -rw-r--r--  1 1000 1000       0 Mär 23 22:02 zigbee.0_2021_03_23-22_02_05_backupiobroker.tar.gz
                          -rw-r--r--  1 1000 1000       0 Mär 23 20:36 zigbee.1_2021_03_23-20_36_04_backupiobroker.tar.gz
                          -rw-r--r--  1 1000 1000       0 Mär 23 20:46 zigbee.1_2021_03_23-20_46_25_backupiobroker.tar.gz
                          -rw-r--r--  1 1000 1000       0 Mär 23 21:59 zigbee.1_2021_03_23-21_59_27_backupiobroker.tar.gz
                          -rw-r--r--  1 1000 1000       0 Mär 23 22:02 zigbee.1_2021_03_23-22_02_05_backupiobroker.tar.gz
                          -rw-r--r--  1 1000 1000       0 Mär 23 20:36 zigbee.2_2021_03_23-20_36_04_backupiobroker.tar.gz
                          -rw-r--r--  1 1000 1000       0 Mär 23 20:46 zigbee.2_2021_03_23-20_46_25_backupiobroker.tar.gz
                          -rw-r--r--  1 1000 1000       0 Mär 23 21:59 zigbee.2_2021_03_23-21_59_27_backupiobroker.tar.gz
                          -rw-r--r--  1 1000 1000       0 Mär 23 22:02 zigbee.2_2021_03_23-22_02_05_backupiobroker.tar.gz
                            @fred-freund Der user iobroker hat i.d.R. nicht die UID 1000
                            cat /etc/passwd | grep iobroker
                            • Fred Freund
                              pi@broker1:~ $ cat /etc/passwd | grep iobroker
                              iobroker:x:1001:1001::/home/iobroker:/usr/sbin/nologin
                              Raspi! Aber am Nas gibt's den smb User für den share!
                                @fred-freund Aber der hat da eine andere UID.
                                • Fred Freund
                                  Auszug ist oben!
                                  Nein abgeschossen hab ich den Vorgang nicht..
                                  Werd mal Nas wegnehmen und schauen was er lokal macht... Oder macht er das trotzdem?
                                  Braucht man das Javascript bkup?
                                  Auch Ohne Javascript..
                                  [ERROR] [iobroker] - host.broker1 Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: Error: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2021_03_23-23_09_27_backupiobroker.tar.gz'
                                  [DEBUG] [iobroker] - done
                                  [DEBUG] [influxDB] - Start InfluxDB Backup ...
                                  [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
                                  [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
                                  [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
                                  [ERROR] [influxDB] - [IGNORED] Error: Command failed: influxd backup -portable -database iobroker "/opt/iobroker/backups/influxDB_2021_03_23-23_09_32_backupiobroker"
                                  backup: open temp file: open /opt/iobroker/backups/influxDB_2021_03_23-23_09_32_backupiobroker/meta.00.pending: permission denied
                                  • simatec
                                    simatec Developer Most Active @Fred Freund last edited by
                                    @fred-freund Versuche mal bitte die Version 2.1.0
                                    • Fred Freund
                                      Fred Freund @simatec last edited by
                                      @simatec
                                      [ERROR] [iobroker] - host.broker1 Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: Error: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2021_03_24-22_45_57_backupiobroker.tar.gz'
                                      [DEBUG] [zigbee] - found zigbee database: zigbee.0,zigbee.1,zigbee.2
                                      [DEBUG] [zigbee] - done
                                      [ERROR] [zigbee] - [IGNORED] Error: EACCES: permission denied, open '/opt/iobroker/backups/zigbee.0_2021_03_24-22_46_03_backupiobroker.tar.gz'
                                      [DEBUG] [cifs] - Copy iobroker_2021_03_24-22_45_57_backupiobroker.tar.gz...
                                      [DEBUG] [cifs] - Copy zigbee.0_2021_03_24-22_46_03_backupiobroker.tar.gz...
                                      [DEBUG] [cifs] - Copy zigbee.1_2021_03_24-22_46_03_backupiobroker.tar.gz...
                                      [DEBUG] [cifs] - Copy zigbee.2_2021_03_24-22_46_03_backupiobroker.tar.gz...
                                      [DEBUG] [cifs] - done
                                      [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.1.22","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":false,"dir":"/home/iobroker","dirMinimal":"sharename/backupDir","user":"user1","pass":"****","backupDir":"/opt/iobroker/backups","deleteBackupAfter":0}
                                      [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
                                      [DEBUG] [clean] - done
                                      [DEBUG] [historyHTML] - new history html values created
                                      [DEBUG] [historyHTML] - done
                                      [DEBUG] [historyJSON] - new history json values created
                                      [DEBUG] [historyJSON] - done
                                      [DEBUG] [historyHTML] start with {"type":"creator","time":"02:40","debugging":true,
                                      Das Backup hat wieder Größe 0
                                      Der Ordner am smb share
                                      drwxrwxrwx  3 1000 1000      4096 Mär 24 22:46 iobroker
                                      rw-r--r--  1 1000 1000       0 Mär 24 22:39 zigbee.1_2021_03_24-22_39_23_backupiobroker.tar.gz
                                      • simatec
                                        @fred-freund
                                        Dann hast du ein Rechteproblem.
                                        Hast du iobroker fix bereits ausgeführt?
                                        • Fred Freund
                                          Fred Freund @simatec last edited by Fred Freund
                                          @simatec
                                          Ja gestern 2x
                                          Mach ich jetzt auch nochmal... Je nachdem welche smb Version ich verwende ändert sich auch die Error Meldung..
                                          2021-03-24 23:00:26.538  - error: backitup.0 (27502) [iobroker] Backup folder not created: Error: EPERM: operation not permitted, chmod '/opt/iobroker/backups'Please reinstall backitup and run "iobroker fix"!!
                                          Smb 3.1.1
                                          Fix hat nix gebracht... 😞
                                          • simatec
                                            @fred-freund
                                            Bitte vollständigen Log posten
                                            156
                                            19310
