    4. Harmony Adapter Installation
      MicF1968 last edited by
      ich bekomme den Harmony Adapter nicht installiert.
      Alle anderen Adapter waren kein Problem.
      Deswegen wundert mich die Fehlermeldung, denn wenn git nicht da wäre, würden die anderen ja auch nicht gehen.
      Kann mich jemand auf den richtigen Weg schubsen.
      $ ./iobroker add harmony
      npm install iobroker.harmony --production --prefix "C:/ioBroker" (System call)
      npm
       WARN
      addRemoteGit Error: not found: gitnpm
      WARN addRemoteGit     at F (C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:73:28)
      npm
       WARN addRemoteGit     at E (C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:76:29)npm WARN addRemoteGit     at C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:84:16
      npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:82:15)
      npm
      WARN addRemoteGit  git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_git-remotes\git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-fb3d77aae15e9412d902508acaa2cb87 because of error: { [Error: not found: git] code: 'ENOGIT' }
      npm
       WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package <https: www.npmjs.com/package/@xmpp/xml="">npm
       ERR! git clone --template=C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_git-remotes\_templates --mirror https://github.com/swissmanu/ltx.git C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_git-remotes\git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-fb3d77aae15e9412d902508acaa2cb87:
       undefined
      npm
      ERR!
       undefined
      npm
       WARN
      install
       Couldn't install optional dependency: not found: git
      host.Seven24 install adapter harmony
      npm
      WARN deprecated
       WARN
      npm
      WARN
      addRemoteGit
           at F (C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:73:28)npm
      WARN
      npm
      WARN
      addRemoteGit
           at C:\Program Files\nodejs\node_modules\npm\node_modules\which\which.js:84:16npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:82:15)
      npm
      ERR!
       git clone --template=C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_git-remotes\_templates --mirror https://github.com/swissmanu/ltx.git C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_git-remotes\git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-fb3d77aae15e9412d902508acaa2cb87: undefinednpm ERR! git clone --template=C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_git-remotes\_templates --mirror https://github.com/swissmanu/ltx.git C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_git-remotes\git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-fb3d77aae15e9412d902508acaa2cb87: undefined
      npm
      WARN
      install Couldn't install optional dependency: not found: git
      npm
       WARN
      addRemoteGit
      npm
       WARN
      npm
      WARN
       WARN addRemoteGit
       WARN
       addRemoteGit     at FSReqWrap.oncomplete (fs.js:82:15)npm
      npm
      ERR!
       undefined
      npm
       WARN install Couldn't install optional dependency: not found: git
      ERROR: host.Seven24 Cannot install harmony
      ERROR: process exited with code 13</https:></https:></https:>
        @MicF1968:
        Kann mich jemand auf den richtigen Weg schubsen. `
        ich habe zwar noch nie eine Windows Installation gemacht, daher weiss ich auch nicht wie… (unter Linux: sudo apt-get install git)
        Aber dir fehlt GIT (oder npmGit) das musst du noch installieren.
        • Dutchman
          @Homoran:
          @MicF1968:
          Rainer `
          Unter windows einfach github installieren: https://desktop.github.com/
            ich habe sowohl die Windows Version installiert als auch
            npm install gitnpm -g
            ausgeführt und es wurde auch installiert.
            An der Harmony Adapter Installation hat das nichts geändert.
            Mic
              Pman last edited by
              GIT muss als Systembefehl bekannt sein, sich also in der PATH variablen befinden. Dazu einfach mal Googlen oder hier im Forum suchen, war schon sehr häufig der Grund für fehlgeschlagene Adapterinstallationen.
                Das klang schon ziemlich einleuchtend ….
                ... aber git ist im path drin.
                Ich kann mit der Console von überall git aufrufen und es kommt die Parameterliste.
                Noch 'ne Idee?
                  Von der Console aus aufgerufen sieht es ähnlich aus:
                  C:\>npm install iobroker.harmony --production --prefix "C:/ioBroker"
                  npm ERR! git clone --template=C:\Users\Michael\AppData\Roaming\npm-cache\_git-remotes\_templates --mirror https://github.com/swissmanu/ltx.git C:\Users\Michael\AppData\Roaming\npm-cache\_git-remotes\git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-fb3d77aae15e9412d902508acaa2cb87: undefined
                  npm WARN install Couldn't install optional dependency: not found: git
                  npm WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package
                  • Dutchman
                    Ich steh aufm Schlauch Sorry, bei mir war damals genügen um den Client zu installieren
                      fragt mich jetzt nicht warum, aber jetzt gings.
                      ich hatte davor nicht gebootet, vermutlich lags daran, dass nach Installation von git noch ein boot notwendig war.
                      danke für die hilfe.
                        Pman last edited by
                        Ja, für laufende Prozesse wird der PATH nicht aktualisiert, vermutlich lag es daran.
                          Blackeye last edited by
                          ich schaffe es leider auch nicht. iobrker läuft bei mir unter Jessie Light ..
                          npm install iobroker.harmony --production --prefix "/opt/iobroker" (System call)
                          npm
                           WARN
                          addRemoteGit Error: not found: gitnpm WARN addRemoteGit     at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
                          npm WARN addRemoteGit     at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
                          npm WARN addRemoteGit     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
                          npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
                          npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
                          npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
                          npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:123:15)
                          npm
                          WARN addRemoteGit  git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b because of error: { Error: not found: gitnpm WARN addRemoteGit     at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
                          npm WARN addRemoteGit     at FSReqWrap.oncomplete (fs.js:123:15) code: 'ENOGIT' }
                          npm
                           ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b: undefinednpm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b: undefined
                          npm
                           WARN
                          npm
                           ERR!
                           Linux 4.9.24-v7+
                          npm ERR! argv
                           "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.harmony" "--production" "--prefix" "/opt/iobroker"
                          npm
                           ERR! node v6.10.3
                          npm ERR! npm  v3.10.10npm ERR! code ENOGIT
                          npm
                           ERR! not found: gitnpm ERR!
                          npm ERR! Failed using git.
                          npm ERR! This is most likely not a problem with npm itself.
                          npm ERR! Please check if you have git installed and in your PATH.
                          npm ERR! Please include the following file with any support request:npm ERR!     /npm-debug.log
                          host.ioBroker-RasPi install adapter harmony
                          npm
                           WARN addRemoteGit Error: not found: gitnpm
                           WARN addRemoteGit
                          npm
                           WARN
                           addRemoteGit
                               at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)npm WARN addRemoteGit     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
                          npm WARN addRemoteGit  git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b because of error: { Error: not found: git
                          npm
                          ERR!
                          npm WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package <https: www.npmjs.com/package/@xmpp/xml="">
                          npm ERR!
                           Linux 4.9.24-v7+npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.harmony" "--production" "--prefix" "/opt/iobroker"
                          npm
                          ERR! node v6.10.3npm ERR! npm  v3.10.10
                          npm ERR! not found: gitnpm ERR!
                          npm
                           WARN
                               at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)npm
                           WARN
                          npm WARN
                          addRemoteGit     at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)npm WARN addRemoteGit     at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
                          npm
                          npm
                          npm
                          ERR! Linux 4.9.24-v7+
                          npm ERR! node v6.10.3
                          ERR! npm ERR! Failed using git.
                          ERROR: host.ioBroker-RasPi Cannot install harmony
                          Wenn ich versuche Git zu installieren, nur Fehler…..
                          • Dutchman
                            Die Meldung von der harmony Installation sagt das git fehlt.
                            Welchen Fehler bekommst du Dan Bein installieren von git ?
                            Send from mobile device
                              hier die Meldungen. Ist wohl nicht mehr da 😞
                              • Dutchman
                                hast du
                                sudo apt-get update --fix-missing
                                ausgefuehrt ?
                                  nein, natürlich nicht…. Danach klappt auch die git Installation und der Adapter läuft auch
                                  @Dutchman:
                                  hast du
                                  ausgefuehrt ? `
                                  2339
